251 -
Posts posted by humeur
cable between TI99 & X10 ?
merci de ton scan mais ce qui me faut c'est la liaison au ti 99 via la port joystick et k7
jean louis
I seek the wiring of the cord going to the X10 Package TI99
if you have a schematic
thank
jean louis
use module ti diag for testing if your ram broken.
jean louis
i confirm this a vram is broken
jean louis
If you have cc9900 micro expansion broken i buy this
jean louis
i write just 2 basic by mechatronic,
if exist actually most which two basic of course, also LOL
jean louis
it also exist the 2 basics from Mechatronics : Mechatronics extended basic 1 & 2 , Extended Basic II Plus
no just two
Mechatronics extended basic is a same of ti extended basic
and the two is apesoft Extended Basic II or apesoft Extended Basic Plus is a same
jean louis
OPA announced a TMS99xxx processor plug in for the console in MicroPendium with 12 MHz operation speed. As far as I remember the board should be clipped just over the 9900. I ordered a TIM and hoped to buy these device too, but the TIM was not shipped to me and the 'Speedboard' was never released. A few days back I was looking for the SBP9989NL (4.4MHz, 64 pin, 16 bit data bus, 9995 instruction set, 128K ram addressable, ... ) on the internet, if it might be a replacement for the TMS9900 in the console, but the price is exorbitant. So this is cancelled. There was also an advertisement in MicroPendium issues about a p-box card with a forth microprocessor on it, which promised a lot of speed. Sad to say that nobody ordered this card.
i have a SBP9989 a picture of this
the SBP9989 is I2L technologie is not a same of the tms9900.
jl
just Happy New Year 2012 for all
you and your familly
Jean Louis from france
hello
you have this computer is work with the 9995
look http://powertrancortex.com/index.html
and you have tomy tutor computer
jean louis
3 pictures of the TI LOGO II French
one Picture with Box is very very rare In France too.
Jean Louis ask humeur
I have many scsi card broken, i search a schematic have you this ??
thank
Jean Louis
Interesting. Unfortunately, now I have to learn French as well as TI Assembly language. 8^)
a same for me but in English
jean louis
look this
http://www.abandonware-magazines.org/affiche_mag.php?mag=87&page=1
this is a French revues of the Ti99
jean louis
you can also find hundred game listing here :
http://www.abandonware-magazines.org/affiche_mag.php?mag=7&page=1
very good weekly review, with full program for all sorts of computer.
jean louis
Well, having all the chips socketed makes the repair a lot easier, and does offer the option to brute-force the repair by swapping each part in turn until it works. Word of caution, there are a *lot* of variations of 74-series logic chips, so if you are going to attempt the repair yourself, make sure you buy *exactly* the same chip as the original, with all the same letters and numbers. For example, none of these are compatible, even though the numbers of the part number may be the same:
74LS04 74HC04 74HCT04 74LV04
There are more, but I think you get the idea.
use LS HCT, HC is cmos technology no compatible with ttl signal level .
jean louis
Omni flop with Xp work fine.
Jean Louis
floppy drive speed can be changed, on certain model
jean Louis
I have a couple of TEAC drives which have this ability. I am patiently awaiting the next run of KryoFlux boards, and especially software with WRITE capability; any idea when this will happen?
you want to change the speed of your drives ??
jean louis
jean Louis
I wish much to realize it!ehm...
I want to realize it a lot! (so it's correct!)...By jean louis:
the tms2532 of texas instruments is not a same of 2732, a11 is pin 18 of tms but a11 is on pin 21 of 2732.
@ jean louis: But for use tms2532ajl, what is the binary address I have to start program? Do you know I need an adapter for my programmer to ability it for those eprom series? Or it's impossible with my programmer? Thanks!
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4312
i have look your documentation for your programmer
read juste read the tms2532A
read and write the tms2532jl
are you sur of reference of your component.
have you erase your EPROM 20 minutes ??
jean louis
I always wanted one of these carts--- never found one though.
if I find one I'll contact
jean louis
I also read that the mechatronics official dealers proposed the Supergraph upgrade from the Extended Basic 2 card, in modifying the cardridge directly in shop... ( free eprom slot inside or eprom swap ? ).
I do not know this things about Supergraph upgrade... sorry...
this is the internal cart of one of mine XBII
for upgrade change the n82s23 prom for adress decodage, and change one rom.
the prom is not more easy to find.
jean louis
HI. I'm new. I'm Italian and Excuse my English!
I like reprogramming Atari 2600 cartridige and restoration them. But I've a problem with EPROM TMS2532Ajl (The only easily findable after 2716 or 2732 series)
I use GQ-4X universal programmer (Willem derivative) and it supports these TMS2532JL eprom series. The utility is GQ USB Prg Re6.00. It read them and the blank check and verify are ok.
I load games.bin, I click on "write eprom" but when it reach at 4% of the writing process, I gives me the following error: "write failure, Adress=0x000000, Buffer=0xE7, Device=0xFF"
.What is the mistake?
jean louis
X10 cable Help
in TI-99/4A Development
I search a schematic of the cable X10 interface for the TI99 i have for exchange the schematic of the quick disk of mechatronic
jean louis
