chriswhit
    415
Posts posted by chriswhit
  1. I dug out my 7800 after modding my supercharger the other day and to my surprise it fired right up after sitting since 1989. at first all was well. Today I popped ms packman in (the 7800 version). It worked ok till I got a call and let it run the demo screen for about 10 minutes. I pressed the fire button to start a game and noticed that it started on level 8 and the stick wouldn't respond. after I died due to no stick function the controller worked normal till i died again, and on the next life no stick function again. I decided to shut it down and fire it back up to see if it did anything different. Everything was normal after that till I went to the bathroom with the demo screen running. Then the same thing all over again. I have a custom arcade stick I built because I don't have any real 7800 controllers. Could it be the controller or is there a problem with my console? I haven't cleaned the system since new but other than that issue it works great. Ant info would be great as I don't dare to run anything rare in it out of fear it may damage something. thanks
  2. A) this is an 8-way joystick.
    B) it's REALLY rude to come in to someones project thread hocking your own project and selling it to the people looking in MY thread.
    I get it... no one wants it. Consider the case closed.
    MODS LOCK THREAD.
    I wanted to apologize for the misunderstanding. I ordered my parts on October 1st and I'm only building me two and my neighbor two just for the price of the parts as he is my best friend. I should have been more clear on that. I've never had a 7800 stick that worked right and neither has my friend. I have my stick up and running as of today. It was fun with no schematic or 7800 controller to go by. Again I apologize for the misunderstanding. From now on I'll just start a new thread when mentioning that I have a project going on instead of assuming the two topics go well together. hope theres no hard feelings it wasn't my intension.
  3. My 500 xj controller works good on my 2600 and I was wondering if it could be converted with a 7800 wire and resisters to work on the 7800?
    Does it have two separate fire buttons? If so, it should work!
    yes but there are no resistors and the pin out seems to be a little different
  4. I've considered making Joysticks like this myself. Could be a fun project. :)
    I'm making some for my 7800 and a few for my friends to using this stick http://www.sparkfun.com/commerce/product_info.php?products_id=9182 using arcade buttons to. My supplies should be here tomorrow. cant wait. I need Ideas for a case though.
    You do realize that is a 4-way stick right? That means you won't be able to properly play any games that need an 8 way, which include many many very good games. That being said, old 4-way arcade games like Pac-Man and Donkey Kong will play better than with an 8-way.
    I am building myself some 8-way and some 4-way sticks. That way I can play everything the best way possible. If you are looking for one stick to play all games, you definitely need to go 8-way. 4-way will not do. There is a good reason that every console stick is an 8-way.
    thanks for the info I'll find another stick
  5. My Starpath SC is modded in a similar fashion to yours. In fact, the pictures in my mod are of that particular SC. I've run it without difficulty in my brother's light sixer and in both my Heavy Sixer and my third generation 7800.
    What's the unit doing? Specifically what color is the screen when you try to boot it up? Mine did some odd stuff when I was trying to nail down the correct resistor value, which is posted in the mod. The screen came up this brownish orange color when I had the resistance too high.
    I was wondering what size resistor you used to get it to work on your 7800? I just looked and mine is 10k. My 7800 is the first style so it should run in the system right? I used your post as a guide to mod it as I couldn't find the 7432 chip to do it the other way. I also never tried the sc in my 7800 till the mod was done. the post above is mine to answering your questions. Thanks for all the help
  6. My Starpath SC is modded in a similar fashion to yours. In fact, the pictures in my mod are of that particular SC. I've run it without difficulty in my brother's light sixer and in both my Heavy Sixer and my third generation 7800.
    The screen is blue when booting up on a 2600 but on the 7800 it fires up but just says rewind tape while playing a bin file
  7. Have you looked in the 2600 compatibility section in the 7800's FAQ?
    http://www.atariage.com/7800/faq/index.html?SystemID=7800#cat3_3
    batari also provided a full answer to the circuit causing the problems here :-
    http://www.atariage.com/forums/topic/147397-the-7800-timing-circuit-demystifed/
    EDIT: Spelling
    My 7800 appears to be a style 1. Maybe the mod I used is not 7800 compatible. I know I have 120 2600 games that all work fine in it.
  8. I have a self modded supercharger using switching diodes and a resistor instead of the chip. I noticed it doesn't work in ether mode on my 7800 but works flawlessly in both modes on my 2600. I'm using cuttle cart playbin to run games off my computer. Is there something I can do to make it work in my 7800? Maybe I need a different program? do they normally work with a 7800?
  9. I have a self modded supercharger using switching diodes and a resistor instead of the chip. I noticed it doesn't work in ether mode on my 7800 but works flawlessly in both modes on my 2600. I'm using cuttle cart playbin to run games off my computer. Is there something I can do to make it work in my 7800? Maybe I need a different program? guess i put this in the wrong section
  10. Get the four port one. I love mine and it works alright and my switchbox works great. I wouldn't get a two port because it has differences in the cartridge slot that make it incompatible with some 5200 games while making is compatible with the 2600 adaptor. There are also a few four port 5200's that have asteriks in their serial numbers, that means they are four port motherboards, but they have had the cartridge slot changes in order to make it compatible with the adapter, these 5200's have the same compatability problem as the 2 port.
    thanks for the info it will help me a lot in my choice
  11. Oh, what the heck...here's a detailed description of how I did it:
    Here I present The Complete Idiot's Guide to Modifying The Supercharger
    First, we need to know which pin is #1 on each of the IC's, and how they other pins are numbered. I'm going to treat the row of components on the one side of the board as an IC for numbering purposes. I'm also going to explain a simple mod to the audio line to make it easier on modern music devices and I'm going to add everything on top of the board instead of the bottom. I'm also going to assume you either have actual Starpath tapes and a stereo tape recorder like I do or that you have the mp3 files on your digital player. I'm going to assume that you have a program such as playbin that can turn .bin files into audio the Supercharger can load, and I'm going to assume you have at least one Starpath game in mp3 format on your computer.
    The parts:
    One resistor, 5K to 20K at 1/4 watt should work.
    Two switching diodes, 1N914 is common and is what I used.
    The smallest SPDT switch you can find. It'll have two positions at the lever, and three pins.
    About a foot each of three or four colors of wire, I used red, white, green, and black.
    One 1/8 inch replacement stereo headphone jack.
    Rosin core solder, probably about three feet if you use a lot.
    Elmer's School Glue stick
    Tools:
    15 watt soldering iron, grounded if possible.
    Desoldering tool (recommended, but not required)
    Straight blade screwdriver
    Xacto knife
    Wire strippers
    #1 point Phillips screwdriver
    Hacksaw
    Hair dryer
    Multimeter (known as a Fluke hereafter)
    Case mod:
    Use the hair dryer to heat the Supercharger's main label up. Gently begin peeling at one corner, heating as necessary to loosen the glue. Alternately, you can cut through the label with the Phillips screwdriver, but this will scar your Supercharger's label. Once the screw is exposed, you can leave the label as is and remove the screw. Working from the connector end of the cart, gently pry the halves apart. The cart will hinge open on the end label, so be careful not to tear the end label in half.
    Remove the board and the audio wire, then reassemble the cart without them. Tighten the screw. Look at the end label, and look down the sides. You'll see a hole for the audio wire. We want another hole on the other side for the toggle switch. The plastic is not too tough, so your #1 Phillips will cut right through it. Note that there is a split between the case halves where you need to make the hole, so you have to squeeze them together a bit while you cut the hole out.
    Now let's get an overview of the board. Hold the board with the component side facing you and the edge connector pointed down. Four IC's should be on the left. The top is the ROM IC, or U1. The next three are RAM, and for this guide we're going to number them from the top down, U2, U3, and U4. The largest IC is the custom Arcadia chip, which we'll call U5. LAst is the row of components which we will fudge and refer to as U6. U7 would refer to the 7432 in a modified Supercharger, but that's not present or we wouldn't need this guide.
    Time for more physical mods. Make a square cut on the top left side of the board. It should extend down almost all the way to U1's legs, and it should be about that same distance across from left to right. In other words, make it square using U1 as a guide. My Supercharger had no traces in that area, but check yours anyway and if they are there, cut around them.
    Next, let's knock out the simple mod first--the audio line. Cut the audio wire as close to the plug as possible, then strip about half an inch off the conductors. Grab that stereo jack you have and hook the white wire to BOTH of the connections inside the jack. The other wire is ground, so solder it to the largest connector. Make sure the ground and the other wires don't touch, then use the Fluke to ensure that the ground wire has continuity from the SC board all the way to the largest ring on the jack. The white wire should have continuity from the SC board to BOTH the middle ring and the jack's tip. If so, assemble the jack and that's done.
    Another solution to this is to permanently mount a 1/8 inch mono male to 1/8 inch stereo female adapter onto the existing jack. That's what I did, then I taped the jack on with electrical tape and glued that down so it would not unwind.
    Why mod the audio line anyway, you ask? Simple. Back in the day, shoebox recorders were common. That's whaty ou see pictured in the Arcadia manuals with the Atari--a shoebox recorder. Those old recorders have a monaural output.
    On the other hand, today's portable CD players, tape players, ipods, mp3 players, etc, have a stereo output. The Supercharger was not designed to be used with these new devices, and plugging it into them results in the left channel only being fed into the supercharger, while the right channel is shorted to ground. This can strain the audio circuit inside your player (or whatever it's hooked to), resulting in premature failure of the right channel audio. I'm not saying it will damage your ipod or whatever, just that it could. It can also cause problems when loading games into the supercharger, as essentially only half of the signal gets through from the ipod (remember that an old shoebox recorder is going to route the whole signal to only one channel, the ipod routes it to two).
    Now for the more fun mod:
    A few posts up, Batari has a simple diagram which is the actual bankswitching mod itself. In his diagram is an OR gate. If you look at the pinout of a 7432, you see that each of the OR gates on that IC has two inputs, Ax and Bx, and one output, Yx. Let's consider just the first gate, then, which has inputs A1 and B1, and output Y1. The 7432 has a ground leg, which we will also recreate, and a power leg which we do not need.
    Take your two diodes and note which end has the stripe. If you set the fluke to the diode check you can hook the diode up so that the black fluke lead is hooked to the striped end lead on the diode, and the red lead to the other end. You'll see some numbers on the fluke. If you hook the fluke leads up the other way, it will show an OL or some other odd message instead of numbers. This tells you which lead on the diode is anode--when the numbers show, the red fluke lead is on the anode. The striped end of the diode is cathode, and that's where the black fluke lead would be when you have numbers on the LCD screen.
    take the two diodes and twist their cathode leads together. The resistor does not have anode and cathode, so just pick a lead and warp it around the cathode leads. Leave about 1/4 inch of the resistor lead untwisted. Solder the whole thing together save for that last 1/4 inch. Trim the diode leads but leave the resistor lead alone.
    Now look again at the SC board. Each of the IC's has a notch EXCEPT for U6 (that's the component bank). With the notch pointed UP, the top left pin is pin 1. The pins are numbered down the left side, then back up the right side. The memory chips U1 to U4 all have 24 pins, so the top right pin is pin 24. On the left side, ging from notched end to other end you have pin 1 to pin 12, then going from other end to notched end you have pin 13 to 24. REMEMBER THIS. As for the component bank at U6, we're going to assume U6 is oriented the same way as the custom IC, U5.
    Hook one of the anode leads from your OR gate (that's the diodes and resistor circuit you made) to pin 7 on U4. It's the seventh pin down on the left of the chip. Flip the board over and cut the trace on THAT side of the board that leads from pin 7 of U4 to pin 35 of U5. pin 35 is sixth up from the bottom on the left side of U5 as you held the board earlier. Check it for yourself and see, though.
    See that conglomerate of wires with the cathode leads? Tin the 1/4 inch lead that you left on the resistor, then solder it to pin 35 on U5. Ensure that the three leads you soldered together are still, in fact, together.
    Next, solder the other lead of the resistor to pin 12 on U3. This is where the ground connection from batari's diagram is made on the SC board.
    Cut the other anode lead to a length of about half an inch. Position the OR gate above U3. You're done with the board for now.
    Now take the switch and hook about six inches of three colored wires to it. I hooked red to the center lead, then I flipped the switch body so it's perpendicular to the board. I hooked black to the top lead and green to the bottom.
    While you're at it, let's prepare the switch to be mounted in the SC case. It should have a large flat washer and a smaller star washer. Remove all the hardware from the switch body, then place the flat washer on followed by the star washer and one of the nuts. Leave the nut loose until you have the wires connected to the switch.
    Once the wires are connected, lay the switch and the SC board back into the case. Cut the red wire so that its long enough to solder to the remaining anode. Strip and solder it there.
    Cut the green wire so that it can reach pin 13 of the component bank at U6. You can sloder to the component's lead if you wish. Strip and solder.
    Cut the black wire long enough to reach pin 27 of U5. Once again, strip and solder.
    Now for the testing:
    With all of that done, you're ready to test the mods. Plug in the Supercharger, then connect the fluke leads on either side of the resistor so that the black lead is hooked near U3 and the red near U5. Set the fluke to measure DC volts, then hit the Atari's power. You do not need to set DevOS to play a 2600 game, just hit the power. (If you don't know what DevOS is, then you don't have to worry about this.)
    The Supercharger will power up. If the screen is normal, then everything is good so far. Check the voltage on the fluke. If it's between 0 and 2.5, then you're good. If the screen is NOT normal, then the voltage you're measuring is probably too high. Take another 20K resistor from the pack and solder it in parallel to the first one. I literally mean that, solder them so that it looks like current should flow through BOTH resistors (because if you do this right, it will). Try it again. The voltage should be lower this time, too.
    Now let's hook the SC to your sound source. You know the drill, set volume and tone controls to max, then play the file. MAKE SURE to reset them when you are done!
    Flip the switch so that its lever is toward the component side of the SC board. You should be able to load a Starpath game into the supercharger and play it normally. If it crashes at any point, flip the switch and try again. I used Escape From the Mindmaster. It will crash just after the title screen if the switch is wrong. If that happens, flip the switch back and try again. The Starpath game should load and play correctly.
    Now flip the switch to the opposite position from the one that you played your Starpath game in. Use playbin to load Atari's release of Pac-Man into the Supercharger. Yup, non a non Starpath game just made its way into your supercharger! If the switch is in the correct position, Pac-Man will play normally (and it will still suck). If the switch is wrong, Pac-Man will crash as soon as you try to start a game.
    If it passes all the tests, then you're ready to reassemble the SC. Ensure that the switch, the audio wire, and the SC board are in the lower part of the case correctly, then carefully close up the SC like a book. Tighten down the nut on the switch, then replace the screw. If you peeled the label off, cover the entire area with the stick glue and press the label back into place. If not, you might throw some paint on the screw head to make it match a little better. Mine's still silver.
    That's it! thanks to Bob Colbert, batari, Chad Schell (for his work with the Cuttle Cart and getting the audio files into both it and the supercharger) and anyone else who's worked with the supercharger to make this mod possible.
    I used this method of modding my supercharger and It works great with no glitches. used a 5k resister. great mod. thanks
  12. There are different guts in those, too. I can't really explain it, but the earlier encoders used in the Driving controllers are very different from later ones. Later ones had all the guts inside a plastic enclosure. Also the contacts on early ones had a tighter feel to them.
    Of course, the eraly Driving controllers and Paddles had Atari or Sears logos on them.
    I wouldn't worry much about the guts of early paddle controllers. You might wind up replacing the pots someday, so it won't matter what was in them to begin with.
    Thanks for the info. much appreciated.
  13. Looking for some games for a friend to start collection. he has a system but no games. If there's some doubles that's ok as I can use them to help sell systems on ebay. any help would be great. let me know what you have. thanks
    I've got a lot of 150 different games (labels, etc)
    And I have one of 80 or so games.
    I have plenty of extras on top of that as well.
    Shoot me a PM.
    pm sent
  14. Link to a mod that doesn't require the IC. All you gotta do is run down to Radio shack and get a few resistors, a couple diodes, a switch, and some wire. You can also get a jack if you want to do the audio hack.
    No waiting for parts to arrive in the mail! :)
    Almost forgot, there are several mods in that thread. Mine's about halfway down the first page.
    EDIT 2: You'll need a program called wplaybin to "play" the bin files into the supercharger. This is on Bob Colbert's page, I think. Works with his mod and mine both, and it should work with the hacked files that Wickeycolumbus linked to.
    If you use wplaybin on windows xp it doesn't work. My buddy White Wolf found this program that works great. http://schells.com/cuttlecart.shtml
