Cybernoid
972 -
Posts posted by Cybernoid
Let us know if you hear any more info on this 65c816 upgrade...
Well, I personally use cc65 (from www.cc65.org) to compile C code and assemble assembly. I use this on a PC, Unix and Linux depending on where I am sitting.
I use atari800win plus to test my code... the monitor is very useful.
Fantastic!
I like English... My ability to read Polish is quite limited.
Great work.
Hey, I need to tell Adam to submit his latest JellyBeans Title Screen to the G2F Gallery...
~C~
Welcome Russ! I remember playing Preppie and Preppie II with friends for hours back in the day...
Is there any truth to a Preppie III that was started?
-Chris
SIO2USB interface already does this.take a USB hard-drive case (with a drive inside ofcurse) write your ATR files to it. then plug the drive to the SIO2USB interface on the ATARI and boot the computer
Well this is awesome. I did not know that. That is easy!
I would like to see something done for the MyIDE, however, many people have this... well okay maybe about 100 people...
I don't think this too possible without some clever remapping algorithm,most of my 2.5" HD IDE drives have different numbers of sectors, cylinders and heads and so how the data is layed out/extracted would differ between them.
In the ATA spec, there is already a way to send a command to the HD and then read back parameters from the drive including sectors, cylinders, heads and many others. I have already written something for the Atari that will read these values. Just need to port it to the PC. Not sure if it is clever, but...
Hi all,
I have a couple of questions about some software I would like to see for the PC....
This is what I was thinking would be nice:
A software package for Windows that allows you to do a RAW write to an IDE drive or a CompactFlash card/disk. This way you could write ATR images and Data to a disk quickly on a PC, then plug it into your Atari.
This is what I know:
(1) You can access the ATA/IDE registers under windows, but are there any software examples out there that I can look at that anyone knows of?
(2) You cannot "hot-swap" IDE drives, but there are USB->IDE enclosures.
Anyway, if anyone has some information or thoughts, please let me know.
I have a PCMCIA spec here somewhere, so I think I will start investigating the CompactFlash writter first....
Thanks... -C-
Yup, both the new title screen and the game look great!
Now to get Powrooz to update my JellyBeans Title Screen!
(I know you are busy...)
-C-
so... i have now 56k ram left for the game... i managed to switch off the OS and implemented my own interrupt service routine (with help of fox back 2002)...just in case some of you want to do this as well... the $fffe,$ffff is not set correctly but works at the moment...
Thanks for that, Heaven!
And, Boinxx is looking great BTW!
Are the squares with arrows going to cause the ball to move in that direction? Also, will there be "crack" squares that if you hit them too many times they fall?
Anyway, I've liked playing the demos so far....
Well,I guess this also depends on the game and if it uses full screen gfx or only part of the screen. I do remember "Wall Tetris" which uses Gr. 15 RGB mode. The game flickers, but since it only uses part of the screen (and the tetris tiles/icons are relatively small) the flickering is not so heavy and in my eyes acceptable. I guess such a flicker mode could also (have been) done to Jelly Beans, since it also uses only part of the screen... On the other hand, graphic adventures with full screen gfx and flickering would hurt the eyes... just my two (euro-) cents... -andreas.
The game is an RPG. I have decided on the graphics mode. I will use the same Priority-zero trick I used in JellyBeans but done a little more intelligently.
The main graphics mode will be Antic 4, but only using 3 colors: White, Grey50 and Black. So, the screen will be 40x20 in 3 grey scale shades.
However, where ever your character moves there will be a 16x10 color block that "colorizes" the screen. Each "character" within this block will have 9 colors using PM Over-/Under-lays. I think I will fade the luminance away from your character vertically to provide 29 colors on screen at the same time (this is reduced from the 90 on screen in JellyBeans).
This way it will look like you are walking in a color world, but you see a greyscale map area outside of this world.
This is my idea anyway, and I will have to finish the engine to see how this looks. This way I can have many colors in this game without flicker.
Thanks for the euro-cents, especially since 50Hz PAL "hurts" more than 60Hz NTSC in the flicker department.
_C_
Well,I would limit the program to playback only 8bit waves (one can convert the 16 bit waves on the PC a little faster) on the A8 with 6bit quality.
Thanks! I will limit this player to 8bit mono unsigned only to increase loading speed. Playback will be 6bit.
This makes my life simpler for this application anyway...
Okay, I will clean up the simple GUI as well...
nowadays i hate games which flicker... esp. on 8bit machines... on 2600 i do not care because it's a limited system but later on... but that's just my 2 cents.Thank Heavens, I mean Thanks Heaven!
Okay, then no flicker it is....
VBI 1 colors: Black' date=' Red, Green, BlueVBI 2 colors: Black, Magenta, Cyan, Yellow
So color mixing will provide 16 colors. [/quote']
I think that's far too optimistic:
when two colors (with the same luma) are mixed by flickering then you get the best result, but if two colors have different luma (let's say black and blue) then the flickering really hits the eyes. Especially when you're playing a game with flicker for longer than 5 minutes, your eyes get really tired and you want to stop playing. Then, if you want to mix the two palettes you won't get 16 colors that are all useful:
*snip*
If you're going to use pm underlays anyway I wouldn't use flickering but the 5th color instead.
Thanks! This is very helpful. You are right, when the luma differs it is not very nice on the eyes. So, I will avoid this. (I may avoid using flicker altogether, but I wanted to go through the exercise.)
Also' date=' I may use:VBI 1 colors: Black, grey25, grey50, grey75
VBI 2 colors: Black, grey25, grey50, grey75
But with different character sets, this will provide 9 shades of grey, but I will use PM overlays, like in JellyBeans, in areas. (ignoring the 5th color for now).[/quote']
...hmmm, I think it's only 7 shades (black, black-grey25, grey25, grey25-grey50, grey50, grey50-grey75, grey 75). Could be more useful, but it's still just 2 shades more than you already can use (with 5 colors).
You are right according to the way I wrote it. If you have a linear set of
shades 0, 2, 4, 6 you can produce these shades: 0,1,2,3,4,5,6 (7 shades).
But if you have these shades: 0,2,6,8 you can produce: 0,1,2,3,4,5,6,7,8 (9 shades). Which was what I was using to calculate. Actually if you have these shades: 0,2,6,14 you can produce these shades: 0,1,2,3,4,6,7,8,10,14 (10 shades!).
But, I may not use this since it will cause bad flicker...
Flickering is nice for static demopictures but not for games
Okay, I will keep this in mind, and come up with a different way to produce colors...
Thanks
_C_
Flicker varies with monitors.Well, that is true, and my PC TV capture card does not flicker at all!
Well, I am working on another game, and I was wondering what you think of graphics modes.
The graphics mode I am thinking of using is ANTIC mode 4 but change the character set and colors every VBI.
VBI 1 colors: Black, Red, Green, Blue
Also, I may use:
Anyway, my basic question is, "Do you mind this sort of flicker in a game?"
I plan on only alternating between 2 sets of colors/charsets, so the flicker is not too bad (according to my TV experiments), or do you think I should just stay with 5 colors only?
Thanks,
_C_
Hey, I found all my old BBS download disks from back in the day.
On these disks are a few demos, a few games, and a few utilities...
Some of these are simple Basic demos, but I still like "KILCOMIE.BAS" and "APPLE.BAS"... hehehe.
Anyway, I have about thousand more disks of games and demos to weed through, so this stuff isn't exactly organized yet...
_C_
Hi Fandal!
How about playing the creator? I will be available (during my lunch hour) at 11:00am to 12:00 my time (18:00 - 19:00 your time).
Also, check out the new release Version 1.0.2:
http://geocities.com/vlastaar/jellybeans/j...eans_v1_0_2.zip
The READ.ME is a great idea. I will add one to the released versions...
Anyone else available?
_C_
PS - I cannot guarantee that network mode will work at the moment, but having a few testers would be great!!!
Oh. Yup, this basically answers my questions....
Hmm, have to look at G2F again.
Also, isn't there a way to allow ANTIC to load instructions, then turn off the instruction DMA to allow ANTIC to display one line over and over again?
Is there a way to cause GTIA to output video data on line 21 (NTSC)?
Thanks...
I noticed that you can turn on the GTIA modes and use ANTIC mode 2, for a Character-mapped 16 luma or 16 color screen.
Has any program used this? Is it possible for G2F to handle this?
This thinking out loud,
_C_
As a related question, is there an autorun.sys program for DOS 2.0 that allows for high speed SIO, or a patch for DOS 2.0?
Does your PC lock up or your Atari?
I usually use the RI "Serial Control" option. I think this is what you will want with a one chip interface. The safety margin is useful if your PC is slow, but I assume that this is not the case. I would try 2 or 3, just to see...
Adjust the Framing Threshold only if your Atari locks up after is switches to high speed SIO...
These suggestions are only if the Atari is locking up, not the PC...
_C_
Next question, how about programming a universal PCM/WAV player ?!? Meaning with input/load routine, a directory option and of course a playback routine (and maybe also a quit to menu / dir. function and a exit to DOS/DUP function)... That would be very nice. A similar program, called "The sound Utility" by Tom Hunt already exists, but it works only bug-free under sparta or Bewe-DOS (and has many bugs under DOS 2). Last not least it is only 4bit playback...
Andreas,
Since you seem to be the most interested in this project, let me ask you a few questions...
(1) I am thinking of abandoning the 5bit and 4bit playback options, and stick with just 6bit. I do not like the quantization error (thus, high freq hiss) introduced with these modes.
(2) I have a load routine that will read WAV files in a multitude of formats. But the load time can be very long. For example, if I load a 16-bit signed Stereo PCM encoded wave file, my program will do:
(a) Throw away LSB of each sample.
(b) Left/Right Channel mixing.
© Low Pass filtering for the correct play back frequency
(d) Resample to 11025Hz.
So playback is 6bit at 11025Hz. The end result sounds great, but it takes over 2.5 hours to load a Wave file into an Atari with a 1MB memory upgrade. (a 16MB Wave file will be reduced to 1MB-8bit-signed-mono data).
So, is the wait worth it?
I suppose I could break this into 2 programs: one with all the DSP functions for filtering and resampling and one strickly for playback...
Thoughts?
_C_
Have you tried adjusting the "Framing Threshold" above 7 or the "Safety Margin" under "Basic Serial Setup"?
Yeah, I was thinking about this today actually. I see that you can feed Player/missle data directly to GTIA, but how do we feed pixel/playfield data to the GTIA?
Doesn't it use the AN[2:0] bus from the ANTIC chip?
Sio2SD
A little more info from:
http://www.atari8.info/dodajkomentarz.php?...ews=107&lang=en
