bogax
902 -
Posts posted by bogax
WritePFChunk for current_row = 0 to 7 lo_pointer = current_row * 4 print_row = chunk_start + current_row for current_col = 0 to 31 current_bit = current_col & 7 current_byte = current_col / 8 + lo_pointer on maze_ref goto MazeData1 MazeData2 MazeData3 MazeData4 MazeData1 current_byte = Mazes1[current_byte] : goto Continue_WritePFChunk MazeData2 current_byte = Mazes2[current_byte] : goto Continue_WritePFChunk MazeData3 current_byte = Mazes3[current_byte] : goto Continue_WritePFChunk MazeData4 current_byte = Mazes4[current_byte] Continue_WritePFChunk if current_byte & setbits[current_bit] then pfpixel current_col print_row on next next
Edit: removed the final goto (it's redundant)
I see no reason to even be limited to a single data statement to draw a semi-random "maze-style" playfield. You could always look up data segments in multiple arrays for your maze pieces, in whatever way you see fit. All this routine does is draw whatever binary image is fed into it.How could you select amongst data statements with a parameter?
Only thing I can think of is a case statement. (or IF statements)
@bogax
Okay, I see the problem. The elements in your setbits array were just in reverse order. Changed it to this and it works fine now:
data setbits %10000000, %01000000, %00100000, %00010000, %00001000, %00000100, %00000010, %00000001 end
Heck! Darn! Other obscenities as required!
And since the binary array thread is talking about
screen stuff and not bit variables they're backwards
there too.
Ha! Based on that other thread, I'm fairly sure you know what you're doing.How sure are you now
Another thought.
Looks like you could pull the print_row
assignment out of the inner loop
for current_row = 0 to 7 lo_pointer = current_row * 4 print_row = chunk_start + current_row for current_col = 0 to 31 current_byte = current_col / 8 + lo_pointer current_bit = current_col & 7 if hellodata[current_byte] & setbits[current_bit] then pfpixel current_col print_row on next next
Okay, I think I see what you mean. If so, then yes you are right that it is the wrong number of iterations. I changed it to "for current_row 1 to 8." Thanks!
That might do it but then you need to intialize
lo_pointer
Your rows are going to be addressed as 0-7
Is there any chance you can help with converting this to a binary bitmap routine?I can try but you probably want someone who knows what they're doing ;P
I'd imagine it something like this:
dim current_row = a dim current_col = b dim current_byte = c dim current_bit = d dim print_row = e dim chunk_start = f chunk_start = 20 PROGRAMLOOP DF0FRACINC=128 DF1FRACINC=128 DF2FRACINC=128 DF3FRACINC=128 DF4FRACINC=255 DF6FRACINC=24 if joy0fire then z{0} = 1 if !joy0fire && z{0} then gosub WritePFChunk drawscreen goto PROGRAMLOOP WritePFChunk for current_row = 0 to 7 for current_col = 0 to 31 current_byte = current_col / 8 + lo_pointer[current_row] current_bit = current_col & 7 print_row = chunk_start + current_row if hellodata[current_byte] & setbits[current_bit] then pfpixel current_col print_row on next next z{0} = 0 return thisbank bank 3 bank 4 bank 5 bank 6 data lo_pointer 0, 4, 8, 12, 16, 20, 24, 28 end data hellodata %00000010,%01011101,%00010001,%11000000 %00000010,%01011101,%00010001,%01000000 %00000010,%01010001,%00010001,%01000000 %00000011,%11011101,%00010001,%01000000 %00000011,%11011101,%00010001,%01000000 %00000010,%01010001,%00010001,%01000000 %00000010,%01011101,%00010001,%01000000 %00000010,%01011101,%11011101,%11000000 end data setbits %10000000, %01000000, %00100000, %00010000, %00001000, %00000100, %00000010, %00000001 endI used a look up table for lo_pointer because it
only costs a couple bytes, doesn't use a variable
and is faster
edit: ack! wrong! it's significantly slower
(forgot that moves it into the inner loop)
so using a variable:
dim current_row = a dim current_col = b dim current_byte = c dim current_bit = d dim lo_pointer = e dim print_row = f dim chunk_start = g chunk_start = 20 PROGRAMLOOP DF0FRACINC=128 DF1FRACINC=128 DF2FRACINC=128 DF3FRACINC=128 DF4FRACINC=255 DF6FRACINC=24 if joy0fire then z{0} = 1 if !joy0fire && z{0} then gosub WritePFChunk drawscreen goto PROGRAMLOOP WritePFChunk for current_row = 0 to 7 lo_pointer = current_row * 4 for current_col = 0 to 31 current_byte = current_col / 8 + lo_pointer current_bit = current_col & 7 print_row = chunk_start + current_row if hellodata[current_byte] & setbits[current_bit] then pfpixel current_col print_row on next next z{0} = 0 return thisbank bank 3 bank 4 bank 5 bank 6 data hellodata %00000010,%01011101,%00010001,%11000000 %00000010,%01011101,%00010001,%01000000 %00000010,%01010001,%00010001,%01000000 %00000011,%11011101,%00010001,%01000000 %00000011,%11011101,%00010001,%01000000 %00000010,%01010001,%00010001,%01000000 %00000010,%01011101,%00010001,%01000000 %00000010,%01011101,%11011101,%11000000 end data setbits %10000000, %01000000, %00100000, %00010000, %00001000, %00000100, %00000010, %00000001 enddamn! more edits:
should be
even more editing: fixed the setbits (see below)
I phrased that poorly
Suppose you set lo_pointer = 15 (some arbitrary value)
then call WritePFChunk
then the first time you run the current_col
loop current_row = 0 and lo_pointer = 15
at the end of the first pass through the
current_row loop lo_pointer will get set to 0
ie 0 * 32 so your passes would go like this
current row = 0, lo_pointer = 15
current row = 1, lo_pointer = 0
current row = 2, lo_pointer = 32
current row = 3, lo_pointer = 64
current row = 4, lo_pointer = 96
current row = 5, lo_pointer = 128
current row = 6, lo_pointer = 160
current row = 7, lo_pointer = 192
current row = 8, lo_pointer = 224
9 iterations of the current row loop
the first one with what ever lo_pointer is
when you call WritePFChunk
possibly I misunderstand your intent.
On your first pass through the inner for loop
current_col will be 0 and lo_pointer will be whatever
you haven't set lo_pointer yet
At the end of the first pass through the loop
you'll set lo_pointer to current_col * 0
and lo_pointer will be 0 while current_col is 1
(second pass). etc
also you'll make 9 passes through the loop
(0-8 inclusive)
If you multiply by a power of two that's 8 or less
Bb will use shifts so * 8 * 4 compiles as shifts
* 32 calls the mutiplication routine
what i was hopeing to do was check for conditions of the other values by just repeating the code with the difrent value, it works fine on its own but when i try and stack the code it does not work anymore.
I could get the program to read diffrent values, but only when that was the only check in the code. Like if i wanted to do cpx #13.... cpx #14 it would not work.
I will look into the PORTA thanks!
Not sure I understand your intentions.
If what you mean is you want to do something
if the joy stick reads (for example) 14, 13 or 10
ie the same thing for a variety of values
you could do something like this
org $6000 ;Start of the code start lda #100 ;loads to address sta 1537 ;puts the value 1537 into address loop ldx 632 ;Read joystick STICK0 cpx #14 ;is it n? 14, s is 13, w is 11, nw is 10,sw is 9,e is 7,ne is 6,se is 5 beq dosomething cpx #13 beq dosomething cpx #10 bne loop ;if not - go and read it again dosomething lda 1537 ; reads 1537 - this memory is not used by the OS sta 710 ;color screen with it COLOR2 (color reg 2, playfield 2) cmp #0 ;compare value. is it zero? beq loop ;if it is, loop dec 1537 ;if not, decreases 1537 lda #$f ;resets joystick sta 632 ;read joystick STICK0 jmp loop ;starts over again run start ;begin program execute
Of course you could have it do different things
for different read values
Looks to me like that's going to zip through
the colors as long as you're reading one of your
chosen values. (but maybe I just don't understand
enough about how reading the joystick works)
Looks like a pass through the loop only takes
40 or 50 machine cycles at most.
You intialize 1537 to 100, but you don't reset it
to 100 when it gets to 0 so presumably it goes from
0 to 255
Is that supposed to be jmp start instead of jmp loop?
in the sequence:
lda 1537 sta 710 cmp #0 beq loop
the cmp#0 is redundant
Any instruction that could change a register sets the
N and Z flags (also the read-modify-write instructions
like inc, dec, lsr, ror, asl, rol, a memory location)
lda 1537 does cmp #0 implicitly and sta 710 doesn't change
the Z flag.
What the others said.
Presummably, the shadow register contains a debounced
value.
edit some more:
I suppose you all know this already.
It's better to avoid the stack altogether
cell = mapx / 8 cell = mapy * 4 + mapy + cell
saves 2 bytes and 7 cycles
This part doesn't compile, claiming there are duplicate labels. So, do I need to dimension a new "cell"? I tried changing it to cellx, but that causes more problems.
I can't explain that.
All I can say is it worked for me.
This was the result:
.L08 ; cell = mapx / 8 LDA mapx lsr lsr lsr STA cell .L09 ; cell = mapy * 4 + mapy + cell ; complex statement detected LDA mapy asl asl CLC ADC mapy CLC ADC cell STA cell . ;
A little late replying here... (heh heh)
(came across this while Googling something)
Just for completeness, here's what I was talking about
in Bb
temp1=rand/2 temp1=(temp1/4/4+temp1)/4+temp1
which produces
.L00 ; temp1 = rand / 2 jsr randomize lsr STA temp1 .L01 ; temp1 = ( temp1 / 4 / 4 + temp1 ) / 4 + temp1 ; complex statement detected LDA temp1 lsr lsr lsr lsr CLC ADC temp1 lsr lsr CLC ADC temp1 STA temp1
in asm
jsr randomize sta temp1 lsr lsr lsr lsr lsr adc temp1 lsr lsr adc temp1 lsr sta temp1
Well, not quite what I was talking about.
The Bb version mutiplies by .6328125
(1/2 + 1/8 + 1/128) and truncates the
partial products
The asm version multipies by .62890625
(1/2 + 1/8 + 1/256) and rounds the
partial products
In an ideal world, yes.
In a 6507 world, a multiplication (or a division) by a non-power-of-2 is horrendously costly in terms of time, and generally is avoided at all costs. Instead, 6507 coders use approximations, lookup tables, etc.
Hence all the gymnastics in this thread trying to find the ideal way to do it. (Though mostly the gymnastics are for fun. Any one of the posted methods would be good enough in most cases)
Things will be easiest if you can keep one dimension
in powers of 2
Then you can use simple shifts and bitwise logical ops
for composing the cell and bit addresses, there by
avoiding expensive multiplys/divides
Bb will use shifts for multiplying and dividing by
low powers of two, much faster than full blown
mutiplications and divisions (I think a low power
of 2 means 8, 4, or 2)
Near as I can tell, Bb wants a constant for bit ops
so to use a variable you'll have to do it yourself
If you have 256 bytes that's 2048 bits
So say you have 128 (x coordinate) x 16 (y coordinate)
x will be 16 (bytes) * 8 (bits)
You can get the bit address (ie the bit you want in
the selected cell) by simply masking for the
lower 3 bits of x
dim mapx = a dim mapy = b dim cell = c dim cellx = d rem x mod 8 cellx = mapx & 7 rem ORing instead of addition saves a clc so it's slightly rem faster and is possible since mapx / 8 is an integral rem power of 2 bytes per row (ie per y) rem mapy * 16 is done as mapy * 4 * 4 so that Bb will use rem shifts rather than invoking a mutilplication subroutine cell = mapy * 4 * 4 | mapx / 8 if map[cell] & setbits[cellx] then score = 1 else score = 0 rem use an adressable set of masks so you can point rem to them with a variable data setbits %10000000, %01000000, %00100000, %00010000 %00001000, %00000100, %00000010, %00000001 end data clearbits %01111111, %10111111, %11011111, %11101111 %11110111, %11111011, %11111101, %11111110 end data map %11111101, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 %10000001, %00000011, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000111, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00011000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000001, %00000010, %00000011, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00011100, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111, %11111111 end
If you want your map to be something closer to square, say, 40 x 51
You could use a look up table for the mutiplication or hard code it
ie write a dedicated mutiply routine (or just use the built in
multiplication routine which would be slower).
I think I'd go with a look up table (if there's room), it'd only cost
an extra 40 bytes or so and be a lot faster.
Here's hard coded for 40 ie rows of 5 bytes of 8 bits
Each row is 5 bytes so you need to mutiply y by 5
(still uses the same map data, but I'm sure it doesn't make
sense here)
dim mapx = a dim mapy = b dim cell = c dim cellx = d rem x mod 8 cellx = mapx & 7 rem have to use addition this time rem 5 = 1 + 4 cell = mapy + mapy * 4 + mapx / 8 if map[cell] & setbits[cellx] then score = 1 else score = 0 rem use an adressable set of masks so you can point rem to them with a variable data setbits %10000000, %01000000, %00100000, %00010000 %00001000, %00000100, %00000010, %00000001 end data clearbits %01111111, %10111111, %11011111, %11101111 %11110111, %11111011, %11111101, %11111110 end data map %11111101, %11111111, %11111111, %11111111, %11111111 %11111111, %11111111, %11111111, %11111111, %11111111 %11111111, %11111111, %11111111, %11111111, %11111111 %11111111, %10000001, %00000011, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000001, %10000000, %00000000, %00000111 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000001, %10000000, %00000000 %00000000, %00011000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000001, %10000000 %00000000, %00000000, %00000001, %00000010, %00000011 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000 %00011100, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000001, %10000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000001, %10000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000001, %10000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000001, %10000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000001 %10000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000001, %10000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000001, %10000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000001, %10000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000001, %10000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000000 %00000000, %00000000, %00000000, %00000000, %00000001 %11111111, %11111111, %11111111, %11111111, %11111111 %11111111, %11111111, %11111111, %11111111, %11111111 %11111111, %11111111, %11111111, %11111111, %11111111 end
edit: actually
cell = mapy * 4 + mapy + mapx / 8
is faster because Bb doesn't stash mapy
on the stack while it computes mapy * 4
edit some more:
yet more edit: fixed setbits and clearbits
which were good for bit variables but not screen
stuff
I think my own routine can still be more optimized.
You could probably get by with fewer partial products in the reciprocal
multiplication.
When you have rand/2 like so:
a=rand/2
a=(a/2 + a)/4/4/2+1
you get:
6 => 0
5 => 0
4 => 0
3 => 86
2 => 84
1 => 85
That's odd
Are you sure you didn't divide by 64?
ie /4/4/4 instead of /4/4/2 ?
I reckon it thusly
suppose rand returns 255
then:
rand/2 = 127 a/2 = 63 + a = 190 /4 = 47 /4 = 11 /2 = 5 +1 = 6
a=rand/2 a=(a/2 + a)/4/4/2+1
produces
.L00 ; a = rand / 2 jsr randomize lsr STA a .L01 ; a = ( a / 2 + a ) / 4 / 4 / 2 + 1 ; complex statement detected LDA a lsr CLC ADC a lsr lsr lsr lsr lsr CLC ADC #1 STA a . ;
or in assembly
a=rand asm lda a lsr adc a and #$C0 rol rol rol adc #$01 sta a end
What I did different is that the subroutine/function's part that copies parameter values from main code into the library's parameter working area was a subroutine itself, so every library function started with a JSR to get the parameters.
Compared to explicitly loading values and pushing them on the stack and pulling them off, this method results in less memory/less redundant code (especially when there are a lot of routines doing this.) But this method means everything in the library has the overhead of copying the parameters and recalculating the correct address for the RTS.
Having thought about it only slightly, maybe the code
could be simpler and perhaps shorter if the target
of the JSR is one of the parameters.
And if you resolve to never let the JSR and paramters
straddle a page boundary you could simplify things
by not having to calculate the return address
It would cost another couple of zero page bytes for
the subroutine target.
; parameter_pointer is a zero page location ; initialized to zero pla tay pla sta parameter_pointer+1 ; high byte of the return address doesn't ; change so just put it back pha iny lda parameter_pointer,y sta target iny lda parameter_pointer,y sta target+1 iny lda parameter_pointer,y sta parameter1 iny lda parameter_pointer,y sta parameter2 ; etc ; assuming no page crossings so just ; push the low byte of the return address ; back on the stack tya pha jmp (target)
Won't the XOR pass give you $FF in the destination for source=0? So you'd basically get $FF for the entire range, including the 0? I have a headache mind you, so I'm probably wrong.
oops yes I think you are correct.
I thought it was writing a 0 if the source is 0.
On a closer reading it looks like it doesn't write at all if the source is 0
But it looks like it can be done in one pass.
By making the source the destination and using a collision detection mask of FF
and an XOR and AND mask of FF and either arithmetic sum mode
or OR mode
the description of OR mode, mode 3:
"The written out data dest’ is a result of a bitwise OR of source” and dest.
source = ReadSource();
source' = source & blt_and_mask;
source'' = source' ^ blt_xor_mask;
if (source'' != 0)
dest = ReadDest();
if (dest & blt_collision_mask) BLT_COLLISION_CODE = dest;
dest' = dest | source'';
WriteDest(dest');"
So eg in OR mode if the source is 0 it will stay 0
If the source is not 0 then it will get ANDed with the AND mask ie FF (source')
That will be XORed with the XOR mask ie FF producing the compliment (source")
And that will be ORed with the source producing FF (dest')
Then written to the destination ie written back if the destination is the same
as the source.
Not sure I understand the problem (or the blitter) so maybe this
will be whacked.
The problem is to write 0 if the source byte is 0 and write FF if the
source byte is non 0.
The source just happens to be restricted to powers of 2. (including
0)
So do an XOR pass with FF filled destination. to get either 0
or the compliment of the source.
Then do an OR pass between the source and the (now compliment
destination) to get either 0 or the source OR the compliment (ie FF)
Am I missing something?
if a/2 ^ a & 1 then goto __pause_game __pause_game
.L00 ; if a / 2 ^ a & 1 then goto __pause_game ; complex condition detected ; complex statement detected LDA a lsr EOR a AND #1 BEQ .skipL00 .condpart0 jmp .__pause_game .skipL00 . ; .__pause_game ; __pause_game
Not sure I remember the conventions rightly, but assuming bit 0 is the
least significant bit ...
If you add a 1 to a bit you can, in effect, propagate it to a more significant
position via carry
If you add two bits together the sum is the XORing of the two
You can do both at once in this case by adding 1 to a
Then use & to isolate bit 1 to test it (ie a bitwise AND with 2)
if (a + 1)& 2 then goto __pause_game __pause_game
produces
.L00 ; if ( a + 1 ) & 2 then goto __pause_game ; complex statement detected LDA a CLC ADC #1 AND #2 BEQ .skipL00 .condpart0 jmp .__pause_game .skipL00 . ; .__pause_game ; __pause_game
That ought to be something like what you want
Even after seeing where you guys were hiding the rabbit, it still looks like magic. Very weird, but cool. Thanks.
Not sure how to answer that.
My gut reaction is to say there's no magic to it.
But it is sort of magical or wonderous or at least fascintaing,
maybe that's the key to interest.
What it is is pretty mundane 7th grade algebra.
you wouldn't have any trouble learning it.
Boolean algebra has similar rules/properties
I don't know what you mean. For example, if it was temp6 = ((player0y-3)/4)-1 instead, you couldn't do what jwierer did. He lucked out because the number I was subtracting turned out to be 4, but at one time, the number was something else.
temp6 = (player0y-7)/4
I'm trying to figure out how to do the following with fewer steps:
temp5 = 255 : if B_Direction_x{5} then temp5 = 1 ballx = ballx + temp5This works (ie bB doesn't choke on it and it assembles)
dim ballx_dir = a dim ballx_pos = b macro incv asm inc {1} end end macro decv asm dec {1} end end if ballx_dir & 32 then callmacro incv ballx_pos else callmacro decv ballx_posused my own names, sorry if that's confusing
I'm putting adapted versions of these sessions on my web site. Does the information in the first post need to be updated with anything that has been posted in this thread? I know almost nothing about assembly language, so I can't tell.
Thanks.
There's a typo
ldx #0 txa Clear dex txs pha bne Clear...
since the tsx and pha don't affect the flags,
I believe that should be
'since the txs and pha don't affect the flags,'
how many paramters?
in batari Basic
How many parameters can be passed to a Macro?
