Posts
1,374 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by sage
1 hour ago, karri said:
Sorry to hear that @Fadest. My wife and me have to get some new work contracts in 2021 as well. I signed a Japanese style work contract that ends next May due to "high age".?
Weird... I still feel young. Here at the end of the table on a break for dance judges two weeks ago.
Ha really? Japanese style would put you on a pure management post for the last years already.
i would wait until someone *confirms* that it works with several units and time critical games.
i fear this will only work if they find a solution to avoid race conditions and transmit BRKs correctly. There is a reason that there is no well working Emulator<->Emulator or Emulator<->comlynx interface.
- 1
in a way, yes. only for games where you can have a 75HZ refresh from the game engine and/or have enough memory for buffers.
On 10/14/2020 at 9:52 AM, LordKraken said:
ultiple times during each screen refresh. Still it will have an impact on your game performance. People with advanced "demomaker skills" like Sage or Enthusi might develop on that, but I don't see how this technique could be used in a real time game. Maybe for a more static one like chess?
as mentioned, the PATW sokoban clone and some arkanoid/breakout demo clone ...
1 hour ago, Fadest said:
Apart Duranik with Alpine Games and Bonus cartridge, I wonder if someone used more than 16 colors while ingame ?
For me, Alpine Games is a masterpiece, the best game in Lynx library (commercial era and homebrews)
(but maybe I'm biased, Winter Games was my first game on my first computer :D )
indeed.
a few games use rasters, if that counts.
3 hours ago, 42bs said:
USB to Serial adapter:
yep, the diode is needed. I wonder why it was not needed in the old schematics with the MAX232
and with the usual problems....
4 hours ago, Igor said:4 hours ago, Igor said:
@sage thanks, I'll have a look at those threads
feel free to copy what i put together in the spoiler, sorry, that i havent formatted it nicely. If you use it, please add proper credits.
- 1
Spoiler
BLL Comlynx Loader/Debugger
(I wont talk about BLL nor the BLL workaround for the Lynx encryption. The following focuses only on the Comlynx loader/debugger included in BLL.)
Several homebrew ROMs (e.g. Alpine Games, Championship Rally, SIMIS) claim that they contain a BLL loader. So what is the technology behind this and how can you make use of it?
Simply speaking, it is a small piece of code which listens on the comlynx port in the background for some specific command sequences.
Depending on what had been enabled at compile time, these command can be used for debugging the Lynx over comlynx (reading/writing memory, registers, breakpoints), upload and start programs, reset and make screenshots (and send them back to a connected PC).
The most useful feature is the game upload, which can be used for debugging on real hardware. It is much faster than using a flash or sd card which need to swap cards, cables and switching the Lynx off/on. It is very useful for comlynx game development as you can upload the game to several units in parallel by one adapter within only a few seconds.What do you need hardware wise? At least of the loader cards (or the rom on some flash card). A comlynx-serial adapter or a USB serial adapter with 5V level (see below).
The following cartridges contain a BLL comlynx loader. But it might only be active in a specific screen:* BLL Loader Card: selectable speed.
* SIMIS: Main menu only, 9600 baud.
* Lynx Reloaded: Main menu only, selectable speed.
* Alpine Games: Read manual
* Championship Rally: BLL Loader im Tournament screen (after pressing "New Game"), 9600 baud.
* PATW: Loader menu, speed selectable
* most homebrews where the developer forgot to disable the loader: always active, 9600 baud
* Not to forget the flashcard designed by Karri, which allows to flash a ROM via Comlynx.
Comlynx is a serial protocol. Because of hardware limitations on the Lynx side, it uses always 8 bit 1 stop bit and even parity (8E1). The speed is limited to 2400, 9600, 31250, 62500 baud. 9600 is compatible with any PC hardware and adapters, but 31250 and 62500 are not so common, even so 31250 matches the speed of the MIDI standard. In summary, if you want to use 31250 or 62500 baud, you need to chose your your hardware carefully.
Uploading a game which is close to the memory limit of ~56kb, the upload with 62500 baud takes about 10 seconds, but 60 second with only 9600 baud.Limitations and file format:
The game must fit into the Lynx memory. You cannot upload ROM images, but have to upload the binaries which build up the rom image.
The bll assmbler (lyxass) and newcc65/ld65 will produce these binaries directly. For the uptodate version of cc65 you need to create the binary with a special config file (add lynx-bll.cfg to the command line).
Game code can start from $200 on until the position of the hardware registers.
Technical details:
The loader itself is placed at the end of the memory ($FFC0), thus it can not be overwritten by any game code.Documentation from the BLL kit:
The Debugger supports the follwing commands:
$81,"P" - Program
$81,"R" - Reset
$81,"S" - Send screenshot (palette+data)
$82 - continue
$83 - set registers
$84 - write : 0 - byte
1 - word (hi first!)
2 - bytes
$85 - read : 0/1/2
$86 - get registers
The ComLynx-Loader wants:start-sequence : $81,"P" ; command : load program
init-sequence : LO(Start),HI(Start) ; start address = dest.
LO(Len XOR $FFFF),HI(Len XOR $FFFF) ; and len of dataXmit-sequence : Len bytes .... ; data
There is no checksum! If there is an com error, it will not be detected. The upload might stall or the program might crash.
If you read from a file, do not forget to skip the header (and reduce the length accordingly).How to include it in games:
BLL/lyxass:
define the "Baudrate", default is 9615
include serial.inc and debug.inc
call "jsr InstallLoader"ancient cc65 code (newcc65 compiler):
call "InstallUploader();"current cc65:
You can add the uploader to any program by compiling it with lynx-uploader.cfg. This will add an interruptor that listens to ComLynx traffic. But you need to set up the baudrates by yourself to make it usable.I didnt find it, but I copied together some information.
I suggest to add the schematics from the BLL kit with the max chip. I can did out some USB-CL 5V converters, too.
And here are some threads with more and deeper info:
https://atariage.com/forums/topic/132551-bll-carts
https://atariage.com/forums/topic/213073-what-do-i-need-to-load-homebrews
https://atariage.com/forums/topic/14967-lynxpc-serial-cable-back-ordered- 1
For LGSS, you may add the documentation which karri postet here:
https://atariage.com/forums/topic/260379-ls-upcoming-releases-2017/?do=findComment&comment=3736628 -
4 minutes ago, BovineD said:
the roms wont load in Handy either so I think its just bad roms...thx
some rom sites gave lyx a lnx postfix, just to annoy people.
- 1
i had written up something years ago. maybe i find it.
- 1
Request:
You have a prominent article abotu LGSS (https://atarigamer.com/pages/lynx-gaming-sharing-system--lgss-)
I think it would be much more useful to add an article about the loaders which are included in most of the BLL based games. (and beside allow for loading of games over comlynx, even allows for remote debugging, in game screenshots etc.)
chipper export -> handymusic
you have to tweak the instruments afterwards, but hey, there is nothing as a free lunch (or software).
On 9/26/2020 at 4:21 AM, SlidellMan said:
Karri, have you considered doing a series of video tutorials on using chipper?
Yes Karri please do so . I would love to see how this software works for others ?
- 1
16 hours ago, gambler172 said:
where can i find this CC levels?
google.
playable rom images are hidden in the lemmings thread
there are somewhere here in the forum.
as there are only around 30 new levels for lemmings, i did not bother to puit them all into one rom yet, thus there are 30 different roms
for cc i dont actually know. there are hundreds of levels, but not all of them are nice and work on the lynx, as it has some lower limit for enemies etc compared to teh dos version. and some effects are slightly different.
- 1
nice.
I wonder if you want to add the CC and Lemmings ROMs with new levels, as well as the patched Battlezone and Xenophobe, too.
- 1
seems nobody beside Karri tried?
anyway.
I extended it a bit and was merging the midi-synthesizer (which i posted here 3 years ago) with the effect/instrument editor (or the other way around).
now you can trigger effects/instrument from your midi keyboard on the lynx. support for 128 slots instruments and percussion (effects). but only one can be saved to eeprom (128 byte limit :-b ).
there is some possibility to upload/download by midi, but that is a bit too complicated for normal users.
tl;dr
with opt1 you switch between editor and synth player.
as long as you are in the editor, any midi channel (beside 10) triggers the what is in the editor to be played as instrument with the correct note. if you play channel 10, all notes will play the editor content as effect/percussion.
in the synth mode, any midi channel will play the instrument in the slot which has been assigned by the midi-program command to the channel. channel 10 will play effect/perc where the note gives the index in the percussion table.
the editor commands have mostly stayed the same. whats new is that one can switch the play on edit/move from inst to perc/eff or turn it off.
- 1
12 hours ago, karri said:
i just pressed the button "add new loader" in the gui.
Not sure if this was the one from Harry. i did this tools so long time ago.
- 1
and it was not in hex
your offset included the LNX header, that totally confused me :rofl:
CyberPunk experiment 2037 - a new project
in Atari Lynx Programming
how about your lynx sound project? I am am still looking for someone to sort out my instruments ?
