palmheads
    211
Posts posted by palmheads
  1. Got another update! Source code attached
    I implemented the snippet of code Rasmus suggested above for loop timing & sprite collision. Worked great! Have got far more accurate sprite collision thanks to being able to read the status register for collisions. Also was able to remove my dodgy delay loop. Thanks Rasmus!
    The other thing I was able to figure out was cavern walls. Figured out how to read in the data & display, as well as designing the chars that make them.
    I have to now figure out how my sprite can trigger a collision with the walls. Thats my next step.
    Again, thank you everyone for your great advice on this. Been putting in time most days on this, and am enjoying it.
    cheers
    Daryn
    wall2.asm
    • Like 7
  2. Hi all
    As the title says, what CF Card would you recommend to use with your nanopeb?
    I purchased a Kingston 4GB CF Card, and the nanopeb appears to have issues reading from it.
    I can load DSKs using both TiDIR and xvm99 (part of the xdt99 cross assembler tools). Everything looks sweet at this stage.
    I've got my 5V adapter plugged in. TI powers up fine with "NANOPEB-F18 V1" on the splash screen.
    I can go into TI Basic, and type CALL MOUNT(1,1) & it works without Error.
    However if I try any of my known techniques of accessing any of the DSKs on the CF Card, nothing works.
    i.e ('WALL' being a file contained within DSK1 loaded to Volume 1)
    OLD DSK1.WALL
    * WARNING *
    CHECK PROGRAM IN MEMORY
    * I/O ERROR 57
    Or using Mini Memory 'LOAD AND RUN' (as I would on js99er & classic99). I can see the middle CF card accessing LED lighting up.
    LOAD AND RUN
    DSK1.WALL
    * ERROR *
    I/O ERROR CODE 2
    PRESS ENTER TO CONTINUE
    From reading about the nanopeb, it can be real picky about what CF cards work.
    Reckon I should try a Sandisk 4Gb? Or 4GB too large for this nanopeb?
    cheers
    Daryn
  3. Be aware that there are two issues with reading the status register directly from the VDP.
    The first one is software - every time the status register is read, it clears the sprite collision and vertical interrupt bits. So when you read it manually, there is a chance you can interfere with the interrupt routine (which only matters if you are using it - allowing LIMI 2 in your code). The interference is that sometimes you'll grab the bit, and sometimes it will, all depends who gets there first. ;) If you get it first, the interrupt may not happen on that frame. (No real negative consequences, but if you are using it for motion or music, they may slow down).
    The second is hardware - if you read the bit at the exact time it is set, the update is sometimes lost. This is usually only an issue for collision if your sprite is only one row tall or only one row collides, since it's pretty much impossible on the TI to interfere with two sequential scanlines in a row.
    If you aren't using the interrupt routine at all, feel free to carry on as you are - it's just sometimes helpful to have the information above in your back pocket in case you see unexpected behavior later. if you want to work around those issues, AND you /are/ using interrupts, the interrupt routine stores a copy of the status register every frame at >837B - you can read it from there instead of from the VDP directly. (Again, only if interrupts are enabled every frame).
    Don't be afraid of directly polling - hundreds of programs have run just fine for years doing so. Even Extended BASIC does it that way (for CALL COINC). It's only recently we've really dug down deep enough to start understanding those things.
    Will definitely keep this in mind. At the moment this small change seems to have made the collisions way more accurate, even without tweaking the proxmity stuff for a particular sprite - so much fun getting stuff to work! I feel like a game could actually come out of this! :)
    cheers
    Daryn
  4.
    I would suggest to use a routine like this for your main loop timing that also saves the coincidence flag. You need to turn off interrupts (LIMI 0) for this to work.
    * Wait for vsync
    VDPSTA EQU  >8802            * VDP status
    VSYNC  MOVB @VDPSTA,R0       * Clear interrupt flag if already set
           ANDI R0,>2000
           MOV  R0,@COINC        * Save coincidence flag
    *      Wait for next vsync
    VSYNC1 MOVB @VDPSTA,R0
           MOV  R0,R1
           ANDI R1,>2000
           SOC  R1,@COINC        * Save coincidence flag
           ANDI R0,>8000
           JEQ  VSYNC1           * Loop if interrupt flag not set
           B    *R11
    *// VSYNC
    COINC  DATA >0000
    Awesome Rasmus - wee investigate this snippet more & see how it could integrate with my (shitty) code!
    cheers
    Daryn
  5.
    Yup think I found how, something like this
    * VDP read status. Result will be in R0 MSB
    VRDSTA MOV  @>8802,R0    Read status register, resets bits 0-2.
           B    *R11         Delay
    Just quickly tried it in my code before my proximity checking - sprite collision already feels more accurate
    cheers
    Daryn
  6.
    Looking at Editor Assembler manual (pg 169), and the Art of Assembly PDF, it looks like an instruction call 'STST' is the one to focus on?
    Think I am on the right track
    cheers
    Daryn
    I think I found it!
           B    *R11         Delay
    Seem to work!! WOO!
    cheers
    Daryn
  7. Hi all
    Think I've found info about the VDP status register, & particular the collision bit. Actually not easy to find info about it.
    http://www.unige.ch/medecine/nouspikel/ti99/tms9918a.htm
    Maybe a typo below (should be Bit 2)
    "...Bit 1 (weight >20) is the coincidence bit. It is set when two sprites or more have at least one overlapping "on" pixel. This occurs even if the sprite color is transparent. Note that coincidence is checked only every 1/60th of second (1/50th of a second for the TMS9929A), thus if you change sprite positions during that time a coincidence could be missed."
    Just gotta figure out now how to read it
    cheers
    Daryn
    cheers
    Daryn
  8. Hi all
    cheers
    Daryn
  9.
    I encourage you to look at the VDP status register and more acutely the sprite collision bit. You seem to be doing a proximity check which is perfect for squares but falls short for shaped sprites. The collision bit will tell you if one sprite is touching another sprite on a pixel bases. Check for this condition and if it is true then do the proximity check.
    This will ensure that two sprites are visually touching before you spring your whammy.
    I also encourage you to research framing your timing via the VDP interrupt. Will simplify your game programming experience.
    Looks good so far. Keep plugging along, this will end up being pretty cool.
    Thanks for taking the time and putting in the effort.
    Sounds like a plan! Will do some investigations, and see whats involved.
    cheers
    Daryn
  10. Well it's cool and has a neat vector look. I might suggest that you check the collision bit and if it is set then do your proximity checks. Won't cost much code wise and will eliminate false hits.
    Are you using the interrup for throttling or delays?
    Cheers Mark! Will look into the collision stuff more soon I think. Am gonna see how todo a collision to a cavern wall next, then I'II optimise the collision stuff
    Am using a small delay loop for the sprite movement
    delay		li r15,500		;needed time delay
    		dec r15			;for sprite movement
    		jne $-2
  11. Are you getting collisions without actually having sprites touch or is it just the video?
    haha - yeah...haven't optimised the sprite collision stuff. Its pretty accurate for the first sprite I put in the screen (the reactor), but for the others its more 'close enuff!'
    I'II write something a bit better later on, just trying to get the idea of how things work at the moment.
    cheers
    Daryn
  12. Hi!
    OK, got sprite rotation working with moving sprite where its pointing (ie diagional movements, up/down, sideways etc)
    Very much like Thrust & Asteroids etc
    Here is a vid:
    Next step, think I might get some sort of 'wall' collision working. Am not sure how this works. I assume the side of a 'wall' aren't sprites. I'd imagine its some sort of character/screen definition you define, and a "collision" is where you hit some sort of screen limit? Is that correct? Am not sure, will have todo some research.
    If anyone wants to also have a play, here is my code so far
    		aorg >a000		;starting loc for mini mem '7d00'
    		lwpi >70b8		;load registers
    		li r0,>0384
    		li r1,>1100		;set background screen colour black
    	   	blwp @>6024
    		li r0,>0420
    		li r1,dataf		;sprite 0 def starting sprite
    		li r2,412
    		blwp @>6028
    		li r0,>0300
    		li r1,datat		;sprite 0 attr
    		li r2,21
    		blwp @>6028
    		li r0,>01e2		;sprite magnify 3
    		swpb r0			;once interupts enabled, need this
    		movb r0,@>83d4		;and this because kscan is used
    		swpb r0			;and this, because r1 is used
    		blwp @>6034
    		clr @>8374		;clearing for keyscan
    		li r7,>0000		;record where sprite is
    		li r13,00
    loop		limi 2
    		limi 0
    		bl @keyscan		;keyscan
    updatat		li r0,>0302		;rotate through sprites
    		mov r13,r1
    		sla r1,2
    		ai r1,>84
    		swpb r1
    		li r2,2			;send 2 bytes
    		blwp @>6024		;write bytes back
    		jgt loop
    rotl		inc r13
    		andi r13,7
    		li r15,8000		;needed time delay
    		dec r15			;for sprite rotation
    		jne $-2
    		jeq updatat
    rotr		dec r13
    		andi r13,7
    		jne $-2
    		jeq updatat
    coll		swpb r8			;test thrust sprite about to collide
    		swpb r10
    		s r10,r8		;subtract registes
    		abs r8			;absolute value
    		ci r8,>000e		;compare with 0e
    		b *11
    collsp		inc r9			;check next sprite
    		ci r9,>0005		;one more than num sprites on screen. find way of
    					;counting this
    		jeq loop		;start game loop again
    		clr r8			;look at sprite attr table
    		clr r10			;increments of 4
    		mov r9,r5		;get next incr of r4/r5
    		sla r5,2		;r5 being sprite # 1,2 etc
    		li r0,>0300		;vdp 304 - 308
    		a r5,r0
    		blwp @>602c
    		movb r1,r10
    		movb r14,r8
    		bl @coll
    		jgt collsp 		;not hitting, check next sprite
    					;possible collision, check row
    		clr r8
    		clr r10
    		inc r0			;vdp 305 - 309 range
    		blwp @>602c
    		movb r1,r10
    		movb r7,r8
    		bl @coll
    		jgt loop
    					;got a collision here!
    hit		li r0,>0302
    		li r1,>a800		;char code of collision sprite
    		li r15,10000		;needed time delay
    		jne $-2
    		b @>a000		;reset game - back to start
    keyscan		blwp @>6020		;keyscan
    		clr r3
    		mov @>8374,r3	;ascii key to r3
    		ci r3,69		;e key
    		jne $+42
    		li r0,>0300		;move along col
    		clr r14			;prepare r7 for row value
    		blwp @>602c		;read row value
    		movb r1,r14
    		bl @thrustc
    		blwp @>6024		;write to sprite attr
    		li r0,>0301		;move along col
    		clr r7			;prepare r7 for row value
    		movb r1,r7		;move to left byte of r1
    		bl @thrustr
    					;rotate keys
    		ci r3,90		;z key - rotate
    		jne $+4
    		jeq rotl
    		ci r3,67		;c key - rotate
    		jne $+4
    		jeq rotr
    		jne $-2
    		li r9,0
    		bl @collsp
    		;b *11			;back to loop
    					;different points of rotation
    					;mean different pixel movements
    thrustc 	ci r13,0
    		jne $+6
    		ai r1,->0100
    		ci r13,1
    		jne $+6
    		ai r1,->0100
    		ci r13,2
    		jne $+6
    		ai r1,>0000
    		ci r13,3
    		jne $+6
    		ai r1,>0100
    		ci r13,4
    		jne $+6
    		ai r1,>0100
    		ci r13,5
    		jne $+6
    		ai r1,>0100
    		ci r13,6
    		jne $+6
    		ai r1,>0000
    		ci r13,7
    		jne $+6
    		ai r1,->0100
    		b *11
    thrustr 	ci r13,0
    		jne $+6
    		ai r1,>0000
    		ci r13,1
    		jne $+6
    		ai r1,->0100
    		ci r13,2
    		jne $+6
    		ai r1,->0100
    		ci r13,3
    		jne $+6
    		ai r1,->0100
    		ci r13,4
    		jne $+6
    		ai r1,>0000
    		ci r13,5
    		jne $+6
    		ai r1,>0100
    		ci r13,6
    		jne $+6
    		ai r1,>0100
    		ci r13,7
    		jne $+6
    		ai r1,>0100
    		b *11
    dataf		data >0102,>0204,>0408,>0810	;sprite 0 - 4 cnrs
    		data >1060,>8040,>2023,>1408	;main thrust sprite
    		data >0080,>8040,>4020,>2010
    		data >100c,>0204,>0888,>5020
    		data >3028,>2423,>2020,>2020	;top left
    		data >2020,>4080,>4132,>0a04
    		data >0000,>0000,>8040,>3804
    		data >0408,>0810,>d020,>0000
    		data >0000,>0000,>0106,>1860	;left
    		data >8060,>1806,>0100,>0000
    		data >0020,>504c,>8201,>0204
    		data >0404,>0201,>824c,>5020
    		data >0000,>0102,>0202,>0408	;bottom left
    		data >1010,>2040,>80ff,>0000
    		data >0000,>8060,>1804,>0808
    		data >0806,>0102,>04c4,>2810
    		data >040a,>1110,>2040,>3008
    		data >0804,>0402,>0201,>0100	;sprite 1
    		data >1028,>c404,>0201,>0608	;reverse main sprite
    		data >0810,>1020,>2040,>4080
    		data >0000,>040b,>0810,>1020	;bottom right
    		data >201c,>0201,>0000,>0000
    		data >2050,>4c82,>0102,>0404
    		data >0404,>0404,>c424,>140c
    		data >040a,>3241,>8040,>2020	;right
    		data >2040,>8041,>320a,>0400
    		data >0000,>0080,>6018,>0601
    		data >0618,>6080,>0000,>0000
    		data >0000,>0000,>0102,>1c20	;top right
    		data >2010,>1008,>0b04,>0000
    		data >0c14,>24c4,>0404,>0404
    		data >0007,>1820,>4040,>8080	;reactor
    		data >8040,>4020,>ff80,>b0b0
    		data >0c80,>6e1a,>0a0a,>0b0b
    		data >0b0b,>0a0a,>fb01,>0101
    		data >8163,>7f3f,>222e,>6ee6	;ship collision
    		data >ee6e,>2e22,>3f7f,>6381
    		data >81c6,>fefc,>d4d4,>b677
    		data >77b6,>dcd4,>fcfe,>c681
    		data >0000,>0000,>1966,>81f8	;gun turret
    		data >0700,>0000,>0000,>0000
    		data >0000,>0000,>c030,>8864
    		data >1cc6,>3109,>0905,>0503
    		data >1f60,>80b5,>a5b5,>a5a7	;fuel
    		data >8080,>8080,>8080,>8080
    		data >f806,>0169,>4969,>496d
    		data >0101,>0101,>0101,>0101
    		data >0000,>0000,>030c,>1126	;gun turret 2
    		data >3863,>8c90,>90a0,>a0c0
    		data >0000,>0000,>9866,>811f
    		data >e000,>0000,>0000,>0000
    datat		data >0000,>840a	;thrust ship
    		data >5030,>a404	;reactor
    		data >7080,>ac0d	;turret
    		data >1010,>b007	;fuel
    		data >9080,>b40d	;turret
    		data >d000
    		aorg >701c
    		data >7d1e
    		data >7fe0
    		aorg >7fe0
    		text 'UPTHRU'		;name of program
    		data >a000		;starting location
    		end
    up.asm
  13. One cool thing I've found is, with using xdt99 to compile an object I can then add to a disk image, then upload that disk image too js99'er for testing. Because I'm using the mini memory module to load object from DSK1, and because I'm actually starting my code at A000 so I using the 32k console ram (so not actually using the mini memory from 7d00), using DISK2 I can actually have the line by line assembler just sitting there as well. Its been quite handy if I want to see how many bytes to jump ahead with a JNE or something. I can enter the snippet of code (generally only 5-10 lines), & then I can actually see how many bytes from start to end of the code (as the LBLA assembles each line, it tells you how many bytes its jumped ahead for each statement).
    cheers
    Daryn
  14. Am currently working on getting main thrust sprite move in the direction the sprite is pointing (a la asteriods, thrust itself). So moving diagonally etc
    Reckon I know what todo as well! Will try this weekend to get it going!
    cheers
    Daryn
    I got this to (kinda) work in the weekend. However it looks ghastly (sprite jumping all over the show) so needs more work! ha
    So no vid until it doesn't make your eyes bleed
    cheers
    Daryn
  15. Nice start--and you're teaching me some here too, as sooner or later I'll actually learn Assembly! :)
    Helps having good examples to get you started, thats for sure. Thats why I intend just having my source code available to look at. Am no doubt doing things in an inefficient way with the code, but the hardest thing is getting started half the time. And that includes the dev environment you choose.
    cheers
    Daryn
  16. Marvelous !!! :thumbsup:
    And I've got to say I love your use of lowercase and semicolons for comments - have to look at it twice not to confuse it with my own code.
    I'm beginning to have the labels on separate lines (no code) to more easily insert code and move blocks around - with or without the label.
    Yeah that is an issue for sure with putting the comments the way I am. Am using vim on my ubuntu laptop to write code, so I can do block copy/moves, which helps to a certain extent.
    Thanks for the encouragement. All a learning process at the moment, but loads of fun trying.
    cheers
    Daryn
  17. Another Thrust port to a classic machine! :thumbsup:
    Let me know if you need any information about game details. Probably I can help.
    I suspect you would know something about porting thrust to a classic system....the famous Atari 2600 port! Amazing job! :)
    Am sure as I get further into this project I'm gonna face stuff where I have no idea what todo!
    Thank you so much for offering assistance - am smiling typing that!
    cheers
    Daryn
  18. Hi everyone
    Just thought I'd post a wee update on my progress of porting 'Thrust' to the TI.
    I got some sort of multi sprite collision detection working. Sprite rotation also.
    Am using xdt99 & Js99'er, mini memory to load, plus various books like the Lottrup one, Editor Assembly Manual etc. Plus this amazing board!
    Here is a small vid of progress
    Source code below if anyone interested. Nothing spectacular at the moment, all a learning process for me
    Will keep on working at it, and post updates to this thread. Am really enjoying the process!
    cheers
    Daryn
    		li r0,>0384
    	   	blwp @>6024
    		li r0,>0420
    		li r2,412
    		blwp @>6028
    		li r0,>0300
    		li r2,21
    		blwp @>6028
    		blwp @>6034
    		li r13,00
    loop		limi 2
    		limi 0
    		li r9,0
    		bl @collsp
    		mov r13,r1
    		sla r1,2
    		ai r1,>84
    		swpb r1
    		jgt loop
    rotl		inc r13
    		andi r13,7
    		jne $-2
    		jeq updatat
    rotr		dec r13
    		andi r13,7
    		jne $-2
    		jeq updatat
    		swpb r10
    		b *11
    					;counting this
    		a r5,r0
    		blwp @>602c
    		movb r1,r10
    		movb r14,r8
    		bl @coll
    		clr r8
    		clr r10
    		blwp @>602c
    		movb r1,r10
    		movb r7,r8
    		bl @coll
    		jgt loop
    hit		li r0,>0302
    		jne $-2
    		b @>a000
    		clr r3
    		blwp @>602c		;read col value
    		swpb r1
    		movb r1,r14
    					;up and down keys
    		ci r3,69		;e key
    		jne $+10
    		ai r1,->0100		;move up
    		ci r3,88		;x key
    		jne $+10
    		ai r1,>0100		;move down
    		li r0,>0301		;move along row
    					;left and right keys
    		ci r3,83		;s key
    		jne $+10
    		ai r1,->0100		;move left
    		ci r3,68		;d key
    		jne $+10
    		ai r1,>0100		;move right
    					;rotate keys
    		jne $+8
    		jeq rotl
    		jne $+8
    		jeq rotr
    		jne $-2
    		b *11
    		data >d000
    		aorg >701c
    		data >7d1e
    		data >7fe0
    		aorg >7fe0
    		text 'COLLIM'		;name of program
    		end
    • Like 9
  19. Just spent way too much on a PAL Ti-99/4a from Germany on ebay!
    I know for sure my Commodore 1702 is PAL.
    So guess will be buying some beers for one of my soldering hobby friends to modify the Modulator for me! haha
    God I love vintage computers - can't wait until it arrives!
    cheers
    Daryn
