NML32
    664
Posts posted by NML32
  1. This is the latest update from Digi.
    Hi Mark
    This part was just sent to our Product Manager to review. If the parts have to be returned to the supplier for evaluation this process can take a few weeks. We will advise as soon we have any information.
    Please let us know if there is anything else that we can help with.
    Thanks,
    Cristin Gums
    Customer Service
    DIGI-KEY CORPORATION
  2. Did you test with experiment_20130813.sof
    Ref post #176
    http://atariage.com/forums/topic/213827-potential-new-hardware/page-8?do=findComment&comment=2860719
    I had tried the test with just 4-8 up and same thing. The SRAM chip is IS61WV25616EDBLL-10TLI. I looked at the comparison again and see that the failures are in three distinct blocks. It kind of sounds like its the glitchy control panel that others have noted. At this point I'm just going to go on the consideration that this expensive little video converter doesn't work and find something different to connect.
  3. I did a quick test and the two files were different. I'll try it again when I get back home. It took me a while to find a program that would create a 512K text file.
    Thanks,
    Mark
    This is bad :(Could you please try writing/reading the SRAM with the control panel from the new DE1 CD?I just compared the datasheets of the old and new SRAMs but couldn't find anything obvious. Actually, the datasheet of the new IS61WV25616EDBLL chip says it can be used as a drop-in replacement for other standard SRAMs. I'd say the bad batch theory is more and more likely.so long,Hias
  4. Well, I'm sending my DE1 back to Digi-Key and they're going to run some test to determine if there is anything wrong with the board. In the mean time I ordered another DE1 while Digi decides how to handle this. I hope I have better luck with the next board.
    -Mark
  5. SW 5 down and the rest up.
    Going to try the other test.
    Edit: I didn't have much luck with the control panel Board Test. Both RAM test fail and the Flash Test times out.
    Not sure if this means anything but I'm able to flash a MSX (de1_170513.sof) just fine.
  6. Hi!
    Be sure to set sw7 to up, especially if you have a new DE1 board and enable Turbo Mode (sw9).
    The newer boards use slower flash chips. Using 2 waitstates (sw7 down) worked on my board with turbo mode off, but if I enabled turbo mode I'd also get crashes, black screens and lockups unless I set sw7 up.
    Try with a "safe" default setup: sw7 up, sw8/4 according to your desired video config, all other switches down.
    so long,
    Hias
    Thanks for the reply. It helped a little, now I can see something on the screen without doing so many resets. But it's still garbage, black, or green frozen screen.
  7. Got it flashed but I only see a blank screen (black). One time I think I heard test tones while I was messing around pressing keys on the keyboard. I went back tried some of the earlier sof files 20130813 and 22 and I got a screen after pressing key2 many times. But the screen was full of garbage.
  8. Another one of my favorites for the Ouya.
    http://heroesofumbra.com
    About:
    Heroes of Umbra is a 2D side-scrolling online RPG in-progress that plays similar to side-scrolling RPGs like MapleStory and Castlevania. Whether youre on an Android device, a desktop computer, or the OUYA console, online play is platform-agnostic. You can connect and play with your friends anywhere with Internet access, or
    just solo single-player if you cant get (or dont want to be) online.
    The game is completely free-to-play and DRM-free.
