mickcris
    486
Posts posted by mickcris
  1. Thanks for the reply. Yeah, I should have done it under load, but I really dont want to have to take the console apart again as I had a hard time getting it back together last time. I will take a look at the caps. I dont really need the supply, but it would be nice to have a backup.
    edit:
    pulled it apart and c1 and c2 had leaked. Did not check the smaller ones yet but they look ok at 1st glance.
  2. I bought a roller controller and it came with a power supply. It does not power on my system (no video output) for some reason though. The led that I installed on the 5v line is working fine, but the blue led on my atarimax cart only flashes for a second and then turns off. The led should flash and then flash for a bit longer when its reading the SD card. I also tried a real Donkey Kong cartridge and had no video output either.
    I measured the power supply and all 3 voltages are present so I'm thinking it must not be putting out enough current. Has anyone had this happen before and know what component needs replacing in the power supply?
    thanks
  3. how about these 10ft cables:
    http://www.ebay.com/itm/New-Designed-High-Quality-High-Value-Serial-DB-9-Staright-F-F-Molded-Cable-/301022837973
    I think they should fit in the port. Cut one in half and you have 2 cables. Can maybe even find them cheaper.
    even cheaper:
    http://www.ebay.com/itm/10pcs-D-SUB-9-Pin-DB9-Female-Solder-Type-Socket-Connector-/330943108138
    and
    http://www.ebay.com/itm/10pcs-D-SUB-Hood-Cover-for-9-Pin-Plastic-DB9-Brand-New-/140955648667
    then get a spool of 9 conductor cable (I think 6 wires are only connected so probably only need 6 conductor cable).
  4. Well I will take your words for it. Plugs into US power socket and works just fine? There are about 5 of them on amazon so I'll look into snagging one when I get the funds. It's too bad there aren't more inputs. I'd like to plug all my retro consoles in, rather than one at a time. I'm really going to have to re-think my game system rack....
    Get a switch. I got this one and it works great. Just have to use a Euro Scart adapter instead of the one it comes with. You most likely would need that anyways.
    http://www.assemblergames.com/forums/showthread.php?52513-gscartsw-automatic-8-1-SCART-RGB-switch
  5. thanks. probably could have done a better paint job, but it will work for now. The guide i followed for the sms said to just do the 7800 mod with a few changes. So I did disconnect all of the resistors. It does work perfectly on the master system though. I dont currently have any 2600 homebrews or a flash cart for it, but I may revisit the wiring later if I want to use it for that.
  6. Iv got a price, but need to get my own power supply that works with the drive in the UK ? Now I'm really stumped... I assume it's an NTSC drive so it'll be 110, uk are 240...
    So anyone have a clue what power supply would work on a NTSC drive in the uk ?
    Cheers
    A Mega Drive model 1 power supply (or equivalent) is what you need. It runs on a 9v DC (center negative) power supply.
    You could also use one of these (the Trio M1 UK):
    http://retrogamecave.com/shop/4577155957/sega-trio-international/7293614
    I am using a DUO M1 for mine, but it looks like they only have the trio for international so it would have an extra plug on it.
  7. They may have just put in the same max bid as you, but since you put it in 1st, theirs would not count. it would just increase it to the last amount possible by the other bidder and then give the highest bid to you (i think thats how it works). Was your max bid an even number like $100 or something?
  8. claimed
    Non working A26 Maxicart from videogame-wiz. Just pay $3 to have it shipped to you in a bubble mailer.
    I pulled this out of the closet since i recently picked up another 2600. All it got was a black screen. I then pulled out an old xp computer to try to reflash it but the usb disconnects while writing to the cart. It seems to be able to read fine from the flash chip, just not write to it. Maybe someone can get it to work or just wants it for their collection in the state that it is in.
  9. Can you get the xrgb mini in the us, or import only? Anyone know a domestic seller?
    They only sell them in japan. You also have to ship them back to your seller in japan first if you need warranty work. Solaris Japan is one of the places recommended to buy one. Also Yakumo on the assemblergames forum is another good seller.
  10. I like the scanlines on mine. :) Not sure about my other settings though.
    That stinks you guys cant get the official lead easily. It was actually cheaper for me to buy the official cable rather than any of the unoffiical ones on ebay.
