bogax
    902
Posts posted by bogax
  1.
    Did the last post I made make it any clearer?
    yes
    you want to scroll one part of the sprite while the other stays (more or less) constant
    the obvious thing is to use two sprites if you can
    you could flicker the a single sprite ie multiplex the sprite in bB, display the two parts seperately on alternate frames
    you could put the sprite in ram
    not sure you could find 40 bytes
    you wouldn't have room for much else
    I can't think of any other way to do it with the standard kernel
  2. there's some stuff with tables here
    the last one (that notes that it's not very accurate) could be made accurate without too much trouble
    I should have done an accurate one and one not so accurate for comparison, but I was in a hurry
    I doubt the difference would be obvious
    edit: there's also this thread
    I know I've seen 6502 CORDIC code but I can't remember where
  3. I don't know about VBB but bB its self doesn't have any trouble with
    if x = 1 then if b = 4 then score = score + 1
    however
    if x = 1 && b = 4 then score = score + 1
    produces exactly the same code
    for a random number between 16..124
    you need a random number 0..108 + 16
    108 = 12 * 9
    rand produces numbers 0..255
    and you are limited to numbers 0..255 in a byte
    and you'd like to keep as many bits as possible for accuracy
    9 is 8 + 1
    12 is 1.5 * 8
    temp1 = rand & 127 will give you (approximately) 1 * 128
    then
    temp1 = temp1/2 + temp1 will give you (approximately) 0..192 = 1.5 * 128 = 12 * 16
    16 = 2 * 8 so now
    temp1 = (temp1/8 + temp1) = ((12 * 16 / + 12 * 16) = 12 * (16 / 8 + 16) = 12 * (1 + * 2 = 12 * 9 * 2 = 108 * 2
    so
    temp1 = rand & 127 : temp1 = temp1/2 + temp1 : temp1 = (temp1/8 + temp1)/2 + 17
    due to starting with 127 instead of 128 (max) and rounding, the numbers will be 17..123
    due to the limited accuracy the distribution may not be as nice as you'd like
    if you realy want 16..124 then its 127 * 109/127
    which would be something like this
    temp1 = rand/2 : temp1 = ((((temp1/4 + temp1)/2 + temp1)/4 + temp1)/2 + temp1)/2 + 16
    in this case rand/2 gives you essentially the same as rand & 127
    you've got redundant if statements eg
    if pfscore1 = 0 then AUDV0 = 0
    if pfscore1 = 0 then AUDV1 = 0
    could be done this way
    if pfscore1 = 0 then AUDV0 = 0 : AUDV1 = 0
    and doing assignments to the same value consecutively on the same line saves you something
    it loads 0 into the accumulator and then stores it to AUDV0, if it's done consecutively on the same line
    bB won't load 0 again for the store to AUDV1 since 0 is already in the accumulator. it'll just store to AUDV1
    it could also be written like this
    if !pfscore1 then AUDV0 = 0 : AUDV1 = 0
    which also saves you something. because of the way bB and the processor work it doesn't do an explicit compare to zero
    you still didn't show your paddle code
    I suspect the scoring is not working the way you'd like
  4. at first glance
    line 973
    temp5 = (_PEEK_Frame_Counter) + 1 : _POKE_Frame_Counter temp5 : on temp5 goto donef1 donef1 f1 f22 f33 f44
    unless you're limiting frame counter to 4 somewhere I didn't see yet,
    temp5 could go up to 16 and you've only got 6 target labels
  5. the sine table is built on the (possibly) spurious theory
    that it's good to start with the best accuracy and then
    throw away what you don't need
    so the sines are 0..255 and which would give you
    sines -255..255
    the sine function immediately throws some of that away and
    returns sines that range 0..255
    those values are scaled to fit by multiplying by the
    reciprocal of the scale factor
    that's what the scl function does
    if you just want a different radius that can be baked into
    the sine table
    dim angle = a.c
    dim tangle = temp1
    angle = 0
    gosub su
    loop
    temp1 = angle/4
    player0x = sinetbl[temp1] + 42
    temp1 = (angle - 64)/4
    player0y = sinetbl[temp1] + 7
    angle = angle + 0.5
    COLUP0 = $3A
    COLUP1 = $14
    drawscreen
    goto loop
    data sinetbl
    38, 42, 45, 49, 53, 56, 59, 62
    65, 67, 70, 72, 73, 74, 75, 76
    76, 76, 75, 74, 73, 72, 70, 67
    65, 62, 59, 56, 53, 49, 45, 42
    38, 34, 31, 27, 23, 20, 17, 14
    11, 9, 6, 4, 3, 2, 1, 0
    0, 0, 1, 2, 3, 4, 6, 9
    11, 14, 17, 20, 23, 27, 31, 34
    end
    su
    player0:
    %00000000
    %00000000
    %00011000
    %00111100
    %00111100
    %00011000
    %00000000
    %00000000
    end
    player1:
    %00111100
    %01111110
    %11111111
    %11111111
    %11111111
    %11111111
    %01111110
    %00111100
    end
    COLUPF = $48
    player1x = 80
    player1y = 48
    return
    if you want to vary the radius on the fly probably the easiest way is to
    scale the sines to suit
    here the sines are scaled using an approximate reciprocal calulated from
    the radius
    you can vary the radius from 4..40 using joy0 up-down
    none of it is very accurate
    the sine table is not very accurate
    the scl function is not very accurate
    and the reciprocal approximation is not very accurate
    dim angle = a.c
    dim tangle = temp1
    angle = 0
    gosub su
    dim num = temp1
    dim mul = temp2
    r = 20
    loop
    f = (SWCHA ^ $FF) & f
    if f{4} then r = r + 1 : if r > 40 then r = 4
    if f{5} then r = r - 1 : if r < 4 then r = 40
    f = SWCHA
    temp1 = angle/4
    temp1 = sinetbl[temp1]
    temp2 = r * 2
    temp1 = scl(temp1,temp2)
    player0x = temp1 + 80 - r
    temp2 = r * 2
    player0y = temp1 + 48 - r
    angle = angle + 0.5
    COLUP0 = $3A
    COLUP1 = $14
    drawscreen
    goto loop
    ; multiply by .328125 so scales 255 -> 83
    function scl
    asm
    lda #$00
    sec
    ror mul
    loop
    bcc shift
    adc num
    shift
    ror
    enter
    lsr mul
    bne loop
    rts
    end
    data sinetbl
    127, 139, 151, 163, 175, 186, 197, 207
    216, 225, 232, 239, 244, 248, 251, 253
    253, 253, 251, 248, 244, 239, 232, 225
    216, 207, 197, 186, 175, 163, 151, 139
    126, 114, 102, 90, 78, 67, 56, 46
    37, 28, 21, 14, 9, 5, 2, 0
    0, 0, 2, 5, 9, 14, 21, 28
    37, 46, 56, 67, 78, 90, 102, 114
    end
    su
    player0:
    %00000000
    %00000000
    %00011000
    %00111100
    %00111100
    %00011000
    %00000000
    %00000000
    end
    player1:
    %00111100
    %01111110
    %11111111
    %11111111
    %11111111
    %11111111
    %01111110
    %00111100
    end
    COLUPF = $48
    player1x = 80
    player1y = 48
    return
    circle64_baked.bas
    circle64_baked.bin
    circle64_scaled.bas
    circle64_scaled.bin
  6. I forgot to mention that in the case of the line segment circle
    the table is matched to the number of steps in the circle so if you change the number of steps
    the circle changes
    it will get larger or smaller and if things don't add up just right it will probably wobble
  7. here's one that uses a sine table
    dim angle = a.c
    dim tangle = temp1
    angle = 0
    gosub su
    loop
    temp3 = sine(angle)
    temp3 = scl(temp3)
    player0x = temp3 + 37
    temp3 = angle - 64
    temp3 = sine(temp3)
    temp3 = scl(temp3)
    player0y = temp3 + 7
    angle = angle + 1.0
    COLUP0 = $3A
    COLUP1 = $14
    drawscreen
    goto loop
    function scl
    asm
    lda temp1
    lsr
    lsr
    adc temp1
    ror
    lsr
    adc temp1
    ror
    lsr
    rts
    end
    function sine
    temp2 = tangle
    if tangle{6} then temp2 = temp2 ^ %00111111 ; if its an odd quadrant complement the angle in 64 (64 is one quadrant)
    temp2 = (temp2 & %00111111) ; scale to index table 0..63 /2 for 32 elements /4 for 16 elements
    temp2 = sinetbl[temp2]/2
    if tangle{7} then temp2 = 255 - temp2 ; if the angle is greater than 128 then complement the sine in 128
    temp2 = temp2 + 128 ; add an offset so the sine is 0..255 no negatives
    return
    ; data sinetbl
    ; 0, 50, 74, 98, 121, 142, 162, 181
    ; 198, 213, 226, 237, 245, 251, 255, 255
    ;end
    ; data sinetbl
    ; 0, 25, 37, 50, 62, 74, 86, 98
    ; 109, 120, 131, 142, 152, 162, 171, 180
    ; 189, 197, 205, 212, 219, 225, 231, 236
    ; 240, 244, 247, 250, 252, 254, 255, 255
    ;end
    data sinetbl
    0, 13, 19, 25, 31, 38, 44, 50
    56, 62, 68, 74, 80, 86, 92, 98
    104, 109, 115, 121, 126, 132, 137, 142
    147, 152, 157, 162, 167, 172, 177, 181
    185, 190, 194, 198, 202, 206, 209, 213
    216, 220, 223, 226, 229, 231, 234, 237
    238, 241, 243, 245, 247, 248, 250, 251
    252, 253, 254, 255, 255, 255, 255, 255
    end
    su
    player0:
    %00000000
    %00000000
    %00011000
    %00111100
    %00111100
    %00011000
    %00000000
    %00000000
    end
    player1:
    %00111100
    %01111110
    %11111111
    %11111111
    %11111111
    %11111111
    %01111110
    %00111100
    end
    COLUPF = $48
    player1x = 80
    player1y = 48
    return
    here's one that uses a smaller sine table to form a circle from a set of line segments
    dim angle = a.c
    dim tangle = temp1
    angle = 0
    gosub su
    loop
    temp3 = sine(angle)
    x = x + temp3
    player0x = scl(x)
    player0x = player0x + 39
    temp3 = angle + 64
    temp3 = sine(temp3)
    y = y + temp3
    player0y = scl(y)
    player0y = player0y + 6
    angle = angle + 1.0
    COLUP0 = $3A
    COLUP1 = $14
    drawscreen
    goto loop
    function scl
    asm
    lda temp1
    lsr
    lsr
    adc temp1
    ror
    lsr
    adc temp1
    ror
    lsr
    rts
    end
    function sine
    temp2 = tangle & %00111111
    if tangle{6} then temp2 = 64 - temp2 ; if its an odd quadrant complement the angle in 64 (64 is one quadrant)
    temp2 = (temp2 & %00111111)/8 ; scale to index table 0..63 -> 0..7
    if tangle{7} then temp2 = 0 - temp2 ; if the angle is greater than 128 then negate
    temp2 = temp2
    return
    data sinetbl
    0, 1, 1, 2, 2, 3, 3, 3
    end
    su
    player0:
    %00000000
    %00000000
    %00011000
    %00111100
    %00111100
    %00011000
    %00000000
    %00000000
    end
    player1:
    %00111100
    %01111110
    %11111111
    %11111111
    %11111111
    %11111111
    %01111110
    %00111100
    end
    COLUPF = $48
    x = 0 : y = 128 : angle = 0
    player1x = 80
    player1y = 48
    return
    here's one that uses a parabolic aproximation of sines-cosines
    if you look closely you'll see it's actually sort of elliptical
    dim dx = v
    dim dy = w
    gosub su
    loop
    c = c + 1
    if c & 7 then skip
    if x{7} then dx = dx - 1 else dx = dx + 1
    x = x + dx
    player0x = scl(x)
    player0x = player0x + 34
    if y{7} then dy = dy - 1 else dy = dy + 1
    y = y + dy
    player0y = scl(y)
    player0y = player0y + 2
    skip
    COLUP0 = $3A
    COLUP1 = $14
    drawscreen
    goto loop
    ; multiply by .34375 so scales 247 -> 84
    function scl
    asm
    lda temp1
    lsr
    adc temp1
    ror
    lsr
    adc temp1
    ror
    lsr
    rts
    end
    su
    player0:
    %00000000
    %00000000
    %00011000
    %00111100
    %00111100
    %00011000
    %00000000
    %00000000
    end
    player1:
    %00111100
    %01111110
    %11111111
    %11111111
    %11111111
    %11111111
    %01111110
    %00111100
    end
    COLUPF = $48
    dx = $0E : x = $7F
    dy = $00 : y = $F7
    player1x = 80
    player1y = 46
    return
    circle.bas
    circle.bas.bin
    circle2.bas
    circle2.bas.bin
    circle3.bas
    circle3.bas.bin
  8. indexes are limited to 8 bits so it's definetely best to limit your tables to 256 bytes
    when possible
    to that end I wrote a bit of javascript that transposes data so that each column goes into
    it's own table
    for those instances where you need two levels of indirection and still need to compute an index into a
    table of tables so to speak I wouldn't use if statements
    it's probably smaller and faster to use a lookup table
    if you can't fit your table of tables in to 256 bytes you can still do it with microscopic amounts
    of asm
    using RevEng's example
    if roomIndex=0 then roomNumber=room0Data[level]
    if roomIndex=1 then roomNumber=room1Data[level]
    if roomIndex=2 then roomNumber=room2Data[level]
    I'd do it like this (there may be pathological cases where it would be better to use if statments though)
    index = roomOffset[roomIndex] ; room_offset is an LUT for number of rooms x number of levels, zero based
    roomNumber = roomData[level]
    ; so if your room index ranges to 0..14 and there are 10 levels your roomOffset table is
    data roomOffset
    0, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130, 140
    end
    ; and your roomData table will be 150 bytes
    if the table is more than 256 bytes it'd be something like this
    dim indexLo = temp3
    dim indexHi = temp4
    def load_indirect = callmcro ldin
    ; looks up a byte from a 16 bit address, lo byte in temp3 hi byte in temp4
    ; indexed by the value in the variable specified by the first parameter
    ; and puts it in to the second parameter variable
    macro ldin
    asm
    ldy {1}
    lda (temp3),y
    sta {2}
    end
    end
    indexLo = roomOffsetLo[roomIndex] ; roomOffsetLo is a table of the lo bytes of the offset
    indexHi = roomOffsetHi[roomIndex] ; roomOffsetHi is a table of the hi bytes of the offset
    load_indirect level roomNumber
    ; "<" signifies the lo byte ">" is the hi byte
    ; these values/expressions are asm not bB
    data roomOffsetLo
    <(roomData + 0), <(roomData + 10), <(roomData + 20), <(roomData + 30), <(roomData + 40), <(roomData + 50), <(roomData + 60), <(roomData + 70)
    <(roomData + 80), <(roomData + 90), <(roomData + 100), <(roomData + 110), <(roomData + 120), <(roomData + 130), <(roomData + 140)
    end
    data roomOffsetHi
    >(roomData + 0), >(roomData + 10), >(roomData + 20), >(roomData + 30), >(roomData + 40), >(roomData + 50), >(roomData + 60), >(roomData + 70)
    >(roomData + 80), >(roomData + 90), >(roomData + 100), >(roomData + 110), >(roomData + 120), >(roomData + 130), >(roomData + 140)
    end
    you break even somwhere around three or four if statements
    it would also be possible to calculate the offsets at run time
    and if your offsets are a power of 2 that could be fairly fast
    (eg in this case, if the number of levels were a power of 2)
    you could also do something in between like group them into
    tables <= 256 bytes and use if statements to choose a table
  9. Hello everyone,
    I'm trying to finalize a game with the DPC+ kernel. It's got a procedurally generated playfield (among other things), which means I need to call drawscreen a lot to prevent the screen from rolling. To minimize code space, I set up a gosub that looks like this:
    screenrefresh
     DF6FRACINC = 32
     DF4FRACINC = 32
     DF0FRACINC = 16
     DF1FRACINC = 16
     DF2FRACINC = 16
     DF3FRACINC = 16
     drawscreen
     return
    This code works perfectly as a gosub in Stella. But when I put it on my Harmony cart, the game crashes once its reaches it. I'm baffled by the difference. I really, really need this code to work as I'm down to < 100 bytes in each of my banks (many are < 30), and according to my tests, each new drawscreen call takes up 24 bytes. I know I could instead do this with a labyrinthine system of gotos, but that won't be as efficient as I need it to be, either.
    I'd really appreciate any advice. Thanks.
    I don't know if this would work given the problem you're having
    but you don't need a labyrinthine system of gotos
    you'd put a single instance of the screenrefresh routine in some bank and return otherbank
    then in each bank you'd put a single goto screenrefresh bankx
    then when you want to refresh you'd gosub to the goto
    edit
    I don't know how it works with DPC+
    if you're just bank switching and if you're in
    the appropriate bank you can use
    asm
    jsr drawscreen
    end
    and save the bank switch for the drawscreen
    at least that works in stella
  10. Again I'm no expert but I think that's not going to work with DPC+
    Thats for a different sort of RAM expansion
    I think what you want is here
    I think iesposta is correct
    I think it should be possible to poke the player colors
    edit OK maybe not
    at least I haven't been able to get it to work
    (I thought maybe you could point the player color pointers at the stack)
  11. Aha! Now, this is something that I'm pretty sure I understand. I've been wondering how to use tables and it appears that it is easier than I thought... kind of like a 1d (read only?) array... that can be used with multiple objects.
    Thanks!!! Now, I just need to put it to use. :D
    Yes but it's read only only because it's in ROM
    the variables are in sequence in memory so
    a[0] = 3
    a[1] = 4
    sets a to 3 and b to 4
  12. Here is something similar in bB with the tables
    the tables have redundancies and symmetries that could be exploited to make them
    smaller but it would be slower
    I should have mentioned that this assumes that directions is limited to 0..31
    dim tmp88 = temp4.temp3
    if !joy0up then skip
    temp3 = Vx_lo[direction] : temp4 = Vx_hi[direction] : xVel = xVel + tmp88
    temp3 = Vy_lo[direction] : temp4 = Vy_hi[direction] : yVel = yVel + tmp88
    skip
    data Vx_lo
    8, 7, 6, 5, 4, 3, 2, 1
    248, 255, 254, 253, 252, 251, 250, 249
    248, 249, 250, 251, 252, 253, 254, 255
    8, 1, 2, 3, 4, 5, 6, 7
    end
    data Vx_hi
    0, 0, 0, 0, 0, 0, 0, 0
    255, 255, 255, 255, 255, 255, 255, 255
    end
    data Vy_lo
    0, 255, 254, 253, 252, 251, 250, 249
    0, 249, 250, 251, 252, 253, 254, 255
    0, 1, 2, 3, 4, 5, 6, 7
    0, 7, 6, 5, 4, 3, 2, 1
    end
    data Vy_hi
    0, 255, 255, 255, 255, 255, 255, 255
    end
    I may have gotten the tables right ;)
    edit: oops nope
    (fixed now)
    (I hope ;) )
  13. first you consolidate the redundant predicates
    then use a lookup table
    here's a macro to lookup 8.8 values
    you'll have to figure out the table(s) yourself
    untested but it should give you the idea
    ; lookup an 8.8 constant from a table
    ; the table is in two data statements one for hi bytes and one for lo bytes
    ; takes three parameters
    ; a variable to take the looked up value it must be in consecutive locations
    ; eg variable a for the lo byte and b for the hi byte b.a or temp4.temp3 etc
    ; an 8 bit index
    ; the name of the table if the name supplied is "table" then the data statements
    ; must be named tablelo, tablehi
    macro lu88
    asm
    ldx {2}
    lda {3}lo,x
    sta {1}-1
    lda {3}hi,x
    sta {1}
    end
    end
    if joy0up then callmacro lu88 tmp88 direction Vx_table : xVel = xVel + tmp88 : callmacro lu88 tmp88 direction Vy_table : yVel = yVel + tmp88
  14. Wow, that's way over my head. It's good information to have for later when I understand this stuff more. Thanks!
    Is there a simple example of a routine that passed a pointer from a variable? I have looked around on the interwebz, but I don't really get the pointer stuff yet.
    a pointer is a location in memory that contains the location (memory address) of something else
    I suppose by that definition a pointer could be a constant but they're always variables
    technically I misspoke I should have said that it passes a reference since I was talking about the value the pointer would contain
    (which in this case would be the address of the playercolor table)
  15. I'm not all that familiar with the DPC+ kernel
    It looks to me like it just passes a pointer to the color table to the ARM code.
    so short of modifying the kernel
    you could have a routine that passed a pointer from a variable, but the colors themselves would
    have to be in a ROM table and they'd have to be in the graphics bank and I think the only
    way to get them there is with a player color statement
    it might be possible to have all the colors in one big playercolor statement though
  16. functions are pretty much useless (or worse) in bB
    about the only thing you can do is assign it to a variable
    use a subroutine
    you don't need (or want) an end statement, just return
    whatever is in the accumulator is what the functiion returns
    a function always passes two values and puts them in temp1 and temp2
    whether you supply parameters or not
    function dummy
    b = 3
    return
    c = dummy()
    c contains 3
    function void
    return
    l = 5
    d = void()
    temp1 and d contain 5
  17. On a sidenote, I can't figure out how to limit the firebutton properly so the players can't hold them down?
    Assuming you mean you want something to happen once when the fire button is pressed and not
    happen again until the fire but is (released and) pressed again
    check the state of the fire button and if it wasn't pressed last time and is pressed this time
    do whatever
    save the current state for the next check
    something like
    if joy0fire && previous_state = 0 then do_something = 1
    previous_state = 0
    if joy0fire then previous_state = 1
    if do_something then go_do_it
    ; or
    temp1  = previous_state
    previous_state = 0
    if temp1 = 0 && previous_state = 1 then go_do_something
  18. I don't quite follow you so maybe I'm missing something
    why don't you just do something like
    schnooga=0
    for temp1=0 to 17
    if shnooga = 2 then skip_schnooga
    if ooga-2=booga[temp1] then schnooga=1
    if ooga-1=booga[temp1] then schnooga=2
    skip_schnooga
    next
    you can do somthing like modulo for powers of 2 in binary using AND (ie "&" in bB)
    15 mod 8 is
    15 & 7
    7 being 8 - 1
    in binary %00001000 (8 ) and %00000111 (7)
    bB does a bitwise AND
    bits in the result are the ANDing of corresponding bits in the operands
    AND is
    0 AND 0 = 0
    0 AND 1 = 0
    1 AND 0 = 0
    1 AND 1 = 1
    %00001111 (15)
    & %00000111 (7)
    = %00000111 (7)
    %00001110 (14)
    & %00001101 (13)
    = %00001100 (12)
    the player 1..9 variables are in order in memory
    so you should be able to eg address player3x as player1x[2]
    but I haven't tryed it
  19.
    I wrote a short routine to test it and apparently rand16 never returns 0
     dim rand16 = aux1
     scorecolor = $1E
     COLUPF = $76
     for i = 0 to 255
     for j = 0 to 255
     if rand = 0 then score = score + 1
     if !(j & $3F) then drawscreen
     next
     score = score + 1000
     next
     scorecolor = $3A
    loop
      drawscreen
      goto loop
    Heck! Darn! (other obscenities as required)
    After actually thinking about it for two seconds it occured to me that, since rand16 goes through every number 1..65535,
    0 must come up(since there are certainly combinations of bytes that will produce a 0 when XORed).
    use rand in an if statement and it just tests the rand variable, it doesn't actually call the rand routine
     dim rand16 = aux1
     scorecolor = $1E
     COLUPF = $76
     for i = 0 to 255
     for j = 0 to 255
     temp1 = rand
     if temp1 = 0 then score = score + 1
     if !(j & $1F) then drawscreen
     next
     next
     scorecolor = $3A
    loop
      drawscreen
      goto loop
