grips03
+AtariAge Subscriber
    4,338
Posts posted by grips03
  1. I made some twin sticks using total carnage setup and they work well.  I never had time to release/build more of them.  I will likely in the next couple of years.  Plan is use total carnage setup.  I would at least put that as option in your game as TC is pretty popular game.  I might (10% chance) add a second pcb/cable for this other game I can't remember the name of that forces the person to use both controller ports, but it gets super expensive due custom pcb / two donor controllers, etc.  Closer to $500 vs. a total carnage only twin stick being like $300-$350.  Plan is for both to have rapid fire 2.0 build in as well. Yes prices I know are crazy, but if others can build for less please do, shipping and low volume are killers.
  2. On 4/2/2021 at 7:25 PM, Gummy Bear said:
    Damn these look sweet!
    I'll definitely be picking one of these up at some point.
    I've been meaning to grab a repro Pro controller for a while, might as well get one of these RF beauties.
     I sell via eBay as well, which might be easier for UK.  I think I have 4 or 5 controllers left for sale.
  3. In general I would recommend either the stock gray keypad button controller or reproduction pro controller.  The stock gray is easier as the internal ribbon cable is much better.  I would pick which one based on the d-pad you like.  Don't use stock black keypad button controller, as the d-pad does not like the angles as much, so not good for games like Raiden.
  4. 15 minutes ago, intvdave said:
    All the code changes should be complete. The 2012 release had 6 screens. This release will have 35! This deserves a name change to....
    SUPER PRO KOTM!
    Some are speculating a CIB release. This will not happen. My audience is those that purchased the 2012 game and want to upgrade it or are interested in a ROM.
    Just let us know when to order.  And thank you for all you do.
  5. I have (5-6) reproduction Pro and (5) gray keypad button with RF.  So if you want a pre-modded controller let me know.
    I'll have RF kits for DIY modders to install, but won't be stocking pre-modded controllers.
  6. I have a reduced price rapid fire reproduction pro controller for sale.  Its in the picture below on the left.  Noticed the band where the cable comes out is missing one level at the top.  Its should have 5 like the right controller, but this one has 4.  Everything else about the controller is like stock.  I'm selling this one for $89 + shipping.  Let me know if interested.
  7. This thread is about me borrowing a console.  Which should prove if its my console or not.
    You think its the controller for some reason.  I think its not, do to using scope and never seeing what you are saying.  Only seeing one score removed, not all highscores.  Knowing that the gate only allows B to be changed, and the RF mod only uses pin column 3.  0 could not be produced by the mod.  If the gate on the mod board messed up it could produce B,1,4,7,*, it really can't produce 0.
    I would recommend you ignore the thread, as I think you are upset about someone borrowing a console, as they think their console might be broken as Al already replaced the cart.
  8. Just now, eightbit said:
    I would guess it is controller related as well. Lots of weird things happen with Jag's and faulty controllers. I had a six button controller not too long ago (new, from the AA store) that for some reason was mapping pause and a button at the same time. Al exchanged it and he confirmed it was a problem with the controller. If the game is checking port status and will erase EEPROM if it finds a specific button combo I would say that would be the first thing to check (the controller that is)
    You are describing a short on the ribbon cable connection.  Its common on the repro pro controllers due to bad soldering job.  This is not the issue here.
  9. I used a scope while developing the rf mod, so yes with a scope I never saw any strobing.  Also from your description it seems all the highscores would be removed, not just one.
    In earlier versions of Rebooteroids I saw beta testers reporting static sounds.  I'm not sure if root cause was ever found, do you know?
  10. Strobing is not possible.  RF code is written in such a way that the RF mod does nothing by default.  RF also only works on B button, not A button, this is controlled by a logic gate.
    When a highscore is deleted, it does not delete them all.  Example first time playing new cart Al sent I get 179K.  Send time playing I get 190K.  Now only 190K is only score listed besides the default one built in the game.
  11. Say it costs $20 or less to ship to me,  but I give them rapid fire 2.0 kit ($30) and install it ($20-30) for no cost to them, and then mail it back at my cost ($20 or less).  The way I see it the person doing the loan is getting a rapid fire kit installed for $20 or less and I get to see if the console is the issue.
    This is the only game the has strange static sounds and loses high scores.  Al replaced the cart and the game does the same thing.  I'm going to replace the power adapter and video cable today.  I already tried different speakers/amp.
    I compared to Youtube and it makes different sounds.
