1,487 -
Posts posted by Paul Westphal
I’m seeing a lot of bad PIA’s these days...
Eightbitfix.com
Yep, Deluxe Invaders. There is a broken .xex version out there that has a screechy fire sound.. beware.
Post a pic of your power supply please. 👍
Cool! I also have a Syquest ezflyer 230mb with power supply. Hook ups are different however.
I put this here so it would not get lost in the marketplace. The driver disk works. The drive itself works as seen in the pics. It comes with another 135mb disk(cart). I just tried it on my 1040STe to see if it worked, and it does. It comes with manuals too. I could not find any on Ebay to compare it to, so any reasonable offer will be accepted. Shipping from Portland, Oregon. PM me if interested.
Hercules workshop ( in Canada ) sells a monitor out to composite ( yellow, red , white ) cable. There are cheaper ones on eBay...
Try Bruce at B & C computervisions in El Dorado, California.
Great info Zoggy, thanks. The guy said it was running when he put it away. I’ll try the warm boot and see if it recognizes it.
Here is some info.
You may also : Turn on the system for a minute and see which main IC's get hot. I know it's old school, but it can help identify a bad chip.. They also have known issues with the O.S.
Paul
Yes. MT ram SUCKS. It has the propensity to not reset after power down. It holds chunks of data, like static ram. FYI- I have seen Atari put a good Japanese ram in the first slot, and the rest were MT. They were aware of this problem, and just tried to save a buck. To make matters worse, they would ship some units with the " terrible two " power supplies that were filled with epoxy. They would overheat, then when they went out, put out extra voltage and fry IC's, starting with the RAM. MMU's don't usually go bad. If the RAM passes, you may want to look into the PIA.
I am seeing more and more bad PIA's these day's, most being revealed by the official Atari 8 bit testing station I have. This program might reveal where th the bad RAM is.
Paul
Eightbitfix.com
eXtended RAM test v0.21.0 (2003-09-16)(-XI-)(SK)(en)[128k].xex
Oops my bad . I thought he said xl. Correct.
Best Electronics in San Jose CA sells brand new keyboard myylars.
All 800xl’s made in Hong Kong are socketed.
Every 600xl was made in Hong Kong, never Taiwan.
No real difference in main chips, however you could swap out rev b basic for revision c..
Japanese ram is preferred over MT ( micron technology) ram .
MT ram has the propensity to not reset. Later 800xl’s and the XE line use these, mostly.
FYI - It’s hard to tell in the pic, but one foot on that resistor next to the 4464 ram chip has been cut, lifted and had the wire soldered to it.
Xrbrevin, if you could share a high Rez pic of your 600xl UAV install I would greatly appreciate it.
The stock 1050 does not support double density. I suggest going to Atarimax and getting a Happy 1050 enhancement that will give you true double density.
You might try taking it apart and cleaning the head with a q-tip and rubbing alcohol. Other than that, it might be a read write error. The Read circuits are U22, U23 and U24. Write is Q1.
I You think there might be other problems with the drive You can contact my disk drive expert in Lompoc, CA, Paul Alhart. ( [email protected] )
I think I speak for everybody on this... YOU ROCK. Thank You for investing time and resources to do this. We appreciate You!
Regards,
Eightbitfix.com
8 bit Phoenix
Posted · Edited by Paul Westphal
I found these pics on this site while comparing OS ROM's : https://atariwiki.org/wiki/Wiki.jsp?page=Rarity 10
Anybody have any information on this game? I looked on Atarionline.pl and found nothing..
Paul
