1,464 -
Posts posted by FarmerPotato
I was looking through eBay to find a replacement 9938 for my Geneve, I just burned out and in the process found this:
This is a pretty simple chip.
PAL12L6 : 12 inputs, 6 outputs
http://pdf1.alldatasheet.com/datasheet-pdf/view/126104/ETC1/PAL12L6CN.html
There is no feedback. (no flip-flop, register, memory etc.) So a simple scan of the 4K input combinations will reveal all the outputs. Reduce and recover the equations.
Download the binaries here:
for "Little" Fugue in G Minor
6 LOAD
BPLAY
for Chariots of Fire:
59 BLOAD
PLAY
or for Ricercar a 6
49 BLOAD
PLAY
May 4th Musical offering: FORTI Decompiled
1. Introduction
FORTI was a sound card for the TI-99/4A PEB, with software written in FORTH. It featured 4 of the TI sound chips, giving 12 programmable voices. Each chip's tone#3 generator was paired with a noise generator, for bass or percussion.
The FORTI software was best known in the form of its 3-voice demo of Bach's FWV 578 "Little" Fugue in G Minor (G-Moll), distributed with the TI FORTH Demo disk in 1983-84. The Bach demo used only 3 voices, on the sound chip in the 4A.
However, other compositions were made for 12 voices. I know of Chariots of Fire (Vangelis), Ricercar a 6 (Bach, Musical Offering, aka Prussian Fugue), and a newer Bach "Litle" Fugue (first 1K lost). On the plain 4A, these sound terrible but tantalizing, as 11 voices compete skilfully but hopelessly for 3 hardware sound channels.
What I did
Starting from a compiled FORTI demo of Chariots of Fire, I decompiled the FORTH words, read out data structures, and disassembled the code for the MUSIC word, which is in the ISR sound driver.
I benefitted from a small amount of leftover original source (from the corrupted Bach demo) and the FORTI user manual, but most of FORTI, especially the music compiling words, is lost to me and has to be reverse engineered.
From internal evidence, the Bach demo is older than Chariots of Fire. The FORTI user manual indicates features not supported in the Chariots of Fire MUSIC driver, which I may create again. I classify features into three versions of the FORTI software:
- B. Bach Demo (TI FORTH graphics demo)
- C. Chariots of Fire
- D. Distribution with FORTI manual
2. Capabilities of FORTI:
2.1 The Data Structures
- Voiceline - a list of note numbers (byte) and duration in ticks (byte).
- Envelope - a list of attenuation bytes, with looping index (high bit set).
- Workspace - set of 16 TMS9900 workspace registers holding the context for one sound channel.
- Pitchtable - arrays of frequency cmds for each note number.
For each of 12 voices, there is a separate voiceline, envelope, and pitchtable, assigned to a hardware sound channel.
The differential tempo counter:
Note durations in ticks (1/60th second) are multiplied by 32 and added into a "Next Note" countdown timer (per voice).
On each interrupt tick (1/60th second), the value DEL is subtracted from the countdown timer. DEL has an initial value of 32. When DEL is modified by the RIT, ACC, and TEMPO words, the effect is that the tempo is increased or decreased. The duration timer is never cleared so no time is lost. All voices move ahead at the same tempo.
When the duration timer reaches 0 or less (it is initialized to 0 to start music) a new note and duration are taken from the voiceline. If the duration is 0, the channel is silenced, and the ISR returns -1 on the stack (bug: and the ISR is removed?)
Looping inside the envelope: in terms of an ADSR model, the envelope will begin with an Attack-Decay section, a Sustain (looped) section, and an optional Release (tail) section which can apply during the last portion of each note. The Release feature is used in the Bach Demo but not Chariots of Fire (buggy).
Envelope bytes are processed every tick (1/60th second), not modified by tempo.
The 16 attenuation values are remapped through a dynamic offset DYN and a 48-byte dynamics table (DYT). This allows words like +VOLUME and -VOLUME to take effect
2.3 Pitchtables
A pitchtable entry is 2 data bytes to send to the sound chip for a note number (the channel number will be added later).
Note number 0 is used as a rest, but a rest is actually defined by having 0 for the sound chip period.
PT0 is the regular pitchtable. Note number 37 corresponds to low A or 110 Hz, which is the lowest musical note a tone generator can produce. Because of this limitation, PT0 fills the bottom 3 octaves (notes 1-36) with a copy of the octave 37-48. If a voice using PT0 plays notes in the range 1-36, they will still be heard, but in a higher octave.
PT1 notes load white noise for percussion.
PT4 is for channel 3 to drive the periodic noise channel and begins with note 0 corresponding to 13.75 Hz.
3. Examples:
Voiceline:
0 VARIABLE VOICE1 QU C D E F EI G A B C 0 ,
compiles a list of note-duration pairs into VOICE1 relying on definitions such as these:49 VARIABLE XPOSE : &* XPOSE @ + SWPB DURATION [email protected] + , ; : A 0 &* ; : A# 1 &* ; : C 3 &* ; : AA 12 &* ; : CC 15 &* ; : EI 24 DURATION C! ; : QU 48 DURATION C! ; : RE DURATION [email protected] , ; : OCTAVE 12 * 49 + XPOSE ! ; ( n -- )
The FORTI manual says to compile a voiceline like so:
START VOICE: VOICE1 ( 1 ) QU C D E F ( 2 ) QU G A B C FINIS
My example based on C/ uses a lower level way:( Verdi Requiem Mv2 trumpet ) 0 OCTAVE 0 VARIABLE VOICE2 ( 131 ) 3E RE C E G E G RE C E G E G ( 132 ) Q CC RE RE 3E C E$ A$ ( 133 ) Q CC H RE 3E C E$ G ( 134 ) Q C RE H RE 0 ,
4. Internals
4.1 Workspace registers
FORTI takes advantage of the TMS9900 workspace pointer context. There is a block of 12 workspaces allocated in the dictionary, one for each voice. In MUSIC version C with dancing sprites, they must be contiguous so that a sprite table address can be found from (STWP-WS1)/8. In version B they are not contiguous.
In the Bach demo, (no sprites) Workspace WS1 might be set up like this:
VOICE2 VARIABLE WS1 PT0 , TRUMPET1 , 0 , 0 , 8000 , 9000 , 12 ALLOT
But with dancing sprites, all WS must be contiguous, in order to calculate the sprite#.0 VARIABLE WS1 17E ALLOT WS1 20 + WS2 CONSTANT WS1 40 + WS3 CONSTANT WS1 60 + WS4 CONSTANT WS1 80 + WS5 CONSTANT WS1 A0 + WS6 CONSTANT WS1 C0 + WS7 CONSTANT WS1 E0 + WS8 CONSTANT WS1 100 + WS9 CONSTANT WS1 120 + WSA CONSTANT WS1 140 + WSB CONSTANT WS1 160 + WSC CONSTANT
The word MUSIC is the core of the ISR and is written in assembler. The first instructions of MUSIC pulls the WP off the stack;ED10 0201 LI R1,>ED18 ED12 ED18 ED14 C019 MOV *SP,R0 fetch WSP ( wsp -- f ) ED16 0400 BLWP R0 effect is R0->WP R1->PC. no LWP on 9900
The full code is in Listing 1 at the end of this article.The workspace registers are initialized before MUSIC first runs, and have the following meaning:
FORTI WS usage. WS is a register workspace ------------------------ R0 voice or cascade addr. List of byte pairs (note#,dur) R1 pitch-table: e.g. PT0 or PT1 R2 envelope. e.g. PLUCK3 or ORGAN2 R3 index into envelope R4 countdown timer to next note. init to 0 to begin. R5 const pitch cmd byte R6 const attn cmd byte (for a noise, pitch is tone#3 and attn is tone#4/noise) R7 pitch cmd word for current note or 0 for rest R8 temp. compute vdp address (for sprite) or envelope address R9 vdp addr of sppat# R10 copy of SGCA, sound card address (copied from SGCA at each ISR entry, sic) R11 not used R12 temp. compute vdp data byte (for sprite) R13 ... R15 after blwp, not used ( Register numbers for use in assembling MUSIC - EO ) 0 CONSTANT NTP ( Note table / voice pointer ) 1 CONSTANT PTS ( pitch table start ) 2 CONSTANT ATS ( attenuation table start / envelope ) 3 CONSTANT ATP ( attenuation table offset ) 4 CONSTANT DUR ( countdown timer duration ) 5 CONSTANT PVID ( pitch voice ID ) 6 CONSTANT VVID ( volume voice ID ) A CONSTANT SG ( sound card address ) C CONSTANT PNDX ( pattern number vdp address ) ( D E F are clobbered on entry to MUSIC but could be temps )
4.2 Player wordsWords PLA1, PLA3, PLA12 begin playing 1, 3, or 12 voices, resp.
: PLA12 ' BMUSIC XMUS ; ( play : PLA3 ' CMUSIC XMUS ; ( play only WS1-3 on internal snd only ) : PLA1 ' DMUSIC XMUS ; ( play only WS1 on internal snd only )
where: MUSIC0 85EE SGCA ! MUSIC ; ( 1110 1110 only chip #0 with enable low ) : MUSIC1 85F6 SGCA ! MUSIC ; ( 1111 0110 only chip #1 ) : MUSIC2 85FA SGCA ! MUSIC ; ( 1111 1010 only chip #2 ) : MUSIC3 85FC SGCA ! MUSIC ; ( 1111 1100 only chip #3 ) : MUSIC4 84FE SGCA ! MUSIC ; ( 1111 1110 internal only ) : MUSIC5 857E SGCA ! MUSIC ; ( 0111 1110 say chip 4 ) : MUSIC6 85BE SGCA ! MUSIC ; ( 1011 1110 say chip 5 ) : MUSIC7 85DE SGCA ! MUSIC ; ( 1101 1110 say chip 6 ) 3424 VARIABLE PSTART : XMUSIC WS1 MUSIC0 OR IF 83C4 @ PSTART ! 0 83C4 ! OFF ENDIF ; : DMUSIC 0 XMUSIC ; : YMUSIC WS2 MUSIC0 WS3 MUSIC0 OR OR XMUSIC ; : BMUSIC WS4 MUSIC1 WS5 MUSIC1 WS6 MUSIC1 WS7 MUSIC2 WS8 MUSIC2 WSA MUSIC3 WSB MUSIC3 WSC MUSIC3 OR OR OR OR OR OR OR YMUSIC ; : CMUSIC 0 YMUSIC ; ( for PLA3 ) : XMUS CFA ISR ! INTLNK @ PSTART ! ;When playing just one voice:: MUSIC0 85EE SGCA ! MUSIC ; ( 1110 1110 only chip #1 with enable low ) : XMUSIC WS1 MUSIC0 OR IF 83C4 @ PSTART ! 0 83C4 ! OFF ENDIF ; ( f/finished? -- ) : DMUSIC 0 XMUSIC ; : PLA1 ' DMUSIC XMUS ; ( play only WS1 on chip#1 or internal snd )
In PLA1, DMUSIC is the ISR which calls MUSIC on one workspace pointer. (PLA12 and BMUSIC make a player that calls each of 12 voices.)4.3 Sprites
The version of MUSIC in Chariots of Fire draws dancing sprites on the screen (Bach demo does not have this.) For each of 12 voices, there is a sprite. The note number translates to a column on the screen, while the attenuation is shown by a colored bar where height indicates loudness.
4.4 Misc
Chariots of Fire utilizes 11 sound channels across 4 chips. Interestingly, it defines addresses for MUSIC5,6,7 as if the author imagined having more chips than 4.
5. Optimizations
It's quite likely that I'm not analyzing the final version of the MUSIC word. That said, I see the following optimizations that could be made:
* SGCA is placed on the stack and copied to the workspace R10 on each tick. This should be configured before music starts playing, just like other registers that don't change.
* The envelope release (or tail) segment looks buggy in Chariots of Fire (whose envelopes don't rely on it.)
* Byte swapping and SRL by 8.
movb *r8,r8 ab @DYN+1,r8 srl r8,8 movb @DYT(r8),r8 movb r8,*r10
could beclr r11 movb *r8,r11 swpb r11 a @DYN,r11 movb @DYT(r11),*r10
6. Missing WordsParts of the music entry system were not present in the compiled demo:
- Defining words like VOICE: FINIS and <ENV: ENV> were not recovered. I speculate that the demos B and C were created in a lower level way, and that these defining words were invented for the final distributon.
- Envelope word =REPEAT to encode the sustain loop
- 3 SHARPS established a key signature, modifying the behavior of note words like F. In the demo, F pushes a constant note number 8 (plus octave). This implies
- T for Tie or slur is not present. I don't see that MUSIC implements any means to vary frequency.
- R: and :R to repeat a section in a voiceline. These save memory, but would require runtime implementation in MUSIC.
- convenience word =TEMPO
- counting words =MEAS and +MEAS
- Envelope defining words <ENV: ENV> produce code that copies the envelope PFA into a WS. This requires a <BUILDS DOES> construct. In the demo, envelope words are just arrays.
- The words +VOLUME and -VOLUME and dynamic markings from PPP to FFF.
- CONDUCTOR is the top defining word and is not present
- SILENT is not present
- +FIFTH and words that transpose voices at runtime, not compile time, will require support in MUSIC.
- <ALBUM and ALBUM> words
- =GR and GR that subtracts time (for a grace note) from the previous note duration. In the demo, GR sets DURATION to 1 tick.
- =FERMATA and FERMATA
- =DRUM to set a WS to play noise
- <PHRASE: PHRASE>
I was disappointed to find nothing about tremolo in this demo. Envelopes are just attenuation changes, which is how an organ tremolo operates, but on other instruments, tremolo means to vary the frequency, or play two frequencies for the overtones. (T or Tie/Slur effect on frequency is unknown; perhaps it just skips the tail.) An envelope for pitch would allow many more effects.
The FORTI manual lacks a dictionary.
The pitch table is flexible enough to allow different temperament. The pitch table we take for granted is the equal tempered system in which music can be transposed to another key without changing its character.
8. Acknowledgments
David Olson retrieved the Chariots of Fire demo disk.
Rene LeBlanc for his FORTH disassembler, which I obtained in 1985 and never used until now.
Gene Hitz and Owen Brand provided the MATIUG disk library, which I converted to DSK format, finding the TI FORTH source.
The BERG/WERNECKE FORTH decompiler found in the MATIUG disk library.
Lee Stewart's fbFORTH and TI FORTH manuals which I used as a reference throughout, especially on the dictionary entry structure.
Tursi for Classic99 in which I did most of the work.
Kryoflux hardware and software was used to efficiently acquire hundreds of legacy disks.
CANTRELL, the TI engineer named on the FORTI "stereo card" schematic. Who is CANTRELL?
9. References
FORTI Music Card Users Manual and Schematic at WHTech
Listing 1
* code field of MUSIC * Load workspace from stack arg ED10 0201 LI R1,>ED18 ED12 ED18 ED14 C019 mov *SP,R0 fetch WSP ( wsp -- f ) ED16 0400 blwp R0 effect is R0->WP R1->PC. no LWP on 9900 ED18 C2A0 mov @SGCA,R10 ECCE is pfa of variable SGCA. typ 85EE(#1 chip) ECCE ED1C 04CC clr R12 ED1E C104 mov R4,R4 duration timer. clear to start ED20 1531 jgt LABEL2 * next note ED22 D330 movb *R0+,R12 get note number in R12 ED24 098C srl R12,8 ED26 C1CC mov R12,R7 get note number in R7 ED28 0A9C sla R12,9 sprite col = note# * 2 ED2A 0209 li R9,>d844 WS1 D844 ED2E 02A8 stwp R8 ED30 6209 s R9,R8 (WSx - WS1) is a multiple of 32 ED32 0938 srl R8,3 divide by 8 ED34 0228 ai R8,>4301 address to write, in SAT 4301 ED38 06C8 swpb R8 ED3A D808 movb R8,@>8c02 set up VDP address 8C02 ED3E 06C8 swpb R8 ED40 D808 movb R8,@>8c02 8C02 ED44 D80C movb R12,@>8c00 sprite col = note# * 2 8C00 ED48 0588 inc R8 ED4A C248 mov R8,R9 vdp addr of sppat# ED4C D230 movb *R0+,R8 duration ED4E 0988 srl R8,8 ED50 0A58 sla R8,5 times 32 . 32 is the neutral value of DEL ED52 A108 a R8,R4 add, because need to pay time debt ED54 1509 jgt LABEL1 * silence * bug: if R4 is at worst 1-DEL, R8 is at worst 32, if R8<DEL-1 then music may stall FINIS ED56 0640 dect R0 leave R0 pointing to the last (valid) note ED58 C206 mov R6,R8 attn cmd byte ED5A 0228 ai R8,>0f00 silence 0F00 ED5E D688 movb R8,*R10 write to sound chip ED60 02E0 lwpi >8300 8300 ED64 0719 seto *SP put -1 on the stack ( wsp -- f ) ED66 045F b *NEXT LABEL1 ED68 A1C7 a R7,R7 note# * 2 ED6A A1C1 a R1,R7 pitch table address ED6C C1D7 mov *R7,R7 ED6E 1605 jne NOTE else, turn off voice: REST ED70 C206 mov R6,R8 attn cmd byte ED72 0228 ai R8,>0f00 silence 0F00 ED76 D688 movb R8,*R10 write to sound chip ED78 1005 jmp LABEL2 why not LABEL6 NOTE ED7A A1C5 a R5,R7 pitch cmd byte ED7C D687 movb R7,*R10 write to sound chip ED7E 06C7 swpb R7 ED80 D687 movb R7,*R10 write to sound chip ED82 04C3 clr R3 * note in progress LABEL2 ED84 C1C7 mov R7,R7 pitch cmd or 0 if none ED86 132E jeq LABEL6 nothing to do ED88 D212 movb *R2,R8 envelope first byte (N in sustain) ED8A 0938 srl R8,3 ED8C 8108 c R8,R4 R4 is counting down from duration*32 ED8E 1501 jgt SSTAIN ED90 1003 jmp LABEL3 SSTAIN ED92 0203 li R3,>003f start envelope at 3fh-R8*32 003F ED96 60C8 s R8,R3 LABEL3 ED98 0283 ci R3,>003f 003F ED9C 1102 jlt LABEL4 ED9E 0203 li R3,>003f R3 max 3F 003F LABEL4 EDA2 0583 inc R3 at least 1 EDA4 C203 mov R3,R8 EDA6 A202 a R2,R8 envelope pointer in R8 EDA8 D218 movb *R8,R8 EDAA 0988 srl R8,8 EDAC 0288 ci R8,>0080 0-F attentuation, 8x cmd byte 0080 EDB0 1501 jgt ENVJMP EDB2 1006 jmp LABEL5 * envelope cmd byte ENVJMP EDB4 0228 ai R8,->80 FF80 EDB8 C0C8 mov R8,R3 new envelope index in R3 EDBA A202 a R2,R8 EDBC D218 movb *R8,R8 they seem to have run out of registers EDBE 1001 jmp LABEL6 * R8 lsb is attn LABEL5 EDC0 06C8 swpb R8 * adjust attn by dynamics table LABEL6 EDC2 B220 ab @DYN+1,R8 ECD9 EDC6 0988 srl R8,8 ugh EDC8 D228 movb @DYT(R8),R8 D1BA EDCC 06C9 swpb R9 vdp address of sppat# EDCE D809 movb R9,@>8c02 8C02 EDD2 06C9 swpb R9 EDD4 D809 movb R9,@>8c02 8C02 EDD8 0A28 sla R8,2 mpy by 4 EDDA D808 movb R8,@>8c00 set sppat# to attn 8C00 EDDE 0928 srl R8,2 EDE0 A206 a R6,R8 add attn cmd byte EDE2 D688 movb R8,*R10 write to sound chip LABEL6 EDE4 6120 s @DEL,R4 Subtract DEL from timer CC60 EDE8 02E0 lwpi >8300 8300 EDEC 04D9 clr *SP put 0 on the stack EDEE 045F b *NEXT-
I heartily agree. I celebrated by beginning the day in TI FORTH and downloading Starting FORTH to my phone again.
That said, I also got out LEGO Yoda #7194 and I hear there are Wookie Cookies nearby.
We could find more information if somebody goes to the TI Archive library, located here
https://legacy.lib.utexas.edu/taro/smu/00063/smu-00063.html
Sometime in the past TI donated the whole archive to a library, occupying over 1500 cubic feet of material.
I got this information when I asked TI support about buying/getting some TI-99 internal documents this year.
I might be able to go to the SMU library in Dallas. Thank you for pointing this out!
What sections do you think are most relevant? I think RG-14 Consumer Products Division.
That would mean to copy the byte at the address pointed to by R8 to address >0001. Maybe you had a STWP in mind?
I can work with that.. There is already a STWP which I can keep around in R13.
STWP R13 this is already paid for
CLR R11
MOVB *R8,23(R13) to low byte of R11
Based on Rasmus' cycle counts, this is at best slightly faster. (Note: registers are in external ram >D844)
I see this code 2 times, so I consider
AI R13,23 point to R11 lsb
Then each time
MOVB *R8,*R13
I can take care that the high byte of R11 will stay 0.
Thanks - I've been watching eBay for these for a month or so - this one is mine now.
I put my first 910MP (from PC Liquidators) in long-term storage for Midwest Gaming Classic. We used it on the 4A and Geneve (composite only). Long-term storage means I only get it out when the show is held. I am NOT traveling with that thing again.
(I took a full P-Box, disassembled 910MP, Geneve with keyboard, plus my main F18A console on the plane. All but the F18A console and Geneve card went into long term storage.)
Great monitor for the geneve 994a or any other classic tech has composite, vga, rf and rgb input 19in 4:3 ratio. Not my auction
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F183205352870
Sent from my LG-H872 using Tapatalk-
I have been finding this in ISR code and I am wondering how wasteful it is in cycles? Would someone who knows TMS9900 timing care to analyze it?
All registers are in external RAM (full wait state penalties).
movb *r8,r8
srl r8,8
Proposed Optimization:
clr r11
movb *r8,r11
swpb r11
The programmer has RUN OUT of temp registers and is overusing R8, but I see R11 is free.
Thanks in advance!
I got the first prototype built!
Works great. I need to make one adjustment on one of the holes used to help mount the SCART connector as it's a little too far. This will allow the pressure-clip to go in easier. but it's nothing to do with the circuit, which is good!
Love it! I look forward to ordering a lifetime supply from you!
Nice and simple layout. Is there a specific reason for using the surface mount ICs, in particular the '244s and '245? I ask only because from a repair perspective, they are the chips that bear the brunt and are often in need of replacement.
Not speaking for Matt, but I realized that TI doesn't have a DIP for SN74LVC245A (there is a 244) which I chose to go between 5V bus and 3.3V chips (my FORTI project).
Thanks, I will read that.
I began with your fbForth 2.0 manual Dictionary Entry discussion, and started to write my own decompiler from there. Spent most of last Thursday on that.
When I think I understand how TI FORTH works, I will go back to the present and continue looking at the ARM assembler inner interpreter for MeCrisp FORTH (I spent most of January and February on that!)
-erik
I do not know whether it would be useful to you because you probably know how it works, but, in “Appendix O” of my TI Forth Instruction Manual: 2nd LES Edition (2013), I annotated much of the TI Forth source code in DRIVER (assembled as first part of FORTHSAVE loaded by FORTH) and BOOT (assembled to FORTH). I had to puzzle out how TI Forth worked before I could launch into development of my file-based block I/O fbForth 1.0 and, especially, its cartridge version (fbForth 2.0), so I thought I might as well publish my notes of that effort.
...lee
Good news:
David Olson located a SSSD disk of FORTI card demos. It contained the Bach BWV 578 Fugue in G Major ("Organ"), Ricercar (unknown) (12 voices), and Chariots of Fire (12 voices). As I remembered, the 12 voice tunes sound awful on a plain TI-99/4A (well, Classic99.)
Unfortunately, it is only the binaries in the first 90 screens of the disk. The second 90 screens containing the source were never copied!
The compiled dictionary lacks most of the FORTI compiling words and what is does contain doesn't fully match the documentation (it lacks some note and duration words). Perhaps it was an early demo. I believe this disk was demoed at the Lubbock TIUG around 1984 when there was an active FORTH SIG.
My goal is to recreate the FORTI composition system, if that means decompiling the FORTI music demo from binary or recreating from scratch.
I started decompiling the binary. Really learning how FORTH works, finally!
I found Rene LeBlanc's FORTH-DISASM in my old floppies, and looked around in the FORTH interpreter. I am paying this shareware fee, though it is 30 years since I received this disk.
Meanwhile, David and I converted 160 disks (the first box out of 3) of the Milwaukee Area TIUG library to DSK format, using Kryoflux. Owen Brand had received the MATIUG library from Ted Z and brought it over. Among 16 FORTH disks (10% of the first box of disks!), I found copies of the TI FORTH source distribution, and several disks of games or utilities including FORTH DECOMPILER - BERG/WERNECKE. That will be useful.
A surprise I did not expect was to find my name E.Olson on FORTH code from 1984 on Disk #103. This must have been printed in a Lubbock TIUG newsletter and typed in by a Milwaukee member!
(There is still some cleanup to do on these disks, because 30 had at least one bad sector. But I understand Owen has two full sets of disks from the library, so those disks must be checked.)-
You were lucky that the Vectrex attended in the same year as you
I first went in 2005 and played Minestorm. A lot. For me it was the first time I'd seen a system outside of a magazine ad and comp.sys.vectrex. I got a shout out in a message on Yahoo as "minestorm guy".
Vectrex have been on again, off again since then on the Museum floor. They are also rare in the vendor hall. I think there was one on Friday night. They do sometimes appear, working or not, and sell fast for $200 and up.
I saw the Color Vectrex. I didn't have time to stop and play it. (I also had no time for Space Duel... same guilty pleasure... But I did play Cosmotrons! If you like Minestorm you'll see why.)
Heck, they claim there were 1000s of games. I played only a handful: 3D Pong (mechanical). VideoBrain Gladiator. Magnavox Odyssey Escape.
I'm working on a Verilog 9902. The idea is to provide CRU bus compatibility with existing TI-99/4A software that writes directly to the 9902.
It's easy to add a large ring buffer behind it.
Once it's virtualized, there's many uses for it. You would use any TI-99/4A terminal program. One port can access an internal device console. Another port can be routed to the outside world through a USB adaptor. An actual RS232 DB25 connector is kind of the last thing on my mind.
Greg did some play-testing of the mouse driver today, and I've got some usability issues to work out. ( It is well behaved, just too fast and some symantec issues )
I haven't had Symantec issues since I switched to Borland.
Bit of a TI FORTH summit happening late nights at Midwest Gaming Classic. We will be sure to check out Camel FORTH!
Thursday: Tour Yerkes Observatory, namesake of YERK (i.e. MOPS) OO FORTH on the Mac II.
Friday: set up TI FORTH exhibit, fbFORTH cartridge. Scan pile of newfound old floppies for any lost FORTH code! First public demo of FORTi sidecar.
mini-hackathon. Write a game in FORTH!
(My other exhibits include TI LOGO on the original 99/4, games on the F18A, Geneve 9640.)
Saturday: talk about FORTH to anyone who will listen as ten thousand folks walk through exhibit hall.
We will also play with the TI LaunchPad MSP430FR33 running FORTH variants.
I advocate doing everything in FORTH. If you want to experiment with low level features like writing to VDP for sprites or Bitmap mode, it's interactive.
As a teenager, I went that route. FORTH was my second language after BASIC. But constructing large programs in FORTH, especially main loops, was beyond me.
All I did was (bitmap mode) circle drawing routines and typing up code to make bitmap images drawn on graph paper.
I ended up adding bits of assembly to my Extended Basic programs (draw lots of graphics, scroll, do RS232 communications) until I was comfortable migrating everything to
assembly. If I had stuck with FORTH, I might have learned to structure things better.
The thing that bugs me about FORTH now is how to package a program for delivery. I think folks just want to download one file and run it.. TI FORTH has blocks
(entire disk image) and other FORTHs have multiple files. I'm not sure how to transition a FORTH game into the cartridge space either (at the very least this
would still require 32k RAM expansion.) -
I just tested two working PHP1800 sidecar disk controllers with original TI external (single sided) floppy drive.
What model# of drive do you have in the P-Box?
Actually, the card uses one TMS2532 (4K) and one Motorola MCM68764C (8K) EPROM.
I did not see that at first, but it is obvious now. The photos were texted to me and I looked at them on my phone.
I have some 2564s for use with the TI EPROM programmer, but I also had an adapter for 2764 that Nick Hulbert put together.
-Erik Olson
David Olson found this example of the TI Double Density controller card prototype.
This one uses two TMS2532 eproms and the NEC upd765 double density controller chip.
I believe this is the card nicknamed "Lewisville" after the TI office in Lewisville, TX. Back in the day, a Front Range 99'er newsletter editor relied on a Lewisville card and we had an interesting time exchanging files on floppy.
I'll have the card at Midwest Gaming Classic. Maybe we will do some elementary troubleshooting on it.
Any supporting information is welcome.
NEC Datasheet: http://www.cpcwiki.eu/imgs/f/f3/UPD765_Datasheet_OCRed.pdf
I learned that Apple //gs users are in the same situation. Here is a circuit with LM1881 to connect an Apple //gs to a Samsung 710. (Borrowed from MSX!)
http://www.apple2faq.com/knowledgebase/15khz-compatible-monitors/
I'm going to try out an Apple //gs monitor on my Geneve!
I still want to get a modern LCD solution though.
Eagerly watching this effort! I need to get a Geneve monitor solution of some kind.
I ordered a Samsung Syncmaster 910MP for my Geneve.
I am comfortable assembling surface mount, if you reach a kit stage.
(is this 0803 discrete components?)
FORTi
Background:
FORTi was a Pbox card with 4 sound chips. This allowed 12 voices. The supplied FORTH software let you control attack, sustain,
tremolo, and use the Periodic noise for bass notes. A demo for 3 voices only was part of the TI FORTH Demo disk.
I've been working on a tribute to the FORTi card.
I built a FORTi card in hardware. (over two years but.) I scanned all my floppy disks with KryoFlux hoping to find any FORTi software. Alas, I did not find any!
We had a demo of the FORTi card at the Lubbock Users Group around 1984. (Our meetings at Texas Tech's 4A lab attracted up to 100 people in summer meetings. Our FORTH Interest Group had a separate meeting.)
At one point, I had the original Bach "Little" Fugue in G minor, BWV 578 (included in the TI FORTH Demo), Chariots of Fire for 12 voices, and one other disk.
These were the versions that show graphical bars for each voice.
I do know about the manual from WHTech:
I do not think I ever had the original software distribution with the compiling words. I may try to reconstruct it from the manual!
Wanted:
If anyone has any FORTi disks - compiled songs or source code - I'm very much interested in them.
I'm trying to get this project into a showable state by Apr 13.
-Erik -
I must have been one of a small number of folks that actually purchased MyArt and the mouse--and I bought four of them, one for each of my Geneves, one for my then brother-in-law in Germany, and a spare for emergencies. The non-payment for MDOS work already done was pretty much widespread knowledge at the time of the buyout. I know I threw in some cash for that effort (I think I handed $50 or $100 to Beery Miller at the Wiesbaden TI Treffen), as I figured it would be the only way we Geneve users had a chance at long-term survival. I also liked the fact that it would no longer be beholden to the vagaries of any one person or company. That was some of the best TI money I ever spent!
I think I heard that remark about MyArt in 1988 or 89. Good for you.
In August 1992 I had just started an internship, and I borrowed $200 against my first paycheck to send to Beery for the MDOS buyout. I consider that money well spent.
SCART-Genie 9640 PRE-ORDER NOW!
in TI-99/4A Computers
I ordered two!
Any chance of offering a kit form? I would order two more for the future.
