mizapf
    5,366
Posts posted by mizapf
  1.
    Why did the TI programmers not see the need to zero GPLWS R8 like the following (as in the console ISR)?
    Well, because to err is human and to write crappy code is a particular form of that. We do have some bugs and bad designs in the TI ROMs, like the DSRLNK that is already in the console but always returns to the GPL interpreter, or the bug in the TI disk controller that produces unexpected bytes in the preamble, or the cassette routine that just happens to work correctly but actually has a big flaw in it.
  2. So you don't use the file name stored inside the TIFILES file? (If there is one)
    I'd expect relying on the name in the host file system can cause trouble with the missing case sensitivity in Windows systems (while the TI file system is case-sensitive).
  3. I have not heard of problems with particular applications in MESS.
    Please allow me to point out that I included a disassembler in TIImageTool that can disassemble memory dumps (PRG), tagged object code (D/F80), and GPL. Maybe it can help you even better than DISkASSEMBLER.
  4. 10.6 on an Intel core 2 duo Macbook Pro it would run and function. I could not seem to find an option to extract a dsk or a lone file from the dsk to a folder. I'll have to try again to record the exact error message, something about the destination folder/file couldn't be found. The program would create the foldr, but it was left empty. I was able to make a new .dsk folder, which came up as a tab in the program window and put something on it, but it was still in .dsk format. The docs aren't clear enough for my adelpated noggin, but maybe if I spend more time, I'll figure out where I've gone wrong.
    You can export a single file with right mouse click on the file (show the context menu), then select "Save as TIFILES".
    You can export a complete disk with the Export function in the "File" menu. Select a target directory, then save. You get another dialog window that asks how the file names shall be created. Finally, you get a message window "Export completed successfully".
    I once suggested to use the extension ".tfi" for TIFILES format (as a general indication regardless of the tool or emulator), but there are also other extensions (like xmo, because Xmodem tools were the first to create such files) or none.
    BTW, the 1.5.0 you get from the "Get info" most likely shows the required Java version, not the release number of TIImageTool.
    The Export function works recursively, just in case you have subdirectories on the image.
  5. Thanks for the help! Using 10.4.11, it would run by clicking the jar file. Menus worked to locate a file, but then it would be a spinning wheel.
    This is an indication that an exception occured. Could you please run TIImageTool from a shell / command line and report what is printed there?
  6. The diagnostic program cannot run with Editor/Assembler because of
     AORG >7120
    at the beginning of the file. Unless, of course, you somehow installed RAM at that location. I'd expect that loading seems to work, but the console will lock up on start or do other weird things. The REF/DEF table will be updated, but points into the void.
    If you remove that line or do a AORG >A000 there is some hope that you can assemble it for E/A as usual, and it may run. Take care of the memory test routine; it must not overwrite the test program.
  7. Hi Robert,
    what I know about the standard TI 32K is that the even bytes appear as 0xFF while the odd bytes are 0x00. That is, after power-up, memory words show up as FF00 FF00 FF00 etc. This is also emulated in MESS when you turn off the 32K console mod and instead plug in the 32kmem as a peripheral card.
    There was one case where this behavior made a big difference: The TurboPasc99 compiler and runtime refused to run when memory is initialized as 0000. And I remember that it was the time when I upgraded my console when I gave up on TurboPasc.
    What 32K mem are you using in real life?
  8. It is START, but you should be more specific about "not get it working".
    BTW, tigameshelf delivers this file wrongly by text/html MIME type, not application/octet-string as would be appropriate. This can be defined in the webserver's conf file. I wondered why I get the file as a dump in my browser.
  9. OK, there is one issue in the code: The reported CRU address is wrong. The bit it actually wants to complain about is 1304, not 1302, but as we see in the CRUERR block, it takes the R12 address, strips off the first 3 hex digits, moves the remainder to the high byte but divides by two: (0x1304 & 0x000f) << 7
    This makes sense when you want to say: "Bit x", but they add the string "130" before (BASE).
    So if the address is actually 1304, we can see in the CRU map that this is the HANDSHAKEIN pin when reading, and doing a SBZ/SBO means to set the HANDSHAKEOUT (see Thierry's CRU map). I'd say this is not guaranteed to be equal. So maybe this is a false alarm.
    *** CRU BASE ROUTINE ***
    CRU    INCT R12
           SBO 0
           TB 0
           JNE CRUERR
           SBZ 0
           TB 0
           JEQ CRUERR
           CI R12,>130E
           JEQ PIO
           JMP CRU
    CRUERR LI R0,>169
           LI R1,CRERR
           LI R2,11
           BLWP @VMBW
           ANDI R12,>F
           SLA R12,7
           LI R0,>1A9
           LI R1,BASE
           LI R2,3
           BLWP @VMBW
           MOVB R12,R1
           AI R1,>3000
           LI R0,>1AC
           BLWP @VSBW
    CRWAIT JMP CRWAIT
  10. The hardware for the 99/8 Hex-Bus is in the OSO chip, Michael.
    As far as I could figure out from the schematics of the 99/8, and in particular from the OSO chip, the chip is mainly a bus adapter that cannot do much more than converting 8-bit bus words in the console to 4-bit words on the Hexbus and back, and also processing control lines (like "bus available") or raising interrupts. IIRC at the other end of the bus there is a complete controller system together with another 9900 or 9995 that gets the words from the bus and executes some DSR.
    In MESS I implemented a simple version of the OSO mainly to avoid a lockup.
    Also, let's see what the schematics reveal. If there is a processor, it will also have some ROM, and this can be difficult to dump; probably only by taking out the ROM and reading it in a special device.
  11. Judging from the diagnostic tool and from the schematics, the CRU Bit error message may indeed indicate a defect 74LS259 latch or other issues on the signal path. The error message is printed on the screen when the bit value read via CRU differs from the bit value previously written on the same address.
    Concerning CRU operations, it is not guaranteed that you can read the bits that you previously wrote with SBZ/SBO/LDCR. The circuitry must allow for reading bits via CRU and giving them meaningful values. In this case, we can actually read the latches values.
  12. We already have the Hexbus ROM, but I still need to "guess" a suitable hardware for it; this is the main problem. Apart from the fact that there is still a lot of other things to do before.
    To do it properly, we need the schematics of a Hexbus floppy. Unlike our 4A peripheral devices, the Hexbus devices are more autonomous; they have an own CPU with a device operating system. On the other hand, as we only have high-level commands on the Hexbus, we can do something like an "abstract floppy drive", that is, when we have a command like "read a sector", we'll deliver the sector contents from the disk image, and not involve a complete disk controller emulation.
  13. You can see Exbasic II in action in the TI-99/8 emulation in MESS. However, at this time you cannot use floppy support because we still need a Hexbus floppy emulation. The DSRs on the existing controller cards do not work with Exbasic II. Briefly, Exbasic II sets up the PAB in CPU RAM instead of VDP RAM, and finally locks up; you can start it when you don't plug in any controller for now.
    On the Geneve we have ABASIC.
  14. Is it possible to put in a feature request?? I'd love to have side by side windows and/or windows you could drag and drop between. :thumbsup:
    But these are already two features: separate windows and DnD. :-)
    I have them on my list; for that reason I'm counting with 1.5x instead of going to 1.6 because this is my plan for the next release.
  15. Hi
    I just got a TI rs232. At this moment I don't even have a cable made up for it.
    I loaded the TI diagnostic into MiniMem. When selecting the RS232 test it shows a bit failure at 1302
    I used easy bug, C1300 1 and the card doesn't turn on.
    It does turn on at C130E 1
    Is this normal for the rs232 card ?
    Yes. The RS232 card uses bit 7 to control the LED. Unlike other cards, it does not light up when the DSR is active. Bit 7 at base 1300 is 130E. This also explains why nothing can be seen on the LED when setting 1300.
    I don't know what exactly is tested with the diagnostics. Maybe you should have a look at http://nouspikel.group.shef.ac.uk/ti99/rs232c.htm#CRU%20map which lists all bits with their meanings. Bit 1302 is used for PIO, not RS232.
    (Why is the forum software always messing up weblinks??)
  16. All I really want to do is convert the DOADs to FIADs. I'm closer to doing that with the V9T9 Java version on the laptop.
    Well then, if you have Java anyway, why don't you try TIImageTool? This is one of the use cases I wrote it for. You can "export" the disk image to your host file system and get a collection of TIFILES files. I guess this is what you want ot achieve. Works with sector dump images (v9t9) and track dump images (pc99).
  17. I never had any contact to Spectrum users, most had a C64, I had some contacts with fellow TIers, but I was always wondering how the Spectrum compared to the TI.
    Now with MESS, I finally had a chance to get a glimpse, but the first impression was quite, well, modest. In fact, now I know that our TI has a fairly pretty presentation with its master title screen, module selection, and the Basic. Although, as we know, the stock console has its disappointments, without any doubts.
    So if you had a Spectrum, how did it "feel" like? (Apart from the rubber keyboard.)
  18. Why "dir"? - Quite simple: "ls -al" are two words, and they appear as two separate arguments. Also, I used "type" and not "cat" for a text file output. I don't want to imply that you get something like a shell with all of its functions.
    You may have noticed that "lsf" is an analogy to "ls -F".
    And actually,
    $ alias dir
    alias dir='ls -l'
  19. I remember I had the ones with black button and an orange line around it, and I think the Texas Instruments name was white (but my memory can fool me).
    Today, I still have my Competition Pro, and when I recently opened it I noticed that there are no signs of aging, despite the groaning noise it makes when I play Munch Man or TI Invaders on MESS. But this seems to be merely caused by the rubber around the lever.
  20. From time to time I still learn new things in Java ...
    The first invocation (with -jar) made the class loader fetch the ti.image.TIImageTool class (declared as the main class within the jar manifest), which references some Swing classes (graphic toolkit). Although no window is brought up, this seems to imply a lot of additional (but useless) class loading, maybe also initialisations in static parts.
    The second variant loads ti.image.CommandShell which does not reference TIImageTool itself but only the support classes for interpreting images. Accordingly, no Swing elements are loaded, and things become much faster.
    The HFDC has support for floppy directories, but (as with GeneveOS) only for three subdirectories in the root directory and no deeper nesting.
    The SUBDIR argument is comparable to the argument of directory list commands in DOS or Unix shells. That is, if you have a directory ABC on your floppy disk or hard disk, you get a directory listing of ABC if you add it as the final argument (CommandShell dir imagefile.dsk ABC). On my hard disk, I can use "CommandShell dir myharddisk.hd ASM.DIV.PROG" to get a list of all files (and subdirectories) of the directory HDS1.ASM.DIV.PROG.
    If you have some skills in shell programming, you may be interested in the "lsf" command. It decorates directories with a ".d" suffix. That way you can implement a recursive search in a script file by getting the names, looking for strings with the ".d" suffix, and using them for a new invokation (clipping off that suffix, of course).
    The lsf command also decorates file names of type DIS/VAR 80 with a ".t" suffix. Again, you may make use of that, for instance, to implement a search tool in a shell script. (BTW, I uploaded yet another version, now including a "type" command for text file output.)
    Did I already say that I love script programming?
