Posts
15,160 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by _The Doctor__
it will all end up on theftbay, where the fence and pawn are one and the same.
Close, you need to read more slowly the hint hint hints. No hint on a correct line but hint on something that needs a look or possible change.
Make sure all .jeds, all firmware, and all plugins are up to date.
those that report all works for them please list your running revision number of all
those that report all do not work please list your running revision number of all plus example attachments of files that failed to launch
remember not everything likes basic, pbi, high sio, SDX, or all memory extension choices.
this ain't new, remember when they blocked .exe and the like? well now they are .xex
don't feel like we all want to make bin into ibn nib or inb. They're idiots, so maybe we work around it and let them know how silly it is and why it never worked when they tried this ineffective annoyance years earlier with other extensions.
Most hacks name crap as a harmless file type anyway... like .tmp test.dat and so on. These guys are elementary lame.
plain deoxit without the protectant/lube followed by the methods I outlined and gave links to in the past. I can't remember at the moment but they are in the forum. once done you won't have to keep at it no where near as much again.
Someone made a carrier box that nicely attached to the vent holes and allowed the lights and switches to be in that, looked fine. Maybe it needs recreation?
So print whole bezel or print snap on bezel box
Many of these carts do not take signal timing length into consideration for data transfer. The 800 cart port is slightly different spec due to ras cas rather than phi
on cart port ultimate cart gets it correct others can do the same if coded like ult and another that get it right. else
you have to modify cart slot signal with wire or upgrade needs to do this for you which some do. Some might have fixed this with a jed update or or cart boot file on SD etc
– POWER LED: anode (longer leg) through resistor approx. 1 kΩ to supply +5V, cathode (shorter leg) to ground (GND)
– ACTIVITY LED: anode (longer leg)through 470 Ω resistor to +5V, while the cathode to RX output on Arduino board (HINT HINT HINT)also you can put another resistor value (higher) or have another in series to dim them and keep from drawing to much power from the arduino or power source. (hint)
also, most SD card readers don't need the menu selection system and can't set images without it, The ones without displays of any kind might require the menu but it's up to them to find a solution. Once he image is selected, the machine won't be using any of that menu memory anyway.
- 1
A Popeye enhancement of saving the scores?
1 minute ago, woj said:
Wait a second - is my interpretation that AVG emulation of AtariMax carts supports "flashing" into the CAR image correct?
it does save the data
54 minutes ago, yorxs said:
I successfully got FloB running on the 400 mini noticed it says the game supports optional stereo Pokey. When the game loads it indicates Mono sound. I checked the .cfg file created for the game, but I did not see any options relating to sound. Also I could not find anywhere in the PDF manual where it discusses sound. Does anyone know how to enable the optional Pokey sound on the 400 Mini?
The 400 mini is an underpowered emulation box in a nifty case, it is not an 8 bit per se' ... I'd check out the 400 mini section tagged incorrectly at the top of the page, click on that and ask 400 mini emulation questions there.
2 hours ago, AtariPhreak said:
Right - I’m lucidphreak - I contributed some to the BBS Guru’s group, was the guy that found Marshware, dropped names of bbs software I had found mention of that we went on to find for real, etc… i just havent been as active since the switch to email addresses here.. My Side3 and U1MB should be here soon - and once they are installed I’m hoping to run a BBS again..
I think you put you reply in the wrong quote box so I broke it out for you
fujinet.pl
ANODE directory
launch it.
register with it.
use it.
- 1
You can thank Helen for that.
Though he certainly did not invent the processor nor was he the father of... wow talk about something needing an edit. They certainly couldn't have meant how this translated.
Bad guess, this all shows it can be done, just that other pieces to the puzzle aren't filled in. If you would like to fund it, then it can be... otherwise, people have got to eat, have a place to live, and perhaps some transportation.
There are modes of write protection on all of these systems including disks
Make sure any installed application on the serving computer are allowed to write
Next make sure the emulated disk is not write protected by notch.
Next that the emulated disks files are not in set protected by the DOS.
Next that the serving app does not have the image slot set to protect the image or virtually protect the image.
and so on.
Depending on device and SIO filter? 10 divisor indexes better
Some some NTSC units did not handle simple us doubler warp well, until the first set of caps were clipped, and for DIVISOR 0 both sets.
So it helps from 52k on up to 127 (125)
- 2
- 1
definitely make sure the instructions to fix the messed version board go far and wide but none of it's creation files continue to propagate and ask others make them go bye bye. Anything is fixable of course . The new revision is here already though.
The last version 6 looks to be moving along nicely so it's all good. Happy times.
Correct Atari DOS is usually 2 Floppies to start and you either have to use it's set up utility or poke any others on and write the DOS files.
If RespeQT is running, can you boot disks and pull data from it?
Wrong ANTIC can be a memory issue among other problems depending on the machine and it's modifications the warning is correct.
- 1
until someone kicks in with Disk I/O etc the GEOS project probably will not move forward.
AtariMax SIO2PC usb devices employ a controller that allows xf551 and similar high speed handshaking schemes that no other devices can do, as a result the USB portion requires that you use virtual com drivers when used with other USB devices, including roll your own ftdi cables etc, so that you are using their usb drivers and not the AtariMax driver.
Standard serial port SIO 2 PC rs232 etc will work as is and you can make your own, use an atarimax, etc
Yes that would be the best option.❤️
- 1
CPM/Z-80 card for the 1090XL -- Calling anyone with Z-80 experience!
will the card allow the z80 to access additional ram etc for mdisk (ramdisk etc?) of cpm fame?
