chart45
    858
Posts posted by chart45
  1. I am really enjoying this game, but could someone tell me how to beat the first boss? It's probably really simple, but everytime I get to it, I can only take a couple hits from his hair before dying. Not sure if I'm supposed to dodge the hair and attack with the beam or something else. A small spoiler would be helpful to get moving along in it. The instructions are very vague. Thanks
    https://youtu.be/BbobE4HSA2E
  2. Nice! This is a major breakthrough for the ColecoVision, as there are quite a few steering and paddle-type games out there!
    Thanks for using your creative energy to support the ColecoVision!
    I would love to see a PCB produced.
    i made one with eagle i'm waiting for it... i dont put to much hope on the first rev since i'm not to good with this kind of stuff.. if it work i will share like i did with the parker brother pcb
  3. Just curious. Is it possible to give a quick assessment of whether the driving controllers board components are common enough one could build a driving controller board with your device to put inside another racing wheel like a thrustmaster without cannibalizing an existing Colecovision driving module?
    here the diagram...
    http://www.le-grenier-informatique.fr/pages/la-collection-d-objets/colecovision-expansion-module-2.html
    there is nothing you cant find
  4. Hello all!
    My friend wanted to test the Colecovision he bought without the PSU. Didn't work and then we verified with my own machine (from which the PSU we used was on). And it didn't start either. So, maybe my PSU has died (haven't used it for a long time) or friends Colecovision broke my PSU ;)
    I measured the PSU and got only 10V from 12V line. All others seemed fine. I don't know, if I will bother to cut the PSU open and try to repair it (there seems to be a kit for this).
    So I though to use an Jamma-PSU, very cheap from ebay. How much there is room inside CV? Smallest one I found was this (http://www.ebay.co.uk/itm/Silver-Output-5V-12V-24V-7A-6A-2A-Switching-Power-Supply-For-Jamma-Arcade/263237080002?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649) and I was wondering, if it would fit inside CV. Seems to have enough current output and would be very easy to install otherwise...
    i use this one for years inside my cv
    http://ca.mouser.com/Search/m_ProductDetail.aspx?Cincon/CFM40T-01/&qs=a9HUcNGsM2BO67El0yNmhQ==
  5. I can confirm that Kung-Fu Master works in CoolCV without issue.
    you dump the game from the cart or you got the rom from collectorvision (Beta tester) cause on the cart the decoding is not the same as the others 128k game so the dump dont work properly... or you have to open the cart dump the chip and than edit the file to change the banck switching address....after that it will work on atarimax and coolcv...
    or they release 2 version of the game?
  6. as you can see my english is not really good
    so if you look at the diagram the transistor are on off switch for the 6v batt... when the coleco is on the orange wire is high so transistor let the power from the battery pass trough... the coleco need both signal on purple and white wire its the way he knows if you turn left or right... my goal is more to have a padle than a steering wheel but both project could be achive at the same time... the only thing we need its a small rotary encoder with enough complet cycle in one rotation... it should be easier in the steering wheel project since you have more space to work...you can use gear to change the ratio and have more complet cycle in one complet rotation
  7. i use those little rotary encoder in my video
    https://www.ebay.ca/itm/171906808593
    the problem is the number of pulse in one rotation
    this is why i need a doubler circuit and a way to be sure to not fry the fragile cv controller chip...
  8. last year i was working on a padle project and i let the project down since i dont have time to work on this... i know i have nice hand😉
    this little pcb with dual reluctor work with out any power source but since it so little my plan was to make a signal multiplier circuit but this pcb will need a external power... i think guys like dave,brian or harvey could build it in no time
