Wrathchild
    2,924
Posts posted by Wrathchild
  1. Depends what image they are using.
    With an UNO/AVG/Ultimate style cart that can CAR/ROM images then running a title that runs in 16K or less is fine.
    If it is an XEX version of a ROM then that cannot load to RAM and then relocate to the ROM area as there is no RAM there.
    Some 8K games can be relocated to have their code in the top 8K of the 16K of RAM and then run in the lower 8K.
    ATR images are generally out the the question as a mod'd OS is loaded in the area under the OS which again is not RAM on a 16K machine.
    [Edit] Additionally the UNO/AVG type carts use their own XEX loader code copied into RAM (typically at $700).
    That can conflict with the XEXs trying to be loaded as tape games would typically load from $480/$500/$600.
    So a way around that is to use a compression tool (e.g. exomizer) to create a self-extracting version from this that loads at, say, $900.
    Sometimes 16K versions of games are patched as XEXs but now need more that 16K to load, again compression would get around that.
  2. Our first Atari was a 600XL with 16K so fond memories of tape games played on top of some mentioned already:
    TT Racer, Match Racer, Baja Buggies, Alien Swarm, Encounter! (came with both 16K and 32K versions), Ghost Encounters / Action Quest, Sea Dragon, Stratos, Attack at EP-CYG-4, Galactic Chase, Canyon Climber, O'Riley's Mine, Zaxxon, Shooting Arcade
    Plus there are the Brian Howarth and Scott Adams 16K tape versions of their adventures.
    Some needed the OS/B translator but you should be able to find patched versions online.
    Go for the tape versions as often the disk versions needed more memory, but you can find then as XEX versions rather than CAS and run from an SIO2xx device.
    Or make a compilation of them on an AtariMax multicart. :)
  3. The source is referencing POKEY and PIA when in the first post you said these were missing?
    38 minutes ago, atariry said:
    VBWAIT: lda ANTICrVCOUNT ;WAIT FOR NEXT VBLANK BEFORE MESSING
    This seems odd as there is no actual check going on here?
    What should be going on here is that only middle (RESET) vector goes to PWRUP.
    The IRQ handler might not have much purpose in a simple design and so could be handled with:
    IRQ_BRK:
        CLD
        JMP (VIMIRQ)
    DUMMY_IRQ:
        RTI
    INIT_IRQ:
        LDA #<DUMMY_IRQ
        STA VIMIRQ
        LDA #>DUMMY_IRQ
        STA VIMIRQ+1
        RTS
    The NMI handler should be able to handle display related interrupts and so this would include the vblank and dlisplay list interrupt:
    NMI_handler:
        BIT NMIRES
        BPL not_dli
        JMP (VDSLST)
    not_dli:
        CLD
        PHA
        TXA
        PHA
        TYA
        PHA
        STA NMIRES
        JMP (VVBLKI)
    This would therefore need so basic functionality associated with it, e.g. copying shadow registers to h/w registers
    INIT_NMI:
        LDA #<DLI_Dummy
        STA VDSLST
        LDA #>DLI_Dummy
        STA VDSLST+1
        LDA #<VBI_handler
        STA VVBLKI
        LDA #>VBI_handler
        STA VVBLKI+1
        RTS
    DLI_Dummy:
        RTI
    VBI_handler:
        LDA SDLSTL
        STA DLISTL
        LDA SDLSTH
        STA DLISTH
        LDA COLOR0
        STA COLPF0
        LDA COLOR1
        STA COLPF1
        LDA COLOR2
        STA COLPF2
        LDA COLOR3
        STA COLPF3
        LDA COLOR4
        STA COLBK
        LDA SKSTAT
        AND #SKSTAT_LASTKEY_PRESSED
        BNE KB
        LDA KBCODE
        CMP CH1
        BEQ KB
        STA CH
    KB:
        STA CH1
        PLA
        TAY
        PLA
        TAX
        PLA
        RTI
    In your startup code you can add calls to INIT_IRQ and INIT_NMI
  4. There is also an advantage of the 2nd (indirect) option as this can be used direct from ROM (cartridge) code where the 'target' is then stored in the RAM area and so can be modified. With the 1st version the trampoline JMP cannot be located in ROM as any store to the target address has no affect. Therefore those 3 bytes would instead have to be relocated to RAM and assembled with a different run address so that calls to it resolved to the relocated address.
  5. 9 hours ago, Eyvind Bernhardsen said:
    You have to use the indirect mode. I think it’s “JSR (X)”, but it’s been a long time since I wrote any 6502 assembly.
    Close, you'd ned to use a JSR to a JMP
    CallFunc: .byte $4C ; JMP abs
    FuncAddr: .word 0
     .macro SetFuncAddr addr
     LDA #<(:addr)
     STA FuncAddr
     LDA #>(:addr)
     STA FuncAddr+1
     .endm
    ThisAndThat:
     SetFuncAddr DoThis
     JSR CallFunc
     SetFuncAddr DoThat
     JSR CallFunc
     JMP ThisAndThat
    DoThis:
     LDA #0
     STA COLOR3
     RTS
    DoThat:
     LDA #15
     STA COLOR3
     RTS
  6. What you are doing sounds more closer the 5200 and so I'd suggest taking a look at its ROM routine.
    I presume the RAM runs from $0000->$3FFF and the ROM from $E000->$FFFF and so the ROM sets the startup/interrupt vectors in the last 6 bytes.
    The 5200 OS has the Atari logo page and so would be a good starting experiment.
    The only difference is that instead of the OS looking for the cartridge and using it's init/run vectors, your application code would be in the ROM area instead.
  7. On 2/27/2020 at 9:47 PM, Wrathchild said:
    As GatHG loads at $900 and SLB at $500 is presume the AVGCart bootstrap is running in that area and hence being trashed.
    I have finally got around to fixing the Star League Baseball XEX by chopping 1K from the front so that it now loads at $900 and then once loaded it puts that 1K back at $500.
    Therefore this will run OK on a 32K machine (and hopefully now from an UNO/AVG cart)
    Star League Baseball (low load).xex
    • Like 4
  8.
    5 minutes ago, jamm said:
     flashjazzcat is going to have quite a challenge improving on that
    Considering the AVG stands on the shoulders of the UNO and fjc has previously given advice to tmp, I find this a bizarre comment. In what regard would he have to improve something?
  9. 20 hours ago, dmsc said:
    One question: ¿should VBI vector the immediate or the deferred VBI?
    My recommendation would be VVBLKD as out-of-the-box the OS is pointing this ($224) to the Pull Y/X/A and RTI code vectored to by XITVBV.
    So you would hook this a call to SETVBV with A=7 and XY with the routine's address.
    At the end of the constructed VBI code, you would end with "JMP XITVBI".
    Injecting "LDA #0, STA $4F" into the VBI code might be OK to do (although does affect attract mode colours) but an alternative could be to offer a command within the VBI such as "NO_ATTRACT" which performs "LDA #0, STA $4D"?
    Perhaps the $224.w value can be copied to $238.w when setting up (before the SETVBV call) as Mapping states that as spare? This can then be loaded into XY and SETVBV called to restore.
  10. I'd forgotten to mention another idea, let the user state WSYNC as in the example you are in Gr.0 and even with a DLI stated each line then you can only update registers every 8 lines.
    DLI SET graded_dli = $04 INTO $D017,
    DLI        = WSYNC, $06 INTO $D017,
    DLI        = WSYNC, $08 INTO $D017,
    DLI        = WSYNC, $0C INTO $D017,
    DLI        = WSYNC, $04 INTO $D017
    The way you've coded things already automatically injects the WSYNC store between the LDA/STA of the first 'INTO' and so the same principle can apply to an INTO preceded with a WSYNC.
    This would permit multiple WSYNC entries to be used, e.g. re-writing the above:
    DLI        = WSYNC, WSYNC, $08 INTO $D017,
    resulting in something like:
    fb_lbl_graded_dli:
        .byte    72
        .byte    138
        .byte    72
        .byte    169
        .byte    $04
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    169
        .byte    $06
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    169
        .byte    $08
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    169
        .byte    $0C
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    141
        .word    WSYNC
        .byte    169
        .byte    $08
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    169
        .byte    $06
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    169
        .byte    $04
        .byte    141
        .word    WSYNC
        .byte    141
        .word    53271
        .byte    230
        .byte    COLRSH
        .byte    104
        .byte    170
        .byte    104
        .byte    64
    [EDIT] So taking the test.bas, building it with 'fb-int' and then replacing the DLI code in the 'asm' file with that given above and then building that with:
    cl65 -t atari -C fastbasic.cfg -o test.xex test.asm fastbasic-int.lib
    gives:
    test.asm test.bas test.xex
  11. I think the ideal could be something like this - as if you define the routines in reverse order then you can reference them, and the last does not need to set the first if this is done in the VBI, e.g.
    DLI SET dli3 = pos INTO $D000, pos INTO $D001,
    DLI        = $CE INTO $D013
    DLI SET dli2 = pos INTO $D000, pos INTO $D001,
    DLI        = $88 INTO $D012,
    DLI        = DLI dli3
    DLI SET dli1 = pos INTO $D000, pos INTO $D001,
    DLI        = $28 INTO $D012, $2E INTO $D013,
    DLI        = DLI dli2
    VBI SET vb1 = DLI dli1
    VBI vb1
    As an example, the VBI can then also be used to call a linked RMT player routine
