dilinger
    109
Posts posted by dilinger
  1. Hello,
    For the people using the Windows environement,
    I've found a Perl script to fix an issue when working with GCC and Visual Studio (2013 Express in my case).
    The problem came from the format error reporting between GCC and VS, there are not compatible so we can see the error messages in the VS Output window but we cannot interact with them. So, you have to look manually for the line(s) and file(s) to see the errors.
    This script takes the output produced by a batch file and converts the error messages. The following line has to be added in the NMake section of your project configuration properties for the : Build, Rebuild All, and Clean Command Line.
    build.bat 2>&1 | c:\Perl\bin\perl.exe gccfilt.pl
    The Zip file contains the script and a screen capture from VS.
    I'm not the author of the script and the original link is here : http://www.codeproject.com/Articles/370890/GCCFilter-A-script-for-compiling-with-GCC-in-Visua
    Thanks,
    gccfilt.zip
  2. Hello,
    I'm using Jlinker on Windows and I meet an issue reported as "unsupported relocation information in Absolute COFF export".
    I use C (m68k-aout-gcc) and ASM (smac).
    My compiler options are -c -m68000 -Wall -Werror
    My ASM options are -fb -rp -v
    Jlinker options are -v -w -e -rp -a 802000 x 4000
    Could you point me on directions to know where the problems may come from?
    Thanks.
  3. Hi,
    Do you think we have a chance to see a tracing support in the future? I can serve as tester if it can help a little.
    For the moment, I have only the emulator to check the .cof and no (serious) tools to debug yet. But I do not complain, the emulator is cool and this is just a hobby.
    Thanks,
  4. Hi All,
    I have heard about a Jagulator version with an integrated debugger. I've looked for it and was out of luck so far.
    Do you know if such version exists and where it can be downloaded?
    Also, I wanted to thank you for all the valuable informations you have put in this site over the years.
