2,596 -
Posts posted by johnnywc
Okay, I had a few minutes to run some tests:
On the unmodded RF 4-switch Atari:
1. If switching is disabled, the interference is greatly reduced to only a few sparkles when you move either joystick. The interference is the same whether or not DUMP_PORTS is enabled or disabled.
2. The distance of the circuit to the Atari does not seem to have any noticeable effect on the interference (when switching is enabled). I had it right on the Atari vs. 6 feet away.
On the AV-modded 7800, the circuit works perfectly and there is absolutely zero interference (the picture is crystal clear) and there is no interference when either or both of the joysticks are moved in multiple or different directions. This is consistent with what we saw in Nathan's original design that used multi-plexers; no interference on AV-modded Ataris. The interference is only on unmodded Atari's using RF.
I'm not exactly sure how to measure the ohms at the TV connector for the RF Atari. I have a potentiometer that I can measure ohms with but I'm not sure what I'm measuring across. Do I disconnect the cable from the TV? Apologies for the simple question!
51 minutes ago, ChildOfCv said:One other item to check: Could you verify that you get 100 ohms on the TV end of your RF cable? If it turns out that the output connector is the issue, then we've been spending a lot of time chasing our tail.
Will do! I know Nathan is seeing the same interference on his machine also so I don't think it's just my output connector but I'll check.
51 minutes ago, ChildOfCv said:Also, how close are your electronics to the Atari? Does moving them away help with the interference?
A few feet, I will test by moving the board (I have it connected to a 12 ft cable) and see if that makes a difference.
Thanks for the suggestions!
2 hours ago, ChildOfCv said:Yeah. The meter is probably averaging the voltage. I guess player 2 gets more select time?
Okay, that makes sense. Yes Player 2 gets 192 scanlines of select since I set DUMP_PORTS right after vertical blank is done and then switch to player 1 when I turn on VBLANK at the beginning of overscan, so that gets 70 scanlines. Doing some quick math, Player 2 is 192/262*5.0V = 3.66 V and Player 1 should be 70/262*5.0 = 1.33, which is almost exactly what I'm measuring.
2 hours ago, ChildOfCv said:Thanks
You know, I wonder if you should only be activating the dump during the vertical blanking period? Just for the fun of it, activate the dump port and the vblank itself at the same time, and turn both off at the same time. This will still give you the toggle, but would help to distinguish noise from the switchbox vs the possibility that the dumping is what causes the weirdness. Yeah, you can't effectively read the inputs that way, but let's see how it affects the video and work from there.
Good idea, I'll update my test program and see if it makes a difference. I already have the ability to turn off switching using the left difficulty switch and then I can use the right difficulty switch to have DUMP_PORTS be a constant 1 or 0. As I mentioned above, I'm activating the DUMP_PORTS right after vblank is over and turning it off at the beginning of overscan. I can switch this logic so I'm dumping the ports at the beginning of overscan and resetting it back to 0 at the end of vertical blank and see if that makes any difference.
2 hours ago, ChildOfCv said:By the way, did you say that this only happens on the 2600? Because I have an unmodified 7800 but not a 2600. I could do experiments on mine if I could at least duplicate the behavior.
Unfortunately I only have a modified 7800 so I can't test if the interference is there, but I will test to see if there is interference on the modded 7800. I have a modded 2600, modded 7800 and an unmodded 2600 which is what I'm doing most of my testing with.
Thanks for the ideas, I'll post my results soon.
John
Okay, I had a few minutes today and hooked up diodes (1N148) between the bus transceiver outputs and the Atari, with the cathode nearest to the transceivers. Since we're connecting the outputs of the 2 transceivers before connecting to the Atari, I assume one set of diodes is sufficient *after* the outputs are connected?
The good news is that the interference is reduced a lot, but there is still a good amount on the screen. Whats odd is that the interference is a white static line on the top of the screen and short lines on the bottom of the screen which is different than what we saw before using one of the direction pins (we used LEFT) as the select line where the static mostly appeared on the bottom and wasn't as pronounced.
I'm not sure if this was pointed out explicitly, but the interference is only visible with non-modded Ataris using an RF connector (there is no interference if you are using AV input with a modded Atari). Also you mention above about the Genesis controller; all my tests are using stock Atari joysticks.I'm hoping that maybe using a 74LS04 inverter will reduce the RF interference (if that is indeed what it is) based on that blurb above that I found on the net that suggested the LS vs the HC would be better for RF.
Another small point, and this may be a non-issue but figured I'd post my observations: When I do a straight-thru test (that is, just hook up the joystick directly through the Atari), as expected an open connector measures at 5V and when closed it goes down to 0V. This is also true if I pass the joystick input through a bus transceiver (x245). However, when I add in the inverter with the pull up resistor and have it switching between 2 bus transceivers, when I measure the output at the Atari for a direction it measures about 5V for open (4.98) but only drops to 3.68V when a switch on 1 joystick is closed. I assume this is because the value is rapidly changing from 0V for the closed switch on Joystick 1 and 5V for the matching open switch on Joystick 2?
EDIT: I just did a test with the button, measuring the voltage at the Atari pin 6. If both buttons are open (not pressed), it's about 5V (4.98). If both buttons are pressed, it's 0.56V (almost 0). However, if the button on the joystick that is triggered on pin 9 (select line) when it's low is pressed, the voltage is read at 1.67 volts. On the joystick button that is triggered on pin 9 being high, the voltage is 3.86V (but still registers as a low). Again, I assume these voltage measurements would be better viewed on an oscilloscope since the measurement at that pin is being changed 120 times a second (twice per frame) as we set and reset DUMP_PORTS on VBLANK.
Regarding the interference, it does get much worse when a switch is active (ie. you press the button or move in a direction) and more prevalent when you combine them. Also, the interference is greater when switches on the joystick that is triggered on low pin 9 (DUMP_PORTS = 0) are active vs. the other joystick.
Based on these findings, should we expect different results with the open collector bus transceivers?
I'm going to try with the octal buffers (x244) and see how the interference compares. Any other suggestions are welcome! I'll also pick up some 74HC05's as you suggested above.
Thanks again for all the help!
John
45 minutes ago, ChildOfCv said:LS and HC technologies seem mostly compatible, so I'd go with what's cheapest. HC is newer technology and more likely to exist in good quantities and price.
Great thanks. The LS are slightly more expensive but I found this blurb on the 'net re: RF interference. I'm not sure how accurate it is but for a couple bucks I'll pick up a few LS04's and see if it makes a difference also.
For the gates over-all:
HC is very ESD sensitive - in circuit and out of circuit, it will
'latch up' in circuit and fry.
LS is a power hog but it's hardy.
HC designs usually have 'richer' frequency content - so if RF
emissions are a problem go with LS if you can."
45 minutes ago, ChildOfCv said:Yeah either one ought to be fine. I'd go with the one that's in stock. I'd also consider using an inverting multiplexer with normal outputs, and going through 74xx05's for final output. It would be more chips, but less total cost.
Okay, I ordered a couple that were in stock and they'll be here by Wednesday. RE: the inverting multiplexer; can you recommend a specific chip? What does a 74xx05 do?
As for my progress, I did re-wire up the xx245 bus transceivers (no diodes yet) using an 74HC04 and using pin 9 as a select through a 10K pull up resistor and the control works great, but as expected there is interference. I did notice that the interference goes away almost completely when I disconnect vcc to the inverter (not sure if that info is helpful).
John
15 hours ago, ChildOfCv said:Okay, I'm a little embarrassed but I got it working with the 10K resistor; I was not hooking up the pull up resistor correctly and wasn't taking the measurement after the pull up resistor. 😳 Probably explains why I got a C+ in EE209
I'm going to re-build the rest of the circuit using the octal buffers (244) or bus transceivers (245) and confirm that the joystick switching still works (like it did before) and then move on to trying to reduce the interference using your suggestions with the diodes to simulate open collector variant. At this point I may just take the plunge and invest the 10 bucks in 2 of the 74ALS641. Before I place an order, do you see any benefit in getting 74LS04 inverters vs the 74HC04 inverters that I'm using now? I'm not sure what the difference is but since the shipping from Mouser is per order and is usually as much as the components
I'd like to try to order everything I need at the same time.
One change I'm going to suggest is to use pin 9 as the select line as it looks like the harmony cart checks to see if pin 5 is high (INPT0) on startup to determine if paddles are connected (as many games do). If we use pin 9, then INPT1 will be logical high on startup and we can ground INPT0 so it's low and we can use this as autodetection for the multi-tap (INPT0 = 0 , INPT1 = 1 on startup) which differs from paddles/Genesis controller which has both INPT0 and INPT1 high on startup or a regular joystick which has both INPT0 and INPT1 low on startup. Using pin 9 will make the QuadTari/multi-tap "Harmony friendly"
This it the API I need to have nailed down in the next week or so (how to detect a multi-tap is connected and how the switching is going to take place) since that is in code and hopefully we can resolve the interference issues without changing the API.
I'll post my results here as I make progress.
Thanks again for the help and the education on pull up resistors!
EDIT: Checking Mouser.com, there are a couple options for the 74ALS641:
vs.
Looks like the difference is in Low Level Output Current (24 mA vs 48mA) and min/max supply voltage (4.5V - 5.5V vs. 4.75V - 5.25V). Also the second one has a lead time of 8 weeks and the first one is in stock. Would the first one be suitable with the 24mA/4.5V - 5.5V?
2 hours ago, ChildOfCv said:Hmmm... is it possible that your program clears VBLANK elsewhere? I assume that paddle games still work. So the TIA must be able to ground the pins. The technical manual doesn't seem to mention the amp pull capabilities of the dump transistors, but it has to be enough to dump the capacitor while the input potentiometer is still pulling it up.
I'm pretty sure that I'm not clearing VBLANK anywhere else (I stepped through the debugger).
2 hours ago, ChildOfCv said:On the other hand, the potentiometer ranges from 0 to 1 meg on the paddles. So you could try a larger resistor to see if the 10K is just too strong for it. Maybe 100K.
I can try that. I know for a fact it worked before so something is amiss. However, when I first tested it I had it going through my 4.7K resistor network that I am using for the joystick inputs and it did work. I abandoned that when it stopped working which I now know is because I fried the inverter lol, so I'll try that again and see how it goes with the 4.7K and I'll also try a 100K. Silly question, but wouldn't a 100K be stronger than a 10K or am I misunderstanding how resistors are measured? I know they're in Ohms and Voltage = Current * Resistance (V = IR); probably the only thing I remember from EE 201/209 lab back at the University of Connecticut in 1988
I'll also try another Atari in case I damaged my test one, but the paddles do work great on the system so I don't think I damaged it at all.
Any other suggestions are welcome and thanks again!
John
17 hours ago, ChildOfCv said:No, the dumping transistors only pull to ground. You need a pull-up resistor on your board to bring it high. Remember that this is the circuit that the paddles are usually connected to. The paddles have a potentiometer connected to +5 with the wiper going to the I0-I3 connection. Typically, the Atari will pull the value to 0, then time how long it takes for it to rise to the trigger threshold as it charges the capacitor. In our case, we're using a small resistor so that the time will be almost instant, because instead of using it to read an analog value, we're using it to output a value.
Thanks for the explanation! I'm able to get the signal high by connecting pin 5 to a 10K pull up resistor and the other end of the pull up resistor to +5V. Unfortunately no matter what I set VBLANK to, the value at the end of the resistor connected to pin 5 is always 5V. For a test I connected the other side of the resistor to ground and as expected the value on the vcc side was 5V and the other side was 0V. Setting bit 7 of VBLANK doesn't seem to be having any effect on what pin 5 (or 9) are doing. Of course it's quite possible that I'm just doing something incorrectly or have it hooked up wrong. Right now I'm just working with the input from the Atari, (vcc/ground/pin 5) and the 10K resistor and measuring voltage at the pins. Once I can prove that I can switch the logic of pin 5 using VBLANK, I'll add in the inverter and then the bus transceivers one at a time, measuring along the way to make sure I don't mess anything up.
Interestingly it seems that I damaged my inverter chip (74HC04) at some point (probably screwing around with disconnecting/connecting wires to view the static) as I did an independent voltage test on the input/output pins and no matter what, all of them were high (5V). I switched out another chip and it worked as expected (1->0, 0->1), so that explains why I did see it working for a bit when I first connected the circuit and then why it seemed to just stop working.
I'm not sure where to go from here, this may be over my head but I'm very interested in learning if you have any other suggestions or helpful tips. I'm releasing Wizard of Wor Arcade and Galagon at the PRGE on 10/19 and both games are supposed to support this interface. Although it's very unlikely that the adapter will be ready to sell by then, I want to at least nail down the API. Being able to use pin 5/9 vs. one of the direction pins (we were initially using LEFT pin 4) would be ideal so hopefully we can get a prototype working with the switching at least.
Thanks so much!
John
So I'm having some difficulties using the VBLANK method to select a joystick. It was working for a bit yesterday but after I disconnected the circuit and reconnected it, it's no longer switching. I modified my test program so you can use the difficulty switches to enable/disable the switching, and when the switching is disabled I use one of the difficulty switches to enable or disable the VBLANK dump ports bit (0x80 of VBLANK) so it's constant. It seems even if VBLANK bit 0x80 is set high constantly, the voltage coming off of pin 5 and 9 is always 0 (which explains why it's not switching).
Maybe I'm misunderstanding how we can use pin 5 (or 9) as a select line? I would assume you would set VBLANK to 0x80 and that would drive pin 5 and 9 high (on both ports), and if I set VBLANK to 0 it would drive pin 5 and 9 low, so I wrote my 'switching' code to read joystick 1 (assumes pin 5 is low), enable DUMP_PORTS (VBLANK=0x80, sets pin 5 high, or so I thought), wait a bit, read joystick 2 (assumes pin 5 is high), and then disable DUMP_PORTS (VBLANK=0, sets pin 5 low I thought).
The odd thing is that this *was* working when I first hooked it up so I'm not sure if I fried something on the Atari? Right now I'm just taking measurements directly off port A of the Atari (no joysticks) and pin 5 is always low no matter what I'm setting VBLANK to. I confirmed that the other pins (U,D,L,R and the button) are all high and go low when I enable them with a joystick (directly connected to the Atari) so I'm pretty sure I'm measuring it right (I'm measuring voltage with a multimeter). For what it's worth, I did hook up some paddles with Video Olympics and it works fine so whatever is charging the capacitors in the paddles still works fine.
Any help is appreciated!
Thanks,
John
2 hours ago, ChildOfCv said:What I'm wondering about is if the interference comes from the fact that highs on your run-of-the-mill logic gates push current. This open-collector variant does not do that. It works in much the same way as the joystick would: On a high, it acts like it's disconnected. On a low, it shorts the output to ground.
Of course, that fact alone probably means it takes less power to run, since it's not trying to supply any voltage. But it may just be that absence of the pull-up that makes the difference.
If there were an open-collector equivalent to the 74ls157, I'd suggest an experiment of pulling the one out of your Genesis joystick and replacing it with that. But alas, it appears that bus transceivers are the most straightforward open-collector alternatives. There is a 74als760 which only goes in one direction, but they seem to be similarly priced. Maybe a buck cheaper, but still a lot more than your standard logic.
Of course, if the proof of concept works, we may be able to search for a cheaper (but probably more total chips) alternative.
Oh, and about the resistor network: I just chose 20K because it should allow enough current to turn the input on. 4.7K should work too.
Well, some good news: using 4.7K pull-up resistors and switching using pin 5 by enabling/setting DUMP_PORTS (0x80 on VBLANK) works great!
As it turns out, I must have last used tri-state bus transceivers (74HC245N) since those were in my bread board, so I used those in my test. The interference line is pretty pronounced; worse than with using the left pin as the select line. I'm going to try with the octal buffers (74HC244N) and see what it looks like with that. I think the reason why Nathan went with the solution above is because there is no interference just using ground to select the active joystick, but that solution has it's own issues with control and not registering diagonals. Do you think using the 74ls157's instead would eliminate the interference? I should note that I'm using a 74HC04 inverter; I'm not sure how that compares to the 74ls04 inverter in your design above (what does the HC and LS stand for?). One thing that I did notice that as I was fiddling with the wires while it was connected, when I disconnected the wire going into the inverter input the static was really bad all over the screen, and would go away completely (even the line on the bottom) when I moved the end of the wire (still disconnected) away from the breadboard. Not sure what it all means but figured I'd mention it. I'll take a video and post it on YT so you can see what I mean.
EDIT: Very strange, but I just rehooked up the circuit to the Atari to get some video of the interference and the VBLANK switch isn't working (it's always registering joystick 1). It was definitely working before so I'm not sure what changed.
Anyway, at a minimum you've improved our design; using the VBLANK register certainly has it's benefits, including simpler code and allowing a joystick plugged into the adapter to be used with any joystick-enabled game.
12 hours ago, ChildOfCv said:Hello there!
Thanks so much for this; I think it's very similar to the one above that uses the octal buffer? One issue is that the select line is on port 2; the ultimate goal is to multiplex two joysticks on 1 port so the other port is free for the Atarivox, but I see you have a solution for that below. My concern is that we'll still have the interference with this design since it is similar to the one above that uses the octal buffer (I did the design with 2 SN74HC244N chips). The control was great but the interference was bad. Is there less of a power draw from the 74ALS641? Also it looks like those chips are very expensive if I'm reading it right; about $4 each, almost 10 times more than the 74HC244N! 😮What is the advantage between using a bus transceiver vs. an octal buffer?
12 hours ago, ChildOfCv said:And just thinking about it, I realized that the TIA's input could be used to select the direction instead. That way you don't have to change how the 6532 ports are used, and the result is usable on either port.
There's a pull-up resistor on the port which will almost immediately charge up the Atari's timer capacitor for port I0. To read the second input, set bit 0x80 on the TIA's blank register. This pulls all ports I0-I3 down, which swaps bus transceivers.
Wow that's a very good idea about using the TIA blank register and dumping the pots using the VBLANK register! One benefit I would think would be that you could use a joystick plugged into the adapter for games that aren't doing the switching since that bit would always be low (assuming the game is not dumping the ports) so it would always read from one joystick.
Regarding the 20K resistor network; I had bought a bunch of 4.7K RNs for the octal buffer design; do you think that would be suitable for this design as well?
Thanks again! I'll need to order a couple of the bus transceivers to test this; in the meantime I'm going to test my octal buffer solution using the VBLANK dump pots as the select line. I assume I should be able to do the following:
During vertical blank:
- read joystick 1
- dump pots (VBLANK bit 8 = 0x80, SEL = 1)
During overscan:
- read joystick 2
- disable dump pots (VBLANK bit 8 = 0, SEL = 0)
In this way both joysticks can be read every frame and there is a sizable amount of time between VBLANK dump pots being set/reset.
6 minutes ago, ChildOfCv said:What's the voltage on the affected pins when you do a diagonal? It has to be pretty low to be registered as a low. There's a grey area between low and high voltages that registers as whatever it feels like, when the voltage is in that range. So you have to make sure your lows are low and your highs are high.
Thanks for the quick feedback! I'll mention this to Nathan @gauauu so he can measure the voltage; unfortunately I don't have the circuit built over here.
Looking at the schematic, do you see anything obvious that may be causing the issue? It seems that the directions work fine if done individually (up, down, left, right) but only cause issues when they're diagonal. I'm not sure what the difference would be if 1 or 2 are activate at the same time. Speaking from someone who has very little experience with this; the circuit I built with the octal buffers had pull up resisters on the joystick inputs. Would those be needed too plus the diodes that were added to ensure the current flow was going to the right way (we previously had the issue where one joystick could control both players sometimes).
Hello all,
I know it's been a while (busy summer!) but Nathan T. and I are back at trying to get this multi-joystick circuit working. Right now we are using the design where the joysticks are connected in parallel and activated by hooking the select line to ground through a diode. Although this did work by removing the interference, there was a control issue where one player was able to move the other player when both where pressing in the same direction or action (holding down the button for example). It was recommended above to put diodes on all of the inputs from the joystick (which Nathan @gauauu) has done in the latest design. The good news is that the control issues seem to be fixed, but there is an issue with diagonal movements. They don't always register for some directions and for others (when you're pressing RIGHT for example), the diagonals never register.
Here is a schematic of what Nathan is testing with; any ideas would be greatly appreciated! Seems like we're getting close!
13 minutes ago, Richard H. said:Demo doesn't work on my UNO cart. Anyone know why ?
Hi Richard,
I don't believe any CDF/DPC+ games run on the UNO cart (Draconian, Mappy, Scramble, Galaga, etc.) but I believe someone in the UNO cart community may be working on that.
Hello all,
With the release of Wizard of Wor Arcade approaching (October 19th @ the Portland Retro Gaming Expo), here is an updated demo ROM that is 99% complete.
Note that this new demo requires Stella v6.0.1 or better (or Stellarator) to run in an emulator, or it can be run from the Harmony or Harmony Encore.
The demo ROM contains all the features of the full version with the following exceptions:
- The word "DEMO" is alternately displayed with the SKILL level on the title page.
- Savekey support for high scores and game options has been disabled (AtariVox speech is supported in the demo).
- The Maze Editor and ability to play with custom mazes is disabled.
- The game will go back to DUNGEON 1 after DUNGEON 8 is completed. The full version contains 99 levels
Directions for playing the game can be found in this post, with these additional notes:
- On NOVICE skill, the first 3 dungeons are always the same set of 3 mazes.
- On ADVANCED skill, starting on the 2nd dungeon, the walls of the maze may crumble during a level, making it more difficult to hide from the monsters, so finish the dungeon as quickly as possible!
- The right joystick button can be used to change the # of players on the title screen (same as the SELECT switch)
- Note that 2 player co-op mode is not available if there is a Savekey or Atarivox plugged in (since 2 joysticks are required). Wizard of Wor Arcade supports Nathan Tolbert's QuadTari adapter that allows you to connect 2 joysticks up to the left joystick port, freeing up the right controller port for the Savekey/Atarivox. This will be made available sometime after the release of the game (Nathan will be providing details).
To do:
- Mike Haas (aka iesposta) has completed more Atarivox speech phrases that need to be added
- A sound effect for the crumbling walls in ADVANCED mode will be added
- Game play tweaks/difficulty ramping if needed
Thanks again to Nathan Strum for the graphics, Mike Haas for the Atarivox speech and sound fx, Ross Keenum for additional sound fx (Wizard shot, Worluk shot and Wizard escape sounds), and to all those who have provided feedback with testing, most notably James & his crew over @ ZeroPage Homebrew! I also want to thank Nathan Tolbert for his many hours spent refining and testing the QuadTari interface and accommodating my specific requests needed to make it work with one controller port to free up the second one for the Atarivox/Savekey.
The box, manual and label have been finished by Dave Dries (thanks so much Dave!) and he's done an amazing job! Al will be posting teaser shots soon!
Any feedback is appreciated!
Thanks,
John
wowarc_20190812_demo_NTSC.bin wowarc_20190812_demo_PAL60.bin
15
Just now, sramirez2008 said:It'll be great to see you guys again and it would be nice to meet Nathan.
It will be good to see you too Steve!
34 minutes ago, -^Cro§Bow^- said:But I'm hoping there will either be fixed Avox units or Atari only Avox units for sale along with the game at PRGE in which case, I will pick up one.
Hey Jesse,
I know @Albert has been working with Richard H. and I'm pretty sure they were able to come up with a new design that fixes the issue. I'm not sure about availability at PRGE; I know Al is flat out getting a whole slew of games ready for release at the show. 😮
PS It will be good to see you at PRGE!
Hello there!
19 hours ago, MissCommand said:Did you mention in the show that the Wizard Of Wor binary you were playing had been posted? Can you direct
me to the link?
We have released two ROMs; the initial one last year and the updated one in February for the maze editor contest. I do plan on releasing an updated ROM demo in the next week or so.
14 hours ago, MissCommand said:Okay, I do have the initial demo. I do hope there is a decent ROM released... or at least a way to pay for just the
finalized ROM (and a copy of the manual). I basically just do not have the space (or money) for an entire 2600 setup
and a cartridge collection in my apt, but do not mind paying for this game, it is a fav of mine... especially with all the
great voice clips!
I believe Al is currently working on a Downloads section where people will be able to pay/contribute for full ROMs; I'm not sure about copies of the manual though. I'm sure he'll be releasing more info on this in the near future.
Thanks!
John
On 8/5/2019 at 9:28 PM, PacManPlus said:I will be there. First time in Portland!
Just made hotel reservations and flights.
Awesome! It will be good to see you again Bob! Now we just need to get @Nathan Strum to go for a full-fledged Lady Bug development team reunion!
17 minutes ago, thevnaguy said:gotcha, I thought it was like space invaders on the 2600 where you would start with both players on the screen at once
thanks for clearing that up
Both players start on the screen in NOVICE skill level and in CHALLENGE MODE.
Updated ROMs for Galaga (now renamed Galagon) are available in the Homebrew forum in this post!
Enjoy!
John
1 hour ago, thevnaguy said:Has anyone been able to pay the two player co-op mode? I cannot get it to work using stella 6.0.1. Just keeps going into a single player game when selecting co-op mode.
Hello there!
I just tested it and co-op works fine for me. Note that co-op is basically a 1 player game but both players take turns controlling the ship and both players each control a ship at the same time when you rescue your fighter and get double ships. If you start the game and your ship has red trim but the reserves have blue trim, you are in a co-op game. Once the red ship gets destroyed, player 2 will then control the blue ship.
Hope that helps!
John
PS Note that you must have 2 joysticks plugged in for co-op mode. The release version will support Nathan Tolbert's QuadTari adapter that will allow you to plug two joysticks into the left controller port, freeing up the right controller port for the Atarivox/Savekey.
Hello all,
Here are the updated NTSC and PAL60 demo ROMs for Galagon (aka Galaga).
PLEASE NOTE: If you plan on playing this in an emulator, you must use the latest version of Stella (6.0.1) or Stellarator. The game works on the Harmony (and Encore) with BIOS 1.0.5 or higher.
The game is full functional with the following changes:
- Savekey support has been disabled
- After completing stage 8, the game goes back to stage 1
- The word "DEMO" is displayed on the title screen.
There have been numerous changes since the last demo ROMs. Thanks to all the suggestions and recommendations! We are looking to finish the game up in the next couple of weeks in preparation for the game's release at the Portland Retro Gaming Expo in mid-October, so any feedback is greatly appreciated!
Thanks,
John
- changed title screen to "Galagon" (thanks Nathan!) to coincide with the official name change from Galaga to "Galagon"
- the repeat fire response is faster for difficulty A (no autofire)
- removed the "150" score display during gameplay for killing a boss in formation (still displayed in the SCORING screen),
- moved enemies closer together on first wave of challenge stage so you can hit them as they fly in, per the arcade
- changed blue bee loop pattern so it doesn't fly as low under your ship
- fixed a bug where you could change skill level by pressing left/right on the Credits screen
- the breathing/expanding sound is stopped when there are no ships left in formation
- increase star blinking speed to better match the arcade
- added SFX when selecting the skill level (bee sound when decreasing, butterfly sound when increasing)
- removed the boss destroy sound after a 1000 point bonus on the challenge stage. It now plays the sound of the last enemy destroyed, per the arcade
fixed SFX for special ships to match the arcade:
- scorpion: boss destroyed SFX
- Galaxian: boss hit once SFX
- all others: butterfly (red enemy) destroyed SFX (was the bee sound)
- you can now cycle through the number of players on the title screen by pressing the Joystick 2 button
- changed order of enemies flying in to match the arcade (blue bees are flown in last)
- fixed the order of flyin patterns 4 and 5 on stage 1 (they were reversed) move the wrap around enemies so they don't fly off the edges of the screen
changed it so enemy ships don't fire when they're really close to your ship
updated ship explosion sound (thanks Ross!)
add "PLAYER 1&2" message when both ships are active during co-cop
no fire on flyin for NOVICE until level 4; fire on flyin for ADVANCED on level 1
added in CHALLENGE MODE:
- Select CHALLENGE MODE by pressing left or right on the title page until CHALLENGE MODE appears for the skill level
- Challenge mode can be 1 or 2 player, or even 2 player co-op!
- The object of Challenge Mode is to clear as many challenge stages before you run out of ships while obtaining a high score
The rules of Challenge Mode are:
- You always start with a double ship with 2 in reserve
- Extra ships are earned the same as in a regular game: 20,000, 70,000 and every 70,000 after that
- All stages are challenge stages. After a challenge stage is complete:
If you have double ships:
- Perfect score: no change
- If you hit 38 or more enemies, you will lose a reserve ship, keeping the double ship. If you don't have a reserve ship, you will lose one of your double ships.
- If you hit 30 or more enemies, you will lose one of your double ships.
- If you hit < 30 enemies, you lose BOTH double ships
If you have a single ship:
- Perfect score: Bonus ship awarded as a double ship
- Otherwise, you lose a ship
added in CO-OP mode.
- To select CO-OP mode, press the SELECT switch (or Joystick Button 2) to cycle the # of players until 2 PLAYER CO-OP is displayed.
Select the skill level for CO-OP:
- In NOVICE and CHALLENGE MODE, both players start the game since both ships are active
The object of CO-OP mode is the same as a 1 PLAYER game except both players are working together to achieve 1 score.
- When there is one ship, the player controlling the ship alternates each time a player ship is destroyed or captured.
When there are two ships, each player controls one of the ships and can independently move and fire!
- Player 1's ship has RED trim, Player 2's ship has BLUE trim
- Players cannot cross each other's path
- Players can 'push' the other player by moving their ship against the other ship. Players can resist being pushed by moving the joystick towards the other ship.
The rules of CO-OP for a regular game (NOVICE, STANDARD or ADVANCED):
- PLAYER 1 starts in control of the ship (RED trim), except in NOVICE mode where both ships are active to start. In this case, PLAYER 1 controls the left ship (RED trim) and PLAYER 2 controls the right ship (BLUE trim)
- When there is 1 ship being controlled, the RESERVE ships are trimmed in the color of the player who will control the *next* ship.
- When a ship is destroyed, if there are reserve ships, the *other* player will take control of the next ship.
When a ship is captured, if there are reserve ships, the *other* player will take control of the next ship.
- Note that if a ship is destroyed while the other is captured, the player captured will control the ship and the player that was destroyed will now be captured
- When a ship is rescued, BOTH players will now each control one of the ships (PLAYER 1 controls the RED trim ship and PLAYER 2 controls the BLUE trim ship). Note that the ship that was rescued will always be on the RIGHT while the ship that did the rescuing will be on the LEFT
- Both players are working towards one high score. The game ends when all ships have been destroyed and there are none left in reserve.
- At the end of the game, hit/miss results are displayed for each player. If a high score is obtained, only one set of initials are entered.
The rules of CO-OP for CHALLENGE MODE:
- Both players are active to start (PLAYER 1 controls the RED trim ship on the left and PLAYER 2 controls the BLUE trim ship on the right)
- If there are double ships and 1 ship is lost, the ship on the left is removed (the ship that has been active the longest)
17
Champ Games will be in attendance also! My brother and I will be manning the Wizard of Wor Arcade and Galagon displays so be sure to stop by!
Thanks to Al and Atari Age for such an amazing setup, it's by far our favorite booth @ the show!
Joystick multiplexer help
in Hardware
Hi Nathan, thx for the clarification. Hmm, I thought the 4 player adapter you put together used the grounding logic and not the chips and you weren't seeing interference with it (just control issues)? Do you mean the first iteration of the adapter that used the multiplexers? Maybe I'm confusing the two?
