6,812 -
Posts posted by arcadeshopper
10 hours ago, RickyDean said:Well for you Foundation Z80 card owners, I may have finally gotten the OS for us. In the zip find a dsk image, in Kaypro II format, called MRSBootCPM.dsk, I used my DeviceSide FC5025, and cut open the disk envelopes and finally got one that would read. I then read out the other disks that came with it, included in the package. Someone try this and let me know if it boots your Foundation card, when you follow the manual. You can probably test these disk images with a Karpro II emulator, maybe in Mame. Please report your findings.
kaypro ii in mame says 'invalid image'
you have the same folder open in both sides.. select the disk image and open that in the other side
4 minutes ago, GDMike said:I saw that, but I didn't know how to do the copy part.. thx.
When I'm done, do you want these files?
These are what beery supplied
you select the file on the right side in my example, and right click, and pick COPY FILE
8 minutes ago, GDMike said:I tried, I used TDIR and either it doesn't do that or I'm not seeing it.
Thx for the response
sure it does.. first you make a disk image under the file menu, make sure you make one your controller can read.. then you open that disk image on one side, then you copy the files from the other side over to it..
27 minutes ago, GDMike said:I looked at these files and there 8 and 9k bytes.
And gotek doesn't recognize them.
My EA disk that was converted and is seen and used on geneve module loading is a 180k dsk file.
Do you know how to convert these?
gotek only works with disk images, copy them into a disk image
yes no twists in the cable.. a lot of PC cables have twists.. TWISTS ARE BAD in the TI..
If you have JUST the gotek plugged in, set it to d0 and it should answer to DSK1.
this reminds me of the issue with facemaker and finalgrom99... if you have anything else plugged in you get graphics corruption
Is the cable straight through?
Sent from my LM-V600 using Tapatalk -
Nice work!
Sent from my LM-V600 using Tapatalk-
You are welcome to upload it at thekeep.net
Call tipi("HTTP://ftp.whtech.com/TIPI/MXT")It can print but it's 40 column and no ansi
It can print but it's 40 column and no ansiTIPI's TELNET is a proof of concept/example program so people can see what is possible with the TIPI TCP support... And a PI fixing tool in the event of desperation.
I don't BBS, so it isn't ever going to be a priority for me. But the source is available in the examples section of the github repo.
I've heard Beery has TCP enabled some other term program. Maybe it is more feature rich.
I have belts and cables and disks to use that with a trs80 model 100-200 in my storeI just clicked the 'buy now' button on a unique bit of kit.
Specifically, a unique floppy drive.
(More information, for those needing more than just the product manual.)
(I happen to have a Brother electronic knitting machine that uses them, that is lacking the drive. I decided to finally get one.)
It is a (potentially, it also can use a wall-wart power plug) battery operated FM encoding 3.5" diskette drive, that communicates on a modified RS232C interface. It is one of the short list of devices I have considered suggesting in the various CC-40 accessories threads in the new subforum, (and as the topic has come up). Given that its communication system is so simple, a micro controller could easily sit between it and a CC-40, turning it into a swanky hexbus compliant disk system. Since such projects have recently come to exist (with FOSS code for microcontrollers to communicate with hexbus master controllers in the wild now), and since I just ordered one, I thought I would bring this up again. (Granted, it only holds 100kb/disk, and likely uses 720kb diskette media, but it isn't like the CC-40 is a powerhouse of spacious RAM to put data into to begin with.)
Now, I have no intention of using it in that capacity, since I DO happen to have a perfectly good knitting machine in need of the drive.
I do not have a CC-40, nor a hexbus interface
for my 99/4A-- But this is the OT thread, and the OT is that I purchased one of these drives.
Nope other than the old screen capture trick with load interruptAny way to capture a screen to printer with telnet? That would be so awesome when BBS'ing.
21 hours ago, cobracon said:Thanks! Off to look for a new wifi modem. What would be the best term program for my setup?
think I list those in the FAQ..
On 3/10/2020 at 7:31 AM, pixelpedant said:This is something I’ve kind of wanted to have (or otherwise, to make) for a while. Which is to say, a good TI-99/4A “soundtrack” which is in effect just a collection of longer uninterrupted and continuous musical compositions (hence, almost inherently, title tunes) for classic TI-99/4A games. Especially Alpiner’s, Midnite Mason’s and Protector II’s title screen music really made an impression on me, back in the day. So good I barely wanted to leave the title screen.
In the present day, there are homebrew games and demos which are absolutely killing it, when it comes to TMS9919/SN94624 musical compositions. But I wanted to revisit some 80s era classics first. I can definitely see how a “soundtrack” of the best of all eras, or the best of the modern era, would be desirable, though. Including glorious stuff like Bouncy’s Obstacle Course and Flying Shark and Tursi’s Mega Man 2 conversion and what have you. But that feels like a different category from what are, in these cases, mostly PSG translations of classical or traditional music. I also didn’t include any jingles or fanfares or otherwise very short compositions, here. Or any which I simply don't find very listenable.
Title List in play order:
Alpiner
Anteater
Jawbreaker II
Midnite Mason
Mouskattack
Protector II
Slymoids
Arcturus
Blasto
Hustle
St. Nick
Driving Demon
Ambulance
Hangman
Hen House
Junkman Jr.
Rotor Raiders
Tombstone City
Tris
Yahtzee
Very cool, would be cooler with the music pieces listed
at least the ones that are not originals
I have them in stockJust played through it on a real machine. It's an absolutely playable demo with a few puzzles, and not too hard. A few glitches with the blood stains. The red potions give health and and green potions and the barrels give might (the ability to attack). You need to use the mouse or joystick to get and use the keys. I wish a had a TIPI so I could try the mouse interface, but it's supposed to work well.
22 hours ago, gferluga said:Thanks everyone for your answers.
However, my white PAL 99/4a, with blue power button, doesn't see the FinalGrom99 cart.
I can plug many TI cart, but not that one.
On screen (C) shows 1981
Any idea?
what does the side port look like? In the FAQ you can see the different versions between the original (brass) and QI (aluminum/silver)
Greg
You won't need most of that because I do it all for you when you buy the drives from my store
How about hooking up a modem or wifimodem with a serial cableHi all I have a nano peb and was wondering "what are my options for getting online". I have v1 with the 9 pin port.
Thanks
Pinout is the same as a pc
You should RTFM or load it in mame and check out there first
When you load gpl you have a menu selection for rompage
It's not serial it's a bus mouseI can't find a layout of Geneve connectors, I read the Geneve has 2 game adapter ports? A mouse port? So where is the mouse port. I've got a 2 button serial mouse? Not sure it'll work, but I don't know where the connector is anyway..
Look in the FAQ for the ports
Zoom-TI-99ers Pandemic 4A Club Online Virtual Meetup
in TI-99/4A Computers
This week is Sunday at 3 Pacific
