6,415 -
19
Posts posted by nanochess
1 minute ago, Milli Vee said:Does anyone know how many cycles I have to work with when the VDP triggers an NMI and when it starts the next screen? I don't want to overload my NMI routine too much and stomp on the VDP.
It is easy to calculate.
As the Z80 works at 3.58 mhz, you have 3579545 cycles to work.
You should divide this number between 60 (the number of video frames per second on a NTSC console) 3579545 / 60 = 59659 clock cycles per video frame.
Each NOP instruction take five cycles so you can execute a total of 11931 NOP instructions before the interrupt is generated again.
This page contains the total cycles for each instruction: (use the Timing Z80+M1 column)
http://map.grauw.nl/resources/z80instr.php
Some games do everything inside the NMI vector, so the main loop is just a jump over itself.
Other games only update the VDP while inside the NMI vector, so you must leave enough cycles for the game processing code. I use this kind of logic in my games Princess Quest, Mecha-8, and Mecha-9.
And some games only do everything outside of the NMI vector, and use Z80 loops, and don't even synchronize with it.
Enjoy it! 😎 As an interesting side note, this game took 3 years in development because I started it around July 2016. More info https://nanochess.org/aardvark.html
6 hours ago, Thomas Jentzsch said:Now I am jealous.
Maybe we need to start sharing the trophy, one year with you, one year with Nathan, one year with me 😄
2 minutes ago, ZeroPage Homebrew said:Looks great Oscar!
- James
I was wondering how I didn't took the picture before!
2 hours ago, Gray Defender said:Amazing article! The Awards are well deserved! Such great ports, you and the team should be proud!
Thank you! This reminds me that I need to take a picture of the award along the game!
I was reading the thread and discovered I had forgot so many things, so I collected everything and made a small article about Aardvark.
12 hours ago, carlsson said:I read that comment from Nanochess and I wonder what he means. Take any GRAM card that is 8x8 or 8x16 pixels (some MOBs). As far as I can tell, every bit is used to its maximum in the GRAM memory. I think he meant the BACKTAB where the two upper bits are unused and can be used to store additional data. Those two bits are not involved in selection of which GROM/GRAM to display.
Edit: Unless of course the reference was to bits 9-10 which form address bits 7-8 in selecting GROM in CS mode, but per the stic.txt mentioned above are ignored for GRAM and BG/FG mode. It might very well be so that the BACKTAB holds all 16 bits and that the CPU can read all of it, but since STIC won't bother about bits 9-10 as long as bit 11 is set, you have a total of 4 bits (9, 10, 14, 15) to store additional information as long as you use GRAM. On an expanded console with 1K or 2K GRAM, the bits 9 and 10 would apparently be used by the STIC which means BACKTAB would contain garbage if you at the same time tried to use those two bits for own information.
I was thinking on Utopia, I remember reading invnut's Utopia Revealed!
Just made IntyColor to support the expanded GRAM by using the -t option. Notice the only mode that can access the 256 GRAM cards is the Color Stack mode.
As always the source code is at https://github.com/nanochess/IntyColor
Let me show also a tiny example using the cutegirl.bmp file (from my previous demo to test for Tutorvision/Super Pro systems):
./intycolor -b -s0707 -t cutegirl.bmp cutegirl.bas ./intybasic cutegirl.bas cutegirl.asm ./as1600 -o cutegirl cutegirl.asm ./jzintv -z3 -G2 cutegirlFor jzintv is very important the uppercase G, otherwise with the lowercase g it tries to load a strange GROM file.
On 4/7/2021 at 12:37 PM, Peripheral said:How are we supposed to know which games benefit from ECS and/or ivoice?
Running jzintv's rom2bin on the .rom's typically gives a config file that says things like
ecs = 1
voice_compat = 1 (or voice = 1, for Mr. Turtle)
From some old threads, I gathered that "ecs = 1" is conservative, and should probably
be replaced with ecs_compat. So I was guessing that the contest entries do not use ECS.
And I guessed Mr. Turtle was the only one using ivoice.
But from this award, it seems Infiltrator can also use ECS and/or ivoice.
So which contest entries can use ECS and/or ivoice?
And going forward, is there a way to determine this on our own?
thanks!
Both Infiltrator and The Pandora's Incident can use the extra sound chip on the ECS.
It is indicated in the posts made by the author. It is easy to tell by yourself if you run jzintv with and without ECS support (and you have good ear).
We knew Mr. Turtle had voice because the author showed it in the video he made. Also you need to run jzintv with voice support.
If the author doesn't tell us, it is not immediately obvious if ECS or voice is used.
I remember running Bomb Squad on emulator and never hearing the voice nor missing it because I didn't knew it had voice!
2 hours ago, DZ-Jay said:@nanochess, or any other moderator, could I get "edit" privileges on the first post, please?
I'm not so powerful 😄 let me ask the league of wizards @Tempest
Added a video of the book in the first post.
4 minutes ago, imstarryeyed said:Just ordered the book on Lulu, it looks like it will be a good one.
I also picked up Mapping The Vic for the Commodore Vic 20.. Lulu has been great to get out of print commodore vic / 64 books at reasonable prices!
Wow! Didn't knew about these out of print books. Thanks for the tip!
Just added the Special Prize awarded by Mark/Space Inc. it is for Infiltrator!!!
(edited first post accordingly)
It is easier to consider a certain X or Y coordinate over a threshold to confirmate if your sprite is touching the border.
For example if using a fractional movement and an imaginary 4 pixel border around with a 16x16 sprite:
IF #x < $0400 THEN ' left border exceeded
new_room = -1
ELSEIF #x > $9400 THEN ' right border exceeded
new_room = 1
ELSEIF #y < $0400 THEN ' top border exceeded
new_room = -10
ELSEIF #y > $5400 THEN 'bottom border exceeded
new_room = 10
END IF
The variable new_room could be zero when the room isn't changing. You need good collision check with walls to avoid passing impossible paths from room to room.
Typically the card detection is something like this:
#c = #backtab((#y / 256 + 0 ) / 8 * 20 + (#x / 256 + 0) / 8)) ' For top left, the plus zero expression is to adjust the offset if checking other corners, in this case top left
When handling a map with multirooms, you need a table of cards to walls.
For example:
IF collision_room(room * 24 + (#c AND $01f8) / 8 ) <> 0 THEN ' We have a collision
Supposing there are only 24 cards per screen. And you'll fill manually the DATA table for collision_room (24 values for each room).
The collision handling is highly dependent on the game. For example, if you have speed variables you could make the player to reboot, or simply adjust the X,Y coordinates to be outside the collision.
Modulo is an expensive operation in terms of time.
The second half of the code recalculates several things unnecessarily:
imap = 0+mX + ((1+mY)%hMAP)*wMAP #i = map(imap) + #j SCREEN #xyrooms,#i + tX , 0 + (9-tY)*20 ,9-tX,1+tY,9 imap = (1+mX)%wMAP + ((1+mY)%hMAP)*wMAP #i = map(imap) + #j SCREEN #xyrooms,#i , 9-tX+(9-tY)*20,9 ,1+tY,9 imap = (2+mX)%wMAP + ((1+mY)%hMAP)*wMAP #i = map(imap) + #j SCREEN #xyrooms,#i ,18-tX+(9-tY)*20,tX+1,1+tY,9I would do it as:
IF mY = hMAP - 1 THEN mY = 0 ELSE mY = mY + 1
imap = mX + mY * wMAP
#i = map(imap) + #j
IF mX = hMAP - 1 THEN imap = imap - (hMAP - 1) ELSE imap = imap + 1
#i = map(imap) + #j
IF mX = hMAP - 2 THEN imap = imap - (hMAP - 1) ELSE imap = imap + 1
#i = map(imap) + #j
On 3/30/2021 at 10:56 PM, IntvCasey said:will you post in here when its available? I will buy it soon as I see its available, thanks.
And now it is available the hardcover version of Advanced Game Programming for Intellivision!!!
4 minutes ago, carlsson said:Damn me and my big mouth!
Well, it would be unfair to steal from you (or the printing company, perhaps).
You should have taken advantage of the hidden promotion
The printing company never loses. And a few dollars between friends is nothing
1 minute ago, carlsson said:Hm. I can swear it was 17.xx EUR yesterday when I looked, but now it is 25.50 EUR. The US price is 29.27 USD. It must have been a currency conversion hickup at Lulu's side. Too bad I didn't take advantage of it. 🙂
Just changed it a few minutes ago! 😅
4 hours ago, carlsson said:By the way, is there a reason or is it a mistake that the price if you buy from Lulu in French or German is 30% lower than if you buy it in English (US)? That is before shipping, which is roughly the same for both options. I seem to recall something similar was true about your first book too, much cheaper on Lulu if bought from what appears to be an EU printer than an US printer.
Didn't knew about this. I'll give a look. Supposedly I set a price and it is translated automatically.
Edit: just revised and Lulu had some strange numbers for the other currencies. I put again the USD price and all changed accordingly. Not sure what happened but indeed the price was lower.
Maybe an instance of the emulator still is running in the background and Windows notices the CFG file is still used. Or you have the CFG file open in Notepad or another application.
1 hour ago, Mik's Arcade said:i know you get plenty of appreciation on this forum, but I just wanted to thank you again for all this effort.
The intellivision is by far my fondest video game memories from my childhood. I came from a relatively poor family and everyone had an Atari. I used to have to go to their houses to play games. Then my upstairs neighbor had the Intellivision and I was hooked. And then me and my brothers all worked odd jobs and pooled our money and ultimately got our own Intellivision. Such a great system and library
So, to be able to tinker around and try to program games for Intellvision is really like me being able to relive my childhood. It's almost therapeutic!
PS....I recently watched the Queen's Gambit on Netflix, so I'm totally digging the Kilobyte's Gambit
Thank you for sharing!
Coincidentally my neighbor downstairs also had an Intellivision when I was age 5, but I wasn't allowed to touch it because I had a history of breaking controllers 😅
So talking about a "must have" that keep until the adult age 😉 glad you are enjoying it!
PS. Haha you saw the chess games!
New Intellivision Brasil website
in Intellivision / Aquarius
Nice site! 👍🏻
