Wolfram
Banned
    369
Posts posted by Wolfram
  1. and to answer your question... yes... you can trigger DLIs via the Display list...so your 8 pixel example only is right when using DLI and 8 line generating display list command... so...when using DLI feature in f.e. charmode then yes...in general only triggered at the beginning... but you can walk "down" by doing STA WSYNCs f.e.
    or
    you can use POKEY IRQs to have interrupts on a special scanline or even on a special point on screen...
    many ways to go...
    not so flexible then in case of charmode. walking down will waste cpu time.
    so, charmode instruction will "generate" 8 lines. bitmap mode instructions will make only 1 line? or you can either ask for 8 lines or 1 lines of any mode?
    if not then how is this possible:
    QUOTE (Rybags @ Wed Apr 22, 2009 2:47 AM) *
    8 pixel boundaries are irrelevant. Atari can have 3 bitmap lines, a character line, 2 bitmap lines, a character line.
  2. Paddles are another thing though, as only the buttons go through $dc00/dc01, the adc-part is done by SID. And lightpens affect VIC registers, even though they use the control ports as joysticks and paddles do. There's some weird wiring under the hood, really :)
    indeed :) there's a trick to read the state of the space key by only reading VICII registers ;)
  3. Again, who said anything about a bounding box the size of a pixel? You're really shameless, aren't you. :|
    you're just wasting your time with him, he will never give not even a nanomater away from his views. sometimes even the a8 fans turn him down for stuff like he's trying to prove a8 sprites are better than c64's ;)
  4. At the risk of causing any more bickering, here's a nice little demo showing all 256 colors used in motion (albeit fairly lo-res). Apologies if this has been posted - I am a sicko who has read nearly every post of this thread, but my memory isn't that good!
    Stephen Anderson
    That's a nice demo as it definitely shows something that the c64 will never be able to do.
    Along with everything else I pointed out in this thread which recently joined C64 fanatics have not read as can be told by their repeating the same mistakes.
    on both machines it takes 1 minute to show something the other machine will be not able to do, and neither example will prove much about the overall capabilities.
  5. 8 pixel boundaries are irrelevant. Atari can have 3 bitmap lines, a character line, 2 bitmap lines, a character line.
    0 CPU cost.
    And if you want to split hairs, with some CPU expenditure you can do shortened text modes, or vertically expansion on bitmap pixels.
    I think you can do 2X and 4X zoom horizontally on 160*200 without CPU expenditure by just changing DLs. Of course vertically you can zoom any amount 1X, 2X, 3X, 4X, 5X, etc. I suppose you can use nearest neigbor approach vertically and get fractional zoom factors. And then there's the mirror effect or repeating scanlines from the display, which is easily done with ANTIC (compressed display). And the ability to cause DLI on various length mode lines and also have the ability to do scanline based IRQs such that you can play back DAC audio during HBlanks.
    Atari is overall superior; only reason some people think C64 is superior is because they don't understand the Atari hardware.
    yeah, that's why it cant do the typical 80's game in c64 quality.
  6. I am still waiting for algorithm from Barnacle Boy for his pixel perfect algorithm that uses only bounding boxes.
    Where did I say pixel perfect collision is done using only bounding boxes? Quote please.
    Post #4693: "Using bounding boxes doesn't mean missiles have to go through people's legs and under their arms, unless you specifically want them to. Exaggerating stuff to try to make your point doesn't actually make your argument stronger, you know. And the c64 can do pixel perfect collision. "
    I wasn't exaggerating; you were by claiming using bounding boxes you can allow for missiles to still go under their arms or through the legs.
    btw you forgot to pick about the fact that VIC2 collision detection at the case of multicolor sprites handles '01' non transparent pixels as transparent. I'd love to see you complaining through 2-3 pages about that :D
  7. C64 developers were better off dropping some DMA cycles on the sprites (width) and making their collision registers more useful or adding a better multicolor sprite.
    you cant be serious. bounding box collision detection is incredibly cheaper to do with cpu, than having to use the cpu to compensate for the missing width and draw that stuff by "hand". same goes for less wide sprites with more colors. it would be fucking (excuse me) stupid to do that.
  8. Is there any reason NOT to get a C128, if a person was into checking out the C64 scene?
    @wood_jl I've thought the same. It was kind of nice to see so many great extensions to the C64.
    I don't think they got of most of the restrictions that makes the C64 inferior to A8 to get C128. C128 still has restricted palette, not ANTIC based scrolling, gfx mode splitting, GTIA modes, simpler overscanning, 60-bits of collision detection (at pixel level for games like Popeye), 4-DAC audio, more restricted joystick/keyboard i/o, etc.
    I heard 128D had a better keyboard interface. C128 had a RGB output to prevent the pixel color shifts in 320 mode but it's still comparable to CGA graphics whereas Atari requires VGA graphics to display (beyond EGA).
    if you add up the pros and cons c64 is the superior. it can do the average 80's game scenario better than a8.
    big palette but unable to display more then the c64 vs smaller palette more colors displayable
    no HW scroll but can compansate it with cpu better than a8 can compensate for its inferior sprite system.
    HW collision detection - unused in most games
    4dac audio - to use it u need all the cpu vs SID making hands down better music with much lighter cpu usage
    joystick/keyboard problem on c64 side - came across no game utilising both being not able to read them both without problems
    I/O - A8 wins for the standard setup
  9. 8 pixel boundaries are irrelevant. Atari can have 3 bitmap lines, a character line, 2 bitmap lines, a character line.
    0 CPU cost.
    another of those features where the a8 wins hands down, but there's no real need/use for it.
  10. In other way, how possible could be to install a SuperCpu for Atari? I have seen a couple of Atari on old years working with 65C816 CPU compatible with 6502 assembler.
    it would be surely possible. on the c64 the supercpu is more of a computer on its own hence c64 bus cant be 20mhz, so it has to use own ram, copying its inner state into the c64 as needed.
  11. Is there any reason NOT to get a C128, if a person was into checking out the C64 scene?
    c128 is a good choice. 99,99% compatiblle, there's a nice 128 demo as a bonus, and a some c64 demos use 2mhz mode on the borders to speed things up.
  12. It's better to have pixel perfect collision in hardware than in software. Period. Whether exactly how many games use it is a subjective thing because I doubt he has taken into account all possible games that can be written or even seen all the games that have been written.
    bullshit. exactly how many games use HW collision detection is not subjective. its a very hard fact. also it has nothing to do with non existing possible games.
    It fits perfectly with people wanting the C64 palette on Atari imagery. Atari palette maps better to real imagery than the C64 palette so it's Dr. Frog's philosophy.
    bullshit. he complained about the inability to put red green blue etc colors beside each other in effects.
  13. I rather have missiles going through people's legs and under their arms than hitting them. Most sprites shapes are not boxes.
    now just picture a 2d stick figure. its not possible to pass a "missilie" through it's legs and under their arms, without touching any pixels. and even if it would be possible imagine the fustration, when your bullets misses the enemy sprite since "missiles" happily goes through legs and arms :D and most sprite shapes can be happily estimated with boxes, hence most games do that, and it works nicely.
  14. The C64 has not been designed to be technology advanced , it has been designed to cost the less as possible.
    Pure bulls**t. The VIC2 has been designed to be the most competitive sprite engine of it's time and that's just what it is.
    It's competitive but that doesn't mean it wins in all cases. There are many events in the olympics so just because you have a faster backstroke/freestyle swimmer doesn't mean you'll win all swimming events. Get the picture? Your logic is that when Atari shows it's better at sprite useage in vertical direction or in overscanned cases or other cases, you're going to show wider sprites at more resolution although the event calls for something else. So when we talk about collision detection of 60 bits vs. 8 bits + 8 bits of vagueness, you're still going to use your freestyle swimmer.
    P.S.: for those that don't know there's a C64 register for sprite detection called the "Vague sprite collision register": whenever a sprite collides with another sprite, it sets the bit for both sprites that collided. So if sprites #0 and #1 collide and sprites #4 and #5 collide, you end up with 4 bits being set. And now if sprites #0 and sprites #4 collide and sprite #1 and sprite #5 collide, it sets the same 4 bits and so on. So to calculate what collisions actually took place, you can do the following algorithm:
    eenie, meenie, minie moe
    catch the sprite that is colliding so
    if it's not colliding, you won't know
    but who cares if you let one go
    This made me laugh out loud.
    Thanks.
    when multiplexing HW collision detection is useless anyway. and why waste 60 precious bits on collision, when most of the sprites have to be software ones anyway... sprites instead could have been a byte wider or smth on the a8. or use those 60 register bits for a 16 color mode where each color is pickable from the 128...
  15. the scroller fx are killer... I guess sprite overlays?
    but i prefer the 16 lum mode but it is personal taste... it is artistic and nothing to start bashing...as we simply could switch to mode10 or mode11... (changing LDA/STA into the prior register).
    yes, sprite overlays. I wonder why almost no a8 demo uses the 16 color modes? (I only recall numen's "doom" engine) guess having the same luma would not give as good results, as the monochrome modes.
    also there are hardly pixel effects, filled vectors, etc eventho the a8 is faster. can you show me a8 "newschool" demos gong for 160x200 and 3d stuff ?
  16. Particular for 3D Objects it is way better to have 16 lumas of one chrome.
    Wrong colours kill the effect of depth.
    this is only true if you want to have some kind of monochrome depth shading. otherwise just plain wrong.
    monochrome vs 16 color:
    And vice versa.... If turning into the style of C64 usage, the Atari beats the limits by far...
    what are you trying to say? turning what into what style, and what limits ?
    You know what I'm writing about: Using the "main screen" for some nice pic and open a small windows for "breathtaking" FX ;)
    the c64 is much better at mixing gfx & effects
    btw: interlaced 2x2x16 below... the scrshot obviously "cheats" and the fx is dead slow, just before you complain...
  17. I knew these demo. Ok, they demonstrate technical things. But I think the problem with Atari 's demos even if they are a great technical achievement they are not really nice. the Artistic side is missing i think.
    in C64 demo , there are more artist touch . that's my feeling. Of course surely a matter of personnal taste.
    And why the Atari having 128/256 colors , most of effect in demo are mainly in shade of gray , or shade of red, or shade of blue or shade of green? Can we not put Red , green , yellow and blue together??
    In fact in demo, i would prefer something less technics but nicer.
    I would be very curious to see how could look the Coca container part of the Deus ex machina on a Atari.
    sure there's less artistic touch, but the smaller scene explans that. simply the competition is not as hard as on the c64. you dont need to do that much for an a8 demo to stand out as on c64.
    that 16 shade 4x4 mode is really overused in a8 demos, but you have to understand that the cpu is the fastest in that mode, and its nice for texture mapping/etc effects :)
  18. I think the Coke animation would be pretty simple to reproduce ( There's a small 1k? demo that has a similar 'twister' effect in antic F, and the pms could give the red can colour ) - which bit is the light effect?
    I guess players+pm's wont make up for the needed width to get a 2nd layer.
    light effect= right side of the twisting logo is darker :) its really nothing.
  19. Is there a Demo on Atari , that could rival with Deus Ex Machina on C64 ?
    Mainly , i'm impressed by the Coca container animation and light effect.
    sure:
    btw, I'm the least impressed with the coca stuff, the rotating textured shit is the best :) could be done on a8 aswell and even better...
    bear in mind that in (8bit) demos shear cpu power what counts most and the a8 is better in that.
    except if you prefer music/gfx.
  20. rename is there. the rest is missing. a fair comparison would be looking at the first dos on the A8 side. ;)
    Ah... but if the 1541 is not to be judged by the speed of the default firmware, then the Atari is not to be judged by DOS I. :)
    its ok to compare the beefed up, or the default drives. but mixing would be no fair, right? :)
