repetto74
266 -
Posts posted by repetto74
Yes I do have the original still working. I am just buying spare parts whenever I found them just in case :-)
So you mean I may try to piggypack the original clock generator with the new one?
HI Home Automation,
Both IC's comes from the same reseller and I barely do not think tahat they mix good and bad IC's. I am somehow convinced that the TMS9904ANL is not the proper clock generator suitable for the TI99/4A.
Hi Guys,
I am buying some spare parts of the TI99/4A to have them available for any repair needs. I have found some e-bay resellers in China with VDP chip, Clock generator, CPU and rams. I have tested successfully the VDP chip (does not look as a new old stock but a new manufacturing) but the clock generator fails (black screen and continuous tone on power up). Now I would like to be sure the one I purchase is the correct because the marking is different. The E-bay clock generator is marked TMS9904ANL while the original one is marked TIM9904ANL. Are they different then or is the e-bay clock generator a scam?
Thanks,
Rick
I have only check colours displayed in the main low res graphic mode. are there some more ? I am not very used to Tandy Coco programming.
hi jhd,
yes in basic mode I can display any of the 8 available colours without any problem for both machines and as per the pictures colours are displayed as they should be at the prompt. What is weird is that the LCD screen is not really displaying a B&W pictures as you can see in pictures. It is more like a mix of faded blue and green with a lot of striped patterns. weird ...
Hi guys,
I have both a PAL coco1 and a PAL coco2 the first being modded to composite and the second one using the RF output on a CTR monitor. Both will display a decent prompt screen (green and black). Today I received a CasDuino and tried to load some CAS images (Donkey King) but I have a weird result on screen for both. On the COCO 2 hooked to the RF output I do have a clear picture whenever the green and black display mode is shown but a scrambled picture with washed out colours when in High Res mode (pictures) as if the CRT Tv tuner goes out of sink when the high res video signal kicks in. On the COCO I through composite on a PC screen or the CRT TV I do have a stable picture but the colours are completely washed out with only a mix of blue and green on screen (this is barely unwatchable).
What can be wrong? Is there any tweak to be done to the color circuitry potentiometer?
Thanks
Well difficult to read out this schematic image. Wondering just if the whole project was available to print out the circuit board. I do see also that this is apparently for NTSC COCO's while mine is a PAL version.Thanks anyway! :-)
Hi R.Cade,
Ok sounds interesting but is the project free or is this something I will have to buy? I am looking for a free project I could build myself :-)
Hi Guys,
I have successfully built a fairly simple composite mod for the COCO 1 here :
http://www.cocopedia.com/wiki/index.php/File:Trs80coco2compmod.gif
This works pretty good and I can have a very decent composite picture over an LCD screen. Now I am wondering how to perform a composite mod on a COCO 2? As far as I read over the net this COCO1 mod is not compatible with the COCO 2 (a close look at the Coco2 MB reveals that there is no video encoder chip MC1372). Is there any DIY alternative?
Here is a picture of the RF modulator on my COCO 2.
Thanks
Rick
OK guys it is solved luckily!! It was just a bad contact with a chip. A good cleaning solved it.
yes I did sole it. it turned out to be one of the two console ROMs (U611) which was faulty.
hi guys,
I have an issue with a TI99/4A. I had to open it to apply some thermal paste on some chips but when mounting back and testing I had a garbled image. I was suspecting the metal shielding was shorting the extra RAM chip piggybacked on top of the TMS9900 (Tursi mod) but the suddenly all went black and now I just do not have a video signal at all. No black or blue screen but just "no signal". the power led is turning on but that's all. That's really stupid from me and now I do have fried something for sure. I have soldering skills and tools but need maybe someone to point me out where to look at now.
What can be the main cause of a total absence of video output ?
The only check I did was to ensure that the main PSU and the modulator were ok by plugging them to a working Ti99 and they do work.
thanks
Rick
PS : I gave a check at the power supply PCB and do have correct voltages of +5V, -5V and +12V.
hi guys,
thanks
Rick
Hi Combat Commando,
You have a PM :-). Refer to the TI99/4A schematic to find out the ROM positions on the board. As far as I remember the U611 I changed is the one perpendicular to the TMS9900 CPU. I have sent both image files of U610 and U611 as they are different (Low byte ROM and High byte ROM). Good luck !
Hi Arcadeshopper,
Thanks for the explanation
This Alexkid looks solid!! May push people to switch to the FinalGROM just to play it
Ok because Alexkid is available in the roms list for the FlashRom99 in the repository so maybe this is a mistake then.
Has anyone managed to get Alexkid working on the FlashRom99? I cannot get the file to be displayed on the FlashRom99 menu. All other games are working OK.
Thanks
Rick
Hum hum....... yes I do have an Iphone
Don't ask me why they are displayed 90 degres it's a mistery for ma also
OK so I mounted back the PCB into its metal case and mounted back the machine. On power up I was getting a garbled prompt screen with weird colors. After re-opening and testing all was fine again so I do have probably one or more shorts with the metal case. I suspect probably the piggybacked LS021 to have its legs touching the metal case. I will try to tape the whole area and check again
Hi Jedimatt42,
Thanks for the test I will let it run as soon as possible :-). Actually all wiring shave been checked for continuity at their solder joint with a multimeter and all was good
TI99/4A PAL Clock generator
in Hardware
Hi Ksarul,
Thanks for your answer which is confirming what I was thinking :-). I definitely assume that TMS9904 will not work as should the original TIM9904. TIM9904 are hard to find, I hear that there is apparently an alternative 74LS362 which can do the same job. Is that true?
