Ksarul
+AtariAge Subscriber
    6,647
Posts posted by Ksarul
  1. The cartridge pictured was manufactured and sold by Navarone (I have one). Tenex sold a lot of them, along with the other game cartridges they released. Later, DataBioTics also released it (they had the rights to do so with Navarone titles after Navarone shut down), but released it under two names: King of the Castle, and Escape! The earliest (and rarest) cartridge release was by Exceltek.
  2. The failure with the 2732s probably had another cause: programming voltage. I'm pretty sure that the TL866-II lost the ability to program 21V chips. For those you would need a TL866CS instead. You do have to be careful even there, as early 2732s require 25V, but most later ones seem to be tolerant of 21V and all 2532As are 21V chips.
    On the adapter, I haven't seen any 2732 to 27C128 adapters either. There really hasn't been a need for such, as most of us can program the 2732s.
  3. You could zip it and put it up here, Alan. Then we can get it moved to the other TI repositories (like the WHT FTP site). It is good to see you are still around! I bought one of the early versions of FORTRAN99 (V2.3?) and later upgraded it to the FORTRAN99/9640 FORTRAN issue. I had a lot of fun with it. . .
  4. Typo-II was released by ROMOX. It is a bit uncommon as ROMOX cartridges go, but not especially rare. They come up for sale about once a year on average. A normal ROMOX cartridge (most of their titles) would sell for between 15 and 30 dollars depending on condition, this one would sell for a bit more, probably between 20 and 40, again, based on condition.
  5. Since it has a GROM, you could put it into an UberGROM cartridge to make a standalone cartridge out of it. You would just have to load the data into the appropriate number of the Atmel 1284P GROM slots using a programmer capable of writing to it. That would make a permanent cartridge of the program.
    • Thanks 1
  6. If it will load into the FinalGROM, it will work in an UberGROM, you just have to take the ROM portion and burn it into the 512K flash chip and then properly place the GROM files into the UberGROM. This process creates a complete image that can be copied, as you only need to build the image once. @acadiel has extensive experience creating UberGROM images, and may be willing to help here.
    Note, I suspect that the original request was for a means to use the program in ROM-only mode, which isn't an option based on the need for GROM space in addition to ROM space--and in this case, you also don't have the option of lobbing the GROM stuff into the 32K space, as that is actually being used as User space by the program.
  7. It is interesting and odd that the older equipment has higher quality output--but it isn't really surprising. 20 years ago, scanners were in the feature-war mode, so lots of good ideas were tried out. Now they are more commodity items as part of a multi-function printer (and generally of lower output quality). Hopefully, the issue will be resolved soon and your wonderful scans can continue. Many thanks for all you do!
  8. Fabrice, on the chips, you might want to check Rochester Electronics. They are an authorized OEM for a lot of discontinued chips from other manufacturers, making certified replacements using the original chip dies once their supply of NOS chips is exhausted. Their prices are usually good on a per-chip basis, but their minimum quantities for a chip are sometimes very high (1,000+). I have an account with them and order a lot of chips that I haven't been able to find from other sources there (and it is good that they only supply certified original chips).
    • Thanks 1
  9. There are some issues here: the console power-up routines only recognize a limited number of GROM bases, and each GROM base is "technically" limited to five GROM chips (GROMs 0, 1, and 2 are in the console and are generally excluded, but may be used, as seen with applications for the GRAM Kracker, GRAMulator, HSGPL, and MaxiMem). The UberGROM board allows you to set up 15 GROMs (and 1 GRAM space), using multiple GROM bases of your choice. Similar multiple GROM-base solutions were also used BITD: the OPA POP Cart, the Guion-modified Triton Super Extended Basic cartridge, and at least one German multicart board. Note that even more devices emulate the 5-chip cartridge GROM space of a single GROM base (Wiesbaden Supermodul and Supermodul-2, TCB Modul, Karlsruhe Modul, Errorfree Modul, FinalGROM, TI EGROM cartridges, and others). So it has been done to some extent, just not at all matching your use case. The HSGPL card is probably closest, as it fills a 512K space with GROM data and switches context from module to module from a master menu.
