74 -
Posts posted by low.blow
Thank you very much for your insight. I did not know about inside corners. That could be a problem. I will have to double check how much gap I left there. The quote is just under $50US 5 board minimum. Not really worth it, but I've done dumber things...
Certainly not tied to this software, just seemed easy to use and was free. Do you know of any free alternatives?
Anyway, thanks again. Good information.
Hi all, I usually post in the Atari 8-bit forum but had an Amiga 500 question.
Back in the day, I had an A500 with a CSA Derringer and DKB Megachip in it. The problem was that the Derringer had to be raised
up with an extra cpu socket in order to clear over the top of the Megachip. The issue with that was that the Derringer now
interfered with the bottom of the keyboard and wouldn't fit in the case. What I did back then was remove the keyboard and attach
it via a cable, and use the keyboard externally. It worked fine, but was ugly.I recently found some of my Amiga accessories in storage, and got the bug to play around with that stuff again. I bought an A500
on ebay(rev 6a). I still have my Megachip, Derringer, external hdd, ram, etc... I want to put it all together again, but want to
do things a little different this time.I made a riser for the Derringer with proto-board and ribbon cable that offsets the cpu socket deeper inside the case(see attached pic). It allows
the Derringer to clear the Megachip and the bottom of the keyboard. But it looks a bit "hobby". So now what i've done is make a
pcb layout in PCB Artist by Advanced Circuits that does the same thing. I decided to also include a kickstart switch on the same
board. I borrowed the design for that from SepticSurgeon here.My question is, can someone look at the attached pcb layout and point out my mistakes? It is very simple, but I've never done
anything like this before, and I have no idea what I'm doing. The odd board shape is to fit around the megachip. Do my
measurements look right? Are the trace widths acceptable(power, ground, data)? Do the traces run where they should(I've looked
dozens of times and they seem right to me. The CPU riser is just pin to pin, and the kickstart switcher is pretty simple)?
Anything I haven't considered? The attached file is PCB artist .pcb format, but I can export a .dxf if needed although I have no way of viewing it to know if it
exports correctly...
TLDR:
Can someone look at my pcb layout(in pcb artist format, or .dxf if needed) and point out mistakes? Doesn't need to be perfect,
just functional.
Do the measurements seem right for a rev 6a mobo(to fit around a Megachip)?
Any advice I haven't considered(besides the waste of money)?
Thanks in advance!
Probably not doable any time soon, but it would be awesome to see this support the touchscreen mode of the colleen emulator for android. Maybe outside the scope of what you want to do though?
Just seen this - why on earth not PM myself or Andy - we're both on this board?!?
sTeVE
Oops, sorry if you didn't want this back out there. I will remove it immidiately if you want!
Is this the one?
It's funny, I had completely forgotten about my Atari until I moved and happened to run across the only piece of my Atari that I had left - a grey sio cable. Once I saw it, the memories came flooding back. I have been re- hooked since. Bought a 400, added ram and a video upgrade. Floppy drive, sio2pc, 850/830 etc...
Maybe not the most professional solution, but what I did is lined up and cut a hole in the perf board that all of the pins fit through - then bolted the tabs on the sio connector to the perf board. Then just soldered my ribbon cable directly to the pins. Perhaps not the best solution, but it is very solid.
Haven't had a chance to check it out on real hardware yet. But I just tried the digital edition with 'Colleen' on my android phone, and level 1 is quite playable so far. I imagine when I get a bit further, the touchscreen controller will be my undoing. Can't wait until I have enough time to play for real, but still great game so far. Thanks jacobus!
Cannot wait!
Silly question, but why not leave those pins physically disconnected?
n/m, I see.
The Rana drive can use the same supply as the 1050.
It was just after the xl series was introduced. I had an Atari 400 upgraded to 48k since they first came out and a rana 1000 floppy drive. I loaned the drive to a "friend" who had an Atari 800. He was having trouble using it, so he took it apart and ended up breaking it. I was too young to fix it, and too poor to have it fixed. I remember wanting a 1450xld sooooo bad, but no way I could ever get one. I just sorta faded out of computers after that, until I started hanging out with a friend with an Amiga. I had another friend with an st, and was torn which one to get, but eventually decided on Amiga. I used that until picking up a 486dx2 in electronics school. Pc ever since. Although, I'm running with an Atari 400 again, and am in the process of upgrading an Amiga to match my old system.
I was able to download all of the files, but was unsuccessful converting them to .cas. I tried wav2cas and a8cas. I don't really know how to use a8cas very well. I was able to create bad .cas files(and .hex files), so I'm pretty sure I was using it correctly(without using the more advanced options...). Maybe Kr0tki or someone more knowledgeable than I could get these fixed for you. Sorry! Good luck.
The levels didn't seem too bad, but the recordings seemed very noisy with a loud whining sound. Tweaking it in Audacity didn't seem to help...
I tried real quick to fix and convert the first file with no luck. I was unable to download the second file, dropbox 404 error.
I'll give it another go later on if no one else gets to it first.
Cool, can't wait to play it.
I really like this. Is the instruction pdf still accurate in that it should run on a 48k 400? Great job in any case. From the latest video, it's looking like a lot of fun!
I have never heard what that chip sounds like, but I picked up an nos one from eBay a while ago so that I can build a "cheep talk". Still need the oscillator and other components though...That's what my AtariVox has - it's a very capable and easy to program chip.
I will have to look up atarivox on YouTube and check it out.
I seem to recall ANALOG running an article on how to build your own speech synthesizer - a quick google shows #29 had an article titles "Cheep Talk". Wonder if that was the inspiration...
Could be, although the Analog "cheep talk" calls for an SP0256-AL2 speech synthesizer chip.
Bosconian?
Edit: no gods or grids.
He responded to a query I sent a few weeks ago about my sio2pc. It took about a week to receive a response. Fairly quick...
@Remo that is beautiful.
Can someone look this over and tell me if its alright?
in Classic Computing Discussion
Crap, my quote was $47 each! 5 minimum. I may be sending you a pm, if you don't mind sharing your sources.
I originally started with a smaller board(still over 100mmx100mm), but couldn't make it work without dozens of via's. It got too complicated for me to follow. I'm guessing the smart thing to do would be to split the board into two since both sections are discrete anyway. Looks like I could get each around 50mm x 130mm.
