3,127 -
Posts posted by AtariGeezer
On ebay, you have to look a few times a day. I've bought alot of stuff really cheap. Loose Assem-Edit carts for under $15.00 w/free shipping. A 600xl for $20 w/free shipping and so much more...
1 minute ago, Faicuai said:Basic-XE extension problems has been already identified (floating bus-data on $D013) and sw-mitigated with targeted patch for the library. In fact, I am running BasicXE with OSS extensions 4.11
Where are the tests (and root-cause) of Bit3 malfunction on Incognito? Do you know the link or reference?
Where is the Basic-XE extension patch? Haven't seen tests of the Bit3 malfunction. My Bit3 has been boxed since I installed the Incognito.
For me it's a toss up of (8.5) 800's, (8) 810's and (10) 1050's...
The Bit3 incompatibility of the 800/Incognito was mentioned awhile ago. The other issue is not being able to use the Basic XE Extension disk.
Hmmm, got a green one, should I get the red one too? 🤪
Just tried the external SIO2SD and I see that error...
3 hours ago, manterola said:Thanks for the ESP-32 Flasher... it is great.However, by having the esp32 in the SIO Bus, all communication in the bus is disrupted so I cannot boot any terminal program from my disk drive. If I turn off my drive, the esp32 device does not boot by itself.
Thanks again
Have you tried booting off the SD Card yet? CnfgTool.atr in Root, all others in ATARI Folder...
I only use SPIFFS for storing the WiFi Settings.
7 hours ago, manterola said:So the question is: how to program the esp32 with your firmware.
Just tried this tool and it works: ESP-32 Flasher
9 hours ago, flashjazzcat said:If you have the newer Incognito firmware with the built-in Hias high speed SIO driver enabled, you should be able to max everything out at divisor 0.
Okay, I'm still using Candle V2 Bios. Need to update that soon
Does it require the Cpld V3 update for that?
23 minutes ago, DrVenkman said:Where do you get that from?
Just guessing since I did have a problem with SIO2SD at the faster baud rate, thought it might be related...
The SIO2SD runs better using firmware 2.5 on the 800, RespeQT would need to use a slower Pokey Divisor...
Atari WiFi Modem v0.3 update.
This update includes support for SIO2SD, plus more Hayes AT Commands that allow comm programs such as FoReM XE BBS that test each AT command for a valid response in text or numeric format depending on V0 or V1 settings.To configure the SIO2SD, you'll need to place the CnfgTool.atr in the SD Card's Root Directory. Then when you power up the fujinet board, you'll see the blue LED light up for a few seconds before it goes out. You have to press the Program/Flash Button before it goes out to boot the cnfgtool.atr.When the Atari WiFi Modem has completed it's Initialization, the blue LED will blink twice...After booting up your Atari, you can press the Program/Flash Button to rotate Drives 1 to 4. The blue LED will blink indicating which emulated Drive is in Slot #1. So the first time you press it, it will blink twice indicating D2: is now in D1: ...The SIO2SD supports up to 8 ATR / XFD images that can be configured using the CnfgTool.atr. After DOS loads, press L to load a binary file, then SIOV20.XEX...Today I connected to Kyle's BBS using Bobterm 1.22 and was able to download a 16k cart file @ 19.2k successfully
Jay-
10 hours ago, mimo said:selling my 1450xl motherboard was a big mistake, so I would like that back
If I ever decide to sell it, you'll have first dibs
An 815 and a floppy board for my blackbox. Already have most of the common stuff. Still have the 1450XL
9 minutes ago, bob1200xl said:Bob Woolley did a simple hack that allows you to hook up a PC monochrome monitor to the XEP80. I think it even got published in Atari Classics magazine. Probably in the SLCC Journal, also.
Bob
And my post below it...
Should be ok now.
On 1/17/2020 at 2:40 PM, JohnPolka said:I actually found that the latest version of BobTerm performs the best of the bunch at 9600 baud. When I used the Express Cart! to connect to Part-Time BBS and the Basement BBS, I noticed some buffer overloads with some of the ATASCII screens/movies. Another good test is the 'W'ho's called command (which dumps the last 50 callers to the BBS).
-JP
I get complete dropouts with bobterm above 2400, which version are you using?
On call logs, don't all callers show a connection at 9600 baud when using the lantronix devices on the BBS???
Good news
Tonight I'll be testing the APE Time code I've added a few days ago, the Server code is ready for testing a BBS and in a couple of days I'll have a companion ready for a BBS Server / TNFS Server or what have you. It's using the onboard SD Card as a SIO2SD device that will have 9 virtual drives and can use the Flash / Boot Button to rotate drives
iTari Game Console
Thought it might be a tad bigger than what you planned for...
