1,487 -
Posts posted by Paul Westphal
Besides OEM power supplies, I have found that the modern 400/800 power supplies from 8 bit classics are excellent.
Bummer. Sorry, maybe they will send you a replacement?
The SD card should be a small one and make sure its formatted. You just drag and drop the files to the SD card ( no folder needed ).
It CAN do some .ATR's( disk images ) but stick to .XEX files. You can get them at Atarionline.pl.
The Uno Cart will not work on a 16k machine, which the stock 600XL is. It WILL work on a 48k 400, but NOT a 800.
Get one from The Brewing Academy.
SOLD!!!
Hercules workshop up in Canada had good quality cables. His cables split the audio out to two speakers.
FYI you can get brand new motherboards from Best Electronics, but they are like a box of chocolates... 😀
Millipede, Centipede, Crystal Castles. Millipede is awesome with it! I also tried Galaxian with mixed results. I didn’t know about Slime, thanks.
Every Hong Kong labeled 800xl I have opened was fully socketed. Every Hong Kong labeled 600xl I have opened was socketed.
Paul
Eightbitfix.com
If its made in Hong Kong the chips are socketed, which means easy repairs. If it’s made in Taiwan, the chips are probably partially or fully soldered to the motherboard, which is more work to repair.
Keep in mind some later games and homebrews require 64k or more, so if they don't work...
Atarionline.pl
Swap the NTSC GTIA for a PAL one.
Some demos require swapping both to run.
Paul
Eightbitfix.com
This is relevant because I found out that the Uno cart works on 48k 400's, and NOT the 800.
I have two restored 48k 400's for sale, with dust cover should you need one.
Eightbitfix.com
Well in restoring a few ST's that had them missing, I eneded up using motorcycle fuel line. Yep. It works great and kinda cushions the floppy drive. I did have ONE plastic spacer left to get the length off before I cut the fuel line. On one unit I put a plasic guide inside the fuel line to guide the screw when I put it it. ( it was an extra spacer from a Ultimate 1mb upgrade for the XL XE line. )
Bruce at B & C Computervisons probably has some.
Paul
Hi all,
He replied to my inquiry. He is still re-working the game with new tools. He sent this video..
Paul
15
1 mb ram , TOS 1.2 ( I believe)
1) RAM Card
2) CPU Card ( which is hidden inside the aluminum shield)
Paul
Eightbitfix.com
Indus GT O/S Chip Part Number
Best Electronics : http://www.best-electronics-ca.com/8-bit_.htm
Indus Atari 8 bit GT Disk Drive Upgrade ROM. This plug in Unreleased Indus OS Rom will give you a Faster Sector Mode 50 - 75 faster, Increased Stepper Rate of 50% faster and Shortened Motor Timeout from 9 seconds to 2.5 seconds. Requires you dissemble your Indus Disk Drive, unplug the old OS chip and insert the upgrade OS chip. Includes the New Indus OS chip and 1 page written instructions. CB103141 $15.95
