6,812 -
Posts posted by arcadeshopper
It's in the binary file encoded in ascii imho if you don't know what you are doing, leave it aloneSo what determines the name that appears in the list then? How do you manually alter it?
Sent from my LM-V600 using Tapatalk
Correct
The units are different than what I specified before given the software upgrade and removal of my hack to set paper dimensions from environment variable in IDK what unit... probably was dots. But at least I don't have to mod the software to change the paper size.
Ebay says NOS tractor feed paper was indeed 8.5" x 11" after removing the sides.
I have a genmod Geneve I picked up from bill in az and it has this loose cap right below the orange bodge wire.. I assume I need to put it back in there just confirming
Sent from my LM-V600 using Tapatalk -
For FinalGrom99 the filename needs to be 8.3 as stated clearly in the documentation.
Rename the files to be 8 chars but don't change the last char they need to be g and c for the grom and rom files
Sent from my LM-V600 using Tapatalk-
What you had before seemed to workI am trying to fine tune the PI.PIO, after updating the RWAP's main Printer2PDF epson emulation code. I had some page size numbers I was using before, but I don't recall were the source for them was... I'm wondering if anyone has US fan-fold '80 column' tractor feed paper and can give me a measurement in millimeters? Looking for the post-perforation-tear-off dimensions. The default length of the page for the converter doesn't seem right, and the default width seems a little narrow.
Searching the internet, there is some grey area on what the standard was, as standard US sizes changed as a result of the presidency in the 80s. Or so I've read.
I would gladly receive the same for typical tractor feed paper used in the UK as well, although I suspect the software has that right.
Don't use edge use brave
Thanks!
no nothing
rave speech is old, only a few around these days .. have you read the FAQ?
Clean your cart portOh I understand finicky protos, but the weird thing is that it used to work and now it doesn't. I haven't changed a thing with my setup, which is why it has me perplexed.
That cart is unreleased beta software at best. The fact that it works at all is a boon.
27 minutes ago, Tempest said:After a long time in not using my FinalGrom I fired it up again today and couldn't get Tutankham to work. Looking back on this thread I see I had this problem before, but now I get a scrambled screen regardless of if my PEB/CF7+ are plugged in or not. After the PLAYERS? screen it scrambles itself. Anyone else having this problem or is it just me?
BTW has someone made an updated rom pack that includes all the roms that have been added since 2017? I'm lost track of all the new ones.
nope go ahead and make one and attach it here and I'll upload it to whtech
1 hour ago, snume said:Yeah, I just couldn't bring myself to pull the trigger on a Lotharek with the exchange and postage but as soon as they released an HXC firmware for the gotek I hooked it up. Found a model and 3D printed a mount that let's me have a 5 1/4, a 3 1/2 and a gotek all in the original opening of the PEB. Loving it.
did you design this? is there a stl somewhere?
The 9918/29 can't display more than one foreground color per 8 pixels horizontallywait, are you saying your game can't show these images?
Post a photo of the switch
NopeHello all -
Just wondering: has anyone utilized the TIPI as a FP math coprocessor for the TI? Seems like a natural fit, passing arguments and results back and forth by means of the messaging interface.
Seems slow to use a hard disk as a fpu
Pm sent
8 minutes ago, Ksarul said:Note, you may still need access to 32K for the program to run. Not all programs run directly from the FinalGROM. Some are lobbed into the 32K memory space and executed from there.
there is no may.. dm1000 and dm2k both require 32k
11 minutes ago, BeeryMiller said:I couldn't get a transfer to complete without an error..... This is Windows 10 Edge.
Opens fine here.. win 10 Adobe reader dcI'm looking for several things.
The Myarc Advanced Basic PDF on ftp.whtech.com under the Geneve folder appears to be corrupted. Can someone please confirm? I've tried loading on 3 different computers without success and hopefully someone has a good scan some place. I've got an original unscanned, but looking for a good scanned version.
Second, I am looking for the software manuals for McCann's software The Printer's Apprentice and The Geometer's Apprentice, both for MDOS.
Any help is appreciated.
Thanks.
16 hours ago, TimsterAA said:Hey there... Sorry to hijack this topic, but doing a web search landed me on this message in this thread. 🙂 Two questions if I may: is the DM1000-v61 bin file you're referring to here "Disk Manager 1000", and if so, is this working for you off a rom cart? I have a FinalGROM99 and I'm looking for a copy of this that's compatible to use with it. If this is it, do you have a link to where I may download it or maybe you could share it here? Thanks in advance.
files for those are here: https://atariage.com/forums/topic/253095-🖥-flashrom-99-finalgrom-99-repository-01012021/
Corey says he fixed it..
sorry bout that, was out of town this weekend.. it's updated as of this morning on the store
Chess and chatti worked fine until just recently so maybe something in your last release or so or he changed something on his server I've let him know as well
Gotek Drives
in TI-99/4A Computers
It's as much plug and play as any disk drive is.. you have to use the proper cabling and drive select a gotek can only be drive 0 or 1 and you obviously can only use disk images of the format that your controller can read
