6,812 -
Posts posted by arcadeshopper
BBS The Documentary for those of you that need to know what you are clicking on before clicking on it
Guys, check out this 3D printer on Kickstarter right now.
Cool, long as you don't mind waiting till 2015 for a printer
anxiously awaiting the after-pics
Well, the CF2K version is the one I downloaded and included in the Rom so far, so we're good there.
How many versions of CFHDSX do we need?
Gazoo
Probably just Fred's if it works with all versions like it says
more ideas:
remind me
saver
I could only find one version, v1.2, on Fred's website. So that's the one I used. Let me know if I need to change it.
Gazoo
Jamie has patched the software version of HDX1 to work on the new nanopeb2
malilonj via yahoogroups.com
Aug 9 (4 days ago)
I have posted this application at http://webpages.charter.net/nanopeb/.
Documentation is under the works. Also, I'm looking at TELCO for conversion.
Also cf2k is now supporting it as well:
Hi all,
An updated version of Cf2k v2.2 is available here:
http://home.vodafonethuis.nl/fgkaal/
Cf2k searches the DSR for a printer port.
If it find "PIO." it is a Cf7+
If it find "SIO." it is a nanoPEB
If it find "COM1." it is a nanaoPEB2
Could not test it myself (yet), but if a nanoPEB 2
owner will do this and post the results I would
appreciate it.
enjoy,
Fred
(reposted)
I've added CF2K and looked at CFHDX. There are 2 versions of that, P and S. Should I add both, or do they function the same?
Gazoo
Serial vs Parallel,, nano serial, cf7 parallel.. nobody is using the parallel version as it stopped working with the surface mount vers of the cf7 only the very oldest work right.. btw there are two versions of the serial version, one for 9902 and one for 16550 com1 version
Greg
A couple of questions....
1. Do you use your TI for "real" world applications? (do you use it in your work?)
2. What computers do you use in your work? (Mac or PC?)
3. Desktop, laptop/notebook or tablet?
My answers:
1. Do not have a TI
2. Mac and PC
3. Desktop for serious GIS and Image analysis, MacBook for lighter GIS work, Laptop for Linux experimentation, and tablet for mobility.
1 - no not anymore used too but not since say windows 95 years..
2 - PC with linux or windows 7
3 - desktops and android tablet
1. Do you use Linux?
2. If you do, what distro?
3. Do you emulate the TI under Linux?
My answers:
1. Yes
2. Gentoo (mainly) and Ubuntu.
3. Yes, the java based v9t9 and dosbox for pc99. Havent used MESS under Linux as yet.
1. yes at home and at work
2. Xubuntu for desktops Centos for servers at work
3. Yes mess64 works great, also have classic99 in wine
Gives me more hope....I have a feeling if you want a professionally looking built one, we could take one of the Amiga ones and put a different end on it:
http://amigakit.leamancomputing.com/catalog/product_info.php?cPath=21_72&products_id=226
You can buy scart connectors off ebay.. I had to get one to make a cable since the geneve required an external 3v power supply to select rgb on the scart.
Let us know if you ever try the HDMI converter with the Geneve, and what model it is. Also, does it stretch the image, or provide black bands at the sides for the proper perspective?
Gazoo
Looks stretched on the amiga.. fills the screen horiz.
You only need to do the unlock sequence for the F18A, and the scrolling is done via a single VDP register update. You would just need to divide your time between tile-level scrolling by 8 and update the horizontal scroll reg accordingly.
Assemble and run the attached program on and F18A enabled 99/4A. :-)
Get a Dallas (Maxim) NV SRAM chip to use instead of the EPROM for testing. They are a little pricey ($13 each I think), but worth it for development work. They are and SRAM with the same pinout as and EPROM, but have a built in battery that lasts 10-years from the last time the device had power applied.
http://www.maxim-ic.com/app-notes/index.mvp/id/4006
http://www.maxim-ic.com/datasheet/index.mvp/id/2648
http://www.digikey.com/product-detail/en/DS1230AB-70%2B/DS1230AB-70%2B-ND/1130311
But I only see a 256K-bit and 1024K-bit, no 512K-bit :-(
is it programmed like an eeprom?
woowoo factor 10
useability factor -1
cool find-
fyi I received notification these were shipped last week. Eta 14 working days
Last few stragglers should send in their payment for their orders please!
I have a CF7+ and have not had any problems myself, then again my use these days is generally limited to running F18A test programs from the E/A cart. However, it looks like this is panning out to be a slight PEB vs. CF7+/Nanapeb difference.
The OLDER ones don't have any issues.. It's the newer models that I have seen the problem with. (com1, v2 etc)
I've had some issues with the NanoPEB with the f18a.. turns out the sidecar looks for vdp a few milliseconds before the f18a is ready.. Jamie is working on a new model to fix this that delays the nano a few more to time it right.. Might be the issue if you have weird assembly issues.
Greg
ti99pc creates archives on the pc
I have had good luck with the SCART to HDMI adapter on my amiga.. that might work for the Geneve etc with a SCART cable. I made one for my Geneve to use with the samsung 910mp
Thanks! Also to everyone else who replied.
Got them working nice.
So, now I have this thing out and running, is there any other more recent games I could create disks to play?
What ended up being the issue?
For the Bandit disk, use the Extended Basic Cartridge. At the Extended Basic prompt, type RUN "DSK1.LOADBAND" and press enter to run the program.
For the Munchman ll disk, use the E/A cart. Press 5, and press enter at the prompt. This will load DSK1.UTIL1 and run the program.
Let us know if you're successful.
Gazoo
If you don't have an EA cart you can use a EA loader for Extended Basic to load it.. There are a few out there.. Funnlweb is a good easy choice.
Greg
I don't really remember much about how to use my TI-99. I have a PEB with the memory expansion and a DSDD (360K) drive installed in it.
I use a windows98 PC and ti99-pc to write images to floppy disks. I have an old Adaptec scsi card in the pc that has a floppy controller on it.
It can do SD disks, no troubles.
So, I use ti99-pc to make disks for Munch Man II and Bandit. The process goes OK, and I can catalog them with TI99-PC and I see the files on the floppies.
TI99-pc says they are both 180K DSSD disks.
When I put the disks in the PEB with Extended basic cart, I boo the system and the disk light goes on but I'm only greeted with the Basic prompt.
I tried to catalog the disks using my Disk Manager cart, but it is version 1.0 and I don't think it works with double sided disks...(?)
I have an editor assembler cart, but I don't know how to use it really...
I'll attach the DSK files here in a zip. Maybe someone can be so kind as to look at them and tell me how I might get them running on my TI?
Thanks.
Is your disk controller TI? or Myarc/Corcomp?
Try formatting the disks on the TI and then copying the files on the PC to them. The PC drive may format them in a way the TI can't read. The TI controller is capable of max Double Sided/Single Density
Any disk manager will catalog any disk as long as the controller can read it. The catalog program in the disk controller manual will work in extended basic.
Best disk manager is DM2K, also on whtech in the fkaal directory or off his webpage..
Greg
I totally agree, I had a great time learning about FPGAs and HDL while doing the F18A. However, as soon as you say "yeah, I'll make them available...", you go from a hobby project to having to provide a finished product, complete with packaging, a store, instructions, support, etc. Before you realize it you are in way over your head, and providing a *product* is not very easy.
You do an excellent job too
Anyone expecting to make a profit on TI hardware more than a few bucks for your trouble is dreaming
or sitting on a large supply of Gram Kracker's Greg
There are two problems with your idea really:
1. The RAM on the F18A is not external. FPGA's typically have internal "Block RAM", and in this case the FPGA I used had enough to cover the 16K of VRAM, line buffers for the video generation, and 2K left over for the GPU's use. I can't simply add more RAM without making the board bigger, redesigning the board, increasing the part count and cost, etc.
2. You assume I'm earning money on the F18A and that it is lucrative. I'm making "tens" of boards, not thousands or millions, so I hardly get bulk discounts on anything and I have to front a lot of cash to just reach the minimums on a lot of things (like having circuit boards made, etc.) Contrary to what most people think about the demands for retro-hardware, the global F18A market is *maybe* 300 customers, and I have not even sold 150 boards to date (and I started selling in 2012). The cost pays for the parts and a little bit of the labor to build the boards, not much else. You better *really* want to do a retro-hardware project for reasons other than money, because you will not get rich off of it, or even make a living from it, and if you are lucky you will break even.
HDX pre-order
in TI-99/4A Computers
Arrived today!
