4,338 -
Posts posted by grips03
I'm using the same encoder as juansolo, so my settings are the same.
I'm going to try that
Rebooteroids bonus stage certain is very slow with rotary. Does the game support switching between standard d-pad and rotary to overcome this? Otherwise how are people playing the bonus stage with rotary controller?
Thought I would share a picture of the controller I use for Rebooteroids, it makes playing this game much easier. Current high score is 160,580 (#31).
Normal B button is fire.
Right brown button (A) is thrust.
Left brown button (C) is hyperspace.
This way the pointer finger can hit thrust or hyperspace, which keeps the right thumb on button B.
The red button at the bottom is for rapid fire, which is not needed for this game.
Brown buttons are: ADTS25NV (Digikey). Held in with hot glue.
9
Adjusting trim fixed the issue. Not sure I like rotary control, but will spend some more time with it.
I built a rotary controller tonight using PEC11R-4015F-S0024 encoder (24 PPR).
However rotation is too slow in Rebooteroids game. I made Rebooteroids rotate rate the highest it could be and its still too slow.
I did not adjust rotary trim setting in Rebooteroids as I'm not sure what it does.
Would 32 or 36 PPR help to speed up rotation?
Is it expected that AA could fulfill the amount of the orders they have with the number of carts being sent?
Increasing color setting on TV helps. I'm going to try more TV and OSSC settings.
Does anyone else have TMS-RGB mod with OSSC? Can you post pictures of the colors with the above games? I'm most interested with Ms. Pac-Man.
I do have a spare Citrus3000psi RGB board, so might swap back to that and see if its any better with OSSC. My current Coleco with Citrus3000psi RGB is not so good. I think its the memory going again on that one.
Did anyone ever make replacement CV system boards?
For the Intellivision arcade controllers I use to make I used a Xilinx CPLD to convert what arcade buttons, joystick and keypad sent (common ground) to what the Intellivision wanted. The single AA battery usually lasted quite long with normal usage. Perhaps a passive one could be made, but at the time the CPLD seemed like the way to go. It would certainly cost less if power/CPLD was not needed. 16 directions is not really needed IMO.
I think people would like a 4/8 switchable arcade stick with built in keypad that required no external power, and perhaps rapid fire too
Thank you making TMS-RGB. The install is very easy to do. Very clean wire routing, solder points, etc.
I installed the TMS-RGB today and on the PVM it looks better than the Citrus3000psi RGB Colecovision I have
So I took the TMS-RGB Coleco up to the Sony LCD I use with OSSC and tried Pac-Man Collection. With Ms. Pac-Man the orange ghost and the red ghost are almost the same color. And the pattern for level 1 is orange. If I play PMC with F18a the pattern for level 1 is red. And red ghost and orange ghost are easily not the same color.
Anyway to adjust the colors on TMS-RGB to be more like F18A colors?
TMS-RGB board is from: Mobius Strip Technologies
RGB is cable is plain wire.
L9 has been removed.
First photo is TMS-RGB and 2nd photo is F18A. Both use the same TV.
One pre-modded O2 console left for sale.
Are the pads super fragile?
I noticed some use plastic knob and some others use metal. Which works best?
Also some are smooth and some have diamond texture. Which works best?
Right now I'm thinking of using: OEJNI-90-2-7 (Digikey or Arrow).
Diameter = 23.5mm
Height = 15.88mm
Metal / Diamond texture
or
OEJNI-90-4-7 <--same as above but matte black -
8 hours ago, chicgamer said:I can. Do you just want to see how it's wired?
Wired and where its mounted. I've wanted to mod a controller for Rebooteroids to see if I can get higher score. Does controller retain d-pad?
Can you post photo of inside of controller?
O2 console has (2) db9 joystick ports added to the front, Atari 2600 pinout. Cartridge connector is slightly out of position, but cartridges fit in perfect as the O2's cartridge opening more than accounts for this. Also tested with Voice Module and that fits and works great too. Voice module not included. Has one replacement rubber foot, see photo.
added 2 Odyssey 2 RGB pre-modded consoles for sale. photos coming soon.
Awesome!
To play as second character beat the pyramid or type the code. Its a one player game, its just another hero to play as.
Purchased used Odyssey 2. Charged $35 for shipping. Shipping on box was $16.25. Received $15 refund after complaint.
Odyssey 2 has aftermarket power supply, see picture. Was not told before sale.
Aftermarket power supply whines/hums, see video. Was not told about the issue before sale.
Aftermarket power supply has rattle, see other video. Was not told about the issue before sale.
Aftermarket power supply also had power connector changed, see picture with heatshrink tubing. Was not told about the issue before sale.
Seller reply:
"There's nothing I can do about the other issues." <--meaning the power adapter
Would not recommend buying from this seller.
I made a Rapid Fire kit for Atari Jaguar standard controller and Starwander (Reproduction) Pro Controller, see the development / sales thread below if interested.
Grips03
joined
Rebooteroids controller
in Atari Jaguar
New highscore, 172,740 (#23)
It was sort of cheap as I got to level 56 and the spaceship does not start in the center so I figured the level hung or something, but no, the spaceship was towards the top of the screen. So I died there once, maybe twice.
