apersson850
    1,063
Posts posted by apersson850
  1. Some DSRs already allow the use of CPU RAM buffers. But you can only use that feature in your own assembly programs, since no "normal" programs would expect data to end up in CPU RAM directly.
    Yes, the UCSD p-system has an entirely own file handling structure. The directories are completely different, compared to the TI's normal files. The p-system uses only the sector read/write subprogram, to access the data its own file handling system needs.
    If you need to read a normal file, sector by sector, but don't want to use the normal file based I/O, then you have to read the disk catalog (by reading the sectors it's in), find the file name, read the file catalog sector, find out where the file is stored and then read that file from these sectors. I've done that, when I wanted to read a DIS/VAR 80 text file on a disk with "normal" files from within the p-system, to convert these DIS/VAR 80 files to the p-system's text files.
    The p-system, already on the normal Pascal language level, supports three different abstraction levels of disk access:
    1. Reading files with a defined content, where a stored real becomes a real value in a real variable etc. Commands like put, get, seek, read and write are used.
    2. Reading files block by block (the p-system uses 512 byte blocks, i.e. two sectors at a time), disregarding the content of the file. Blockread and blockwrite are used for this.
    3. Reading disks block by block, disregarding the file structure on the disk. Unitread and unitwrite gives access to this functionality.
    I've done a  program, in Pascal, which reads MS-DOS disks too. It works fine with the old 360 kbyte disks, as they can be read with my drives I use with the CorComp controller. I don't have the hardware to read the 1.2 Megabyte disks in the TI.
    The normal operating system has these capabilities too, but you can't just like that access them from BASIC. But among the "hidden" subprograms on the disk controller are not only the physical sector read/write program, but also support for formatting a disk and accessing files by sector, not by content. This is used by disk manager software to copy files, for example. Then the content isn't interesting in itself.
  2. As I wrote above, if you have SYSTEM.LIBRARY on the root volume (#4:), then everything is automatic.
    Here's a piece of code from one of my programs, a program which uses several units defined for this program only. It also uses one system unit, crt.
    You can see that the uses-clause is given file location information to tell it in which file to look for the appropriate unit. These units are not consolidated into any SYSTEM.LIBRARY file.
    This particular code section is actually from Turbo Pascal 4.0, but the same code runs under the UCSD p-system on the 99/4A as well.
    In this example, the units contain global data definitions and then different sections of the program, like data entry, data display, data disk storage etc.
    I included the complete main program, since it shows how you can create a fairly complex program, but still keep the main program small and easy to overview. The main program here only handles the main user's menu system and some minor housekeeping. By then doing the real work in the different units, I could work on one of them without caring about all other stuff in the program. This was especially important when working with the TI 99/4A, since the whole program is 4000 lines long. It doesn't fit in the editor and compiling everything takes a loooooong time, to say the least. That wasn't much of an issue with Turbo Pascal, but the same convenience of working with one piece at a time ruled.
    program dust_buster;
     (* Dust evacuation dimensioning software system.
        Idea: Sven Lundgren, Process Ventilation.
        Program: Anders Persson. *)
     (* A-DATA 880705 *)
    uses
       crt,
       (*$U dustglob *) dustglobal,
       (*$U dustent  *) dust_entry,
       (*$U dustshow *) dust_show,
       (*$U dustio *)   dust_io,
       (*$U dustchng *) dust_change,
       (*$U dustprin *) dust_print,
       (*$U dustback *) dust_back;
    var
       i,
       choice: integer;
       stop: boolean;
       hmr: ^integer;
    function menu: integer;
     (* Displays the main menu *)
    var
       choice: integer;
    begin (* menu *)
       clrscr;
       gotoxy(20,1);
       write('DAMMUTSUG  v4.2');
       gotoxy(20,2);
       write('===============');
       gotoxy(1,5);
       write('1 - Inmatning');
       gotoxy(1,7);
       write('2 - Visa data');
       gotoxy(1,9);
       write('3 - Žndra data');
       gotoxy(1,11);
       write('4 - Spara data p† skiva');
       gotoxy(1,13);
       write('5 - H„mta data fr†n skiva');
       gotoxy(1,15);
       write('6 - Utskrift av resultat');
       gotoxy(1,17);
       write('7 - Utskrift av material†tg†ng');
       gotoxy(1,19);
       write('8 - Avsluta');
       gotoxy(5,23);
       write('Process Ventilation   A-DATA 88');
       repeat
          choice := ord(readkey);
          if choice<>15 then
             choice := choice-48;
       until choice in [1..8,15];
       menu := choice;
    end; (* menu *)
    function ok_to_kill
     (* Checks if the current system is stored, and, if not, allows storage
        before continuing. *)
       (var stored: boolean;
        var plant: plant_type;
        var filename: string): boolean;
        (* Shows the save or abandon option menu *)
       var
          choice: integer;
       begin (* menu *)
          clrscr;
          writeln('Det nuvarande systemet „r inte lagrat!');
          gotoxy(1,4);
          write('1 - Spara data p† skiva');
          gotoxy(1,6);
          write('2 - Forts„tt utan att spara');
          gotoxy(1,8);
          write('3 - Avbryt valt alternativ');
          write(bell);
          repeat
             choice := ord(readkey)-48;
          until choice in [1..3];
          menu := choice;
       end; (* menu *)
    begin (* ok to kill *)
       if not stored then
          case menu of
             1: begin
                   save_data(plant,filename);
                   stored := true;
                   ok_to_kill := true;
                end;
             2: ok_to_kill := true;
             3: ok_to_kill := false;
          end; (* case *)
    end; (* ok to kill *)
    begin (* dustbuster *)
       if data_files_ok then
       begin
          mark(hmr);       (* To allow swift release of heap space before a new
                              system is entered. *)
          stop := false;
          repeat
             choice := menu;
             case choice of
                1: if ok_to_kill(stored,plant,filename) then
                   begin
                      release(hmr);
                      mark(hmr);
                      new_data(plant,stand_dim);
                      filename := filedefault;
                      calculate(plant,stand_dim);
                      (* If plant.next=nil at this point, there can't be any
                         system to preserve. Otherwise, prevent accidental
                         erasure. *)
                      stored := plant.next=nil;
                   end;
                2: show_data(plant);
                3: if ok_to_kill(stored,plant,filename) then
                   begin
                      change_data(plant,stand_dim);
                      stored := false;
                   end;
                4: begin
                      stored := true;
                   end;
                5: if ok_to_kill(stored,plant,filename) then
                   begin
                      release(hmr);
                      mark(hmr);
                      plant.next := nil;   (* Just in case nothing can be read *)
                      fetch_data(plant,filename);
                      stored := true;
                   end;
                6: print_data(page_height,plant,prdevice,filename);
                7: cost_report(page_height,plant,stand_dim,cost_info,prdevice,filename);
                8: if ok_to_kill(stored,plant,filename) then
                   begin
                      stop := true;
                      release(hmr);
                      clrscr;
                   end;
               15: secret_service(show_change,page_height,prdevice,stand_dim);
             end; (* case *)
          until stop;
       end; (* if *)
    end. (* dustbuster *)
  3. One thing I didn't mention in the post Rossman links to above, was the mapping of the libraries.
    Separately compiled units, whether you made them yourself or they were provided by TI, have to be accessible at two different occasions.
    The first occassion is when you compile the program using the units. The second occasion is when you run the program that uses the units.
    The p-system can always find and access units, both at compile and run time, that are stored in the *SYSTEM.LIBRARY file. Note that the asterisk at the beginning of the file name is the shorthand root volume (#4:) prefix. The SYSTEM.LIBRARY file provided with the system when you get it contains the system extensions that TI developed to provide access to TI 99/4A specific things, like sprites and sound.
    When you create your own units, you have two options. Either you include them in SYSTEM.LIBRARY or you keep them in a separate file. To include them in the system's library file makes sense if they are of general interest. A general input utility is a typical candidate for this. But if you develop a unit that's meaningful in one program only, where the reason for making it a unit could be that the program is too large to be edited as a single unit, and you can break out a section that has a specific and (preferably) separate task in your program (like printing a result), then it makes sense to place this unit in a file by itself. I've developed some program for my 99/4A, where one main program relied on the use of half a dozen units. These units were all specific for this program, so I included them in a separate library.
    The supplied utility program LIBRARY.CODE is used to open a library file as well as add or remove single units from that library.
    If you then compile a program, which references the system unit support, as well as your own unit printfix, and that unit is stored in the file printutil.code, then you need to write your program like this.
    program unittest;
    uses
      support,
      (*U mydisk:printutil.code *) printfix;
    begin
      (* bla bla bla *)
    end.
    That's sufficient for compiling your program. The compiler will now know where to find the interface section of the unit.
    When it's time to run the program, you need to tell the runtime system where to find the implementation section of the unit. When it's in a file outside the SYSTEM.LIBRARY, like in the example above, you have to create a file which tells the system where to look. This is the USERLIB.TEXT file. That file simply contains the line MYDISK.PRINTUTIL.CODE to tell the system where to look.
    You can use an execution option to set the name for the library index file. Press X L=mydisk:unitfile.text to tell the system that you have your own unit index file on your work disk.
    Such a unit index file can contain multiple lines, telling the system to scan through all of them, to located the proper units, if your program references many different units, spread over different files. Or you can use the LIBRARY.CODE program to consolidate all your units into different slots in your own library file, in which case your unit index file only need to point to that library.
    • Thanks 2
  4. As far as I can see from the picture we do have here, this is a 32 K RAM addition, and that's it. Some who added 32 K did put in 64 K RAM, but only used half of it. Made it easier to handle the gap in the address range, where the 8 K and 24 K RAM banks aren't adjacent.
    I did add 64 K RAM too, but more glue logic to make all of it useful.
  5. The way I added 16-bit wide RAM to the machine not only speeds up memory access to the normal memory expansion. It also adds another 32 K RAM, which can be paged in, in 8 K chunks, across the rest of the address space as well. In addition, the fast 32 K RAM expansion can be paged out, to still allow access to the normal memory expansion in the box.
    So this modification increased CPU-addressable RAM from 32 to 96 K. Today, when we large RAM-disks, and interfaces to SD-cards with Gigabytes of storage, this is nothing. But when I invented the design back in the mid 1980's, it was quite a large memory for a home computer. The first IBM PC could be bought with 16 K RAM in 1981...
    As an example, I could page in RAM to get a contiguous RAM file in addresses 0000H-7FFFH. That means monitor ROM, DSR and command module ROM is paged out, but frequently you can do some meaningful actions without them. With this setup, you have access to a 16 K words array, which can be directly addressed by the CPU, to use for internal sorting or whatever. Then just page the RAM out again, and any normal activity in the computer can't touch your array.
  6. Simply by installing 16-bit wide RAM inside the console, the speed of assembly programs where both the workspace and code is in expansion RAM is increased by about 110%.
    Thus you don't have to consider where to put your workspace in RAM PAD to avoid disrupting something in the system, but still get full speed.
    The difference when running programs in TI Extended BASIC is much smaller, but can still be noticed. Forth runs a bit faster, but just like the p-system (Pascal), it already has the workspace and the inner interpreter in fast RAM, so the difference isn't astonishing.
  7. On 1/23/2020 at 2:44 PM, Airshack said:
       Anyway, it’s working now. I have a bridge key on my game map!
       MOV    @MAPDAT, R6     * pointer to beginning of map
       LI        R7,>D900          * Character D9 = bridge key
       MOVB  R7,*R6               * Place key at map origin as a test
       My problem last night was I was using the following first line:
        LI        R6, @MAPDAT        * then basically corrupting MAPDAT
       Caused all sorts of havoc onto my game screen.
    Well, none of the above is 100% correct.
    MOV @MAPDAT,R6 will not store a pointer to MAPDAT in R6, but the content of the memory word at MAPDAT. Thus your byte >D9 will end up at the address pointed to by the data at the first word of MAPDAT, not in the first word of MAPDAT. This will defnitely not be what you expect, and will perhaps lock up your computer. That's the least myserious thing that could occur.
    On the other hand, LI R6,@MAPDAT isn't correct either. It's not even correct syntax, since such a construct doesn't exits for the TMS 9900. What you want to do is LI R6,MAPDAT, since it's the value of MAPDAT you want to use as a pointer to the first MAPDAT word.
    To map an area in memory, that's not in line with your code, you can use a construct even TI's original assembler provides. You can use dummy segments, where the dummy origin, DORG, allows for generating entries in the symbol list, without generating any code.
    DORG >8300
    FIRST DATA 1234
    SECOND DATA >35F2
    THIRD BYTE 22
    FOURTH TEXT 'X'
    Will generate symbol table entries for the labels, like if they were assembled starting at address >8300. But no data is created in a dummy segment, nor loaded into memory at load time.
    • Thanks 1
  8. On ‎2‎/‎18‎/‎2019 at 10:49 AM, fabrizio said:
    I'm sorry I did not understand the word "housing" !
    I was referring to that the case for the "terminal" on the TM990/189 is the same case as was used by the TI 59 calculator.
  9. TI Extended BASIC to begin with. Then came the Maximem, a module simulator (like Gram kracker), into which you could load more or less any module. One at a time, of course.
    After getting the p-code card, my programming was mainly done without any particular cartride, as none is needed by the p-system. But I used the memory inside the Maximem as a RAM-disk.
  10. Well, if somebody reports to the FCC, or similar authorities over here, that they have noise preventing radio reception, then an on location investigation could take place, in which case your modified electronics could be found as the culprit, in which case you could be held responsible. But there are many "could" in that chain of events.
    One of the main reason the FCC was so worried about this in the old days, compared to nobody caring back then in Europe, is the general state of everyday technology in the US being some 50 years behind Europe. Here, FM broadcasts took over from the much more sensitive AM radio broadcasts in the 1950s. Thus there wasn't much concern about electromagnetic noise until all the computers coming in everywhere put the first requirements for legislation similar to what you had in the US in place in 1995.
  11. No, I've never used my TI expansion box without any floppy controller. When I bought the box, I got the flex interface, 32 K RAM expansion, RS-232 card, p-code card and TI disk controller from start. Put two Teac FD 55B drives in the PEB from start too.
    I've since changed to a CorComp double density controller, added two more IBM DSDD drives, added a real-time clock card and added an IO-card, with digital and analog interface circuits. The last addition is a Horizon RAMdisk. Now the box is full, unless the RAMdisk card is modified to contain the memory expansion as well.
  12. I never converted my TI to any real 80-column thing. Just simulated by moving the screen sideways.
    But when I did do word processing on the TI, it was mainly with TI Writer. Only texts intended for use on the p-system were written with the p-system's Editor program.
  13. 4 hours ago, globeron said:
    It is not really inside the TI-99/4 or /4A console, but in the PEB (and think it runs on its own like the UCSD Pascal),
    It's more like the Geneve. The UCSD p-code card is just a memory card, with 60 KBytes of ROM/GROM. It's still executed by the TMS 9900 in the console.
    This card has its own CPU (Z80), just like the Geneve has its own TMS 9995.
    Interesting to see their timing comparisons with the TMS 9900 and the Z80. The TI fails miserably, but a lot of that is due to the memory architecture in the 99/4A, not the CPU itself.
    The TMS 9900 would do the first example in 7.3 us, when memory is at full speed, and has more "registers" available.
    In the second example, they use the fact that the Z80 has a block move instruction. Still, with no wait states limiting the TMS 9900, and taking advantage of that it's a 16 bit CPU, thus moving a word at a time, the 9900 will still complete that sequence in 7 ms. So in this case the long time is both due to slow memory and inefficent programming.
