242 -
Posts posted by channelmaniac
Need a keyboard for that CoCo?
Nice! I have a CoCo 1, 2, 3, and MC-10 here... need to hook one up in the game room and break out all the pieces I picked up over the past few years... multipak, disk drive, etc...
I should go Google a good composite video circuit for the older CoCos... and try it on the MC-10.
I have a couple of tubes of these chips, just don't have them up on the website yet... but, good luck ordering from China. Too many counterfeits...
You did just fine on that one.
It all depends on what you have to spend budget-wise. I just picked up a Pace MBT-201 with soldering and desoldering iron off of Craigslist for $150.
RAM upgrade is simple to do. Instructions are on the download page on my site.
Are you sure?
co, no c0: http://www.arcadecom...735/2995543.htm
I'm not the expert... I've seen chips that looked both ways so I simply picked one way to list all the chips on my site.
Raymond
Big pink pencil eraser followed by a wipe with a lint free cloth that has some pure isopropyl alcohol on it.
If that doesn't do it then I break out the fiberglass pencil.
I'll be updating the instructions and kits I have on my site for the Dual BIOS mod... There are issues with some brands of EPROMs if you tie an address line directly to ground where they are sourcing the current to float the line high and the chips will get finger blistering hot then fail. The power and ground lines should connect each with a 220 to 330 ohm resistor.
Upper most address line
Switch ------------- 330ohm------- ground
330ohm
+5v
I used to work for a grey market Apple repair depot back in the mid 90s called Contemporary Concepts. We had a dishwasher and used it to clean hundreds and hundreds of boards... and back when Apple had individual key switches on keyboards we cleaned the puke filled keyboards too. After the keyboards dried we'd lubricate the key switches and test them, replacing a couple of bad ones here and there...
NO batteries. Hot water wash. Hot water rinse. NO santization sequence and NO heat dry. No soap either. Let the boards dry well (a day on DIP boards, 3 on SMT) and you are good to go.
Heat dry WILL melt plastics. The radiant heat is too much for many of the softer plastics.
Today when I work on arcade game boards I just use as hot of water as I can stand, a tooth brush, and some liquid dishwashing soap and scrub the hell out of 'em in the kitchen sink. I dry them in the oven at 170 degrees F for about 20 to 25 minutes and they come out sparkling clean and toasty. Be sure to use oven mitts!
I just did a Neo Geo 2 slot board that came in VERY nasty looking. After cleaning it looked like new.
RJ
Find a friend that can solder in another switch!
If you have a pic of the switch, I probably have one here on a parts board.
PM replied.
I have a few boxed 99/4a systems to scrap out... they are worth more as parts than as a whole computer...
I know I have both beige and black keyboards... and will sell 'em off for $5 plus shipping.
I'd be shocked to see TI-99/4a systems selling for "a coupla hunnert"... If they do I have 3 or 4 in the box.
I have an old TI-99/4 that I expect to sell for that price, but not the /4a.
One of these days I'll assemble the mother load of TI stuff into a big tested lot and sell it. I have several /4a, one /4, 3 PEBs, disk drives, cartridges, disks, voice synths, and more. Enough to make one nicely loaded setup with a /4 and maybe one with a /4a. All that is missing is the TI branded monitor.
At the speed the CV runs at you can use 200ns, 150ns, 120ns, or 100ns DRAM just fine without any issues.
Of course, it's best to have matching speed DRAMs but at that slow speed you can mix/match DRAM speeds and manufacturers with little issue.
For the switch, you can pick up dielectric grease at any automotive store. It's used for installing spark plugs as a little bit in the boot keeps the boot from sticking to the plug so you can remove them without the wire pulling out of the boot.
Little bits of boot sticking on the plug makes it difficult to get a socket it so you can remove it during troubleshooting or tune-ups. -
PAL chips have been sold!
Hey gang,
Long time lurker here...
I was wondering if anyone knew of a ROM or a cartridge that exists to do some bank testing on the ColecoVision mainboard? I have a RevF that appears to have been submerged in Coca-Cola or some other toxic abrasive yet the board still functions... mostly. It will load standard ColecoVision carts but nothing with a large memory footprint. So homebrew games like Mario Bros. will not load or play.
I bought some ICs to replace bad memory (if that's the case) but I was wondering if there was a way to test the memory... I do have a way to burn a ROM if necessary. Of course, it might be a trace since it's all nice and bubbly but I still think it would be great to have a bank tester if there were such a thing.
Thanks,
-Madaracs
Check this website out for some CV Mod Boards with full PDF instructions available. They also have a mod to replace the current +5v memory chips with memory chips that require less voltage... therefore of course less heat build up. Looks like some nice stuff, but I'll let you decide as my days of fiddling have long past.
Has anyone else heard of this place or dealt with them?
http://www.arcadecom....com/index.html
Jim
Hi Jim,
That's my site.
Raymond
OK,
I was going through a box of surplus CPU boards and found a some items I don't have a need for and can't test, but thought that someone here would have an interest in.
First up: Atari 800 CPU board with no chips, labeled "5" in black silkscreen. All part locations are in black silk screen and a hand written "000166" is on it. No idea if that's the serial # of the board... all the other CPU boards had white silk screen so this one stood out. It has "C014360 REV 1 ©79" on it.
$5 on the empty CPU board
SOLD: Second up: 3 x CO14887 - PAL ANTIC
SOLD: Third up: 3 x CO14889 - PAL GTIA
$2.50 each on the chips. As mentioned, I can't test them. They came off surplus boards that I bought > 70 of.
Fourth up: Atari 800 Personality Board with all chips, labeled "4" in white silkscreen. Labeled C012989 REV E.
$7.50 on the Personality Board.
Fifth up: Some kind of Atari disk drive analog card. Labeled "CO17761 REV 4"
$4.00 on the disk drive board.
Plus shipping. I do take PayPal.
Thanks!
RJ
Dang... Vermont... I'm in Texas.
I'm looking for an old version of the Apple II+, the one that uses the special character generator chip and not the simple ROM. I'm wanting to build a replacement circuit for that old chip and need a board to experiment with.
RJ
Most of those silly USB adapters won't work with DOS based devices... you'd need some kind of drivers that worked in DOS mode PLUS all the extra signaling lines that may be missing from the USB versions.
OK,
I've had some of the 2600 cartridge slots sitting around in the filing cabinet here and just ran across them tonight again while cleaning. I don't want to throw them out so the first person to PP me a few dollars to cover shipping can grab 'em instead of them heading to the landfill.
There are 8 of them. Some have the plastic cartridge guide and some don't.
Thanks!
RJ
I have a console listed in Marketplace. It is refurbished and tested. It has the A/V mod, pause button mod and intro skip BIOs installed.
You should look into doing the 5v only memory mods too... Makes the system more reliable.
How about 50/50 mix of type B and C for the 8-bit computer. Can you do PayPal?
If you can, I'll PM my account name, then you could generate an invoice for me, and I can pay up straight away.
A dozen or so should be sufficient - so, say ~ $24 worth in total including postage.
Thanks for the PMs and the purchase.
I still have plenty left!
How many of the type B and C (for the 800) boards do you have?
I wouldn't mind getting hold of some, but not really worth it unless I could at least partly fill one of those $15 International mailers you guys can use... they hold around 16 populated 7800 boards, so should hold at least that many computer cart boards.
I have over 200 of them combined... mostly the C boards. How many did you want to get? I can put them in a tyvek FedEx envelope and shove it in the USPS Priority Mail Flat Rate International envelope. That's $13.60 for all I can stuff in it (up to 4 pounds in weight)... and I should be able to stuff a bunch in it.
Tandy 64k Color Computer OR Ti994/a ?
in Classic Computing Discussion
Bummer... The keyboard I have sitting here is a melty CoCo 2 version, not the 3. Would be a good upgrade for a CoCo 1 tho.
