1,722 -
Posts posted by TwentySixHundred
Oh ok thanks here is the bas file i have found in the folder i was trying to upload and yeah i fully understand about people demanding answers. If you can find the time to have a look that would be great and i will still keep looking over my code to find out what i have done wrong.Thanks againdefault.bas
Hi im just starting off using bB but i have ran into a little problem that when i have compiled the code it runs but is just a flashing screen? Probably sounds a bit silly but if some one could point out what i done wrong in the code would be great. Thanks. Oh it seems my project didnt compile or something it says 0k and isnt bas.bin just bas. So how am i going to show the code
does AA allow people to post code? -
Why not just use an emulator? Stella is fairly accurate now and is only getting better i have a 2600 console but use emulator.
You can always use an old PC with Svideo out and pug it straight to the CRT.
Yeah its real fun to play on original hardware but i say collect it in mint condition and play emulator.
I find PC is more reliable as you can keep backing it up if your hard drive fails not to mention emulation looks better on LCD/LED TV's.
My next project is going to be an emulator box or Arcade machine but not sure what to build first
Well here is another one i said i would make with a revamped DK jr Sprite, still not that good but atleast he doesnt look so much like the gingerbread man lolDonkey Kong (Hack).bin.a26
Edit: I forgot to mention that DK will jump left and right this is not a bug because its a single sprite that flips in reverse and back again. You will notice on the original DK he does the same but its a front on view, this trick saves space rather then using two sprites for animation.
Here is a small one i done changed Jumpmans nose a little, the barrels dont look like Pizza's and slightly changed DK himself. Also the teapot looking enemy's in stage two are just a random sprite i made not to sure if i happy with them though. All i know is the DK sprite doesnt have much room to play with so design is very limited. However im think of modifying a DKjr sprite to replace DK but gotta see if it looks ok. Anyway have a look if you want
Donkey Kong (Hack).bin.a26 -
Hi guys,
I tried doing a channel scan with the Atari in the antenna port, but it seems to be still picking up tv signals on channels 2 and 3, so i've got no way of telling if it's working.
Thanks, purplecashew
Have you tried it on a VCR? Also try to swap out the power supply if you can although i know Atari stuff can be very hard to come by in Australia. Might want to check out the RF cable as i know my 2600 jr began to give me problems ,lucky the jr can be replaced with a VCR cable.
Was never a fan of mac computers ,i always wanted to like them as they looked so different and mysterious but never could. Thing is i started with Dos on the PC side of things then followed onto Win 3.11 and so forth.
As a young lad my two first computers ever were a IBM 286 running Dos of course and an Atari 2600. I used to actually like looking through the directory (dir/p)
and typing .exe on the end of the run file lol. Was sorta like a game in it self.However i do find the other apple products very cool indeed like the Ipod ,iphone and pad are great products.
its just IBM Dos and Atari2600 i have a soft spot for.
RIP Steve
Klax is a awesome game and the last to be made
Check your Difficulty Switches
Brilliant thanks for that i didnt even think of it ,like i said im from Australia and grew up with the PAL but when i went on the emulator with NTSC i noticed it auto firing. To start with i thought my PC was having a hissy fit but realized it was only that game. Thanks for that now i have to mod the NTSC version also
Congratulations and really good for your first homebrew mate
Personally i dont think a graphic hack will help as the sprites are already fairly good for the 2600 ,only the alligator's sprite looks bad. Note that i said sprite as it is just one sprite that reverses making it look like two. So in other words i say it would need to be coded just for that simple graphic hack.
Other then that to add vine restructure with two additional stages the game would need a complete work over.
Would be impressive and nice to see none the less
Sounds like Joust where you are a small bird running and hitting other birds turning them into eggs to collect ,or if its a sorta 3d game Desert Falcon
@ Save2600 Yeah i found it a bit odd as the PAL version you can just hold down the fire button and it auto fires anyway. I was the same tho ,never knew because i grew up as a kid with the PAL version in Australia. I sorta like it better as i can time my shots rather then auto fire the whole time. Awesome game never the less ,was always one the first carts id throw in the system
I like Vanguard and was one my favorites back in the day ,only thing i did not like was the shrimp sprites. Funny you speak of this game i just made a hack yesterday to change the choppers,balls,shrimp and arrows. They are now different style choppers the balls are space mines ,shrimp are UFO's with magnetic force field and arrows look more like space ships. I uploaded a .bin in the 2600 hacks section of the forum but is PAL version as i did not like the auto fire on NTSC version
H2
in Atari 7800
If it does 7800 and 2600 i will be in when its ready ,even if it just works on 7800
Looks good ,hope the controllers work otherwise that could be a problem too
Did you get a 5200 as well or just the Pacman 5200 game? If so do the controllers work
Dig Dug without a doubt
Just completed another hack but with Megamania for 2600 (NTSC)
Player Ship: Changed
UFO's: Same
Hamburgers: Now look more like the 5200 version
Bugs: Are now 4x4 tires
Radial Tires: Same
Diamonds: Now green Satellites
Steam Irons: Same
Bow Ties: UFO's
Space Dice: Same
Well looks to me the 16 is the better board
Hi fellow AA members just done a Vangard gfx hack to change some sprites and stuff.
Player ship: More sleek
First wave: Chopper's (Not sure about)
Balls: Into Space Mines
Shrimp: Into UFO's with magnetic force field withing a close radius
Arrows: Into Space Ships (also not sure about)
If you think the choppers and arrow space ships look silly let me know ,other then that i am happy with my UFO's and Space Mines
Nice job
Berzerk is such a great game -
Im from Australia too and yes most our older TV's do not need a coax adapter it should plug straight in. Have you tuned in the Atari like its a TV station? As long as its connected to the RF input turn the Atari's power on and do a station scan on the TV. Even if its just a black screen it should find that ,and no the VCS does not make any noise when on. If still nothing try another TV if nothing again sounds like there could be a problem with the system ,also someone you know may know about tuning Atari's/VCR's in
Can it be done with bithacker?
bB newbie in need of some help
in batari Basic
Ok reading on with your tips looks like i got alot to learn but anyway i put the code in a notepad++
bB.txt
