e1will
    364
Posts posted by e1will
  1. Could ASM be used to put three scores on the screen
    Yes... but if you want to stick with bBasic you could just show them on alternate frames. Show one for a few seconds, then the other, color-coded to help indicate what's what.
    --Will
  2. I noticed that if you reset a player multiple times on one scan line it isn't drawn at all. I lost the original program I found this in (I was afraid of asking then) so I modified the How to Draw a Playfield example to show this. Is this a bug in stella, or can you not do this on a real Atari? I thought I read somware that you could do this to make a backround that repetaed the same pattern over and over again but I can't remember where that was. thanks in advance for your answeres.
    I haven't gone through the .asm you posted, but here's how I do it in the game I'm working on:
    WriteLives
    STA WSYNC
    NOP3
    WriteLives_loop
    LDA graphicPtr,Y
    DEY
    BPL KeepOnWriting
    RTS
    KeepOnWriting
    STA.w GRP0
    STA GRP1
    REPEAT 8
    STA RESP0
    STA RESP1
    REPEND
    STA RESP0
    STX GRP1
    STX GRP0
    JMP WriteLives_loop
    It's a little clunky, but it works. Give that a try in Stella... works fine with 2.8.x and 3.0.
    Hope this helps.
    --Will
  3. I am worried of a potential con where there is noise on the controller lines, and by accident, we get 1100, and then are stuck in driving controller mode, when we really have a joystick plugged in. How high is the probability of something like this happening?
    I don't have any info on the driving controllers (I'd be curious to see some of those answers myself), but regarding "sticking" them in driving controller mode, you could always snap back to joystick mode if you saw a 10nn or 01nn pattern, meaning they'd pushed the joystick left or right. Should be a quick test you can run every few frames as a sanity check... chances are if there was a noise issue where the game thought it was a DC but they had a joystick, the player would probably wiggle it in various directions to get a response.
    --Will
  4. Hello everyone!
    Here's the latest version: v0.11.
    This has a new feature for AtariVox and SaveKey users (and Stella users too): You can save your game and return to it later. This is handy if you've reached level 14 or so and don't want to lose your place, but need to go do something else. (Like play Juno First for a few hours.) You can load your game exactly where you left off when you return.
    To save your game, go to the egg shelf room (screenshot attached) and press the Fire button on the joystick. If the program was able to save the game successfully, it will move you to the score room. If it was unsuccessful, it will move you to the credits room. It will be unsuccessful if you don't have an AtariVox or SaveKey attached (or if you're running in an emulator and don't have the game properties configured to use an AtariVox or SaveKey as the P1 controller.)
    To load your game, start a new game, go to the egg shelf room and press Reset on the console. If the program was able to load the game successfully, it will move you to the score room; if not, to the credits room.
    Special thanks to stephena and especially cd-w for the help in getting the AtariVox interface working correctly.
    There is a known issue where the screen will roll while it's reading from or writing to the save file. That's on the to-fix list.
    I've got some more neat stuff on the way for the next version, so stay tuned...
    --Will
  5. Is there additional documentation available for the optimized code? I was just going by the code example from AtariVox.rtf (revision date 2004-NOV-16), perhaps that doc is out of date?
    No, I never do documentation. :)
    Unfortunately I am pretty busy over the next weeks, so most likely I won't have time to look at the code again. Maybe someone else can help?
    Oh, no problem. I've got it working with the original code, so I'm using that. (Actually, I'm trying my own optimizations at that, which I'll post if they work.)
    --Will
  6. Thanks! My problem now is that the 107-byte optimized code gave me just enough room to get the save/load features in... I had to temporarily comment some stuff out to get the 169-byte original to fit, so I'm going to be in code-squish mode for a while. 32k seemed so roomy when I started!
    The optimized code was tested to work, so I suppose that it is mainly a documentation flaw. Probably a return value is different from what you expect.
    --Will
  7. I'm glad you got it to work - I guess there are still some issues with the optimised i2c code. I'm looking forward to hearing speech in Duck Attack now - it is a really nice original game.
    Cheers,
    Chris
    --Will
  8. I am using the unoptimised version in Juno First - I think it would be best to start with this code.
    Chris
    Swapping in the original i2c.inc fixed the issue! I'm able to write to the .dat without problems now. I'm using the same example code, the only change is including i2c.inc instead of i2c_v2_2.inc.
    Thanks for the debugging help; I really appreciate it.
    --Will
  9. I'm not sure - try it without this test and see what happens :)
    Chris
    Well, if I comment out the BCS (and the ROR I just added) and just let the example code plow on through with its jsr i2c_txbytes, the .dat file is not updated (contents all $FF, Windows modification date unchanged.)
    I assume you're not using Thomas's optimized version in Juno First? Would I be better served to just use Alex's original version? Or are there known bugs with it?
    --Will
    buffer = $80
    jsr	i2c_startwrite	; Start signal and $a0 command byte
    ;   ROR
    ;	bcs	eeprom_error	; exit if command byte not acknowledged
    lda	#$01			; upper byte of address
    jsr	i2c_txbyte
    lda	#$40			; lower byte of address
    jsr	i2c_txbyte
    ldx	#$00
    write_loop
    lda	buffer,x		; get byte from RAM
    jsr	i2c_txbyte		; transmit to EEPROM
    inx
    cpx	#$08			; 8 bytes sent?
    bne	write_loop
    jsr	i2c_stopwrite	; terminate write and commit to memory
    clc
    rts
    eeprom_error
    sec
    rts
  10. OK, I see the problem. If you look at the definition of the i2c_startwrite command, the last line before the rts is "bcc i2c_rxbyteloop". This means that the carry flag will *always* be set at the end of this function. I think that Thomas has optimised out this bit of functionality. In fact, it looks like you should test bit 0 of the accumulator rather than the carry flag. I suspect there must have been a note about this somewhere, but I can't find it now. Anyway, hopefully this should solve the problem!
    Chris
    Ah! I'll give that a try, then. Thanks!
    --Will
  11. Correct, the first jsr i2c_startwrite is failing (setting the carry flag.) The binary is posted above (post #18), the first jsr i2c_startwrite is at $B9C3. Either stepping through it in the debugger or letting it run at normal speed seems to produce the same results.
    --Will
    I'm having a bit of trouble finding the AtariVox calls in your code. Can you let me know when they are called in the game, and which bank/address they are at. Ideally, if you could separate the AVox stuff from your main code and post the source, or post a symbol file for the Stella debugger?
    Chris
    Sure, symbol file attached.
    --Will
    EDIT: The jsr i2c_startwrite call is the only call in the game that pushes the stack pointer down to F3, so if you have trouble locating that call you can just add a breakif {sp==F3} and it will catch there. Starting a game, move the robot to the right door and into the light blue room, then pressing the fire button is what triggers the AtariVox call.
    DUCKNTSC.zip
  12. If it still doesn't work, then it might be a problem in the programming of the AVox itself. Unfortunately, I can't help in that area.
    If I understand correctly, the problem is the very first "jsr i2c_startwrite" command, before any AtariVox or SaveKey programming is performed. I suggest that e1will posts the binary containing the problem so that we can debug it and see why this is happening.
    Chris
    --Will
  13. Just thought I'd take care of the obvious first; you are restarting Stella, correct? It's not enough to select the AVox as the right controller in the UI. You then have to restart Stella with the same ROM to pick up the change (as indicated by the text at the bottom '(*) Changes to properties require a ROM reload').
    Yep, definitely restarting Stella each time. What's interesting is when I recompile the ROM, Stella will "forget" that I've specified AtariVox for the P1 controller (perhaps it uses a checksum or modification date rather than simply the filepath of the ROM?) and reverts it to Joystick, but regardless I do change the controller setting outside of the game (and then confirm it's still set correctly by looking at the config after starting the game.)
    --Will
    EDIT: Tried it with the commandline argument, still can't access the EEPROM: Stella.exe -fullscreen -1 -rc atarivox DUCKNTSC.BIN
  14. There is an option to use a real AtariVox in Stella (Input Settings -> Virtual Devs -> AVox Serial port), but I don't think this will interfere with the SaveKey stuff. Have you tried setting the right port to "SaveKey" instead? Do other games (e.g. Juno First) do their SaveKey saving and loading fine with this version of Stella? Could the stack pointer be overwriting something (e.g. the SaveKey temp variable) when you do the jsr? If it still doesn't work, you could post some more of your code here.
    Chris
    Setting the P1 controller to SaveKey gives the same results. Juno First is working fine saving and retrieving its high scores, so Stella is able to read and write to the .dat file. The stack pointer is at $F7 when the SaveAndLoad_Main function (which contains the example code) is called, and drops to $F5 when the jsr i2c_startwrite is called; the temp variable is at $DD, so there shouldn't be a conflict there.
    Here's how I'm calling it: the main game loop calls a joystick input function (PlayerMove, at $F374 in bank 7), which checks if the fire button is being pressed in the egg shelf room. If it is, it JSRs to the SaveGame function, which JSRs to the SaveAndLoad_Main function ($B9C3 in bank 3) which contains the example code. The first thing that function does is call jsr i2c_startwrite, which on return has the carry flag set. (And viewing the contents of the .dat file confirm nothing has been changed from all $FF's.)
    When SaveAndLoad_Main returns, it puts the player in either the score room (if the carry flag is clear, meaning success) or the credits room (if the carry flag is set, meaning failure), and so far it has always done the latter.
    --Will
    DUCKNTSC.BIN
  15. I just wanted to add that if you'll be using an AtariVox with Stella, you must use this latest optimized i2c code. Thomas released this new code in part because we found a bug when adding AVox support to Stella.
    Well, I'm brand new to programming for the AtariVox, and I must be making a rookie mistake, although I don't know what it is.
    I'm including Thomas's i2c_v2_2.inc, I'm using the example code from AtariVox.rtf EXACTLY as it's written, and I've got my ROM configured in Stella to look for the AtariVox in the right port (screenshot attached). But when the example code runs, the first jsr i2c_startwrite always returns with the carry flag set, which from the documentation means it was unable to communicate with the port.
    buffer = $80
    jsr	i2c_txbyte
    jsr	i2c_txbyte
    ldx	#$00
    write_loop
    inx
    bne	write_loop
    eeprom_error
    rts
    Is there some initialization that I'm missing? Or a Stella configuration option I've missed?
    --Will
  16. Maybe the new locations have something to do with it??
    Of course, the specific ROM must actually use the AVox device (ie, it must have the controller type set to AtariVox, either in its properties or manually from the commandline). Otherwise, a EEPROM dat file will never be created.
    I've tried specifying different locations for EEPROM path, including these:
    ~\Application Data\Stella\
    C:\Stella\
    ...and I get the same results each time. I know it's not a Windows permissions issue, since Stella has no problem with the "Save ROM" feature in the debugger with ROMs in the same directory as what's specified in the EEPROM path.
    This behavior is consistent with other games I've tried that have AtariVox functionality (e.g. Juno First says "SAVEKEY CARD NOT FOUND!" when I start it in the emulator.)
    Anything else I might try? Am I correct in understanding that Stella should create C:\Stella\atarivox_eeprom.dat if stella.ini shows "eepromdir = C:\Stella\" and I start a game like Juno First?
    --Will
    EDIT: Nevermind! The problem was the P1 controller type. Apparently it had reverted to Joystick somehow. Changing it back to AtariVox fixed the problem. Thanks for the reminder to check that setting.
  17. Is Stella 3.0 handling the AtariVox EEPROM emulation differently than 2.8.x did?
    I can't seem to get 3.0 to either read the existing atarivox_eeprom.dat file or create a new one, and running games that worked fine under 2.8.4 (e.g. Man Goes Down) no longer save or load under 3.0.
    --Will
  18. Great game. I will give it some more play tomorrow.
    A minor comment:
    IMO, at the credits screen, "Duck" and "Attack!" should have the same with (like at the title screen). Looks better that way. Also the vertical space between the two words is much bigger at the title screen. It should look identical on both screens.
    Good suggestion. I've changed the credits logo to match the title screen's.
    v0.09 is attached - the major change to this version is a new "Continue" feature. If you reach level 6 or higher before running out of lives, you can continue the next game at the same level (with score reset to zero) by pressing the fire button before the timer runs out.
    To compensate I've cut down the number of levels you can select from the title screen to 5 (from 9). To get to level 9 now you'll need to beat levels 5, 6, 7 and 8 first.
    I've got a really neat feature planned for version v0.10, so stay tuned!
    --Will
  19. I just wanted to add that if you'll be using an AtariVox with Stella, you must use this latest optimized i2c code. Thomas released this new code in part because we found a bug when adding AVox support to Stella.
    Thanks for the heads-up. Out of curiosity, what was the nature of the bug?
    --Will
  20. Thomas also posted an optimised version of the AtariVox i2c code.
    I'm hoping you will be adding AtariVox speech to Duck Attack?
    Chris
    Thanks for the updated .inc link!
    I would love to have some sounds in there (a nice robotic "duck in vicinity!" would be great) but I'm not sure if I have the byte-squeezing skills to pull it off. I'm going to play around and see if I can manage it, although I'm not optimistic since things are pretty darn tight as it is. (And I don't actually have an AtariVox, so testing would be tough.)
    I did decide to add a "save game" feature, though, so that if you're wandering around on Level 14 and want to play something else for a while, you can save the game to the EEPROM and resume it later. That (and high score retention) will be in v0.09. Since Stella emulates that, testing should be straightforward (I hope).
    --Will
