tz101
Banned
    2,126
Posts posted by tz101
  1. I saw my local Wal Mart clearancing HS controllers after Christmas for $5 a piece. Since I don't have a system or any games, I passed. Does anyone know if these controllers can be rewired to work with other systems like say, Sega Saturn? If so, then I might go back and pick a couple up.
  2. I will agree with a couple on here and say that my initial reaction to seeing Super Mario Bros. demonstrated in a Target store, I was awestruck. I don't think SMB actually hit the arcades with the Playchoice 10 until the carts were released to the stores, so I had never even seen it in an arcade at that point. My initial reaction was that you could actually move a character in a cartoon. Nobody had ever offered that before. Simply amazing for 1986 tech.
  3. Because all the 2600 consoles up to the 2800 used a male "stereo" plug to fit into the console's power port, it becomes difficult to find another systems adapter that will fit. The SMS, NES, and Genesis all used female adapter ends on their power bricks. The Sega Genesis model I used a 9v DC adapter like the Vader requires, but you would have to cut and splice the end plug from your overheating power brick. Also, be careful about polarity. VCS Atari power brick outputs 9v DC (not AC as you originally posted) and the Genesis model I/Sega Master System power adapter also outputs 9v DC. Again, just watch for polarity if/when you splice the different connector onto a Genesis/SMS power brick. The Atari uses center positive polarity, while the Genesis/SMS adapter has center polarity of negative. This is not a problem as long as you wire it correctly when you make the splice. Definitely do not use a NES power brick on your Vader 2600 console as it outputs AC current which will permanently damage it. The 2600 was made to accept DC input. You can use DC current to power an AC device, but cannot use AC current to power a DC device. Hope this helps.
  4. Actually, if you are somewhat mechanical you can repair and clean old dirty pots with little effort.
    First, unplug the six controller wires (three for each pot) that connect to the pots, being careful to remember which colored wire connected to which pot connection point.
    Second, remove the pots from the plastic 5200 controller housing. On some controllers this can require a little force since the pots are dlued into the controller from the factory.
    Third, use a jeweler's flat type screwdriver to bend up the four crimped corner tabs on the pot outer housing.
    Fourth, disassemble the pot, taking notice of how the stem and disc are oriented for later reference. You will also have to remove the rotating pot arm at this step. It is press fit over the pot shaft so may require a little force.
    Fifth, use fine grain sandpaper to lightly polish the ends of the "feathered" metal contact that rotates within the pot, then finish cleaning it with a cotton swab dipped in 91% alcohol.
    Sixth, Use cotton swab and alcohol to thoroughly clean the carbon pad that is on the inside of the pot's stationary housing. This carbon pad is what contacts the feathered metal connector during game play.
    Seventh, reassemble the pot and use the jeweler's screwdriver to re-crimp the four corner tabs of the outer metal housing to capture all the internal components in their proper place.
    Eighth, replace the pots into the controller plastic housing and reconnect the colored wires to their proper contacts.
    Ninth, press the pot arms back over the pot stems and properly adjust the on-screen movement of your avatar/cursor. The best game for this alignment is Missile Command. With the cursor centered vertically on your TV screen the upper pot arm should be positioned at exactly the 9 o'clock position. With the cursor centered horizontally on your TV screen the lower pot arm should be positioned at exactly the 6 o'clock position.
    Finally, reassemble the controller casing, being careful to not rotate the pot arms out of their proper positions with the plastic slider plates.
    Plug it into the 5200 console and enjoy.
  5. For all of us, there has to have been an event in our lives where we recall first being wowed by a video game or system. A defining moment we will never forget. I will show my age and tell that my first video gaming "wow" moment came in the late 70s as I stepped into a Sears store in our town and saw an Atari VCS (wasn't yet called the 2600) for the first time. Up to that point I had seen a Pong system at some relatives' house and that was about my level of exposure to video games. Every electronic game I had ever seen in a public venue had been pinball or some derivative thereof. Atari and Sears blew my juvenile mind with the shear amount of games I saw displayed on that wall rack. Who knew you could have one appliance that offered so many awesome game playing options? Bowling, Space Invaders, Circus Atari, Combat. They were all there in grand array at that Sears store that night. My life has never been the same since.
  6. I am not so certain that power adapters are affecting the color discrepancies you are experiencing. This might be as simple of a fix as to take the Vader's case apart and adjust the color saturation adjustment screw on the main board. I just had my Sears Video Arcade II console putting red coloring on E.T. where the landscapes should have been green. Then, I tried Activision Enduro and the ground was red and the sky was beige. All I did was take the console apart and make adjustments with the Enduro game powered on and all the color problems were solved.
  7. I have the Atari Flashback I along with a handheld Activision plug-n-play unit purchased at Walgreens and a couple Atari compilation discs for Gamecube and PS2, but really wish somebody would license and manufacture an Activision version of the Atari Flashback II system. Playing all the 2600 Activision titles on real CX-40 style sticks would be a truly unbeatable experience. Probably would have to include a paddle for Kaboom as well. Although I have 27 of Activision's carts in my 2600 collection, I am missing some good ones like Pitfall II and Plaque Attack, and have had real difficulty finding them at used game dealers around my area. The Activision Flashback console would solve all of that for classic 2600 gaming fans. Please, somebody say you'll do this in the near future.
  8. Really, the decision is between you an God. I know I am risky with the ban on religious posts, but so be it because it is the absolute truth. Evidently, you collected video games from the time you were a child. At some time, perhaps recently, you became somewhat obsessed (for lack of a better word) and decided to collect as much as you could as fast as you could. I am guessing from your wording that it has become somewhat of an unhealthy "addiction" for you at this point in your life. Now, what has led you to this decision, to sell it all off? Do you find that all your time and thoughts are spent on video gaming and collecting? Is it strapping your budget? Then, yes, this is unhealthy. However, also realize that everyone needs hobbies and interests in life, or it would be really boring. Is this decision coming from you but maybe really coming from a significant other? You know, like maybe your wife has stated some dislike for your video gaming and asked you to spend less time with this hobby and more time with her and the kids? OK, then take that as a sign that some reallocation of your time is necessary in your family and relationships. Maybe, just maybe, you keep all or most of your current collection and vow to put a hold on buying anything else, at least for the foreseeable future. Of course this takes real self discipline on your part, and again, only you and God know where you stand in that department. Or, as you have alluded to, maybe you go forward and sell it all off due to lack of restraint. Only question I would ask with that is how certain are you that your buying and collecting behavior would suddenly change, just because you have suddenly sold it all off. Ultimately, your depression and need to make changes in your life run deeper than these games and systems, and may well require some real soul-searching and prayer on your part. Having said that, if that room half full of gaming stuff is becoming too great a temptation and perhaps even a burden in your daily life, then by all means do what you feel the Lord leading you to do. If I truly felt God telling me to sell all my gaming stuff in order to spend my time on more "profitable" pursuits like art or what not, then by no means would I hold onto it for one more day, regardless of perceived difficulty of reacquiring it at a later time. Your health, and your family's overall well-being are much more important than any video games or systems. No amount of money can buy peace of mind.
    Best wishes to you, and I hope you get past your depression soon.
  9. Just got it fixed. Found the fried transistor, replaced it with one similar enough. You have to shake the switchbox sometimes but it works fine. Unfortunately but not to anyones surprise the controller they sent me dosent work but the trakball works great. All I can play on it is glaxian, missile command and centipede. Its still awesome though.
    Get with Best Electronics for replacement flex circuit and pots and your controller will work good as new. They are very reasonable on their prices too.
  10. I wonder something... I read that the "fuse" on the controller board is actually a resistor that opens when too much current is drawn through it. Was it designed to do this, or was it an oversight? If it was an oversight, a higher wattage resistor could be used to totally eliminate the trouble.
    It is not a resistor. It is a fuse in a package that looks like a resistor, so it's not surprising that some random person would say it's a resistor as though he knew what he was talking about. Not that a low-value high-wattage resistor would be a bad thing, but that's not what it is.
    I had one get blown for some reason, I think I had a controller open and was poking around in it. When that happens, the controllers won't work, period, because the fuse is on the power line to the controllers. I replaced it with a single strand of thin copper wire. Not quite as safe, but still better than a big fat wire.
    Replacing the controller PCB fuse with a wire will work as a temporary fix, especially if no controllers are recognized at all. Another quick fix that is a little easier is to simply take a pair of needle nosed pliers and twist the original fuse 360° so that the wire "legs" are touching, and this essentially bypasses the fuse. I do not recommend this as a permanent repair because, again, the controller PCB fuse is designed into the system for a very important reason: Protecting the remainder of the DC console's electronic components from electrical shorts and surges generated within the controllers and their cords. It is cheaper to pay $2 for three picofuses than who knows what for a replacement DC console.
    See my image below for the F1 fuse location on the DC controller PCB.
  11. The 5200 is a great system it's the original non centering controllers I dont like, unless the game
    is better suited for them. Unfortunately most of the good games are not better suited for them.
    I think they should have just did a centering joy and sold paddles separately for games like breakout
    and such.
    Replaced the flex circuits, stick rubber boots, and pots with new ones from Best, and guess what, the sticks are centering. Even games like Pac Man and Ms. Pac Man play nicely with the new rubber boots. What a difference new parts can make.
  12. I, Robot -- I spent a few days in residence as part of the "University Orientation" a few months before classes started (this was in 1988). The arcade in the residence included this apparently very rare game. I have never seen it anywhere else.
    I, Robot was a sweet game. My second favorite arcade game to Galaga. They had an I, Robot cabinet at my local Aladdin's Castle for quite some time when it first came out.
  13. ...the movement of the controller wire during regular gameplay is often enough to nudge the connector in the port to the point where the DC no longer registers the connection. Any maintenance I can do here - guides online maybe?
    This sounds to me like a loose controller port connection. The fix is to take the controller PCB out and reset the solder points for whichever port is causing you the troubles. Basically, just use a solder iron to soften the solder at the various solder points for each controller port and presto, your problem should be solved. If it was the infamous fuse/resistor, the DC console would not recognize any controllers any of the time, and since yours does with a wiggle of the cord, that tells me the problem lies with the solder connections of your controller port(s). Hope this is helpful.
  14. I wonder something... I read that the "fuse" on the controller board is actually a resistor that opens when too much current is drawn through it. Was it designed to do this, or was it an oversight? If it was an oversight, a higher wattage resistor could be used to totally eliminate the trouble.
    Not recommended. The fuse/resistor on the controller PCB was designed to protect the system from shorts within the controllers and their wiring. I replaced the original on mine and it looked like a resistor. The ceramic fuse I replaced it with was rated at .5 amp per recommendation from a poster on another forum. If you go higher on the amperage rating for this fuse, then your system components will be at risk. Again, not recommended.
  15. DC works in a system designed for AC power, but not the opposite direction. AC into a DC console is a bad situation. This is why the NES console can be powered with a DC Genesis power adapter, but you should never use the NES AC power brick on any other game systems, as most of them are rated for DC power consumption. That is unless you wish to fry them.
  16. I have my original Activision game cartridge from 1982, but it has bit the dust (see attached screen images). All it gives me is either vertical stripes or rolling horizontal lines. Seeing that every other 2600 cart works fine on this Sears Video Arcade II console, I am fairly certain that the problem is with the cartridge. I peeled the label with a heat gun and then disassembled the cartridge by removing the two phillips head screws. In looking over the PCB, I cannot see any broken traces, and just to be certain I re-soldered all connection points and ROM chip pins. Still, all I get is the vertical stripes, albeit differing patterns at different times, and sometimes I can hear the sound of the Enduro cars coming through my TV speakers. I have polished and used alcohol on the game's contacts, to no effect. Anyone know of anything else? Is this a case of the ROM chip somehow having been zapped or exposed to a magnetic field? I have begun to think that it is a problem common to Activision 2600 carts because I had a Pitfall II game that met a similar fate years ago. After much cleaning of the contacts I finally gave it to the local landfill. Any good suggestions for repairing this?
  17. I have had this game in my collection for many years and had only dabbled with it a couple times before, but enough to know it was not "the worst video game ever made". After reading and posting on another thread about someone being frustrated with E.T. haters online, I actually have found it to be quite an interesting and fun game to play. Since I do not have the original instruction manual, information about "zones" and better tactics for eluding the FBI agents would be greatly appreciated. Also, is there a good way to know which wells will contain phone pieces? I seem to lose lots of points by aimlessly going into empty wells in my search for phone pieces. Thanks.
  18. you can afford a pc, a ps3 and software, but don't have $20 for games? back ups my ass. in my 25 years of gaming ive never had software fail on me so i needed a "back up". pirates are just cheap assholes.
    Lots of assumption on your part. I, like many others, see games/movies as an investment. Normally, I create backup DVD copies of all my movies and keep the originals stored away. This protects my investment from scratches and other possible damage. So why is the consumer expected not to protect his/her ~$50 investment in a PS2/PS3 game disc? Only makes good sense.
