gozar
    1,066
Posts posted by gozar
  1. I forget, with Altirra running under Wine, i can use my USB gamepad as Atari 8Bit computer joystick. Work great!.
    Anyway you can config the USB gamepad on Atari800, but is more harder to do, but is possible too.
    You were able to get a USB gamepad to work under Wine? How'd you do that, USB support doesn't exist in Wine.
    Gamepad support is automatic under Ubuntu with Atari800, just be sure to have the gamepad plugged in before started Atari800. I've used a 360 controller, NES USB controller, and SNES USB controller.
  2. If you're familar with the command line in msdos, then any of the unixes command lines will be very familiar. A few gotchas:
    Under Unix:
    • Use forward slash (/) for directory delimeters instead of backslash (\)
    • Commands use the hyphen (-) before program arguments instead of forward slash (/)
    • ls brings up a directory listing
    • cp - copies files (must have a destination)
    • mv - moves or renames files
    Check out this crash course: http://cli.learncodethehardway.org/book/
  3.
    Well, I am putting the stack in extended memory. Seems to work fine. See the telnet I wrote as an example. Restricting things to the R: interface is fine, as long as it's something that naturally lends itself to that protocol. Quite a few of the IP protocols don't really fit very well across a serial device. I tried the route that everybody seems to recommend, which is to have an SBC or other 'smart' device run the stack. Communicating with a device like that over SIO and trying to do polling really isn't feasible given the incredible (comparatively) overhead of a SIO poll. Though everyone seems to think that's the obvious way to go, exactly no-one has done so. At least the Dragoncart exists, and works well. It needs programming though to take advantage of. If your goal is to not require programming, then yes, R: is probably about the best you can do. Incidentally, the dragoncart stack does expose an I: device that I am hoping to make as easy to use as r: is, as in you can use basic OPEN commands and so forth. But enough about that, as that's not really what this thread is about.
    I agree that there would be the need for a common interface. Although SBC's differ, the digital IO pins are usually standard, are they not? I was thinking that just exposing the basic control lines with a suitable 3v-5v conversion layer would be a start, although I am probably oversimplifying things. I just really like the idea of being able to rig up stuff and create custom protocols. If I had a really fast way to interrogate an SBC for ethernet packets, then I sure would use it.
    I found the AX11015, which looks like you can communicate with it over serial, and it will take care of all of the TCP/IP stuff for you. Once Joey_z finishes this PBI board just hang it off of one of the serial ports. Or buy a Lantronix box. :-)
  4. An Arduino would be too limited, plus too expensive. $15 for an Arduino, another $10 for ethernet (or $40-$50 for wifi!), $5 for SD reader.
    You're only $5 away from the price of a Pi which would have 512MB of RAM. Add a case and power supply for the Pi and you're up to $50.
    With something like the Pi (it doesn't have to be a Pi, but it's probably the cheapest) you can use it for so many other things. The more I think about it though, the "server" software would just need to be written so it's portable. Then you could use Windows, Linux, a Pi, a Beagleboard, whatever.
  5. It only takes four wires to connect the SIO to a Raspberry Pi. For network file access I'd just use a regular drive number and have the Pi present the network directory as a SpartaDos or MyDos formatted disk. Telnet would be pretty easy,
    That hard part is writing the software for the Pi.
    Then extend it even further. 80 columns, either through the SIO or wire some GPIO pins to a joystick port ala the XEP80. With the right software you should be able to even get advanced graphics modes by letting the Pi drive the display. I envision this working for games by having the Atari send to the Pi the graphics data (backgrounds and sprites) and then the Atari has to send very little data to change the display. Use a new device, like G:, and use CIO access. You can then send sprite data at the beginning of your program to the Pi, then during the game the Atari would only have to send a few bytes to the Pi to tell it to put sprite 0 at x,y location. The Atari can even turn off ANTIC for a speed increase.
    Bonus points for adding an automatic video switcher, where the Pi can switch the video from the Atari or from the Pi. And if you wire into the joystick port you would be able to do the network play, although I don't know how the other person would see the screen.
    A $50 solution for the Atari that opens up networking and other fun stuff. Too bad my coding skills aren't up to the task.
    You could plug Flash drives into it to mount, have wifi access to the Atari, write a music player that the Atari uses to play MP3s on the pi. And then, the ultimate insult. Install an Apple //e or C64 emulator on the Pi, and write some software to send the Atari keyboard and joysticks to the Pi.
    It really reminds me of the ATR-8000. Just call this the ATR-16000. Or ATR-Pi.
  6. Mine was an 800XL for Christmas of 1984 with the 1050 disk drive (and DOS 3). Upgraded both later to a 256K Rambo for the 800XL and the US Doubler for the 1050 and bought a 1025 printer at some point.
    Today it houses the AtariMax 32-in-1 OS, some sort of video mod I did (which among other things added Chroma, the machine looks amazing on my 1702), an IDE+ with 2GB CF, and ILS KRH so I can use an IBM Model M keyboard.
  7. I saw an eBay listing for the Omnimon OS upgrade, which had a different default font. In my 800XL I have a Warp 32-in-1 installed, so I'm thinking it would be cool to install a few OSes with different default roms. Any idea what's the easiest way to change the rom in an OS dump?
  8. On the subject of other hardware, when I went to college in 1984 the school had 80 column serial terminals screens hooked up to the unix system. These things made the same "chirp" sound for key clicks as the Atari 800. The keyboard had some similarity, too. Anyone know what it was??? I have a vague recollection of DEC, but that could just be residual memory of something later in the Air Force.
    Probably TVI-925 terminals: http://en.wikipedia.org/wiki/TeleVideo
    We had those connecting to an IBM Mainframe running CMS and the Dec Vax running VMS.
  9. Should be fair use.
    Fair use doesn't apply in this situation, especially since this is a for-profit activity. These are derivative copies of the original artwork and as such infringe on the original copyright. Especially since Atari is still using this artwork on current products.
    It's a shame, because I would really like a set. Marc, has there been any discussion with Atari on officially licensed cards?
  10. I never understood why anyone used SIO2PC when SIO2SD is so easy and a disconnected, self-contained solution. With SIO2USB you have to run some software on your PC to serve the disk image. But with SIO2SD, you just pop an SD card with a bunch of ATR's into it and bang-o. Games.
    In my case, I use SIO2USB and Ape on a Thinkpad running Dropbox. All of my A8 stuff is in a folder in Dropbox (currently at 2.8GB) so I can easily use the same images/files with an emulator on my laptop or desktop computer along with my 800XL. Makes it really easy to download new stuff to try, I just put it in Dropbox. The Thinkpad is also wifi enabled, so I can put my 8-bit set up wherever I want.
    I've been thinking about switching to Bittorrent Sync for more space, but I currently have 10.9 GB for free in Dropbox.
  11. Only 2 pins are actually used... been meaning to build a USB adaptor, so long as the wall-wart is > 1 Amp it'd be sufficient, > 1.5 Amps preferable for expanded machines.
    I cut the cords off of some bad ingot power supplies that I'm planning on attaching a USB plug on so I can do this exact thing!
