Caterpiggle
Posts
957 -
Content Type
Profiles
Blogs
Gallery
Events
Posts posted by Caterpiggle
Show any software within ROM chips ?
failed to enter my initials name after the game is over ....
Does not response on my keyboard via Altirra . Not yet tested on the real hardware ....
On 5/16/2021 at 10:39 AM, atarixle said:
Name of that OS system on the screen ? I never seen this before ...
6 hours ago, www.atarimania.com said:
Would you be able to check whether the two cartridges below work with your system? They crash on a standard computer.
Why don't you add 1 wire on GTIA chip like another quote say, pin 3 and 10. Viola ! Bingo ! It might be work at this time !
- 1
Hello Skr,
I am using Window 10. Conjectural 2 Paddles into 1 port. Still failed. That paddles had been tested on real Atari 800XL , works great without any problems. Tested on Arkanoid II. Works fine.
Hello Phaeron,
Myself, why you removed the old features under DirectInput/XInput and move to Input Setup ? I did tried to follow your way, Input Setup. It does not make sense when I full turn 360 degree in my paddle. What I seen the arrow turn only right side area from top to down, that's it. Never show 360 degree, nothing. Buttons does not response at all. Yes, it is hook up my 2600-Adapter II device.
I did downloaded the latest version of this emulator and I still have big trouble how to play Atari paddles via my 2600-adapter II device. I did clicked all the possible input features. Still refused to work with my paddles. But joysticks works fine, that's strange ....
A little off point relates XC11 , does anyone who knew how to repair my broken flop door ? The door is broken off , recorder , itself is working great without any problem , just expect the door !
Wow , very particularly a piece of hardware ever I seen in my entire life ...
So this hardware just testing voltage , that's it ?
Sound like Dell Keyboard ....
- 1
Hello ColleenLover,
Why don't you order homebrew 3D Printer to make "U" kepcap instead ??
I almost forget about this case. No, I have not been digging into 1 of my boxes yet .... ? I wish I knew where it is exactly ! Your country is amazing that I had been visited there before ...
Not in Stuttgart but in Frankfurt am Main. Yes visited there in downtown.
- 1
It seems does not work on Altirra emulator. It just destroyed disk image of that 2.6 F. Nothing show a true speed , just appear as "XXX" on emulator. So I have to test on the real hardware Atari 800 with 810 disk drive.
- 1
Have an photo of replica exactly as on original cartridges ? I has only 1 original ACE80XL.
But I have seen this cartridge before. The label is different from yours. It has real full label compare to "Caution" etc ...It does works fine. So I already know what it is like in screen.
Trying to loading up on my Altirra emulator and it just hang-up in blue screen with 1 cursor. That's it.
Yes ....but I noticed someone on their YouTube and he order ALOTS of black rubber belt from CHINA ! I wonder where is might be ? for their 410.
thank you davebatari,
What about 1010 Hong Kong Version ?
What ? Are you talking something else rather than regular timing belts ? Just for idler wheel shown only ? In that photo, right ?
I apologies for misunderstand. Can you give an specific belts from Lowes that will work 410 & 1010 , regular 3 timing belts ? My apologies once again.
Thank you BillC !
Lowes is even better close to my home ! I failed to understand , how can this rubber belt is prefect fit into 410 timing belts (3 of them). Because those rubber belt is different width ! There are link in UK that offer for 410 and has different width ! How is possible ??? Care to explain.
A little off point , will those rubber belt at Lowes will also fit for 1010 (Hong Kong version) as well ???
Thank you davebatari ,
I will make a visit to ACE Hardware soon and get over with 1 of four 410 recorder and see IF it is works ! If it is works, then I will buy all rubber belts for 3 remaining !
Good evening davebatari,
Where did you buy this universal rubber washers ? At Home Depot ? I has four 410 are broken. Wow all of them are broken ! Easy to take apart inside and replace that black rubber belt above in your 1st photo ? I know there are 3 of belts. But your photo only has 2 rubber belts ?? SO do I have to buy 2 of them ?
What's the latest Atari related thing(s) you've bought on ebay?
I wish I would find mine own Fleet System 2 with diskette & manual somewhere in my place....
Difficult to make a good & prefect disk images with "bad sectors" ? Does your SIO2USB adapter not very helpful features to handle that kind of "bad sectors" ....
