486 -
Posts posted by mickcris
What is a "dyke?" I've only heard this expression used as a slur against women living alternative lifestyles, or "dike" with regards to a levee or other man made land mass that holds back flood water. Poor word choice?
As for your photos, the adapter (properly modded) looks very nice on the butt of a turbografx. I assume all that is needed is to file down the edges of the connector, correct? Also is it true the memory retention only lasts two weeks? Is there some way to mod the device (rechargeable NMHi batteries with a "trickle charge" circuit, etc) to extend the memory retention lifespan? What if I leave the console adapter plugged in but powered off? That would be an issue for me as I tend to game on a variety of old consoles and they often sit unused for periods. I would like to play through Neutopia but the lengthy passwords are annoying.
I spelled it wrong i guess. its actually dikes. but its a common nickname for diagonal cutters.
It uses 2 AA batteries
Radio Shack would most likely not have had the caps you needed anyway. Sounds like you or the previous owner blew up the power regulator. What power supply did you use when you plugged it in?
you can get a cap kit here:
http://console5.com/store/atari-jaguar-cap-kit.html
power regulator:
http://console5.com/store/mc34163dw-soic-16w-package-step-up-down-inverting-switching-regulator.html
this sometimes goes at the same time:
http://console5.com/store/so-8-package-5-volt-regulator.html
You should be able to see if the IC is burned out by looking at it.
More than one bit :
It require more than cutting the connector I think? And if cutting the connector is enough, why not getting a PC-Engine AV booster? Aren't those worth like 30$?
No, you are wrong. Someone could just get an PC Engine AV Booster if they wanted. Since you have never seen a turbografx before im not sure why you were trying to argue with me about it not fitting. I cut off some of the extra plastic on the connector on one with some dykes, since you guys seem to be having trouble picturing it.
it can be made to fit. just need to remove a bit of plastic off the connector of the tennokoe 2. Other than that, the fit is perfect. Just might look a little odd.
Yes, what is holding the Hu-Card
Jewel cases are the same as CD cases
I know someone made some by using a 3D printer, but I don't think the file is available
The Admin at the pcenginefx forums sells 3D printed ones.
http://www.pcenginefx.com/forums/index.php?topic=18661.0
They are $6.50 a piece if you buy 24. I'm not aware of any other source.
think that's why they disabled the youtube comments. I'm sure they would have been amusing so its a shame they did that.
although, i looked at their facebook page, and their fans seem to be pretty happy about the video.
I think there would be enough demand. especially with the 2 new screens coming out this year. You would just have to get the word out that you were selling them. I already have a GG and Lynx screen. I am planning on getting at least one Turbo Express screen when its out.
you could buy one of these instead
If you want it to look good on that tv, you will need to get the NES rgb modded and get a descent upscaler like the xrgb-mini.
bump. added a few systems
hes not making the external version anymore.
http://3do-renovation.ru/How_to_buy.htm
I dont see why you couldn't run a cable out the back.
that psp cable is not high enough voltage for the psone. you need to get the correct cable. you probably didnt break anything.
nevermind. didnt notice for some reason the colecovision PCB was included too. I was thinking of doing this at one point and probably would have bought it last year if i had noticed your thread and read it properly.
good luck with the sale -
Anyone get one?
I have been using one for quite a while:
why did they not learn their lesson last time? they should have waited till they actually had something before doing any kind of announcement. Just gives people months to speculate.
bump. added rgb modded duo-r
The inside stamps on the units case indicate that the Jaguar that I own was manufactured in October '93 (a month before the console retailed). I believe it's safe to say that the Jaguar I own was a launch unit. I've been using a 12VDC, 750 milliamp Radioshack A/C adapter on the console for over 5 years. Never had any problems with the console, and board is in healthy condition.
The console would not properly turn on if the amperage was too low. Even if it's low-enough to cause the system keep rebooting on it's own - you're never going to fry the console with LESS amperage. The A/C adapter? Definitely. The console, however, will be fine.
I've found that any A/C adapter works for any device that you don't have an official A/C adapter for as long as the polarity is a match, are close to the original voltage and amperage, and make sure to use a DC adapter on devices that require direct current, and an AC adapter on devices that require alternating current.
If you follow that rule, everything will be cool
You cut off the first part of the quote. Its the early skunboards that will be damaged by higher voltages as they were connected directly to the power supply.
I think it is possible to cause damage if the power supply current is too low. Have heard stories about people burning out their Sega CDX consoles from using a Geneisis 2 power supply. Just use one with the correct amount of amperage or higher. No reason to try and find the lowest it will work with.
I wonder how many of the backers (there were about 150 individual I think) had a financial interest in this coming to life. Seems to me like there were a lot.
That's just his pant pleat. The low quality video just makes it look weirder than it is.
yeah. im sure you are right. i just focused in on it trying to see where the cable went.
The Official Turbografx 16 Thread!
in Classic Console Discussion
Because its not a Turbo Booster. The Turbo Booster uses a super cap while tennokoe 2 uses 2 AA batteries. The LED comes on when the batteries are low, but also when system is turned on.
