1,117 -
Posts posted by xrbrevin
oshpark is expensive, JLCPCB is much better value for quantity and price
check the pins within the keyboard ribbon slot - sometimes they get pushed back which causes poor contact
16 hours ago, lbaeza said:same dimensions
the pixels past cart uses the same dimensions but it is not commercially produced, instead it is hobbyist/homebrew spec:
Just now, xxl said:let them record own review.
and await the personal abuse from the author 😁
58 minutes ago, Marius said:seems to conclude that there is some conspiracy going on against them.
either a baseless attempt to distract people from the real reason(s) why there is negativity
or a textbook paranoia case from someone who knows their behaviour is not entirely 'wholesome'
..or both?
V61s product range has a few attractive items but the pricing just motivated me to learn how to make my own carts 😁
great fun!
not an easy game so its a delight to see it played well 😁
On 10/13/2020 at 5:18 PM, ok1rp said:After few days of proper working
since it worked properly for a while, i would consider the power supply or GTIA/ANTIC issues.
check the output voltage is not too high or too low - try another PSU if you have one.
Any socketed chips ought to be removed and all contacts cleaned with contact cleaner
sounds like the sdrive Max is getting power but no signal
check the middle pin on the bottom row of the SIO port (it is named 'command') and any associated components. if nothing looks damaged, maybe the chip that manages the SIO port could be the culprit? The PIA chip pin 19 is listed as 'SIO Command' but im sure the pokey chip also has some influence over the port..
Huzzah!
theyre made of tough stuff! 😁
yes the spectrum ports are great but i find it ironic that the coding originates from a Z80 computer and not a 6502 one..! 🤔
I bought some motorcycle parts from a seller in finland and got some licorice pipes
glad you got the thing sorted! 😎
people obtain DRAMs from ebay and aliexpress
5 hours ago, Shanez1998 said:a resource for a new one
try here:
https://atari8bit.net/projects/cart-labels/
do you have another 16k memory module to swap in?
On 9/21/2020 at 1:11 PM, ClausB said:Some 32K boards aren't meant to work in a 400:
https://atariage.com/forums/topic/177885-atari-800-ram-selection/?do=findComment&comment=2225206
I have an Axlon RAM-CRAM for my 400 and a schematic I could photograph.
thanks for the response. if you could upload the schematic that would be great.
I am aware that a number of DRAM pins are common between the whole group but some are not. Id just like to be as clued as poss before getting the multimeter out
A ROM can be replaced with an EPROM if have a burner?
RAM chips can be piggybacked to identify the faulty culprit
2 hours ago, Humblejack said:No, Utah USA
Aw horse-apples!
thanks anyway 😁
Very homebrew looking indeed but high speed SIO is a great mod!
Is the 800XL an 800XL'F' model? i.e. it uses the Freddie chip for memory management? I only ask because i spotted the mysterious plastic blanking plate at the back of the case that the F models seem to have.
I am trying to revive an aftermarket 32k RAM board for my 400. It is the type that uses 16x 4116 DRAMs.
I desoldered and socketed all the chips and found 1x 4116 chip was at fault. My TL866 EPROM programmer says that all the 74LS chips are good but the board still fails to boot. As these PCBs are not the best quality, I'm wondering if I lifted a track that would need to be bridged.
Does anyone have a schematic diagram for a 16x 4116 chip type 32k board? I need to do continuity checks across the DRAM pins but i could do with some knowledge before I commence.
Thanks in advance!
another vote here for antic
Atari 800xl Shift Key Not Responding
some people have repaired them using conductive silver paint
