103 -
Posts posted by Tigerduck
I'd never considered epilepsy warnings before but I included one here since there is quite a bit of flashing with the strobe option.
Good idea, don't know if i can fall asleep tonight. I'm afraid to close my eyes, flashing will start again and again...
By the way, cooool work!
Tigerduck
Thanks for testing. Can you test again with color switch at B&W too?
I am surprised that there are any differences at all.
OK here are the results:
(No B&W switch on the 7800)
ATARI 2600 4 switch PAL CVBS - 33/255/24
ATARI 2600 junior PAL Antenna - 32/257/23
Hmm, with the SEGA Lightgun I experienced the same effect. Additionally there is one vertical line close to the left edgde of the screen witch triggers the gun.
With the original XG1 if have only the line on the left mentioned above. It's much harder to follow the line to keep the trigger with the XG1 than the SEGA.
I don't have an explanation for this behavior.
But to start the little testprogramm with my Harmony, first I have to select and activate the Programm with a joystick then unplug it and change to the lightgun.
Maybe this procedure could lead to a strange behavior.
I experienced wrong input interpretation in the Harmony menu when i plugged in the joystick after starting the console...
TV is a JVC 15'' 4:3 with this results (I was curios and tested it with different machines...)
ATARI 2600 4 switch PAL CVBS - 25/215/22
ATARI 7800 PAL Antenna - 25/214/23
ATARI 7800 NTSC Antenna - 25/217/20
ATARI 2600 junior PAL Antenna - 24/216/22
Hi Thomas,
I have both, the ATARI Lightgun and the SEGA one with converter.
There is no difference in precision in my opinion.
If you like, I can solder you a new adapter for SEGA or lend you my existing, together with the SEGA Lightgun. Or I lend you my original ATARI Lightgun (But only one of the two options, I need one for myself, if I'm in the mood for Alien Brigade
Viele Grüsse
Tigerduck
Please add me to the list, I'd like to have one.
1 Gold for my ATARI 400 PAL, please.
One The!Cart for The!Tigerduck.
As well, one for the Tigerduck...
Spring Break Party with Dimo - cool!
Great series of podcasts, picked some of them concerning my interest.
Very informative and thank you for your clear pronunciation from a non native speaker...
Keep it up!
Just through all the 3 magazines, really great work.
I do not agree with some of the rankings of the games, because it seems to me you are to enthusiastic on some games.
But hey, that's only my opinion!
Good reviews with a lot of background information.
I hope you will release some more magazines, even it's not on a regular base.
Best regards
Tigerduck
Hi, please put me on the list.
Has anyone tested the Rapidus with the Flightsimulator II ?
Is there an improvement in the framerate and is it still useable then?
Thanks for testing
Cool demo, nice easter surprise!
Demo works with SIO2BT and Aspeqt BT on real hardware, but only with Basic on, like "ggn" wrote before...
130K Version the same, only with Basic enabled.
Thanks to Captain Panda
P.S. is there really a hidden part???
@Tigerduck
The new Freezer construction have only one connector, therefore don't need excessive force to remove or place it on its socket.
But I am agree with you, cause the removal and place isn't something for daily use. Or worse just for fun.
Just for my confirmation, the "new" Freezer will work with the old Adapter without any modifications?
I assume that the second connector is only for stability, because conntacts on the board are going through.
OK, everthing is working properly now!
We had the corrected installation guide, but we are to excited to read the guide carefully
Eastern is now the time to check out "The last word" - VBXE version!
Thanks for your answers!
Tigerduck
I'm in with one Freezer without any adapter!
Background:
I have one Freezer 2010 and two adapters. One for the XE and the other for the XL.
My intention was to save money and swap the freezer easily from one adapter to the other.
That's theorie... It's always delicate to remove the freezer from the socket without bending the pins.
The day will come and one or more of the 50 pins will stuck in the socket...
Just my experience to warn other atarians with the same intention.
Best regards
Tigerduck
Hi,
today we installed a VBXE 2.1 from Lotharek into a 130 XE. The RGB output works fine, but no VBXE features are available. When we try to check or flash the core with "FC.COM" is fails with "VBXE IO error" and that's it. I tried changing the PAL/NTSC jumper as described in another thread, but that didn't help (and resulted in a garbled image).
Anybody who has seen or fixed this before?
Tigerduck & JAC!
Hi JAC!
I hope you can cope with this page in german language...
http://www.pitsch.de/stuff/a2600svideo/index.htm
Maybe you remember, you already installed one of these on my 2600er...
Sorry, how do you load the file from DOS 2.5?
- Y -
Option "L" for "BINARY LOAD"
Press "RETURN"
Type in "DUNGEON.OBJ"
Press "RETURN"
Hi Antic-Team,
since I know about your podcasts, I really like long car rides again...
Cruise control mode on and relax. No commercials, no interruption just plain ATARI-Entertainment (with a little TI99/4A
).Keep up the good work!
Tigerduck
New Hardware: Atari 400/800 Super Color CPU Card
Posted · Edited by Tigerduck
Mine is already built in!
ATARI 400 PAL. I desoldered the channel switch to use the hole for the video cable.
Proof:
Just one question. Is the RF output still available when SCCC is installed?
Thank you Jürgen for this great device! Very clear picture now. Thanks to Bryan for UAV, too.
Best regards
Tigerduck
