bogax
    902
Posts posted by bogax
  1. my code:
     temp4 = 4 - anglevar & $07
    temp4 = temp4 * 2
    temp5 = player1x - bxtbl[temp4]
    temp6 = player1y - bytbl[temp4]
    if temp5 < 4 && temp6 < 8 then goto 710
    rem if no collision is detected, skip to the end of the main loop
    goto 800
    rem minimum collision data locations (x, y)
    data bxtbl
    79
    end
    data bytbl
    5, 110,13, 126,45, 110,77, 78,85, 46,77, 30,45, 46,13
    end
    rem check for collision type
    710
    temp4 = temp4 + base & $0F
    rem check if the block is already dead
    if a[temp4] = 0 then goto 800
    rem check ball color against block color
    if a[temp4]<>ballcolor then goto bad_hit
    rem if the hit is good...
    good_hit
    rem set current block to dead
    a[temp4] = 0 : blckcnt = blckcnt - 1
    for yours it could be
    temp4 = temp4 * 2 + base & %00001111
    Also, why do you like using $0F when 15 is functionally equivalent and much less confusing to read?
    force of habit, it doesn't seem that way to me
    but probably binary is clearer
    edit
    I see I mucked up some of the numbers again (fixed)
    (and is why the collision detection was failing)
  2. Rather than try and respond to indvidual points
    with quotes I'm just going to make some observations
    and post this (link to) some code.
    pointers is what you're doing when you index into
    memory with a variable, you just don't get the
    extra layers of abstraction in bB (a good thing)
    I redid the collision code to remove the loop
    that takes some of the curse off as far as using
    an offset (which I call base) into the colors so
    I incorporated that. mainly to demonstrate.
    I changed the collision code it misses at
    six o clock I haven't figured out why.
    I don't think it has an inordinate amount of flicker
    for what it's doing but I may be wrong. it goes over
    on line count. I don't know how stella deals with that
    timing wise. If you look for just one color it's solid,
    if you look for two it flickers about like I'd expect
    if the screen was blanked half the time (which presumably
    it shouldn't be). using one color should take the most
    time in the loop and apparently that doesn't mess it
    up too badly. So my question is could it be its that
    going over it's line budget?
    It looks for a color that's being used and only draws
    the screen if it finds one. It apparently doesn't
    take too long if it just looks for one color and
    pfpixels (v) :) the blocks to the screen and does
    a drawscreen but if it looks for another color even
    without having to draw anything it flickers.
    just looking for another color pushes it over.
    (hmm occurs to me I didn't check to see how it does
    if it looks for two colors but only has to draw one
    color block of one color which would be about as fast
    as looking for two colors could go)
    In general it's a good thing to speed things up
    especially if you're going over time.
    So I might suggest something with out refernce
    to a specific problem, eg flicker, that doesn't mean
    it wouldn't help the situation.
    to that end I incorprated a block count and removed
    tha loop for that (and did some other minor stuff)
    I'm sure there's still plenty of opportunity for
    streamling the code.
    theloon had a couple of interesting suggestions.
    in particular I like the idea of keeping track of
    which colors you're using instead of searching the
    blocks for colors that aren't there.
    for my self I wonder if it might help to bypass pfpixel
    and write the playfield directly.
    But I don't think anything's going to help enough untill
    you have a kernel that can do more than on color per line
    and takes the colors from ram
    edit
    crap wrong version I'll have to find it
    hopefully this is it
    http://pastebin.com/3kCzwKJT
  3. Egh. Tried fiddling with what you offered there, bogax, and while it does make the movement work just fine, the hit detection is completely buggered by the change.
    what I posted was just meant to be an example of
    what would need to be done, the collision routine
    would need to be fixed, I just did't show it.
    And I still can't figure out what's going wrong here:
    I don't think there's anything wrong. Try it with just one color
    (don't change flicker) and then with two (let flicker cycle 0-1)
    the asm I posted for the rotation was bugged, fixed now
    I'd suggest you keep a count of the remaining blocks that
    gets updated when you have a good hit rather than counting
    through the blocks to check if there's any left
    in the flicker code you could pull the color look up out of
    the loop
    you could also up date flicker in one place
     rem cycle through pfpixels, turning them on if they are equal to the color being drawn
    temp3 = blkc[flicker]
    for temp5 = 0 to 15
    if a[temp5] = temp3 then pfpixel ctbl[temp5] rtbl[temp5] on: temp4 = 1
    next
    flicker = flicker + 1 & 7
    rem determines if a color shows up; if not, don't bother drawing that color and return for the next
    if temp4 then COLUPF = temp3 else goto 110
  4. since I don't really understand what a[temp1] = a[(temp1+1)&15] does
    in this case it effects a mod 16.
    0 and anything is 0
    1 and anything is that thing.
    15 is 00001111 in binary
    & 15 is a bitwise and
    so you zero everything but the lower four bits
    kinda like in decimal if you set all digits of an integer
    except the first one (least significant) to zero you get
    that number mod 10 if you keep the first two it's mod 100 etc
    I see your point, though I don't think that it will work with the way the code is currently set up. More than just the visual colors are dependent on the location in the array: the coordinates of each pfpixel is tied to a location in the array which I depend on when determining which color each pfpixel is, so a[0] needs to correspond to ctbl[0] and rtbl[0]. I'm not sure that a single variable is sufficient for carrying that offset in addition to performing the cooldown function (to ensure that the ring rotation isn't per-pixel sensitive), and I'm really not quite sure how it would work at all without the ability for variable values to go into the negatives.
    I don't think it would be much of a problem to fit it
    into what you're doing now. I'm not sure there'd be any
    advantage. it would greatly simplify the rotation code
    at the expense of adding code and slowing things down
    pretty much every where else you indexed the objects.
    you'd also need a variable to remember where your first
    object is,
    or to map the logical location to the actual address
    or between the colors index and the position
    paramters index(es) if you like (how ever you want to
    think of it).
    you'd either need to translate from a loop variable
    to an index or maintain the index in parallel with the
    translation built in.
    I didn't actually count the cycles but it would save you
    450 cycles in the rotation loops at the expense of extra
    150 cycles in the rest of the loops.
     for temp5 = 0 to 15
    if a[temp5] = blkc[flicker] then pfpixel ctbl[temp5] rtbl[temp5] on
    next
    would become:
    translate
    for temp5 = 0 to 15
    temp6 = temp5 + base & $0F
    if a[temp6] = blkc[flicker] then pfpixel ctbl[temp5] rtbl[temp5] on
    next
    in parallel
    temp6 = base
    for temp5 = 0 to 15
    temp6 = temp6 + 1 & $0F
    next
    that assumes you're starting with the first color
    you could also make the object color index the
    for-variable but I think that would complicate
    things needlessly
    as an aside you shouldn't count on temp variables
    if you're going to call something that might use them
    like pfpixel (although I think the only temp variable
    pfpixel uses it temp2)
    rotation is simplified
    rem rotate left
    base = base + 1 & $0F
    possibly I'm missing something but the only thing that
    changes is how the object colors are mapped to the other
    stuff I don't see how that effects cooldown
    I suppose if, where you start has an effect there could be
    problems ie you assume that the first thing in a table
    is also the first object/color
    like if you drew things top down by color here and by table
    location there
    but I didn't see that(?)
    also I don't see what you need negative values for
    here's the old rotation code in asm (untested)
     REM rotate left
    asm
    lda a
    pha
    ldx #$00
    LLOOP
    lda b,x
    sta a,x
    inx
    cpx #15
    bne LLOOP
    pla
    sta p
    end
    rem rotate right
    asm
    lda p
    pha
    ldx #14
    RLOOP
    lda a,x
    sta b,x
    dex
    bpl RLOOP
    pla
    sta a
    end
    miscellaneous
     for temp1 = 0 to 15
    temp2 = (rand/64)
    if temp2 < 2 then a[temp1] = blkc[1] else a[temp1] = blkc[0]
    next
     for temp1 = 0 to 15
    temp2 = rand
    if temp2 < 128 then a[temp1] = blkc[1] else a[temp1] = blkc[0]
    next
    actually you can use rand instead of temp2 in the if-then
    but then bB just uses the last value of rand without computing
    a new one
  5. it appears that bB sometimes treats random as a call
    to randomize ie the same as rand
    I suggest you change random to something else, probably
    something that doesn't start with rand and see what that
    does for you.
  6. it occured to me that if you use the noinlinedata
    optimization you can interleave the x and y tables
    thusly.
    I have no idea if this is relevant
     for i = 0 to 14 step 2
    if a[i] then goto collision_test
    nexti
    next
    collision_test
    temp1 = playerx1-xtbl[i]
    if temp1>3 then goto nexti
    temp1 = playery1-ytbl[i]
    if temp1>5 then goto nexti
    if a[i]<>ballcolor then goto bad_hit
    rem good_hit
    a[i]=0
    bad_hit
    data xtbl
    81
    end
    data ytbl
    9, 114, 17, 130, 49, 114, 81, 82, 89, 50, 81, 34, 49, 50, 17
    end
    and while I'm at it
     rem move all block values to the right
    temp2 = a
    for temp1 = 0 to 14
    a[temp1] = b[temp1]
    next
    p = temp2
    rem move all blocks to the left
    temp2 = p
    for temp1 = 14 to 0 step -1
    b[temp1] = a[temp1]
    next
    a = temp2
  7. I'm not sure I understand the points about:
    move_nothing0
    player0x = (player0x - 1)
    if player0x = 0 || player0x > 240 then gosub change_object0
    return
    ..because your before and after look the same to me.
    yours is gosub, use goto (since you're going to return right away
    any way) that way you save a return
    Also, how are the gosubs bankswitched? They should all be in the same bank. Is the bB assembly using complicated gosub code used for multi-bank jumps?
    if you've got multiple banks and you don't tell bB you're returning to
    the same bank bB assumes you might be returning to a different
    bank and checks and that takes more time. (if you want to gosub to
    a different bank I think you have to explicitly specify or else bB
    assumes it's the same bank)
    philosophical statement:
    there's nothing wrong with gotos just don't abuse them
  8. I didn't really try to understand your code.
    I can see things that might possibly speed things up
    (I didn't try to figure out if they actually would
    or if it would be enough to bother)
    for one thing
    draw_shieldsp0
    if shieldsp0 < 32 then pfscore1 = %10000000 : return
    if shieldsp0 < 64 then pfscore1 = %11000000 : return
    if shieldsp0 < 96 then pfscore1 = %11100000 : return
    if shieldsp0 < 128 then pfscore1 = %11110000 : return
    if shieldsp0 < 160 then pfscore1 = %11111000 : return
    if shieldsp0 < 192 then pfscore1 = %11111100 : return
    if shieldsp0 < 224 then pfscore1 = %11111110 : return
    if shieldsp0 < 255 then pfscore1 = %11111111
    return
    could be rewritten as
    temp1 = shieldsp0 / 4 / 8 : pfscore1 = sh0tbl[temp1] : return
    data sh0tbl
    %10000000, %11000000, %11100000, %11110000, %11111000, %11111100, %11111110, %11111111
    end
    you've got a number of tail calls that could be optimized eg
    move_nothing0
    return
    could be
    move_nothing0
    if player0x = 0 || player0x > 240 then goto change_object0
    return
    and if I'm reading right
    change_object0
    player0x = view_width
    player0y = (random&63) + 1
    tempvar = (random&3) + 1
    if tempvar > 3 then temp5 = 3
    if tempvar = obj_nothing then gosub create_nothing0
    if tempvar = obj_4bunnies then gosub create_4bunnies0
    if tempvar = obj_comet then gosub create_comet0
    return
    could be
    change_object0
    on tempvar goto RET create_nothing0 create_4bunnies0 create_comet0
    RET
    return
    This is just for illustration.
    like I used temp1 without regard to whether you were
    already using it (if you are you'll have to figure
    something else out obviously)
    or like you shouldn't need RET, tempvar should vary 0-2
    edit:
    I see you're doing a lot of bankswitched returns.
    it'd probably help a lot if you knocked that off
    if you don't/can't then an on..goto that only has two
    targets and allows a tail call optimization is probably
    faster
  9. I meant in the context of memory. The 2600 and its cartridges have very limited space, which is why we only get 26 variables, each of which can hold a single byte. How do we also get as many 256-byte data sets as we want? Where is that information stored? It must go into some area of the RAM that isn't available for normal processes, eh?
    not in ram, in rom with the code, which is why either the code has to
    jump around it or you have to put it out of the way of the code.
    and it's read only.
  10. Where is this being stored, out of curiosity?
    the data statements go where ever you put them and the code
    jumps around them.
    there's a compiler optimization, noinlinedata, which I believe just
    tells the compiler not to generate the jumps so you have to put
    the data statements where code won't run in to them.
  11. Now if only I could simplify my big lists of pfpixel coordinates with a data set. Is that possible? Such as pfpixel [temp1]?
    it'd help if you posted what you've got now so we
    can see where you are.
    is it secret?
    this is meant to be a more compact version
    of what you posted before
    untested etc.
    for i = 0 to 15
    pfclear : pfpixel ctbl[i] rtbl[i] on : COLUPF = a[i] : drawscreen
    next
    data ctbl
    16, 20, 24, 27, 28, 27, 24, 2, 18, 12, 8, 5, 4, 5, 8, 12
    end
    data rtbl
    0, 0, 1, 3, 5, 7, 9, 10, 10, 10, 9, 7, 5, 3, 1, 0
    end
    Your suggestion cut my ROM size from about 170 bytes to 734 bytes. I'd love to do THAT again!
    By the way, how many data sets am I allowed? Or is it just as many as I like, so long as they don't total over 256 bytes?
    right
    edit as many data statments as you want up to 256 bytes EACH
  12. So you would compile the game with some inline assembly in the other bank. At this point the game would still be using the old BB kernel, and flicker. You then have to manually edit the rom with a hex editor (like HOM3) to get the game to bankswitch instead of running the BB kernel. Once inside the new bank the assembly logic would decide if the title screen is being drawn. If it is then a jump and bank switch would occur to go back to the BB kernel. Otherwise the assembly kernel would draw. Finally after the assembly kernel a jump and bankswitch occurs to go back to the BB side, and hand off control.
    I know that sounds like a lot, but for an experienced assembly programmer it's not to bad. Since you would be starting out with assembly this might be a little bit too much to ask. You will probably need help to do it, but the plan of attack is there.
    Once the game is finalized (and you compile the assembly in) then there should only have to be a few bytes that need patching if you make changes (I.e. to perform a bankswitch in 1 place, maybe 3 bytes total). Everytime you make a new rom you would have to patch that area, and hopefully that area never changes. The idea and key here is that there is only a small area to patch to get the game working, making the work as little as possible.
    With the standard caveat IAFFAE (I am far from an expert)
    I don't think it would take all that.
    you might be able to do it with the normal bB far call
    (what ever it's called in bB) but if not I think you'd just have to
    have a few bytes of ASM to replace the normal drawscreen
    statement.
    that is to say you'd have your custom kernel in it's own bank
    and go to it instead of the bB kernel using the normal (more or less)
    bB facilities I don't think you'd have to go in and patch stuff
    (and even if you did you could do it in the ASM listing I expect)
    might have trouble with conflicting labels I don't know how that's
    handled in bB (ie can you create name spaces on a per bank
    basis, can labels be the same if they're in different banks or
    will that confuse the assembler)
  13. I worry that the back and forth animation to make this possible with be almost as sickening to the player as the flicker itself.
    yeah that's why I said it still doesn't look very good.
    interestingly I can see it as either two alternating patterns that jump
    back and forth with out regard to the colors or as rotating colored
    blocks
    I don't know how common that would be but it might take some
    practice/concentration for some people to see it correctly.
  14. Another fix is to make sure your latest pfcolors choice is used every time before drawscreen:
    www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors
    excellent.
    that fixed mine so here it is.
    still doesn't look very good to me.
    http://pastebin.com/fHQFsUeJ
    I also wrote a javascript to write out the pfcolors statements
    if anybody has a mind to play with it
    http://pastebin.com/x15JBkqn
  15. I've gone through and optimized the code as much as I can, squeezing out a total of 183 Bytes that have not yet been used. If this kernel thing works to handle the flicker, that can be upped to about 710 bytes, as a good chunk is spent in the flicker code.
    obviously this is untested but it compiles.
    I may well have goofed something up.
    I rewrote the collision code you posted to get rid of those
    redundant if-then statements (and then stuck a couple of
    my own in)
     if playerx1<50 || playerx1 > 133 then goto skip_collision_test
    if playery1<9 || playery1 > 94 then goto skip_collision_test
    nexti
    next
    skip_collision_test
    if player1x = 0 || player1y = 0 then goto 750
    if player1x=156 || player1y = 140 then goto 750
    collision_test
    temp1 = playerx1-xtbl[i]&127
    temp1 = playery1-ytbl[i]&127
    rem good_hit
    a[i]=0
    bad_hit
    750
    data xtbl
    81, 00, 114, 00, 130, 00, 114, 00, 82, 00, 50, 00, 34, 00, 50
    end
    data ytbl
    9, 00, 17, 00, 49, 00, 81, 00, 89, 00, 81, 00, 49, 00, 17
    end
    edit: goofed the datastaments up (now fixed I hope)
    should probably interleave the x and y values but
    this is just ment as illustration so I didn't bother to
    obfuscate
    edit somemore
    more goofs
  16. With 128 bytes of RAM on the 2600 you'd have a hard time to use it as a stack, compiler temporary storage, software parameter stack and your own program variables all at the same time. I suspect that for any non trivial program you'd spend most of your time looking at the assembly language produced by your "C" code to see what it was doing to the extent that you might as well have written it in assembler in the first place ;).
    I think I disagree.
    bB does all those things and would probably benefit from a data stack.
    I think the problem is the overhead involved in implementing one on a
    processor not built for it. And I think that's more a problem of speed
    than of space.
  17. I haven't looked at your game code yet.
    Just to be clear, I'm not saying it's impossible.
    I'm saying it's not possible the way you're trying to do
    it because the flicker is built in. There's no way to
    go fast enough if you have to wait on drawscreen.
    And you have to wait on drawscreen to get a box on a
    particular line drawn before you change the color for
    a different box on the same line. Also since you're
    identifying colors with objects you either have to have
    the objects the same colors, or wait on drawscreen and
    waiting will give you flicker.
    If you use a multicolor playfield you're restricted to
    11 colors and the colors are per line and since the
    objects move in opposite directions relative to the lines
    there's probably no practical way to make it work if you
    need to have more than one object per line.
    So with a limit of 11 colors, one per line and objects
    identified with colors, and one object per line so the
    colors/positions/objects don't interact in impossible to
    implement ways, you're limited to 11 objects each on a
    different line.
    That may be possible although it might not look as pretty
    as hoped. The problem is the pfcolors are normally taken
    from tables in rom so you either have to have all
    possibilities in rom (probably an impossibly large number)
    or coax the kernel to get the playfield color data from
    ram where you can manipulate it.
    That sounds like an intersting possibility/problem and I
    think I'll try and make it work.
    But as I said before I'm no expert, I don't know what more
    advanced options may be available and I have (almost) no idea
    what you can do with DPC+
    Don't give up. If you give up you'll never figure it out.
  18. However if you're only doing two colors per line, perhaps
    you could alternate colors every other drawscreen without
    the flicker being too bad. It might be tricky getting it
    fast enough. Since your pfpixels are fixed you might
    do a playfield statement, change the colors as fast as
    possible (and drawscreen) then do a different playfield
    statement etc.
    I tried it.
    It looks like crap, in stella at least.
     set kernel_options pfcolors
    LOOP
     pfcolors:
     $90
     $90
     $90
     $90
     $90
     $40
     $40
     $40
     $40
     $40
     $40
     $40
    end
    playfield:
    ...X............X........X.....
    end
    drawscreen
     pfcolors:
     $40
     $40
     $40
     $40
     $40
     $90
     $90
     $90
     $90
     $90
     $90
     $90
    end
    playfield:
    ....X............X........X....
    end
    drawscreen
    goto LOOP
  19. I'm no expert
    I'm not really sure what you're trying to do
    and it may not be possible to do it fast enough
    in bB. It may not be possible in ASM.
    But I'm guessing that its absolutely impossible
    the way you're doing it.
    I think drawscreen waits for the next time the
    screen needs to be drawn (60 times a second)
    and draws it. Since you clear the playfield then
    set one pixel and call drawscreen you're only going
    to get one (playfield) pixel each time the playfield
    is drawn and since you immediately do it again,
    it will only last a 1/60 second (except for the last
    pixel).
    You never say what exactly the problem is you are
    having with for-next loops. For-next loops have to be
    short. However you can jump out (goto) and come back
    (or you could gosub, takes longer).
    If that's a problem you're having and since you
    probably ought to replace those long strings of
    if statements with on..goto statements you could jump
    out and back without it costing much (since you'd be
    jumping any way).
    But there's nothing magic about for-next loops.
    It may even be possible to do a faster loop with an if
    statement (if you're careful how you structure it, but
    I'm not sure about that, and a for-next loop is probably
    faster generally).
    As I said I'm no expert, but I think the closest you can
    get to what (I think) you want in bB is one color per line.
    Setting pixels on the fly won't get you more colors with out
    the flicker so you should probably give up doing the individual
    pixels on the fly and just change the colors.
    statement etc.
    if you:
    dim temp = a
    then temp, a, and a[0] (and temp[0]) are all ways
    of refering to the same location.
    You randomize a (a[temp1] while temp1 = 0) in the
    for loop then set it to 0 (temp = 0)
    To speed things up you could use on..goto statements, compute
    instead of select (as in scaling rand), use look up tables
    where appropriate (which may not be faster in and of itself
    but could allow you to use faster code)
    I don't quite get your randomization of the colors
    this time.
    They're not equally spaced nor is the spacing a power
    of two, so this is not the same as yours.
    for temp = 0 to 15
    temp2 = rand / 4 / 8
    a[temp1] = color_tbl[temp2]
    next
    data color_tbl
    64, 128, 148, 46, 214, 100, 14, 0
    end
    It may be possible to speed things up by manipulating
    things directly from bB instead of calling the routines
    to do it but that would require digging into the kernel
    and figuring out what to manipulate.
    None of that code is tested but it compiles
  20. Memory is addressable
    dim one = a
    dim two = b
    dim three = c
    dim four = d
    dim five = e
    dim six = f
    dim seven = h
    dim eight = i
    dim nine = j
    dim ten = k
    dim eleven = l
    dim twelve = m
    dim thirteen = n
    dim fourteen = o
    dim fifteen = p
    dim sixteen = q
    rem random ranges 0-255
    rem scale rand to a range of 0-3
    rem by dividing by 64
    rem division by 2, 4 or 8
    rem is optimized to shifts
    rem the variables are in order in memory
    for temp = 0 to 15
    one[temp] = rand / 8 / 8 + 1
    next
    bit ops can't use variables for indexing
    I think you'll have to do something like this
    rem set a bit
    var = var | setbits[index]
    rem clear a bit
    var = var & clearbits[index]
    data setbits
    %00000001, %00000010, %00000100, %00001000
    %00010000, %00100000, %01000000, %10000000
    end
    data clearbits
    %11111110, %11111101, %11111011, %11110111
    %11101111, %11011111, %10111111, %01111111
    end
    That could be built into a subroutine or a macro
    And it should be possible to def a substitution
    for eg the callmacro statement so you could just
    invoke it like "setb var index" but I can seldom get
    that to work.
    Also the kernel already contains the setbits and
    clearbits data but I think where it is depends on
    the kernel options.
    edit goofed the random color (now fixed)
    I guess there's no easy way to build the bit ops
    into a macro
  21. Here's a more optimized one I developed:
    ;14 bytes, 24 cycles
    sta tempOne
    lsr
    adc #4
    lsr
    lsr
    lsr
    adc tempOne
    ror
    lsr
    lsr
    lsr
    Excellent! I 'd forgotten all about that.
    I'm curious, how you derived that.
    Did you have some sort of sytematic approach
    or was it just sort of by guess and by golly.
    (I never did figure out how to make /5 work
    past 179 using a similar adjustment)
    Ought compile a list of such routines somewhere.
    Maybe bump the divide by seven thread.
