ApolloBoy
    6,081
Posts posted by ApolloBoy
  1. Makes me wonder if they are using emulation for this one, and if so, the soft image might be a filter applied that can be disabled. Otherwise, man.. That would be a deal breaker for me. I like my pixels nice and sharp (not that this product is for me either, but I'm always interested in seeing the progress of these things over the years).
    AtGames does that with their crap (and I do mean crap in every sense of the word) but Hyperkin typically uses cloned hardware for their consoles save for the 77. It's most likely a GOAC console with a cheap built-in composite to HDMI converter, similar to what they do with their "HD" NES and SNES clones.
  2. Actually Japan uses 200V and NTSC, so not an issue. :) I thought Japan was PAL too for some reason, but nnnnnope.
    It's 100V, actually.
    But anyway, to test the 7805 you'll have to use a multimeter and set it to test DC voltage. With the front of the 7805 facing you, place the red probe on the third leg of the 7805, and then the black probe on anywhere there's ground (i.e. middle leg of the 7805). If you're not getting 5V or anything close to it, then the 7805 needs to be replaced.
  3. In my case to try and use a Sophia would mean I have to undo the s-video out I already have installed. Most might think that isn't an issue, but since I have the holes and everything already in place it is.
    I had an S-video mod in my 5200 and I replaced it with the SOPHIA board over a year ago. In my case I used an 8-pin mini-DIN jack for the output instead of the DB9 connector that Simius provided, and swapped out the old S-video connector with it. Didn't have to drill any additional holes and the video output is perfect, never going back to S-video again after this.
  4. Long story short, I just got a PS2 with no power supply, and ordered one on eBay. Shipment is taking forever, and I'm off this weekend. It's the PS2 slim, 70,000 series (two part power supply, small hole in the back). So before it comes, does anything else work with it that's safe to use? I have about 50 different systems, so I have plenty to choose from. Or even if Target sells something that I can buy and return when it arrives. I thought the PS1 or PS3 would be the same, but those are one-part supplies.
    Thanks in advance!
    They seem to work quite well with the Genesis 2 and X'Eye, the voltage is a little bit lower than the original PSUs for those but it gets stepped down to 5V anyway. If you really wanted to, you could build little adapter dongles so you can use it with a multitude of systems, this is actually what I do for most of my consoles.
  5. I have the SOPHIA mod on my 5200, it’s incredible and the video quality is even better than the S-vid mod that I had. It also helps since I have an OSSC as my main setup now and I don’t have to worry about using an external transcoder since the 5200 now has RGB.
