xrbrevin
    1,117
Posts posted by xrbrevin
  1. there are many options depending if you have soldering skills, do you want extra ROM slots too..
    check the profile of user: @tf_hh
    check lotharek's site
    a device called 'antonia' replaces the CPU and gives you selectable RAM and ROM versions/types
    there are others that give you a fixed 256k, 320k, 576k, 1088k but the more modern upgrades allow you to select between any of these.
  2. Thanks for the suggestions. I have a logic probe and the back of the RAM board is accessible so i'll have a mooch about.
    I thought maybe i would take a macro photo of the PCB and then zoom in on the computer to check if any traces are in amiss.
    On the 32k board I did some continuity testing across the DRAMS and all lines appear to be behaving as they should. All address lines are linked, -5v 12v 5v and GND are linked with no crossovers. RAS and CAS lines are linked but only on every other chip, i assume this is due to it being 2x16k on a single board.
    If the worst comes to the worst, i will salvage the 4116s and make my standard Atari RAM board into a 32k one. These '80s aftermarket PCBs dont have a silkscreen and the traces are less than robust!!
  3. Can anyone give me any pointers as to how to diagnose a 400/800 RAM board? I have a 48k one and a 32k one and i feel ive done all that i can with them but I just keep getting the red/brown screen.
    ive checked traces for continuity where there should be and shorts where there shouldnt be. Ive checked the 4116 DRAMs work in a standard board and ive checked that the 4164 DRAMs work in an XL.
    The 48k one receives it's SEL4, SEL5, A14 and A15 connections from the Z103 socket (via a small piggyback PCB) and it also gets the RD4 and RD5 from the cartridge socket (via 2x wires).
    Does anyone know of a procedure for troubleshooting? Im wondering if the 74LS glue logic is at fault.
    cheers!
  4. 3 hours ago, MrFish said:
    Interesting. Maybe someone else has seen one like it before.
    Have you tried doing anything to get it working? There's a lot of solder on those chips that might develop a problem...
    i plan to do an AV mod to the machine first, then i will tinker with the 32k board. i will reflow all contacts and if that fails i will desolder the ICs and test them in a (socketed) 16k board
    shouldnt be too complicated to get it running, no other mods are needed on a 400 unless you exceed 32k.
  5. 6 hours ago, BillC said:
    A 9.5VDC power supply would not supply any power for the -5VDC rail and the voltage doubler circuit for the +12VDC rail would also not work. Both of these voltages are required by the DRAM chips used in the original 400/800 8/16kB memory cards.
    this is why the 400 and 800 have an internal power board.
