repetto74
266 -
Posts posted by repetto74
Hi Nezgar,
Thanks I do have a ATR copy of the DOS 2.5 :-). I will give this a try then and let you know.
Ensure ONLY the 1050 is attached to the SIO when running those tests. (NO SIO2SD)Yes the SIO2SD was disconnected.
Good to remind me to do this with a formatted disk. Unfortunately I do have a lot of disks but for the C64 only. I have a bunch of DD disks also but not formatted with Atari DOS.
Back with news. I am definitely not done with this 1050 drive. I have loaded the Diag Test with the SIO2SD device then connected the 1050 drive with the SIO cable I have for the 1010 datasette (should be the same). First thing I noticed is the activity light staying on longer compared to a power up without the serial cable connected to the 800XL (??). Then I ran the complete test but as the first two test passed all the rest has failed. I have then selected the motor speed but what is worrying me is that I can hear a 3 tone sound repeated all the time and the speed counter stays on "0". I am a little bit lost on what to do as this is my first 1050 drive.
Ok thanks I will sort this out and find a suitable rubber ring of same thickness
Hi Dragonstomper,
Thanks a lot for the clarification
.Sounds good then. I will try to boot the diag test from the SIO2SD and then connect the 1050 to go through a full check then. Ok so the Darlington should be good also as I have a nice +12V :-).One final question : I am missing two of those rubber fittings installed between the drive mech and the main case screw holes. It is not a big deal if I do not use them but in case any idea with what can I maybe replace the missing ones? :-). I think the main idea behind those rubber rings is to avoid vibrations.
I hope the square belt keeps working, because your Hong Kong model needs a flat belt... Thanks for the info! I will keep you posted if something fails
Good to hear you found the issue. I've had the exact same problem in two drives in the past.I have had good success with 6810's from this seller in Switzerland in the 1050:I have a couple of spare for a TI99/4A which uses those rams :-)
I have a question now concerning the combination of the 1050 drive and the SIO2SD device. Can I daisy chain them? I mean connect the 1050 as device 1 to the 800XL and then connect the SIO2SD to the drive? How can I boot from the SIO2SD device then? I am asking because I would like to boot DOS 2.5 from the SIO2SD to format a disk and test.
What I did also is to clean the R/W head with IPA. I will not change both regulators as they are outputting just 12 and 5V so they are still good (maybe some fresh new thermal compound). There is a third regulator on the board but I do not know its function.
which one did you use? The flat one or the square one?which one did you use? The flat one or the square one?I used the square one. The flat one was a little bit smaller and maybe forcing on the main cassette drive. I had some reading issues at the beginning but cleaning the head with IPA fixed the problem :-)
Hi Fred,
Thank a lot! Yes luckily it was just the 6810 RAM chip which was causing the problem + my mistakes at a certain point where I mixed the connectors but all looks fine now!
PS : By the way the cassette deck player 1010 is fixed also. Your new belt is apparently working good
Job is done! Sorry I did really waste my time and yours here
. I have checked on the service manual and it appeared in fact that many of the connectors where mixed and connected the other way around!! I have never fixed a 1050 drive this is my first but as you can see the drive now boots good
. At least I found the fried RAM on the first board.
I will run a diagnostic test now I assume there are maybe some tuning to be done. I will try to load the test from my SIO2SD device and then hook the 1050 drive with the SIO cable
Maybe we have another 1050 taken out from the grave :-)
Ok so I have swapped all the main chips one by one and tested (FDC,CPUT,6532,ROM and RAM). I had exactly the same problem for each swap except when I swapped the RAM 6810 and there I had the dead drive mech and no activity light of the first board :-). So this RAM is bad. What I will do is to use the RAM of the second board into the first board and fire it up.
In the picture enclosed this is how I found the main connectors hooked up. Someone may have put his hands there before so can I be sure they are correctly hooked? I have a doubt when I see J10 and J11 not sitting close to each other.....
By the way thanks for the park sensor supply but I am located in Europe :-(
As you can noticed from the video the R/W head is bumping at the end of the track rail (like some of the 1541 Commodore Disk Drives) but I do no think this is a normal behaviour.
Hi Guys,
Got a 1050 DD for a few bucks sold as non working. I received today a 9V AC 2.1 amps PSU and can start my troubleshooting.
The power led is coming up but that's all. No motor spinning and no movement of the R/W head mech. The activity light is off also.
What I have tested for the moment is the voltage at the 7805 and 7812 which are both fine and read +5V and +12.05V.
I picked up also a spare board untested for a cheap price. Swapping the board with the second and I have now the drive mech coming alive, the disk motor spins briefly then the head mech will step forward and then back to the track sensor and stops. Then the activity light turns on with the disk motor spinning, then all off and on again in a repeated pattern. Is this an indication of a fault code?
I will keep this board for the moment and try to repair with this one. For the first board I may think one chip is fried and does not send commands to the drive mech but I will see that later. Let's try to make a working drive with what I have :-)
Here is a video of the 1050 in action
Thanks
Rick
Thanks Adam1977 but I finally picked a RockPower PSU :-)
On amazon, you find the RockPower PSU with european plug (and probably with UK plug if on Amazon.co.uk).Here is the link to the French amazon site. But I am pretty sure that you will find the same item on the Amazon website for your country.Yes I found the RockPower PSU from a seller in Germany and I am located in Belgium so ordered one for 16 euros :-). This is done.
I might have found a supplier of 9v/3amp AC adapters for the UK, i'm waiting for the seller to get back to me and once i've made sure it works on my 1050 i'll report back and maybe we could do a group buy and get them a little cheaper; i'll keep you all informed I am declaring interest also for a 1050 PSU :-). Located in Europe also :-)
Hard to find higher AMP 220/230V adapters currently, but 2.1A should be sufficient.Is 2.1 amps sufficient? I read somewhere it would need more around 3 amps to be on the safe side and avoid PSU overheat.
EDIT : I have checked other users and there is this RockPower PSU at 2.1 amps which seems to work pretty good so I just ordered one :-). Just to wait a couple of days and I can start some T/S.
Hi guys,
I picked up a 1050 DD non working for a few buck and I would try my chance to repair it.
-the drive came with no PSU and I know it is difficult to find one but if anyone has a link where I can get one of these 9V AC PSU's. I am located in Europe and need a 220V PSU.
-With the hope of putting my hands on a suitable power unit I would like some tips on how to diagnose fault on this drive. Apparently the guy said the red light comes up but that's all, no sound of motor spinning or whatever. It may have a problem with the 12V line of the motor I think but will need a PSU for that. Where should I check for the 12V inputs? The 12V regulator?
Also what can i check now is the impedance of the read/write head to ensure it is ok. Does anyone have the resistance values at each pin of the R/W connector for me to check ?
The mechs is a TANDON.
Many thanks in advance.
Yes the zig zag pattern is only visible with an LCD screen and lifting one log of C54 has completely cleared them :-)
OK I have solved this finally! :-)
For info the right hand side of resistor C54 should be lifted up. This will cut the RF box from the video signal so you will loose composite output but the zig-zag patterns are completely gone by doing this. Probably the RF modulator is just making some interferences.
Hi Fox-1 / mnx
Sorry for pictures, the problem comes from pictures taken in landscape mode with an Iphone :-)
With that being said, those symptoms can also show up when using thin cabling, or bad cabling, or too long... well, anything with cabling, but that's just one possible cause of many.Can't be the S-video cable as it is the same I am using with the modded 600XL and the output is far better.
Hi Guys,
This thread is old I know but maybe some of you can guide me through a small issue I have with this mod. All looks fine and I have a crisp and clear picture on a PAL 800XL after performing this mod. The only thing is a checkered pattern I do see on the background which I do not have on another 600XL after having performed a different mod. I am using an S-video cable with an LCD monitor.
What can cause this and is there a way to improve the image?
PS : The 600XL mod looks totally different, I remember having to cut a couple of traces and solder some resistors in parallel but the result is much better without this zig-zag effect.
Many thanks
Rick
Hi Ksarul,
Thanks for the info. I bought a couple of TIM9904ANL a week ago from the same seller of your link :-). So waiting for them to test. I have a programmer which is the TL866 and do not know if it can test also. I will keep in mind the 74LS362 as a probable replacement also :-)
The TIM9904/74LS362 are early versions and need a 48 MHz crystal. The later TIM9904A needs a 12 MHz crystal. So check the markings on the crystal and that will show which version of clock chip you need.
The original TIM is marked TIM9904ANL so I assume it is the one for a 12 Mhz crystal. Next time I will crack open the TI99/4A I will give this a look
Attempting to repair a 1050 Disk Drive-no activity light no motor/head spin
Hi Nezgar,
Noted I will fine tune the RPM and let you know :-).
