1,800 -
Posts posted by digress
Cool.
I was able to compile the working rom.
For some reason my system doesn't recognize "make". But what I did was enter the make lines you listed above line by line into the command prompt and after it completed each step it worked.
Thank you so much. I now need to try and convert a music file of my own into your demo and see if I can do that step.
Thanks again. I'm trying it. No luck so far though. I'm getting his message when I try to compile using scdd 3.4
Try to link project : snddemo
Multiple definition of gsinit
C:\Documents and Settings\gerry\Desktop\coleco compiler\snddemo>sdcc -mz80 --code-loc 0x8024 --data-loc 0x7000 --no-std-crt0 ../crtcv.rel ../cvlib.lib ../getput.lib ../comp.lib crt0.rel main.rel music.rel player.rel
?ASlink-Warning-Undefined Global '_nmi' referenced by module 'crt0'
C:\Documents and Settings\gerry\Desktop\coleco compiler\snddemo>objcopy --input-target=ihex --output-target=binary crtcv.ihx result.rom
I can't get anywhere with this unfortunately. I got it to compile but I just get an unuseable rom.
Is there a simple c file setup including all necessary files in one directory and a sample music clip that I can compile in SDCC 3.4. Once I can get a working basic file I can figure it out from there.
That sucks, I bought Alcazar & Spy Hunter & Boulderdash & james bond back in the 80's via mail order. I think I paid like $70-80 for all 4. That was a fun week/month after I got that delivery
I actually like james bond. Finsihed it several times. ALcazar. Was really great for the time. Unless you had a c64 there wasn't much else comparable on the game systems.
Of course I still have them. Should have bought more.
I bet you say that to all the girls
Sweet box :-)
Here is the updated artwork
Another great update digress and thanks for sharing this with us as it's been fun watching the game progress over the last couple months.
The box looks very nice as well, but the positioning of the yellow Coleco explosion info splash is really throwing things off for me considering it has always been placed at the bottom-left corner by Coleco as well as Homebrewers. I understand the reasoning so as not to cover up any of the artwork of the box, but what about using the "For ColecoVision & ADAM Computer" diagonal info bar on the bottom-right... this way you won't have an oddly positioned yellow Coleco explosion info splash and with the diaginal info bar, there won't be much of any box artwork covered up.
Good Luck with copleting the game.
Thanks, That's a good suggestion. I did have it in the bottom left as you mentioned but it was too overwhelming.
I did the illustration before putting it into the layout to see how things overlaid and it was not ideal. I'll try the strip and show you the update.
no, windows7 64bit
you might need to update java to the latest.
I did all that, and I get a small pop-up window that says it cannot connect to the chat server.
EDIT: Are you using Windows 8.1 like me? -
Yes actually. I fix one thing and then new glitches show up. I feel like I'm House M.D.
Time pilot is great. Always liked that game . Played it to death. .. or is it played it til death usually my own planes.
Main problem I'm having now is memory as I'm basically at 32K rom size . I'm trying to improve things but I have to make other things more efficient in order to make room.
Learned so much from this . If I make a second game I'm sure there are many mistakes I'll not make twice. Too far along now to start over though.
Weird problems like sprite 0,1,2 & 3 would disappear from time to time. I had to use higher sprite numbers to stop the problem.
Ah, so the glitches are now glitchier?
Nice work, dude!AWESOME Gerry!! I won't be be worth a darn at it, BUT I live the action. Time Pilot has the same action type and I get all turned around and miss shooting the planes, but I love that game too. Great job, keep at it and finish it up, it will be a great game !
Here is a sample of my first prototype box for the game.
New colours, added trailing smoke effect. improved some glitches.
Slowed down the tanks.But increased the projectile speed and rate of fire. I may return to multiple hits to destroy a tank.
uploading a more current video Should be live in 11:15 EST
start>all programs>java>configure java
security tab
set it right down to medium and the chat will work
I've had the same problem.
Thanks, I've been using that. It's a great help.
Still it would be ideal to have a visual composer like video tunes. Which I actually tried using but it doesn't support for full range of available notes that are really available and I would need to figure out a way to out put to a usuable code.
Newcoleco put out a program called, cvnotes.exe. It has rows of button with the musical notes. It has box that provide the bytes for that note. I really need to try and find that thread on this program. This is what I use to sequence music and sound effects.
Found it: http://atariage.com/forums/topic/139854-cv-notes-tool-to-somehow-help-coding-notes/
Yes please, any help would be great. It's pretty difficult to develop music for. I may delay releasing my project if I find this could help improve the sound.
Thanks
battlechess
I looked through the video. I played it back in the 80's too. I see no reason why this can't be done exactly on colecovision and with better graphics than this C64 version so I don't think the designer will much problems limitations wise.
There are 36 characters on the screen with 2 colours each but only 2 of these are animating at any one time and the rest can be just tiles.
and the battle scene the characters are 1 colour plus 1 projectile each so it won't break the 4 sprites per line rule.
This is entirely possible on colecovision
It's going to turn out great I have no doubt.
Bill,
it's a bit too early to think details. We hope - in this preliminary stage of development - that it will resemble Archon I at all
Seriously, considering the ColecoVision's limitations compared to the C64 and Atari XL/XE the developer has his hands full to do. -
I think a sega master system modified to run colecovision games would solve many of these problems
It even has an everdrive available and can already run sg1000 games.
Hi, I ordered a copy of Astro Dodge last year and it's really well done. Very nice graphics and sound effects.
Tell us some more about 'Shifted' and possible a screen shot or video. Thanks
Hi Guys,
For those interested, i still have a number of copies (both Coleco/US and CBS/PAL style) available! PM me or email me at sales (at) revival-studios.com to aquire your copy.
For those interested in new releases for the Colecovision, please be a little more patient. Since i write my own stuff instead of 'borrowing' copyrighted MSX games these take a little more time to produce
I hope to have my next game 'Shifted' out this summer.
Kind regards,
Hi Guys,
Kind regards,
Martijn / Revival Studios
that's funny that's exactly my thought. I was programming a tank slowdown routine til 2 am this morning. will be in the next iteration. I might even put a bit of shake to the tank when it comes to a stop are first starts. we'll see I'm almost out of room
-tank slowdown
-I might put in reverse as well. not sure yet.
-I added a smoke effect that blows away after firing
-I had 3 hit points to kill a tank but it wasn't fun that way. 1 hit ,1 kill keeps you on your toes
planes are too fast too but there are 2 speeds for them if someone has trouble they can just keep it in slow.
working on the music a bit today.
Great preview
but as being in the military a have drove a tank, I feel the speed is a bit fast for the tank movement.
But what do I know, the game itself looks awesome.
https://www.youtube.com/watch?v=i1JVZ-0F8dU&feature=youtu.be
Here is a micro update to show the tank is now more 3d looking in profile view.
Great stuff - this looks fantastic. PM sent.
One suggestion: in my opinion it would look nicer when the tank is also three dimensional when facing left/right horizontally.
Looks really good, digress!
I do have one tiny comment to make: When the tank is facing left or right, it is displayed as a 2D image, but in any other direction, it is displayed as a 3D image. That looks a little weird in terms of animation.Looks better and better each updates!
https://www.youtube.com/watch?v=-1L-94qO0Zo&feature=youtu.be
Here is an Updated video on some progress that I have made.
-some music. It's simple music right now I hope to improve it.
-sound effects
-fixed disappearing sprite issue
-added new screens to add some variety
-added solid buildings tree obstacles, rivers, rocks bridges
-most obstacles are destructive
-improved explosion effect
-changed title screen to greyscale with new layout to save some Kb-
To me it's bizarre that these have become difficult to sell. I use my original modded xbox more than any other system... because it emulates so many other systems.
It plays dvd's
it plays streaming video from your computer
It can provide streaming video to your computer
It plays NES, TG16, Atari, Colecovision, Sierra adventure games, Mame on and on. Sega... super nes... etc.
It can even play PS1 games
It also plays music
It also has 4 built in ports for 4 player games (dungeons & dragons heros is 4 players simulataneously)
It plays Halo & Halo2
It plays copied/backup up xbox games
It can install the game straight to the harddrive
You can hook up a usb mouse & keyboard to it to play sierra adventure games.
Beyond awesome. Plus the one you are selling has an upgraded 80 gig drive and is already softmodded and comes with a working controller & the av/power cables.
Somebody buy this , you will not be sorry.
That is a good point though. We are skewed towards the colecovision side of coleco but if you are looking for lots of hits and bigger traffic etc then perhaps it should be coleco & not colecovision
Might be lots of rod hockey enthusiast that might drop by for instance if they have a place to share
its a fact that not many girls played the retro games much. I'm sure there's a few. But as a hobby I'd say even less so when it comes in my house it's my time away from the wife... plus anytime I start speaking logically.
Although She did get hooked on jewel panic one day on the colecovision.
Colecovision.com - would be my ideal. Easy to find and easy for new people to find. Doesn't seem to be available though.
VGM Compression Tool
in ColecoVision Programming
I have now managed to convert a different vgm file and successfully compiled it and it sounds great. Now I need to try to get it into my program and compile under SDCC 3.4
