288 -
Posts posted by DavidC
4 hours ago, mizapf said:What value has the "video" setting? What happens if you use "-video opengl" or "-video bgfx" or "-video soft"?
I have no idea what that means.
So, I don't know if this is common knowledge or not. When I successfully installed MAME on my Rpi 400 using Ooeygui that is discussed here > https://atariage.com/forums/topic/313851-ooeygui-v40-released/ <
I had a issue with MAME running V E R Y S L O W L E Y. So I did some digging around in the MAME.INI file. I found these settings to work very well for me. If anyone has any other ideas or tweaks, please share them. I figured this stuff out on my own, so I wanted to share with you all that have been so helpful to me in the past. # CORE PERFORMANCE OPTIONS. Is all I did.
3 minutes ago, TimsterAA said:I hope that’s truthful! Good luck - hope you get it!
According to the tracking it has left Massachusetts and is on it's way to Syracuse as we speak. YAY!!
Brand new e-mail..Sorry, we are encountering a delay...blahblahblah...new ETA: Dec 15th. I figured as much. It's ok, gives me something to look forward to. Coupla more weeks, no big deal. Anticipation..lol.
Well, I got it working! I got a new SD card, installed Raspberry PI OS, installed JRE and started from scratch. It still crashed at the very end of installing MAME like it did before. BUT...this time when I configred the paths for everything and hit "Launch" IT WORKED!!! I don't know how or why...but it did. Cool beans. Thanks for your help you guys. I am learning as I go..
3 hours ago, senior_falcon said:Disk access should work with CF7 and a real TI99 but it would be nice if someone tested that to verify.
Have fun!
Works fine with my NanoPEB. Thank you for all your hard work. This is amazing.
1 hour ago, mizapf said:If you can afford some more patience, I would recommend not to switch too early to another OS before this problem is solved. Maybe there is some version requirement for some library.
I will do the best I can to help.
2 hours ago, Shift838 said:i would suggest if you have a different SD card instead of using NOOBS install the Raspberry OS itself onto the new card not sure which OS you selected when booting NOOBS to be installed. If I recall correctly NOOBS gives you an option to install Raspberry Pi OS or LibreELEC as well as options to download and install other 3rd party OS'.
Which did you select to install ?
I didn't, the 400 came with the SD Card preconfigured with The Raspberry Pi OS on it. All I did was turn it on and start using it. I will get another SD card and start from scratch.
edit: What OS do you recommend? If it works on your test Rpi's what OS is on them?
Ok...I typed sudo apt install libsdl2-ttf-2.0-0 in the console and it installed the package. Then I ran ooeygui again and tried to reinstall mame. It crashed again with this message on the console:
Get:1 http://raspbian.mirror.constant.com/raspbian buster/main armhf libsdl2-ttf-2.0-0 armhf 2.0.15+dfsg1-1 [14.7 kB]
Fetched 14.7 kB in 1s (14.9 kB/s)
Selecting previously unselected package libsdl2-ttf-2.0-0:armhf.
(Reading database ... 140632 files and directories currently installed.)
Preparing to unpack .../libsdl2-ttf-2.0-0_2.0.15+dfsg1-1_armhf.deb ...
Unpacking libsdl2-ttf-2.0-0:armhf (2.0.15+dfsg1-1) ...
Setting up libsdl2-ttf-2.0-0:armhf (2.0.15+dfsg1-1) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
[email protected]:~ $ cd /home/pi
[email protected]:~ $ cd OoeyGUI
[email protected]:~/OoeyGUI $ sudo ./ooeygui
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
Traceback (most recent call last):
File "ooeygui.py", line 3595, in _installmame
File "ooeygui.py", line 3833, in mamesetup
File "ooeygui.py", line 108, in desktopshortcut
File "desktop_file/LinuxShortcut.py", line 41, in __init__
File "posixpath.py", line 80, in join
TypeError: expected str, bytes or os.PathLike object, not NoneType
Aborted
I must be doing something wrong.
pygame 1.9.4.post1
/home/pi/mameinstall/mame0226b_ti99_raspbian32bit/mame: error while loading shared libraries: libSDL2_ttf-2.0.so.0: cannot open shared object file: No such file or directory
File "ooeygui.py", line 3829, in mamesetup
File "ooeygui.py", line 265, in modifymameconfig
FileNotFoundError: [Errno 2] No such file or directory: '/home/pi/mameinstall/mame0226b_ti99_raspbian32bit/mame.ini'
Aborted
Copy/Paste from the console after the crash.
58 minutes ago, Shift838 said:From my understanding the Raspberry Pi 400 is a standard Raspberry Pi4 with 4GB ram.
May I ask what OS you have on it if? I have tested on a RPi4 and a couple of others have and it has installed with no issues.
May I ask where it stops for the 98% can you take a screenshot or copy the contents of the status window and post please.
When it reads 98% it should be around after TIIMAGETOOL has been downloaded. After download it should expand TIIMAGETOOL.
You should have a 'tiimagetool' within the directory where you flagged MAME to be installed. If not, then please also check your 'temp' folder within the folder where you ran OoeyGUI to see if the TIIMAGETOOL.zip file is there.
The OS is NOOBS I guess, what ever comes stock, prebuilt on the SD card they supplied with the 400 kit. I will get a screen shot of the error message that shows up on the console.
I am having a helluva time getting this to work on my brand new Raspberry Pi 400. Every thing goes smoothly, everything loads up to 98% on the MAME install window and then it just crashes. I do not get the "MAME was installed successfully" window. It just crashes. I will say I am brand new to Rpi and brand new to MAME so I really would like to know if anyone has made this work with the 400. I need help, if there is any info you need please ask so I can learn what to do to help.
Still just delivery updates. I hope it ships out, that would be wonderful! But I am not counting on it. We'll see.
Well, I just got a e-mail today. Delivery Estimate is now Dec 5..thats this Saturday. I am not going to be holding my breath. It reminds me of the e-mail @themewsh got last week. We will see what happens..
On 11/22/2020 at 4:13 PM, TimsterAA said:Good and bad news folks. My Amazon purchased “The C64” (pre-ordered in August) arrived today, so yes Virginia, there is a Santa Claus.
Bad news is “The Vic20” I pre-ordered in October is now showing as an early January delivery, but it’s also now showing as another “The C64”, and a search on Amazon for “The Vic20” no longer finds that unit. 🤬 I wanted both models! Grrrrrr!!! I never can understand all the licensing and marketing drama on 35+ year old repro tech. Ugh!
How is it? Do you like it?
3 hours ago, Omega-TI said:The << Argon One case >> with a USB wireless keyboard is another option that can keep you unencumbered from wires.
Cool, but...the keyboard is the 400. and stuff.
On 11/19/2020 at 7:41 PM, jrhodes said:I have one hooked up to my pi with a usb keyboard.
Tempted to replace my pi 3B+ with a pi 400 setup...
https://www.raspberrypi.org/products/raspberry-pi-400/?resellerType=home
I just ordered one of these, hopefully I can figure out how to use MAME and other cool things with it.
To everyone on this forum for the countless hours of entertainment.
To all the Authors of the emulators.
To all the creators of the new gadgets that keep our TI's alive and well after all these years.
To all the software authors that keep on coming up with new and interesting stuff.
To all the mind boggling knowledge that is found on this forum.
To Everyone....Thank You! I truly hope you all have a safe and wonderful Holiday Season.
10
8 hours ago, kevates said:So where can I get a safe power supply that will work on both a breadbin C64 and a VIC? What’s the best option?
I have one of these. Works on my 64 and my Vic 20.
Yep, I got the same. Mid Dec-Early Jan. Cool!
OoeyGUI MAME and Raspberrypi 400
in TI-99/4A Computers
Oh, ok I understand. It is set to "auto" if I am looking in the right place. I will experiment with it and see what happens. Thank you for the tip.
