hex65000
    1,535
Posts posted by hex65000
  1. Here's my take on this one:
    Hark back to the hardware forum and how much voltage you have to have above your regulated voltage to have a generally good output. The answer was about 3V. If you drop below that threshold, your regulator will start to sag out pretty quick. The result is that now all of your 5V logic ICs are now running at a lower voltage and bits are going to get misinterpreted or other interesting issues. If this is hard on the ICs can probably be debated. If done in a fairly smooth manner, you can probably reduce any of the harsher transient spikes that will hurt your equipment. Also realize, you get a small transient whe your power up your console. Proper filtering of power is the key element there.
    The next question is what is happening when you toggle the power on and off rather quickly? My guess would be that you are doing something similar to the above only now you're jiggling the voltage around an awful lot. When you do a quick toggle or two, you still have capacitors with a charge that are going to discharge as soon as power is removed.
    So lets say you turn the power off, the caps start discharging and the system is in its dying process. Then you toggle the power back on and the caps are charged again and everything goes back to normal logic levels. The result is really similar, but now you are introducing a pretty harsh transient into the equasion -- that would be rough on the logic ICs.
    Lastly, overheating -- make sure that your 5V regulator is secured to the heat plate on the board, or you could add an extra heat sink if your'e ambitious. It's pretty easy to do and will keep your reguator running much cooler.
    Hex.
    [ Karma is the lazy man's revenge... ]
  2. Yeah, for the most part I find myself running about with a mele weapon like the monster ripper (currently the tesla cleaver). That does solve a lot of my problems, that and I maxed out 'slayer' as fast as I could. Next on the list is 'Desert Soldier' for improved damage with kinetic weapons.
    I don't mind turn based RPGs for combat, it does let me ponder my approach a bit better than the action genre. Like I said, it's like playing a Diablo title, but post-apocolyptic.
    There's a lot of running about and killing things, but It has held my attention quite well. I'll probably play this until I'm sick of thinking about the game (could be a while), but for what cost me sub $20 on the PS2 this is not bad, the only other games to rival that much of my attention has been .//hack #1 and Katamari.
    I don't know how closely it follows the storyline of the PC versions of the game. But here's a lite version of the story so far...
    [ minor spoilers... ]
    You are an initiate of the Brotherhood of steel and you arrive in a beat down city to meet one or more Paladins in the Brotherhood. Instead, you have to cope with the fact that they have wandered off elsewhere and that raiders are kicking the crud out of everyone.
    Following the only lead you have, you go to a city consisting of ghouls. They don't like humans. Or much of anything really. Mutant humans have been sighted here, so be careful.
    You lose to the mutants through treachery (scripted) and are eventually saved by a small number of people in what's left of a vault. They need to escape -- the mutants want in the vault -- the computer has gone a little wonky -- and you need to clean house.
    Hex.
    [ It's a Nuclear blast... ]
  3. Out of curiosity, has anyone else sat down and played this? It reminds me a lot of the Diablo series really. (In structure and gameplay) I've only gone through the first chapter, but I've logged easily over 8 hrs on it already. It does make me want to find the (uninstalled) copies of Fallout 1 & 2 that I have laying around the workshop.
    Right now I'm playing as the girl and _may_ reattempt to play as the ghoul on a harder setting if I can remain enthused long enough. I think I paid $15 for this thing, and so far I'm getting my money's worth.
    As a side note, it's funny that I've been picking up the PC versions of several console games simply because I can get them for much less new than the associated console title. (IE: Thirteen, Magic: Battlegrounds, any Unreal game) funny how that one came full circle...
    Hex.
    [ What's a nice girl like you doing in a post-apocolyptic future like this? ]
  4. I have a quattro Spreadsheet made up I have big headers that descrobe the system, below I have the title, genre, manual, notes, and a running counter on one side so I can see how many I have of a certain platform.
    My list is also horribly out of date. I occasionally update a few things here and there. When I'm out and about, I usually just run off memory. Which has worked fairly well for the most part.
    I may have to add a new column for boxes since I'm starting to get a massive number of them for my Genesis carts.
    Hex.
    [ Brute force answers for elegant problems... ]
  5. Okay, this is more of a collecting thing... I have two picture label copies of Asteroids. Nothing special. However, one shows the copyright date on it on startup and the other does not. The stickers look identical, was the no copyright screen version just a later run of the same game? Any thoughts?
    Hex.
    [ Just can't clean another contact today... :sad: ]
  6. Two problems:
    -- Those switches are not designed to handle the higher frequencies of RF. They spew signal everywhere. I tried that trick with my pelican switch while having two systems on at the same time and selecting one. The picture became total crap. A proper routing of RF is needed for this one.
    -- Your theoretical 15 spots still means that you have to swap connectors down the line. This also gets compounded from the observations I've seen above.
    Okay, It's brainstorm time... The correct way to do this would be to use a relay system with some Xor logic to drive everybody. Conceptually, this would not be tough. They make (and I have had good luck with) high frequency relays that are quite compact. Add a smattering of CMOS logic, SPDT switches and some driver transistors and you are done.
    However, cost would be a big factor. Those relays cost about $4-$5 each. If you build a unit with 5 selections, you have ~$25 in relays. Bulk orders get a bit cheaper, but not much. Everything else would'nt cost that much really.
    Hex.
    [ Is slowly building up his parts bin for the 5200 switch redesign prod. run... ]
  7. Actually, with a bit of work, you can get composite video out of you SMS pretty easily. You can use a standard 5 pin circular DIN connector and get the video and audio component out. For a more complex config (S-video), I can't help you. I don't know where to get an 8-pin DIN that will properly match the connector. (Yes I've tried to for another mini-project.) I assume that your NES is a top loader if you are going the RF route for video.
    I'm pretty sure that there was a report on the forums of the NES light gun not liking some of the newer TVs. Mine is pretty dated, so I dunno...
    Hex.
    [ Scrub scrub scrub those filthy cartridges... ]
  8. Sort of on the topic, I recently broke down and bought one of the logitech wireless ctrlers for the PS2. It is nice. It's not $40 nice, but still, it works on the PS1 / 2 systems just fine. It also fixes the recessed D-pad of the playstation controller, and you can manually turn the vibration off (which I am thankful for)
    I got a chance to check out the XBOX version one day and concluded that yes; I will buy one of these for the house.
    Any obvious downsides? It does transmit RF at 2.4GHz. So it prolly bumps into a bunch of things in that spectrum. (IE: Lan, Phone) The manual claims that it does frequency hop to keep interference down. In a way, my luddite 'hardwired' network turned out in my favor there. And now that I think about it, I wonder how much power that thing is spewing out. It has to be less than a half-watt. The Motorola Walkie-talkies I have contain a stern warning because of the high power levels coming out. Heh, I don't want sentient cancers to appear because I decided to play a bunch of RPGs using the cordless ctrler.
    For the truly paranoid, grounded tinfoil gloves are recommended...:D
    Hex.
    [ So much to do... no idea where to start... ]
  9. Note: This is not designed to be flamebait... just my NSH opinion.
    I'm going to have to go with Katamari Damancy. This game has me literally preaching it's strange merit to anyone who will listen to me. Yeah, I think it's that good.
    I can't comment on Halo2 yet because I haven't started playing.
    Having played Alien Hominid, it's pretty cool, but i really didn't see any major innovation. It's a contra/gunstar heros class title that appears to be well done, but at the same time the 2d-ish cell shading makes me think that this game could have been accomplished on the previous generation consoles to a reasonable degree. (IE: Dreamcast, PS1, N-64, even the Jag)
    GTA is GTA is an RPG. The series just doesn't do 'it' for me. I'll leave the rest for the historians to figure out... :D
    Hex.
    [ Is itching to try out all his new toys.... ]
  10. Castle Shikigami 2 (PS2)
    Genre: Action / Scrolling Shooter
    Found at: Borders Books ~$10.00 new
    Worth: ~ $10.00 or less
    Similar to: Ikaruga / Gunbird 2
    HD Loader Compatable: Yes.
    Good bits: Lots of things to shoot at, borders on possible for the uninitiated. It's moderately pretty and the character options give you some decent style options. Character art is acceptable. While I'm not a conneseur of this genre, it's a competent game and it's pretty challenging overall. I never was really good with the shooting pattern games like Ikaruga. I just like to blaze away and do as much damage as I can. What is unique is that you can select from a bank of characters, you can select from two different special types that are similar in style at the start. Each character has a standard weapon type and then if you hold the button down a 'special' attack. This is a nice aspect that allows you to pick from multiple different shooting styles. The screen layout reminds me of Ikaruga, and the fact that you play a person just floating in the air shooting all sorts of things reminds me of Gunbird 2. It's a shooter. Any questions?
    Bad Bits: Voice acting. It's painful. I suspect random employees were given a poorly translated Japanese script, and no context for what they were saying and just read the lines. Badly. The story might make more sense with a better translation.
    Is it worth it?: That's a toss up. The price is definately right. There is really nothing innovative going on here though. I also hate to say that the acting takes away from the joy of this game. Everything else is at least average in style and content. If you want a staple instead of R-Type Final, or Gradius 5 this is a possible choice... Just don't pay a lot for that muffler.
    What's Disturbing: There is a Castle Shikigami 1. The masochist in me must find it.
    Hex.
    [ Just does not get it... ]
  11. I recently picked up the Pelican Arcade stick and it is big and clicky. It hasn't gotten a lot of milage yet, but it does support all 3 current-gen platforms. I have high hopes for this peice. I have a lot of titles that are digital only and could use a proper stick. My only complaint is a lack of autofire 'turbo' buttons. Still, a nice peice for a 3rd party. If/when I get around to cracking it open I'll comment on the internals.
    Linkies:
    http://www.consolegameworld.com/article.php/id/49/
    http://www.talkxbox.com/hreview11.html
    Hex.
    [ Feels the blood pumping... must shovel snow. ]
  12. I went a little crazy, since I've been putting off purchases of the homebrews for a while... So with the QB cart, I just (like a half hr ago) ordered...
    Climber 5, Oystron, SCSIcide, Skeleton+, Seawolf, Star Fire, This Planet Sucks, Vault Assault, Thrust+ Platinum, Venture II: The Abysmal Abyss, X3V0LuX, Foot Pedal Controller, and Backfire
    Who needs that Steel Batallion Uber ctler anyway...
    Hex.
    [ Established 2004 until 2006... ]
  13. I swear this game is one of those where you just get your groove on and you can just roll up everything. I beat my head against the wall on Make a Star 7 all night last night. Today I managed to pull it off on the second try. There was a great feeling of glee as I started to roll up houses, cars, and Nessie!? Made it to about 22m. It's just a royal pain getting started is all. I think that truly is the hardest part of the game.
    Now I keep trying to collect as many different things as I can. Whee! Dammit, where is that missing majong tile? :D
    Hex.
    [ Ban Na Na ]
  14. That reminds me, did you check out the trailer for Area 51 and Narc on the disc? Narc just screamed stupid honestly. Area 51 created mild interest for me, but nothing that would justify shelling out more than $15. for it and perhaps $10 for Narc.
    I too was disappointed in this title. Perhaps I had my expectations lowered a bit from the pounding it took on the AA forums. The good news is I didn't pay a lot for that muffler. I found it used for $10. I got my money's worth. :|
    As for the Atari Collection I think that too is going to go on my buy it used and cheap list. I have a good chunk of those games already in some other capacity, why buy them again? Also, just because I'm confuzzled, wasn't this an Infogrames/Atari release?
    Hex.
    [ Suspects that he's going to take on Roll a Star 7 very soon... ]
  15. Some other worthwhiles that I haven't seen here:
    Ms. Pac Man, Klax, Sonic Spinball, and Roadblasters
    You really can't go wrong with any of the Sonic games and pts 1 & 2 are so common.
    While you indicated a distaste for RPG types, Shadowrun is pretty cool. A tough find though.
    Hex.
    [ Genesis OC revisted Project @ 30% completion... and progressing]
  16. Another 'big hand' guy here... My only complaint about the BIG xbox ctrler is that stupid jewel in the middle telling you it's an Xbox ctrler.
    Look folks, if you aren't sure what game system you are playing on. Just ask someone. You make the rest of us men look bad. A VMU-style B&W or color LCD display running off the USB port would have been way cool. At least it wouldn't be a waste of space.
    Hex.
    [ needs to look into that thrustmaster ctrler... sweet. ]
  17. I could not bring myself to pick just one. So, I'll break it up into smaller peices:
    8-bit: Vectrex
    I only have 2 carts for this system, but ChristianScott made a good point about the system being truly unique and impossible to 100% emulate. The runner ups were The NES and Colecovision.
    16-Bit: Genesis
    Without beating the 16-bit wars horse again, I just find something pleasing and adaptable about the Genesis. The 32x, the CD drive, and the SMS Power converter. Runner up: SNES
    Hex.
    [ Nothing says Christmas like a big rubbery monster with it's white frosting breath. ]
  18. I do get people asking questions like How do I copy my playstation discs? Can you do it? Do you have that Dreamcast CD with almost a thousand games? Etc.
    I tell them that these things can be done, but I can't help them do it because it's ILLEGAL. (yes, I say it that way too.)
    The piracy culture has gone a fair distance and is now more on making copies for profit. The publishers now also have much stronger laws to beat on western piracy. In the old days you'd swipe a ware at 14.4/16.8hst and move it around your area to keep the goods flowing. If you did get busted, you were running way to high a profile or you were breaking the law in in some other unwise way and piracy was just a tack-on charge.
    The only ROMs I actively have in my collection only is the NES DC emulator. I just don't like dorking with an insane # of bulky NES carts and the inherent instability of the Toaster oven NES. I would never choose to sell copies of the disc I made up. And when I'm questioned about getting copies I just tell folks that there's this search engine called Google -- use it. I do have a small collection of NES carts (I think I'm at around 40 of 50 now) that just didn't emulate well or I didn't have the ROM and I'm too lazy to hunt down a working copy. My NES really doesn't get a lot of milage from me.
    I'm sure that there are guys selling this stuff for big money to foolish humans. That was always the big line for me -- the sale of it.
    Then there are the fuzzy edges of legality that I don't ever feel bad about:
    -- my legal copy has been destroyed and I want an inexpensive replacement.
    -- I wish to play legal original copies of games from other countries at home (without moving or owning 3 of the same basic system) ; Imports
    -- I wish to put my game on a different type of media and keep the original safe from potential damage. ; 'backups' or as I prefer now my PS2 hard drive.
    The game makers frown on these things, but in reality none of them really hurt their business. It's the next logical step of 'backups' that makes them twitch like a hummingbird in a coffeepot.
    Hex.
    [ Remembers his ancient 'glory days' as a Teenage Mutant Ninja Pirate... ]
  19. I am with you Justin. I essentially like the convenience of improved load times and (hopefully) a lot less wear and tear on my CD drive. Although I've been installing software for the past 2 days (~6 hrs) I've chewed up about 60+gigs so far. It's also a way to keep my media from getting munged up. But yeah, HD loader may be the fuzzy edge of legality, but at the end of the day, I did buy legal copies and plan to own them for as long as I care to use Sony's stuff.
    Hex.
    [ just cant sleep because of the constant news coverage... ]
  20. Behold the trap of modern gaming. Watch in amazement as kids who bought GTA: V.C. are disgusted that they can't even get $10 for their $50 game.
    For example:
    Kid: "I'd like to get $30 for this, I paid $40."
    Clerk: "You can buy the 2 pack for $30 new. I'll give you $6."
    Funny that I'm not motivated to buy the next iteration of the series at full price...
    Hex.
    [ Recently noticed that his PS2 collection has mushroomed for no good reason. Naughty Collection! ]
  21. Good luck on that one. I picked up HD loader early in its second run and it is among the best money I've dropped on my PS2. Mind you, after the booter, the network adaptor and the HD I've spent around $160-$180. The other thing to keep in mind is some games choke on HD Loader. There are compatability lists that are very helpful, but some of the ones that just don't work SO tick me off. Such as: .//hack/ , Soulcalibur 2, War of the Monsters and Xenosaga. I have read reports that the current GTA will install, but I have not tried it.
    Actually, I filled up the 40Gig I was using in my PS2 and decided to go and grab a new drive. The closest I could get to a 120Gig was a 160GB drive. :( So now I'm filling it up again with the titles I previously had loaded.
    Also, another handy trick: If you are worried about the data integrity of a PS2 game, simply try to install it. If you get read Errs, you know the disc is probably damaged. Since the whole CD gets read in, you can know the integrity of a game without having to play it all the way through.
    Hex.
    [ Knows his FF 10 is just fine... ]
  22. < My Opinion Alert! >
    And for this fact (the subject line) I am thankful; For Nintendo builds little gaming TANKS. If Sony tries to pull the same cost-cutting tactics that they continue to get away with on their PSx systems, nearly every PSP that was bought on release day will die in about 6 months.
    I also agree that Nintendo has tried some different approaches to gaming. Some have worked out -- and some were just bad bad ideas. Nintendo just has a bad habit of not always thinking a task all the way through it seems (hardware side the Big N rarely half-asses their software). I do get some good enjoyment out of their games and am slowly making a new wantlist for them. (Paper Mario 2, Custom Robo, Metroid, Pokemon)
    On the other side of the coin I've been jonesing for that Steel Battalion 'uber-controller' since day 2.
    Hex.
    [ Last seen reformatting his PS2 HD... ]
  23. I picked this game up on Monday and am totally hooked. It's just so deranged to literally pick up everything in an area and clumsily wobble this huge ball of crap around to make a star.
    And I hate mentioning it, but in the intro, I thought the King's head was a roll of film or something. When he talks down to you I was disturbed by the royal tights that he wears. Scary.
    Damn Bears...
    Still... best $20 I've spent on a current gen game in a while.
    Hex.
    [ It's like super magical Puni-Kyen* Monty Python... ]
    * not that I really KNOW what those two words actually mean in Japanese.
