1,037 -
Posts posted by Bill Lange
Did you build your 1088XEL yetNo, but it is on the LIST!
MultiSIO breakout (like Best's)I like the Best board, but IMHO, it needs to be 5mm or so wider so you don't need to break the fins off the SIO receptacles to mount them.
If the socket on the Apelink board is the standard socket, then I can try to match that exactly. I'll just de-solder one of the receptacles off the board and then have my 3D printed tweaked to line up with the holes.
I have a few 1088XEL around here somewhere as well, so I can check that too.
I do need to figure out how to screw the two parts together while still staying close to the standard socket.
I'm working on a 3D printed SIO receptacle.
I'm using the Best Electronics' SIO Apelink board as a model.
I'm working on two pieces [receptacle/base] that will snap and/or screw together.
Here are some draft photos:
The pieces need some adjusting:
- On the receptacle (top) part, I'm going to move the screw wings flush with the back so that it can 3D print without supports
- Recessed screw/nut holes
- Add some supports/braces to hold the pins in place as well
I'm going to try some pins something like these:
The pins will all likely be one length, so they will stick out of the bottom of the base at two heights/lengths. The pins will need to be clipped off once soldered to a board.
Any comments or suggestions before I get to far down this rabbit hole?
Thanks
Bill
12
I dug around and found a folder full of old Atari stuff. I was going to upload it but then I discovered that I have apparently already done soThere goes the rest of the weekend!
Frogger on the 8-bit Ataris was really well done.He might be referring to Preppie! by Adventure International/Russ Wetmore.
Thanks for the quick response and update Chris!
I'll likely see if I can get it to compile under the Atari Marco-Assembler in the next few days.
Yes, the map is turned left. One of the most interesting archaeological areas in the world.My wife is from Peru (born in Lima / raised in Piura). I've been fortunate enough to have traveled to Peru about a dozen times, including Cuzco and Machu Picchu three or four times. I've even met up with Peruvian AtariAgers while there!
Reset - Resets the game
Select - Changes the active "Commander"/City
Joystick - Moves the active "Commander" icon
I suspect that if it worked, it would work similar to Eastern Front 1941. Unfortunately, I can't get it to do much more than change active commanders and move the icon to neighboring cities.
The code as some interesting "messenger" stuff. Messages can travel twice as fast as armies. (Again, if it worked)
Other than that, it seems to be a pretty, colorful map of Peru twisted toward the left.
Unreleased, never completed, Atari 8-bit game, "Last of the Incas", by Atari/Chris Crawford from Feb - Mar 1984.
Source Code .PDF: Last Of The Incas.pdf
24
This is looking really cool!
Unfortunately our AA family may have a no show on the secret Santa front there is one individual who has yet to receive a gift and I have not heard one peep out of his secret SantaI can contribute if needed. Just let me know.
I put the KryoFlux stream/atx of Adventure Master up on archive.org.
My AASS package arrived today in good order. Thanks SS!
That didn't last long.
I built my first SDrive-MAX including 3D printing the SIO connector and the SDrive-MAX case. I need to update the software to the latest version. Learned a few things and want to try a few tweaks.
I tried printing the XL style case on my FlashForge Finder 3D printer and had some issue. I'm going to try to reprint it with the parts flipped over.
I used 15 conductor cable ... way over kill for this project. I'll try again with a CAT5 cable.
Are these boards still available?
Thank you. I've been tinkering with the idea of building an Atari 8-bit Star Raiders environmental cabinet similar to the Atari Star Wars arcade one. This adapter could be useful in that endeavor.
3D Printed SIO Jack
Its likely to look more like the one on the left with recessed screw head and nut holes.
