chas10e
    849
Posts posted by chas10e
  1. wow, I didn't really know there was actually a member feedback forum ...
    bought some 2600 stuff that is really fun to play ... Dave gave recommendations on how to make a smooth transaction,
    items came quick & exactly as advertized at a reasonable price.
  2. The third pin from the left, in the top pic, that leads to the dab of solder next to "REV E" looks kinda scraped up or something? in the photo.
    yeah that was solder splatter that came off the end of my iron as I was reaching to clean it off .... wasn't there when I started project :_(
    I wished I took a before photo ... also next time I'll try & crop them before hosting
  3. TRIPLE POST ??? yikes
    being newto these forums I hope that's ok: ( I don't see an edit button )
    also i said I was going to post some images so I have to give that a try:
    I'm not at all proud of the work ... the cart has failed (black screen) for better or worse here it is
    (flaming to a minimum please)
    inexperience with the desoldering tool ( looks like a soldering gun with a bulb on top) caused most of the overheating I believe ... tiredness& bad eyesight a contributing factor
    the spool of solder I was using originally has no markings on the label to indicate its size & flux ratio ... all it says is that is is "lead free" basically .... I wished I looked at size when I was loking at other spools
    I bought some helping hands with a magnifying glass attached, a new spool of solder 60/40 rosin core .032" diameter (has lead I imagine) & some desoldering braid
    to say I didn't care about my Asteroids cart wouldn't be true (to look at it you might not think so) I did get to see it power up for just a short bit though ...
    so some more questions:
    • can I use a continuity meter to determine if there is continuity from the contacts to the EPROM ? ( or both sides of the board before the EPROM)
    • for a cartridge of a higher rarity value what sort of place would I take it to to be "professionally re-flowed" should my skills not improve ?
    I do appreciate your time & input and a bit embarrassed about the pics
  4. double post ? ... I'll figure this place out I hope ....
    went & got corded irons ... 7 bucks @ sears for 30w ... & 12.99 @ Radioshack for desolder-iron ...
    I had some solder & it seemed quite expensive to just snag another roll ...
    the solder I have just says "lead free Rosin Core ... fairly small , maybe the size of pencil-lead ....
    at first it seemed to work , initial start-up the screen rolled but when I hit reset button the game started .... I played only for a short bit before turning offthen on again
    then it wouldn't start , got horizontal lines across screen .... Itinkered with re-flowing solder in first row with no change , filled other holes previously that didn't seem to be filled from factory with no change ,
    I tried other console , no change
    I wished I took before phot'o's .... I don't really wanna take after photos as the job doesn't look to neat ....
    I don't think I bridged anything ....
    To reflow 'em, tin the iron, then just touch the iron to each joint long enough to get the solder to melt. Add a tiny bit of solder to each. Once you've reflowed that dead Asteroids cart, use the desoldering tool to remove all the solder and do it all again. Repeat this until you're comfortable reflowing and desoldering that cart. If you make a mistake, there's nothing lost since the cart was already dead to begin with.
    Yes, you can run solder though the empty holes. I typically do this on a reflow if I can't get a response from the cartridge at all. If the cart loads intermittently, I'll skip that part until I've reflowed everything else and tested it.
    yeah the whole point of the exercise is the get comfortable soldering , Asteroids , being a great game , is common & I have a repllacement already ( & I think a cib on the way )
    the de-soldering tool is tricky ...
    whats the reasoning behind ... re-flowing adding solder then removing it all ? ... I probably only needed to re-flow a bit & add a bit I guess ... OOPSIES
    I'll rince recycle -repeat tomorrow perhaps .... my eyes are bugging out
    I did try a reflow on the EPROM pins without removing any solder ,
    again I don't think anything was bridges unless between the green film somehow ( is that possible ? )
    if you desire pics of some gorrilla soldering , lemme know I'll just have to figure out the BB-code for these forums
  5. I'm tottaly going to Radio Shack .... that desoldering thing looks pretty awesome ... I do have a desoldering bulb .... I never tried wick
    First, lose the butane iron. Grab yourself an electric pencil style iron that's rated anywhere from 15 to 50 watts. Grab yourself an electric desoldering iron within that wattage range as well.
    I JUST lite the thing up when I read that ....
    good for use when your a million miles away from some power ....
    k , off to teh store ... prolly grab a sammich too
  6. this particular cart I was planning to use double sided tape ... specifically the tape that cam with cold weather window film it happens to be about the exact width of an end label
    the origonal glue on the face label still seemed pretty useable (picured varient of aeroids) next time I probably would only peel enough to access the screw
    3M also makes a spray-on adhesive I dunno if theres a roll-on type adhesive
    but again this cart is for me to practice on ...
    Good news: your Space Shuttle hasn't gone bad. Either it needs the solder re flowed, or it's simply not compatible with your console. Space Shuttle has, essentially, two different programs out there. We've found carts with FE and (I believe) F8 bankswitching. I don't know the full story, but I do know I stumbled on an FE cart by pure accident when I loaded in up on my 7800. Up to that point, I thought Space Shuttle wouldn't work on a 7800, but I tried anyway, and mine did.
    Also, over time the solder points in some carts will simply fail. It's an easy fix, and usually manifests as a cart that works intermittently. My advice is to try Space Shuttle in a different console--if it works, it's a compatibility issue, if not, it'll have to be opened. I'm leaning towards the latter.
    Asteroids is so common that I would just grab another copy. Steeplechase may have a dead ROM IC. I usually re flow any boards I suspect to have a dead ROM, though, just to make sure. In your case, the box and docs from Steeplechase might be worth what you paid for it.
    I was typing & thinking when you posted this ... it seems to be what might be the deal
    again I have crude equipment & probably cruder skills at this point ...
    what would be some good birthday gift ideas I could give to my family ? :-D
    warming table?
    temperature controlled soldering iron ?
    techniques on reflowing solder may be helpful
    if I don't respong to this thread in a couple days ... I probably burned down the house & in the hospital
    He had thin horizontal black stripes, so you could say he was like a fugitive in that regard.
    The things is, though, he had the stripes on his head, too, so maybe more like a performance artist.
    horizontal stripes ... prolly more like a corrupted referee
    is the color set correctly on your console & your TV ... I hooked my latest heavy-sixer up to my 55" rear-projection TV & split it to my old 19" & discoverd having it on a "movie or sports" setting affeted the colors greatly .... I did have to adjust the pot inside the console as well .... but first needed to get TV right (Pitfall 1 was one of the carts I used to see if colors looked right.
  7. I have already a replacement for Asteroids ... and it very common , so that's the one I experimented with . ...
    still no luck with it ...
    cleaned with 91% alcohol a few time before ... did again to no avail (q-tip wasn't soiled)
    this is the first cart I had ever taken apart .... almost got entire front label off with out messing it up ( DOH! )
    cleaned contacts with a high polymer white eraser ... put in console EPROM up as it would be in the cart , same thing
    I noticed the PCB has holes with solder in them to switch sides of card ...
    from the EPROM toward the contacts that go into the console ... there is a row of 6 holes , some have more solder in them than others ... next row has 5 & last has 2 .... BOTH rows have no solder in them.
    this particular cart I know was stored in an unventilated attic for a good number of years (15 or 20 + )
    the main reason for this post is the $18.00 I payed for a cib I was hoping to give to my niece of "Steeplechase"
    should I try re-flowing the solder in the holes that have solder ?
    do I fill the holes with solder that doesn't have solder?
    do I put a continuity meter from each contact to a point in the EPROM ?
    I only have a butane soldering iron & not any kind of fancy one
    to bad Pitfall Harries strips didn't come .... did he look more like a fugitive or a mime ?
    in YARs Revenge I believe "ITARATARI" is the code used to create the force-field in a normal (good thing the programmer didn't use something obscene !!!
  8. not long ago I came across my first dead atari cart. it was "Space Shuttle" after reading missing manual here in AA & making a crude overlay
    the game would seem to start then messing with the various console switches if I just graze the cart as it's in the console , it's like I pulled the cart completely out & get a bad screen & tone (zig-zaggy horizintal lines)
    that was really a first try for that cart.
    immediately, after that one I tried a game I've played before went bad .... Asteroids
    that cart I get the score & the space ships & music , but no rocks to shoot at.
    I tried cleaning the carts with 91% alcohol , I tried cleaning my Vader unit cartridge slot (cloth wrapped around credit card)
    today I got in the mail "Steeplechase" the PCB pins on it look brand new as it came "cib" all I get is a black screen on this one a few times I'll get two vertical green lines
    did the first bad cart do something to damage both consoles ? ...
    what goes wrong with them ?
