Unstablewarpfield
    117
Posts posted by Unstablewarpfield
  1. Sounds about right. The FZ-1 PSU is integrated into the main PCB and is fairly generic. The only main difference is the transformer (and a common ground connection in NTSC models). Some models have fans and some don't, the connections are still there to add a fan. I have a PAL FZ-1 which has a 230V transformer and outputs ~16VAC. This is fed to a bridge rectifier and corresponding 9V and 5V regulators which can between 10V and 30V. The service manual shows an expected 20VP-P on the transformer output but my DMM only shows 16VAC. This transformer looks like a possible candidate https://eu.mouser.com/ProductDetail/Triad-Magnetics/VPS20-2200?qs=1a1zv8L%252Bh%2F2tr%252BOTTBfGVQ==
    Just be sure to research as much as possible on power supply electronics, this is mains voltages and things can easily get toasty with wrong application.
    Thanks a lot for this!
    I tried finding a transformer that has an output a bit closer to what specs say (15VAC) and I hit a bit of a wall here. The 3do states 30W on the bottom, and I'm not quite certain how many VA to go for. I'm assuming up from that number, so I tried looking around the 35-45VA with a 230VAC input and a 15VAC output. The thing is... I seem to find models with either 20 VA or 50 VA. The 20VA models would all fit really nicely as they have the correct dimensions. I am just worried that they will not have the power requirements needed? When I bump it up to 50VA the dimensions are not correct and the transformer would not fit.
    Any advice what would be safe to use as a transformer capacity?
  2. Thanks for replying. Soldering is not a big deal, I've modded many consoles so far. I just don't know enough about power supplies... What I do know is that it has a separate step down transformer that outputs 15V AC. Here is a link to the schematics of the power supply.
    http://atariage.com/forums/index.php?app=core&module=attach§ion=attach&attach_id=524629
    These 15V AC are taken into a circuit to output 5V and 9V DC. Seems to me that as long as I feed 15V AC into that circuit I should be fine? I have found some transformers that can do this, although I am not certain if 50Hz/60Hz will be a problem. When I receive the console I'd have to measure a bit to see if one of them physically fits but before that I want to be very sure that what I'm trying won't damage the console in any way...
  3. Hey guys,
    I have my eye on a Japanese FZ-1 system. I'd be able to get it for quite a good price, but before I purchase I would like to know if it is possible to avoid an external step down convertor (I'm European) by replacing the build in 110V/60Hz to 15V AC step down transformer with one that follows the specs for my location. Something like a 30VA 230V/50-60Hz to 15V transformer? Or am I thinking to easy about this?
    Anyone know of an example where someone has made this work?
    Thanks!
  4. I don't think there will be a solution Mika, considering the last thing we heared is from over a year ago. I guess that's life though.
    Then again, I can't seem to find our problem under the "known quirks" section on matthews website which potentially could mean that people with a PAL system will be buying the F18A while being unaware of this issue, which is not very nice in my eyes since it is not a cheap mod. Add to that also import fees and taxes and you are looking at a 100 euro upgrade that probably does not work with some games.
    I am now hoping that the PAL version of citrus3000psi mod will work. Time will tell...
  5. For now I wired everything directly and the image seems fine. Got myself a big beefy individually shielded scart cable. I might add some 75 ohms resistors on the rgb lines and see what that does. I could make future revisions and add the resistors on the board. Also VGA is a possibility :-)
  6. For a while now I wanted to get RGB out of my Amiga CD32 to play it a bit more since I can connect it easier through my Framemeister that way. I chose not to do an internal mod, but make an expansion card for the expansion slot on the back of the console. I soldered up the long connector today and had a testrun. Beautiful RGB... Simon the Sorcerer... here we come! :-D
    Scart connector
    Scart connector
    182 pin connector for the amiga cd32 expansion slot
  7. This Intellivision came in a model one case. It is defenately a French model, but without scart. It just has RF. I noticed it looks like an inty 2 on the inside but not exactely. It also is not exactely thesame version as on that website since that one has a seperate psu board. On mine the large capacitors are on the mainboard and there is no seperate pcb for them. Just the transformer feeding directly into the main board.
    I have found some clues to composite mod it, but I'd rather have rgb. Is there a chance that the 4 signals I mentioned could be the rgbs traces?
  8. Hey people,
    I have here (what I think) is a Secam intellivision (model 5156). It was obtained from France and I wanted to mod it to output RGB. I did this once on my pal system and it works fantastic. That said... that pal system contained an LM1886N which I could use to tap into the rgb and sync lines. Not so with this one however...
    Here is a picture of what I see.
    secam intelli
    U4 is in the red circle (YA-3-8900)
    U10 is in the blu circle (N82S147N)
    U14 is in the yellow circle (74LS273N
    oh... me thinks... I just have a look around U10, which is what my pal used as a video decoder and I'll pull a similar trick on that IC. Unfortunately the datasheet tells me nothing of which is what. All I managed to discover is that there are 4 traces coming out of U4 running to U10. From that point on, 4 traces also leave U10 and get to U14. From U14 those 4 traces combine into one through some resistors and run into the RF box. I guess the big question is... what are those 4 traces? I guess I could not be so lucky for them to just be RGB and sync and pul them off of one of those IC's could I?
    Anyone got a clue?
  9. One last post in this topic. There was still some audible noise in the sound when I did this mod. Also some video noise was present. I know this mod is supposed to give a better result so in the end I decided to have a batch of pcb boards made. Installed them yesterday and the image quality is even better then with my home-etched pcb! I run this mod through an xrgb mini and have perfect video and audio quality from my Intellivision now. Happy!
