Richard H.
    1,149
Posts posted by Richard H.
  1. As a side note, does anyone think it might be worth making Atari memory cards? Basically a speechless AtariVox?
    Alex, I'm way ahead of you on this - I have them made already, just waiting for the prototype boards to come back for testing.
    Also, I think I've got around the 2 player problem (because it plugs into the second port). I can't see why the memory card can't be inserted on power-up and then removed when the settings / scores have been downloaded, then inserted again to store new high scores.
    A message on screen saying 'insert mem card now' or something, where as you'll just swap joystick for card.
    I can't see how this could hurt the console - what do you think ?
  2. even had some folks on the [stella] list look it over
    Bob, I just read your stella post about being able to read the EEPROM from the interface after MGD had written to it etc, and just realised what the problem is.
    It's your cable.
    It's either too long or not sheilded enough (12C comms are picky). It works with the interface because the AtariVox is plugged directly into the unit (like the new cased AV).
    Try a PC serial cable instead of the sega extension.
  3. So I kinda wonder if my AtariVox is screwy or something
    I'd test it, but I don't have my console at the moment (a friend took it on holiday :( ), but have you tried replacing the EEPROM (it's in a socket) ?
    To test if it's bad, hook up the PC interface, write a 32K file to it and then verify it back.
    If it is bad, 24LC256 serial EEPROM's are available in pretty much any electronic store (for about $2).
  4. I've been working on a couple of sound progs myself, nothing fancy though
    VoxPlay1 - uses the pre-set sounds
    VoxPlay2 - uses the 5 channel synth (not finished yet)
    If you put some offset values into the other channels, it produces a quite nice doppler like effect.
    Both are for use with the AtariVox and PC interface, and use serial port com1
    VoxPlay1_2.zip
  5. Where's the "I would most likely never purchase such an expensive device with such incredibly limited application" choice?
    Feel free to make something better / cheaper
  6. Would that include games that had any use of it?
    I suppose a game which makes any use of it, whether it be the EEPROM, sound, or both.
    Talking of EEPROM, I'm thinking of making just a mem-save unit without the SpeakJet for folks who only want this feature.
    Also, for high-score saving, how many games can the AtariVox save scores for at one time?
    256
    Is there a risk of some other AtariVox game erasing the scores for another?
    No - that's why I setup this page - memory allocation table
  7. Is this version (stella adaptor case) available yet?
    Not quite yet.
    I was all set to send the final PCB design to Albert, when I noticed the volume control was anti-clockwise increase instead of clockwise increase :roll:
    So I've re-done the layout and had 5 PCB's made to confirm (which'll be back early next week).
    I'll be keeping one of them and sending the other 4 to Albert, so you should be able to get one in this version.
    As a stroke of good luck I'd socketted all the chips on the first batch of boards, so it'll be an easy job for Albert to transfer them to the Stella case version PCB.
  8. Any update on this? I should be able to write something for OS X users to use this.
    I've got a few PCB's of the new PC interface coming next week, I will send you one of them.
    (PM me your address)
    It's the least I can do if you're going to write an OS X driver :)
    Like the new AtariVox design too
    Thanks ! - those Stelladaptor cases are pretty smart
  9. Does he have more of the sega extensions available?
    He had a few hundred when I bought mine late last year, and being such an obscure item, I'm sure he'll have plenty of them left.
  10. If anyone is interested, this guy has 250 brand new Atari 2600 foot pedals @ 2 Euro's each ($2.59) -
    Friedrich-Karl Weide
    Euro Electronic Trade GmbH
    Rheinstr.5
    D-42697 Solingen / Germany
    t: +49/212/221140
    f: +49/212/2211490
    Email :- [email protected]
    I did a deal for some Sega extension leads a while back, and he's a really good guy.
    He also has new old stock of other console stuff, including quite a large selection of Dreamcast titles.
  11. .......I've re-designed the AtariVox PCB to fit into a different case (see pics). I was looking for ages and ages for a suitable case, found one, and it turned out to be the EXACT same enclosure as the Stelladaptor :roll:
    Anyway, the board fits snugly into it, and now plugs directly into the joystick port on a 2600. It won't fit the 7800 due to crap angle and case obstructions of the port, (a work-a-round is to use 2 9D gender changers).
    I've made the volume control accessible through the jack socket hole, as these cases are REAL pigs to get apart once the 2 halves are snapped together :x
    I'm currently re-doing the AtariVox PC interface PCB to fit a case from the same range, so they'll look pretty nice together.
    BTW if anyone want's the old version (which fits a case with speaker) I know Albert has a few built units and PCB's left.
  12. The AtariVox 32K EEPROM memory is split into 2x16K blocks
    The first section is the Static Allocation Area
    It contains 256x64byte pages for specific games to use, this way a saved high-score from one game isn't over-written by another.
    so when the atarivox games come out they will have a PAL version as well as the NTSC
    The first page in the SAA is reserved for TV settings (PAL, PAL60, NTSC). So once you've selected your display settings, the game will alway start in that mode automatically (see MGD for a demonstration).
    BTW new games have to be written, or old games hacked, to work with the AtariVox.
